C_BW4H_2505ԇC_BW4H_2505}
Posted at 2/14/2026 20:12:03
View136
Replies1
҂SAP C_BW4H_2505 JCԇӖYFast2testČIF꠲оģԎͺܶ˳ɾ͉롣ڬFڵĸҵITИIУҪԼĵλ͵IʿCԼ֪RͼgˮʡSAP C_BW4H_2505 JCԇһܺõCԼĿԇSAP C_BW4H_2505JCC㹤кܴ׃Yλ
SAP C_BW4H_2505 ԇV| } | | | } 1 | - Native SAP HANA Modeling:This section evaluates the ability of SAP Consultants to describe and apply native modeling options in SAP HANA. It emphasizes understanding how to build optimized data structures directly within the HANA platform.
| | } 2 | - Fundamentals: This section of the exam measures the foundational understanding of SAP Consultants and covers essential terms and concepts related to SAP BW
- 4HANA and SAP Business Data Cloud. It focuses on the core framework and architecture necessary to navigate and work with these platforms.
| | } 3 | - InfoObjects and InfoProviders:This section tests the knowledge of Data Engineers in working with InfoObjects and InfoProviders in SAP BW
- 4HANA. It involves handling data structures used for organizing, storing, and accessing analytical data.
| | } 4 | - SAP BW Query Design: This section of the exam assesses the ability of Data Engineers to create and run queries using SAP BW
- 4HANA. It evaluates how well candidates can work with query components to retrieve and structure data effectively for reporting and analysis.
| | } 5 | - SAP BW
- 4HANA Data Flow: This section of the exam measures the practical ability of SAP Consultants to load data within the SAP BW
- 4HANA environment. It assesses familiarity with data movement and transformation processes across different layers of the system.
| | } 6 | - SAP BW
- 4HANA Modeling:This section targets the skills of Data Engineers in selecting appropriate modeling options and applying best practices like LSA++ within SAP BW
- 4HANA. It focuses on designing scalable, high-performing data models.
| | } 7 | - SAP Analytics Tools and SAP Analytics Cloud: This section evaluates the skills of SAP Consultants in using tools like SAP Analytics Cloud, Lumira, and Analysis for Office to visualize and interpret data. It focuses on the consultants ability to apply business intelligence tools within the SAP ecosystem.
ʹ挍SAP C_BW4H_2505ԇʂSAP C_BW4H_2505ԇpͨ^Mxxһo㎧^Ҹxo^ęCһe^xֻ Fast2test SAPC_BW4H_2505ԇӖYÿITʿͨ^ITJC횵ӖYϣ@ݿԇYϾ͵УеĿԇy}ӭж⡣ Fast2test SAPC_BW4H_2505ԇӖYᘌԏwV¿죬ӖYϣеITJCҪ£㶼ͨ^ġ
µ SAP Certified Associate C_BW4H_2505 Mԇ} (Q49-Q54):} #49
Which request-based deletion is possible in a DataMart DataStore object?
- A. Only the most recent non-activated request in the inbound table
- B. Any request in the active data table
- C. Any non-activated request in the inbound table
- D. Only the most recent request in the active data table
𰸣D
}f
In SAP BW/4HANA, aDataMart DataStore Object (DSO)is used to store detailed data for reporting and analysis. Request-based deletion allows you to remove specific data requests from the DSO. However, there are restrictions on which requests can be deleted, depending on whether they are in the inbound table or the active data table. Below is an explanation of the correct answer:
A). Only the most recent request in the active data tableIn a DataMart DSO, request-based deletion is possible only for themost recent requestin theactive data table. Once a request is activated, it moves from the inbound table to the active data table. To maintain data consistency, SAP BW/4HANA enforces the rule that only the most recent request in the active data table can be deleted. Deleting older requests would disrupt the integrity of the data.
* Steps to Delete a Request:
* Navigate to the DataStore Object in the SAP BW/4HANA environment.
* Identify the most recent request in the active data table.
* Use the request deletion functionality to remove the request.
* The SAP BW/4HANA Data Modeling Guide explicitly states that request-based deletion in the active data table is restricted to the most recent request to ensure data consistency.
Incorrect OptionsB. Any non-activated request in the inbound tableNon-activated requests reside in theinbound tableand can be deleted individually without restriction. However, this option is incorrect because the question specifically refers to theactive data table, not the inbound table.
Reference: The SAP BW/4HANA documentation confirms that non-activated requests in the inbound table can be deleted freely, but this is outside the scope of the question.
C). Only the most recent non-activated request in the inbound tableThis statement is incorrect because there is no restriction on deleting non-activated requests in the inbound table. All non-activated requests in the inbound table can be deleted individually, regardless of their order.
Reference: The SAP BW/4HANA Data Modeling Guide clarifies that non-activated requests in the inbound table do not have the same restrictions as those in the active data table.
D). Any request in the active data tableThis option is incorrect because SAP BW/4HANA does not allow the deletion of any request in the active data table. Only the most recent request can be deleted to maintain data integrity.
Reference: The SAP BW/4HANA Administration Guide explicitly prohibits the deletion of arbitrary requests in the active data table, as it could lead to inconsistencies.
ConclusionThe correct answer regarding request-based deletion in a DataMart DataStore Object is:Only the most recent request in the active data table.
This restriction ensures that data consistency is maintained while still allowing users to remove the latest data if needed.
} #50
In a BW query with cells you need to overwrite the initial definition of a cell. Which cell types can you use?
- A. Formula cell
- B. Help cell
- C. Reference cell
- D. Selection cell
𰸣A,D
}f
In SAP BW (Business Warehouse), when working with queries that include cells, you can define and manipulate these cells to meet specific reporting requirements. Cells in a BW query are used to display data based on certain conditions or calculations. If you need to overwrite the initial definition of a cell, you have specific options available.
* Formula Cell:A formula cell allows you to perform calculations using other cells or key figures within the query. You can define complex formulas to derive new values. When you need to overwrite the initial definition of a cell, you can use a formula cell to redefine how the value is calculated. This flexibility makes it possible to change the behavior of the cell dynamically based on your requirements.
* Selection Cell:A selection cell enables you to apply specific filters or selections to the data displayed in the cell. By defining a selection cell, you can control which data is included or excluded from the cell's output. Overwriting the initial definition of a cell can involve changing the selection criteria applied to the cell, thus altering the subset of data it represents.
* Reference Cell:A reference cell simply points to another cell and displays its value. It does not allow for any overwriting or modification of the initial definition because it merely references an existing cell without introducing new logic or conditions.
* Help Cell:Help cells are used to provide additional information or context within a query but do not participate in calculations or selections. They cannot be used to overwrite the initial definition of a cell since their purpose is purely informational.
* Formula Cells: These are ideal for recalculating or redefining the value of a cell based on custom logic or mathematical operations. For example, if you initially defined a cell to show revenue, you could overwrite this definition by creating a formula cell that calculates profit instead.
* Selection Cells: These are perfect for applying different filters or conditions to alter the dataset represented by the cell. For instance, if a cell initially shows sales data for all regions, you can overwrite this by specifying a selection cell that only includes data from a particular region.
Cell Types Overview:Why Formula and Selection Cells?SAP Data Engineer - Data Fabric Context:In the broader context of SAP Data Engineer - Data Fabric, understanding how to manipulate and redefine cells within BW queries is crucial for building flexible and dynamic reports. The Data Fabric concept emphasizes seamless integration and transformation of data across various sources, and mastering query design- including cell manipulation-is essential for effective data modeling and reporting.
For more detailed information, you can refer to official SAP documentation on BW Query Design and Cell Definitions, as well as training materials provided in SAP Learning Hub related to SAP BW and Data Fabric implementations.
By selectingFormula cellandSelection cell, you ensure that you have the necessary tools to effectively overwrite and redefine cell behaviors within your BW queries.
* SAP Learning Hub - BW Query with Cells
} #51
You want to set up the replication process for the SAP Landscape Transformation Replication Server.Which actions can you define for a specific table?Note: There are 3 correctanswers to this question.
- A. Set the reading type and portion sizes
- B. Apply mapping rules during the replication
- C. Convert Unicode to non-Unicode
- D. Change or enrich the table structure
- E. Apply customizing settings to the database redo logs
𰸣A,B,D
}f
SAP BW/4HANA Project and Modeling Process
} #52
Which options do you have when using the remote table feature in SAP Datasphere? Note: There are 3 correct answers to this question.
- A. Data access can be switched from virtual to persisted but not the other way around.
- B. Data can be accessed virtually by remote access to the source system.
- C. Data can be persisted in SAP Datasphere by creating a snapshot (copy of data).
- D. Data can be loaded using advanced transformation capabilities.
- E. Data can be persisted by using real-time replication.
𰸣B,C,E
}f
* BW Bridge Cockpit: The BW Bridge Cockpit is a central interface for managing the integration between SAP BW/4HANA and SAP Datasphere (formerly SAP Data Warehouse Cloud). It provides tools for setting up software components, communication systems, and other configurations required for seamless data exchange.
* Tasks in BW Bridge Cockpit:
* Software Components: These are logical units that encapsulate metadata and data models for transfer between SAP BW/4HANA and SAP Datasphere. Setting them up requires access to the BW Bridge Cockpit.
* Communication Systems: These define the connection details (e.g., host, credentials) for external systems like SAP Datasphere. Creating or configuring these systems is done in the BW Bridge Cockpit.
* Transport Requests: These are managed within the SAP BW/4HANA system itself, not in the BW Bridge Cockpit.
* Source Systems: These are configured in the SAP BW/4HANA system using transaction codes like RSA1, not in the BW Bridge Cockpit.
* A. Create transport requests:This task is performed in the SAP BW/4HANA system using standard transport management tools (e.g., SE09, SE10). It does not require access to the BW Bridge Cockpit.
Incorrect.
* B. Set up Software components:Software components are essential for transferring metadata and data models between SAP BW/4HANA and SAP Datasphere. Setting them up requires access to the BW Bridge Cockpit.Correct.
* C. Create source systems:Source systems are configured in the SAP BW/4HANA system using transaction RSA1 or similar tools. This task does not involve the BW Bridge Cockpit.Incorrect.
* D. Create communication systems:Communication systems define the connection details for external systems like SAP Datasphere. Configuring these systems is a key task in the BW Bridge Cockpit.
Correct.
* B: Setting up software components is a core function of the BW Bridge Cockpit, enabling seamless integration between SAP BW/4HANA and SAP Datasphere.
* D: Creating communication systems is another critical task in the BW Bridge Cockpit, as it ensures proper connectivity with external systems.
References:SAP BW/4HANA Integration Documentation: The official documentation outlines the role of the BW Bridge Cockpit in managing software components and communication systems.
SAP Note on BW Bridge Cockpit: Notes such as 3089751 provide detailed guidance on tasks performed in the BW Bridge Cockpit.
SAP Best Practices for Hybrid Integration: These guidelines highlight the importance of software components and communication systems in hybrid landscapes.
By leveraging the BW Bridge Cockpit, administrators can efficiently manage the integration between SAP BW/4HANA and SAP Datasphere.
} #53
You notice that an SAP ERP ODP_SAP DataSource is delivering incorrect values into the first persistent data layer in SAP BW/4HANA. Which options do you have to analyze a potential extractor issue? Note: There are
- A. Use the transaction RSA3 (Extractor checker) in SAP ERP.
- B. Check entries in the table RSDDSTATEXTRACT in SAP ERP.
- C. Use the program RODPS_REPL_TEST in SAP ERP.
- D. Use the transaction ODQMON (Monitor Delta Queues) in SAP BW/4HANA.
𰸣A,C
}f
When dealing with incorrect values being delivered by an SAP ERP ODP_SAP DataSource into the first persistent data layer in SAP BW/4HANA, it is crucial to analyze potential issues at the extractor level in the SAP ERP system. Below is a detailed explanation of the correct answers:
* Explanation: The program RODPS_REPL_TEST is used to test the replication of data from an ODP_SAP DataSource in the SAP ERP system. It allows you to simulate the extraction process and verify whether the data being extracted matches the expected values. This helps identify issues with the extractor logic or configuration.
* RODPS_REPL_TEST is a standard tool provided by SAP for testing ODP-based DataSources. It is particularly useful for diagnosing issues related to data extraction in SAP ERP systems.
Option B: Use the transaction ODQMON (Monitor Delta Queues) in SAP BW/4HANAExplanation:
ODQMON is used in SAP BW/4HANA to monitor delta queues and ensure that data is being transferred correctly from the source system. However, it does not help analyze issues at the extractor level in the SAP ERP system. ODQMON focuses on the BW/4HANA side of the data transfer process.
Reference: ODQMON is primarily a monitoring tool for delta queues in BW/4HANA and is not suitable for diagnosing extractor issues in the ERP system.
Option C: Use the transaction RSA3 (Extractor checker) in SAP ERPExplanation: RSA3 is a powerful tool for testing and validating extractors in the SAP ERP system. It allows you to execute the extractor logic and view the extracted data directly in the ERP system. By comparing the extracted data with the expected values, you can identify issues such as incorrect mappings, filters, or transformations.
Reference: RSA3 is widely used for debugging extractor issues in SAP ERP systems. It is an essential tool for ensuring that DataSources deliver accurate data to SAP BW/4HANA.
Option D: Check entries in the table RSDDSTATEXTRACT in SAP ERPExplanation: The table RSDDSTATEXTRACT is not a valid or standard table in SAP ERP systems. It does not exist in the context of ODP_SAP DataSources or extractor diagnostics. Therefore, this option is incorrect.
Reference: SAP documentation does not mention RSDDSTATEXTRACT as a relevant table for analyzing extractor issues.
SummaryTo analyze potential extractor issues in the SAP ERP system:
RODPS_REPL_TEST: Simulates and tests the extraction process for ODP_SAP DataSources.
RSA3: Validates the extractor logic and verifies the extracted data.
These tools help identify and resolve issues at the extractor level, ensuring that correct data is delivered to the first persistent data layer in SAP BW/4HANA.
} #54
SAPC_BW4H_2505JCԇ]ͨ^ԇú£Fast2testṩoõYϡFast2testC_BW4H_2505}ȫĿԇYϣһԽoͨ^ԇcšǾ֤ܶʵ
C_BW4H_2505}: https://tw.fast2test.com/C_BW4H_2505-premium-file.html
- TC_BW4H_2505ԇMdC_BW4H_2505ԇYώͨ^C_BW4H_2505ԇ 🤾 [url]www.vcesoft.com Wվ C_BW4H_2505 KMdC_BW4H_2505ԇCվC[/url]
- C_BW4H_2505ԇ} 🔗 C_BW4H_2505CYӍ 🦍 C_BW4H_2505} 📺 ⇛ [url]www.newdumpspdf.com ⇚⏩ C_BW4H_2505 ⏪p@ȡMdC_BW4H_2505ھ}[/url]
- C_BW4H_2505JCY 💢 C_BW4H_2505ԇ} 📃 C_BW4H_2505}Md 🥢 ڡ [url]www.testpdf.net µġ C_BW4H_2505 }C_BW4H_2505}[/url]
- C_BW4H_2505JCY 💠 C_BW4H_2505T} 🎻 C_BW4H_2505ԇCվC 🍢 ▷ [url]www.newdumpspdf.com ◁¡ C_BW4H_2505 }C_BW4H_2505ԇ}[/url]
- C_BW4H_2505} 💎 C_BW4H_2505}Md 💘 °C_BW4H_2505} 🧞 _➡ tw.fast2test.com ️⬅️K➠ C_BW4H_2505 🠰ԫ@ȡMdC_BW4H_2505Wָ
- C_BW4H_2505} 🐕 C_BW4H_2505} ❕ C_BW4H_2505JCY 👳 Ո☀ [url]www.newdumpspdf.com ️☀️WվMd▛ C_BW4H_2505 ▟}°C_BW4H_2505}[/url]
- C_BW4H_2505ԇɞͨ^SAP Certified Associate - Data Engineer - SAP BW/4HANA 🆕 [url]www.pdfexamdumps.com ϵMd⏩ C_BW4H_2505 ⏪_C_BW4H_2505CYӍ[/url]
- dC_BW4H_2505ԇc¸SAPJCӖ - |SAP SAP Certified Associate - Data Engineer - SAP BW/4HANA ⏩ [url]www.newdumpspdf.com ϵ➽ C_BW4H_2505 🢪MdֻьC_BW4H_2505CYӍ[/url]
- C_BW4H_2505T} 🔻 C_BW4H_2505JCָ 〰 C_BW4H_2505T} 🎥 [url]www.pdfexamdumps.com C_BW4H_2505 p@ȡMdC_BW4H_2505}[/url]
- C_BW4H_2505} 🐈 C_BW4H_2505ԇ ⏺ C_BW4H_2505}Md 🧧 ⇛ [url]www.newdumpspdf.com ⇚➽ C_BW4H_2505 🢪pȡMdC_BW4H_2505Wָ[/url]
- C_BW4H_2505} 🏅 C_BW4H_2505ԇ 🧧 C_BW4H_2505} 👏 }uWַ▶ [url]www.pdfexamdumps.com ◀_K⇛ C_BW4H_2505 ⇚MdC_BW4H_2505ԇ}[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.intensedebate.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, hashnode.com, www.stes.tyc.edu.tw, ahc.itexxiahosting.com, www.stes.tyc.edu.tw, www.quora.com, Disposable vapes
