[General] F5 - Reliable F5CAB4 - BIG-IP Administration Control Plane Administration PDF Qu
94
General F5 - Reliable F5CAB4 - BIG-IP Administration Control Plane Administration PDF Qu
Posted at 2/14/2026 20:27:13      View156 | Replies1        Print      Only Author   [Copy Link] 1#
Our company's staff conducted a rigorous analysis of the user's characteristics, so our staff created these three versions of our F5CAB4 study guide for you to choose: the PDF, Software and APP online. The PDF verson can be printable. And the Software version of our F5CAB4 Practice Engine can simulate the real exam and apply in Windows system. App online version can apply to all kinds of the eletronic devices. Our F5CAB4 exam questions are always thinking about customers and hopes that you can be satisfied in all aspects.
If you prefer to practice F5CAB4 exam dumps on paper, then our exam dumps is your best choice. F5CAB4 PDF version is printable, and you can print them into hard one if you like, and you can also take some notes on them and practice them anytime and anyplace. Moreover, F5CAB4 training materials cover most of knowledge points for the exam, and you can have a good command of the major knowledge points as well as improve your professional ability in the process of practicing. We offer you free update for 365 days for F5CAB4 Exam Materials after purchasing. Our system will send the update version to you automatically.
New Guide F5CAB4 Files - F5CAB4 Exam ObjectivesAs long as you choose our F5CAB4 exam questions, we are the family. From the time you purchase, use, and pass the exam, we will be with you all the time. You can seek our help on our F5CAB4 practice questions anytime, anywhere. As long as you are convenient, you can contact us by email. If you have experienced a very urgent problem while using F5CAB4 Exam simulating, you can immediately contact online customer service. And we will solve the problem for you right away.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q13-Q18):NEW QUESTION # 13
New Syslog servers have been deployed in an organization. The BIG-IP Administrator must reconfigure the BIG-IP system to send log messages to these servers.
In which location in the Configuration Utility can the BIG-IP Administrator make the needed configuration changes to accomplish this? (Choose one answer)
  • A. System > Logs > Configuration
  • B. System > Configuration > Local Traffic
  • C. System > Logs > Audit
  • D. System > Configuration > Device
On a BIG-IP system, remote syslog server configuration is managed through the logging configuration framework. In the Configuration Utility, this is accessed via:
This section allows the administrator to:
* Define remote syslog destinations
* Configure log publishers
* Control which log types (system, audit, LTM, ASM, etc.) are forwarded to external syslog servers Why the other options are incorrect:
* A. System > Configuration > Local TrafficUsed for traffic management settings, not logging.
* C. System > Logs > AuditDisplays audit log settings and content but does not configure remote syslog destinations.
* D. System > Configuration > DeviceUsed for device-level settings such as hostname and platform configuration, not logging.
Therefore, the correct location to reconfigure BIG-IP to send logs to new syslog servers is System > Logs > Configuration.
NEW QUESTION # 14
A BIG-IP Administrator uses a device group to share the workload and needs to perform service on a BIG-IP device currently active for a traffic group. The administrator needs to enable the traffic group to run on another BIG-IP device in the device group.
What should the administrator do to meet the requirement? (Choose one answer)
  • A. Select Traffic Group on Primary Unit and then select Demote
  • B. Create a new Traffic Group and then fail to Standby Unit
  • C. Select Traffic Group and then select Failover
  • D. Select Traffic Group and then select Force to Standby
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents:
Traffic Groups are the mechanism BIG-IP uses to control which device owns specific application traffic in a high-availability (HA) configuration. When maintenance is required on a device that is currently active for a traffic group, the correct and recommended action is to fail over that traffic group to another device in the device group.
Failing over the traffic group moves ownership of that traffic group (and the virtual servers associated with it) to another available device without forcing the entire device into standby.
This allows targeted maintenance while minimizing impact to other traffic groups that may still be active on the device.
A is unnecessary and incorrect; traffic groups are not recreated for routine maintenance.
C forces the entire device to standby, which may move more traffic than intended.
D (Demote) affects device trust/priority behavior and is not the standard or recommended method for moving traffic group ownership.
Therefore, selecting the Traffic Group and choosing Failover is the correct solution.
NEW QUESTION # 15
Users are unable to reach an application. The BIG-IP Administrator checks the Configuration Utility and observes that the Virtual Server has a red diamond in front of the status.
What is causing this issue? (Choose one answer)
  • A. The Virtual Server is disabled
  • B. All pool members are down
  • C. All pool members have been disabled
  • D. The Virtual Server is receiving HTTPS traffic over an HTTP virtual
In the BIG-IP Configuration Utility, status icons provide immediate health information. A red diamond specifically indicates that the object itself is administratively disabled. When a virtual server is disabled, BIG-IP will not accept or process traffic for that virtual server, regardless of pool or node state.
* If all pool members were down, the virtual server would typically show a yellow triangle (available but no resources).
* If all pool members were disabled, the virtual server would usually still be enabled but unavailable due to pool status, not shown as a red diamond.
* Protocol mismatch (HTTPS sent to HTTP) does not change the administrative status icon of the virtual server.
Therefore, the red diamond clearly indicates the virtual server is disabled, making D the correct answer.
NEW QUESTION # 16
Users report that traffic is negatively affected every time a BIG-IP device fails over. The traffic becomes stabilized after a few minutes. What should the BIG-IP Administrator do to reduce the impact of future failovers?
  • A. Configure MAC Masquerade
  • B. Enable Failover Multicast Configuration
  • C. Configure a global SNAT Listener
  • D. Set up Failover Method to HA Order
When a failover occurs, the newly active device must inform the surrounding network that it now "owns" the shared IP addresses. Without MAC Masquerade, the new device uses its own hardware MAC, requiring upstream routers to update their ARP tables (which causes a delay). MAC Masquerading allows the HA pair to share a "floating" MAC address, ensuring the Control Plane transition is transparent to the network layer
NEW QUESTION # 17
Administrative user accounts have been defined on the remote LDAP server and are unable to log in to the BIG-IP device.
Which log file should the BIG-IP Administrator check to find the related messages? (Choose one answer)
  • A. /var/log/messages
  • B. /var/log/secure
  • C. /var/log/ltm
  • D. /var/log/user.log
When BIG-IP is configured to use remote authentication (such as LDAP), all authentication and authorization attempts-including successes and failures-are logged to /var/log/secure.
For LDAP-based administrative login issues, /var/log/secure contains:
* LDAP authentication failures
* PAM authentication errors
* Authorization and access-denied messages
* Details explaining why a remote user could not log in
* /var/log/user.log is not a standard BIG-IP log file for authentication.
* /var/log/ltm logs traffic management events, not user authentication.
* /var/log/messages contains general system messages but not detailed authentication failure information.
Therefore, the correct log file to troubleshoot LDAP administrative login failures is /var/log/secure.
NEW QUESTION # 18
If you buy our F5CAB4 study materials you will pass the F5CAB4 test smoothly and easily. We boost professional expert team to organize and compile the F5CAB4 training materials diligently and provide the great service which include the service before and after the sale, the 24-hours online customer service and refund service. Our F5CAB4 real quiz boosts 3 versions and varied functions to make you learn comprehensively and efficiently. The learning of our study materials costs you little time and energy and we update them frequently. questions: BIG-IP Administration Control Plane Administration in detail please look at the introduction of our product as follow.
New Guide F5CAB4 Files: https://www.exams-boost.com/F5CAB4-valid-materials.html
Now, there are many people preparing for the F5CAB4 test, and most of them meet with difficulties, Does your mind disturb at this moment for our F5CAB4 practice questions, Buy New Guide F5CAB4 Files - BIG-IP Administration Control Plane Administration sure pass training amazing after service for you, We not only provide you valid F5CAB4 exam answers for your well preparation, but also bring guaranteed success results to you, Our professional experts have worked so hard to update the quality of our F5CAB4 pdf vce.
We can find that the Internet is getting closer F5CAB4 and closer to our daily life and daily work, The role of the Product Owner ismore crucial than ever, Now, there are many people preparing for the F5CAB4 test, and most of them meet with difficulties.
Three Easy-to-Use F5 F5CAB4 Exam Dumps FormatsDoes your mind disturb at this moment for our F5CAB4 practice questions, Buy BIG-IP Administration Control Plane Administration sure pass training amazing after service for you, We not only provide you valid F5CAB4 exam answers for your well preparation, but also bring guaranteed success results to you.
Posted at 3/6/2026 01:20:53        Only Author  2#
Your article is exceptional, thank you for sharing it with us! Thanks to the New PL-600 test dumps demo exam, I reached a new level in my career. Now Im sharing it for free with all of you!
