NCM-MCI-6.10 Latest Questions | NCM-MCI-6.10 New Braindumps Book
Posted at 2/14/2026 20:32:26
With experienced experts to compile and check the NCM-MCI-6.10 questions and answers, we have received many good feedbacks from our customers, and they also send some thankful email to us for helping them to pass the exam successfully. The pass rate is 98.75%, and money back guarantee if you fail to pass the exam. We also provide you the free update for one year after purchasing the NCM-MCI-6.10 Study Guide. If you have any questions, you can consult the service stuff.
By offering you excellent NCM-MCI-6.10 dumps files, PDF4Test make you career bright and successful. We will offer you discount in buying NCM-MCI-6.10 exam pdf. Once you buy our Nutanix practice questions, you will receive the download link immediately. Our aim is to provide our customers with latest exam study guide and the best-quality service. The up-to-date NCM-MCI-6.10 Practice Questions and answers are right here.
100% Pass-Rate NCM-MCI-6.10 Latest Questions | Accurate NCM-MCI-6.10 New Braindumps Book: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI)I believe that people want to have good prospects of career whatever industry they work in. Of course, there is no exception in the competitive IT industry. IT Professionals working in the IT area also want to have good opportunities for promotion of job and salary. A lot of IT professional know that Nutanix Certification NCM-MCI-6.10 Exam can help you meet these aspirations. PDF4Test is a website which help you successfully pass Nutanix NCM-MCI-6.10.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q24-Q29):NEW QUESTION # 24
Task 13
An administrator found a CentOS VM, Cent_Down, on the cluster with a corrupted network stack. To correct the issue, the VM will need to be restored from a previous snapshot to become reachable on the network again.
VM credentials:
Username: root
Password: nutanix/4u
Restore the VM and ensure it is reachable on the network by pinging 172.31.0.1 from the VM.
Power off the VM before proceeding.
See the Explanation for step by step solution.
To restore the VM and ensure it is reachable on the network, you can follow these steps:
Log in to the Web Console of the cluster where the VM is running.
Click on Virtual Machines on the left menu and find Cent_Down from the list. Click on the power icon to power off the VM.
Click on the snapshot icon next to the power icon to open the Snapshot Management window.
Select a snapshot from the list that was taken before the network stack was corrupted. You can use the date and time information to choose a suitable snapshot.
Click on Restore VM and confirm the action in the dialog box. Wait for the restore process to complete.
Click on the power icon again to power on the VM.
Log in to the VM using SSH or console with the username and password provided.
Run the command ping 172.31.0.1 to verify that the VM is reachable on the network. You should see a reply from the destination IP address.
Go to VMS from the prism central gui
Select the VMand go to More -> Guest Shutdown
Go to Snapshots tab and revert to latest snapshot available
power on vm and verify if ping is working
NEW QUESTION # 25
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
VM specifications:
* vCPUs: 2
* Memory: 8Gb
* Disk Size: 50Gb
* Cluster: Cluster 1
* Network: default-net
* Branding must be disabled on the VM
The API call is failing, indicating an issue with the payload:
"'metadata' is a required property",
"'spec' is a required property"
"message": "Request could not be processed.",
"reason": "INVALID_REQUEST"
The body is saved in desktopAPI_Create_VM.txt.
Correct any issues in the text file that would prevent it from creating the VM. Also ensure the VM will be created as specified and make sure it is saved for re-use using that filename.
Deploy the VM through the API.
Note: Do not power on the VM.
See the Explanation below for detailed answer.
Here is the step-by-step solution to correct the API payload and deploy the VM.
This task is performed using the REST API Explorer within Prism Central.
1. Get Required UUIDs
To create a VM, you first need the unique IDs (UUIDs) for the target cluster and network.
* From the Prism Central dashboard, click the question mark (?) icon in the top-right corner and select REST API Explorer.
* Find Cluster 1 UUID:
* In the API Explorer, search for and select the clusters/list (POST) endpoint.
* In the Body field, paste a simple filter: { "kind": "cluster" }
* Click Send.
* In the "Response" body, find the entry for Cluster 1 and copy its metadata.uuid value.
* Find default-net UUID:
* Search for and select the subnets/list (POST) endpoint.
* In the Body field, paste: { "kind": "subnet" }
* Click Send.
* In the "Response" body, find the entry where spec.name is default-net and copy its metadata.uuid value.
2. Correct the API Payload File
The error message "'metadata' is a required property" and "'spec' is a required property" indicates the JSON in the file is malformed and missing the required root-level objects. The file content also does not match the VM specifications.
* On the desktop, open API_Create_VM.txt in Notepad.
* Delete all existing text in the file (including the POST Call and Body: lines).
* Paste the following corrected and complete JSON payload into the file.
* Replace <UUID_for_Cluster_1> and <UUID_for_default-net> with the actual UUIDs you copied in the previous step.
JSON
"spec": {
"name": "API_VM_Task15",
"resources": {
"power_state": "OFF",
"num_sockets": 2,
"num_vcpus_per_socket": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type": "DISK"
"nic_list": [
"subnet_reference": {
"kind": "subnet",
"uuid": "<UUID_for_default-net>"
"guest_customization": {
"is_overridable": true,
"override_branding": true
"cluster_reference": {
"kind": "cluster",
"uuid": "<UUID_for_Cluster_1>"
"metadata": {
"kind": "vm"
* Save and close the API_Create_VM.txt file.
Correction Summary:
* JSON Structure: The original file was malformed. The new payload provides the required spec and metadata objects at the root level.
* vCPUs: Set to 2 sockets (2 vCPUs total).
* Memory: Set to 8192 MiB (8 GB).
* Disk: Set to 51200 MiB (50 GB) and removed the unneeded CDROM.
* Cluster/Network: Placeholders are added for the required UUIDs.
* Branding: guest_customization.override_branding: true is added to disable branding for the VM.
3. Deploy the VM via API
* Return to the REST API Explorer.
* Search for and select the vms (POST) endpoint (the one with the description "Create a new vm").
* Open the corrected API_Create_VM.txt file, copy its entire contents (which now includes your specific UUIDs).
* Paste the complete JSON payload into the Body field of the vms (POST) endpoint.
* Click Send.
The API will return a 202 Accepted response, and the VM will be created (and remain powered off) on Cluster 1.
NEW QUESTION # 26
The Infosec team has requested that all operational tasks performed within Cluster 1 be properly logged to include the top 4 severity levels and pushed to their syslog system using highest reliability possible for analysis. This is to include any Virtual Machine changes only.
The Infosec team has also requested that monitor logs for the given RSyslog Server Module be included for now. No extra logs should be included.
No other clusters should connect to this syslog server.
Syslog configuration:
* Syslog Name: Corp_Syslog
* Syslog IP: 34.142.155.231
* Port: TCP/514
Ensure only Cluster 1 is configured to meet these requirements.
Here is the step-by-step solution to configure syslog for Cluster 1.
1. Access Cluster 1 Prism Element
Since the requirement is to only configure Cluster 1 and not other clusters, this task must be performed in the Prism Element (PE) interface for Cluster 1.
* From the main Prism Central dashboard, navigate to Hardware > Clusters.
* Find Cluster 1 in the list and click its name. This will open the specific Prism Element login page for that cluster.
* Log in to Cluster 1's Prism Element interface.
2. Add the Syslog Server
* In the Cluster 1 PE interface, click the gear icon (Settings) in the top-right corner.
* From the left-hand menu, select Syslog.
* In the "Remote Syslog Server" section, click the + Add Syslog Server button.
* Fill in the server details as required:
* Name: Corp_Syslog
* IP Address: 34.142.155.231
* Port: 514
* Protocol: TCP (This provides the highest reliability, as requested).
* Click Save.
3. Configure Log Modules and Severities
Now, we must specify which logs to send to the new server.
* On the same Syslog settings page, find the "Syslog Configuration" section and click the Configure button (or Modify if a default is present).
* A dialog box "Select Modules and Levels" will appear.
* Uncheck all modules to ensure no extra logs are sent.
* Check the box for the RSyslog Server Module (or rsyslog_forwarder).
* For this module, check the boxes for the severities: Critical, Warning, and Info.
* Check the box for the ApiServer module.
* This module logs all operational tasks and audit trails, which includes all Virtual Machine changes.
* For this module, check the boxes for the top severity levels: Critical, Warning, and Info.
* Ensure no other modules (like Stargate, Cerebro, Zookeeper, etc.) are checked.
* Click Save.
Cluster 1 is now configured to send its audit logs (including VM changes) and its own syslog monitoring logs to the Corp_Syslog server via TCP, fulfilling all security requirements.
Topic 2, Performance Based Questions Set 2
Environment
You have been provisioned a dedicated environment for your assessment which includes the following:
Workstation
* windows Server 2019
* All software/tools/etc to perform the required tasks
* Nutanix Documentation and whitepapers can be found in desktopilesDocumentation
* Note that the workstation is the system you are currently togged into Nutanix Cluster
* There are three clusters provided. The connection information for the relevant cluster will be displayed to the high of the question Please make sure you are working on the correct cluster for each item Please ignore any licensing violations
* Cluster A is a 3-node cluster with Prism Central 2022.6 where most questions will be performed
* Cluster B is a one-node cluster and has one syslog item and one security item to perform
* Cluster D is a one-node duster with Prism Central 5.17 and has a security policy item to perform Important Notes
* If the text is too small and hard to read, or you cannot see an of the GUI. you can increase/decrease the zoom of the browser with CTRL + ,and CTRL + (the plus and minus keys) You will be given 3 hours to complete the scenarios for Nutanix NCMMCI Once you click the start button below, you will be provided with:
- A Windows desktop A browser page with the scenarios and credentials (Desktopinstructions) Notes for this exam delivery:
The browser can be scaled lo Improve visibility and fit all the content on the screen.
- Copy and paste hot-keys will not work Use your mouse for copy and paste.
- The Notes and Feedback tabs for each scenario are to leave notes for yourself or feedback for
- Make sure you are performing tasks on the correct components.
- Changing security or network settings on the wrong component may result in a falling grade.
- Do not change credentials on an component unless you are instructed to.
- All necessary documentation is contained in the DesktopFilesDocumentation directory
NEW QUESTION # 27
Task 1
An administrator needs to configure storage for a Citrix-based Virtual Desktop infrastructure.
Two VDI pools will be created
Non-persistent pool names MCS_Pool for tasks users using MCS Microsoft Windows 10 virtual Delivery Agents (VDAs) Persistent pool named Persist_Pool with full-clone Microsoft Windows 10 VDAs for power users
20 GiB capacity must be guaranteed at the storage container level for all power user VDAs The power user container should not be able to use more than 100 GiB Storage capacity should be optimized for each desktop pool.
Configure the storage to meet these requirements. Any new object created should include the name of the pool (s) (MCS and/or Persist) that will use the object.
Do not include the pool name if the object will not be used by that pool.
Any additional licenses required by the solution will be added later.
To configure the storage for the Citrix-based VDI, you can follow these steps:
Log in to Prism Central using the credentials provided.
Go to Storage > Storage Pools and click on Create Storage Pool.
Enter a name for the new storage pool, such as VDI_Storage_Pool, and select the disks to include in the pool.
You can choose any combination of SSDs and HDDs, but for optimal performance, you may prefer to use more SSDs than HDDs.
Click Save to create the storage pool.
Go to Storage > Containers and click on Create Container.
Enter a name for the new container for the non-persistent pool, such as MCS_Pool_Container, and select the storage pool that you just created, VDI_Storage_Pool, as the source.
Under Advanced Settings, enable Deduplication and Compression to reduce the storage footprint of the non- persistent desktops. You can also enable Erasure Coding if you have enough nodes in your cluster and want to save more space. These settings will help you optimize the storage capacity for the non-persistent pool.
Click Save to create the container.
Go to Storage > Containers and click on Create Container again.
Enter a name for the new container for the persistent pool, such as Persist_Pool_Container, and select the same storage pool, VDI_Storage_Pool, as the source.
Under Advanced Settings, enable Capacity Reservation and enter 20 GiB as the reserved capacity. This will guarantee that 20 GiB of space is always available for the persistent desktops. You can also enter 100 GiB as the advertised capacity to limit the maximum space that this container can use. These settings will help you control the storage allocation for the persistent pool.
Go to Storage > Datastores and click on Create Datastore.
Enter a name for the new datastore for the non-persistent pool, such as MCS_Pool_Datastore, and select NFS as the datastore type. Select the container that you just created, MCS_Pool_Container, as the source.
Click Save to create the datastore.
Go to Storage > Datastores and click on Create Datastore again.
Enter a name for the new datastore for the persistent pool, such as Persist_Pool_Datastore, and select NFS as the datastore type. Select the container that you just created, Persist_Pool_Container, as the source.
The datastores will be automatically mounted on all nodes in the cluster. You can verify this by going to Storage > Datastores and clicking on each datastore. You should see all nodes listed under Hosts.
You can now use Citrix Studio to create your VDI pools using MCS or full clones on these datastores. For more information on how to use Citrix Studio with Nutanix Acropolis, see Citrix Virtual Apps and Desktops on Nutanix or Nutanix virtualization environments.
https://portal.nutanix.com/page/ ... x-Virtual-Apps-and- Desktops:bp-nutanix-storage-configuration.html
NEW QUESTION # 28
Following new security guidelines, it must be ensured that the storage of critical virtual machines will be encrypted in future.
The assignment is to be made by a new category called VM-Storage with a value of softwareencrypted in Prism Central. Make sure a second value of SEDencrypted is also created for future use.
Create the above-mentioned category and perform further configurations in Prism Central for VM-based storage encryption.
Assign the name Encrypted-Storage to the newly created policy.
Here is the step-by-step solution to create the category and the corresponding storage encryption policy within Prism Central.
1. Create the Category
First, you must create the category and the two values requested.
* In Prism Central, navigate to Administration > Categories.
* Click New Category.
* In the Name field, enter VM-Storage.
* In the Add a Value field, type softwareencrypted and click the Add (plus) button.
* In the Add a Value field again, type SEDencrypted and click the Add (plus) button.
* Click Save.
2. Create the Encryption Policy
Next, you will create the security policy that uses the new category.
* In Prism Central, navigate to Security > Data-at-Rest Encryption.
* Click the + Create Security Policy button.
* In the Policy Name field, enter Encrypted-Storage.
* Ensure the Encryption Type is set to Software-based.
* For Target VMs, select the radio button for VMs matching a category.
* In the Select Category dropdown, choose the VM-Storage category you just created.
* In the Select Value dropdown, choose softwareencrypted.
* Click Save.
This policy will now automatically apply software-based encryption to any new or existing VMs that are assigned the VM-Storage: softwareencrypted category.
NEW QUESTION # 29
Are you still worried about the complex NCM-MCI-6.10 exam? Do not be afraid. NCM-MCI-6.10 exam dumps and answers from our PDF4Test site are all created by the IT talents with more than 10 years'certification experience. Moreover, NCM-MCI-6.10 Exam Dumps and answers are the most accuracy and the newest inspection goods.
NCM-MCI-6.10 New Braindumps Book: https://www.pdf4test.com/NCM-MCI-6.10-dump-torrent.html
Secondly, the Software version of NCM-MCI-6.10 exam questions can simulate the real exam environment to give you exam experience more vividly, Details are researched and produced by Nutanix NCM-MCI-6.10 New Braindumps Book Certification Experts who are constantly using industry experience to produce precise, and logical, Nutanix NCM-MCI-6.10 Latest Questions What is more, we have professional experts to maintain our websites regularly.
Click the Create a New Welcome Page button to display NCM-MCI-6.10 Latest Questions the New Page Wizard, To fully test a restore or to perform an actual restore, you have much more to consider because this option chooses NCM-MCI-6.10 the most recent restore and restores the virtual machine without networking attached.
Nutanix NCM-MCI-6.10 Latest Questions: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) - PDF4Test High Pass RateSecondly, the Software version of NCM-MCI-6.10 exam questions can simulate the real exam environment to give you exam experience more vividly, Details are researched and produced by Nutanix Certification NCM-MCI-6.10 Latest Questions Experts who are constantly using industry experience to produce precise, and logical.
What is more, we have professional experts NCM-MCI-6.10 New Braindumps Book to maintain our websites regularly, Also before purchasing our products we offer free PDF demo for your downloading so that you will have certain understanding about our NCM-MCI-6.10 Test Braindumps: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI).
On the one hand, through simulation of our NCM-MCI-6.10 pass-king materials, you can have a good command of every detail in the real exam so that you will be likely to get well prepared for what you have ignored in the simulation of NCM-MCI-6.10 practice materials.
- NCM-MCI-6.10 PDF dumps - NCM-MCI-6.10 dumps training make for your success in the coming Nutanix exam 💑 Search for ☀ NCM-MCI-6.10 ️☀️ and download it for free on 「 [url]www.pdfdumps.com 」 website ✈NCM-MCI-6.10 Testing Center[/url]
- Nutanix NCM-MCI-6.10 PDF Dumps - The Fastest Way To Prepare For Exam 👱 Search for ➠ NCM-MCI-6.10 🠰 and download exam materials for free through ✔ [url]www.pdfvce.com ️✔️ 🍶Dumps NCM-MCI-6.10 Download[/url]
- Nutanix NCM-MCI-6.10 PDF Dumps - The Fastest Way To Prepare For Exam 🤸 Search for { NCM-MCI-6.10 } and download it for free immediately on “ [url]www.pdfdumps.com ” 🎼NCM-MCI-6.10 Exam Preparation[/url]
- NCM-MCI-6.10 Latest Material 🕯 NCM-MCI-6.10 Interactive Practice Exam 🧳 Useful NCM-MCI-6.10 Dumps 🥽 Enter “ [url]www.pdfvce.com ” and search for ➠ NCM-MCI-6.10 🠰 to download for free 💬Free NCM-MCI-6.10 Pdf Guide[/url]
- Pass Guaranteed 2026 Fantastic Nutanix NCM-MCI-6.10 Latest Questions 🧧 Open 「 [url]www.troytecdumps.com 」 enter ➡ NCM-MCI-6.10 ️⬅️ and obtain a free download 🧕NCM-MCI-6.10 Vce Torrent[/url]
- 2026 NCM-MCI-6.10 Latest Questions Free PDF | Efficient NCM-MCI-6.10 New Braindumps Book: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) 🔱 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for ▶ NCM-MCI-6.10 ◀ for free download 🕖NCM-MCI-6.10 Latest Exam Discount[/url]
- New NCM-MCI-6.10 Exam Name 🟧 Free NCM-MCI-6.10 Pdf Guide 🐢 NCM-MCI-6.10 Exam Preparation 🎑 Open ⇛ [url]www.examcollectionpass.com ⇚ and search for ( NCM-MCI-6.10 ) to download exam materials for free ⚡New NCM-MCI-6.10 Exam Name[/url]
- NCM-MCI-6.10 Latest Material 📼 Reliable NCM-MCI-6.10 Exam Practice 🔸 NCM-MCI-6.10 Reliable Exam Dumps 💙 ⏩ [url]www.pdfvce.com ⏪ is best website to obtain ➥ NCM-MCI-6.10 🡄 for free download 🌾NCM-MCI-6.10 Vce Torrent[/url]
- Certificate NCM-MCI-6.10 Exam 🐺 Dumps NCM-MCI-6.10 Download ☸ NCM-MCI-6.10 Latest Exam Discount 📤 The page for free download of [ NCM-MCI-6.10 ] on ( [url]www.examcollectionpass.com ) will open immediately 📘Reliable NCM-MCI-6.10 Exam Practice[/url]
- NCM-MCI-6.10 PDF dumps - NCM-MCI-6.10 dumps training make for your success in the coming Nutanix exam 🔕 Search for ▶ NCM-MCI-6.10 ◀ and download exam materials for free through 《 [url]www.pdfvce.com 》 ⬅Certificate NCM-MCI-6.10 Exam[/url]
- Pass Guaranteed 2026 Fantastic Nutanix NCM-MCI-6.10 Latest Questions 🏧 Open website “ [url]www.pass4test.com ” and search for ( NCM-MCI-6.10 ) for free download 🪔NCM-MCI-6.10 Reliable Exam Dumps[/url]
- www.stes.tyc.edu.tw, tutr.online, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.4shared.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, barclaytraininginstitute.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
