[Hardware] Industries-CPQ-Developer Reliable Test Prep, Industries-CPQ-Developer Valid Exam
92
Hardware Industries-CPQ-Developer Reliable Test Prep, Industries-CPQ-Developer Valid Exam
Posted at 2/14/2026 21:11:28      View171 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest LatestCram Industries-CPQ-Developer PDF Dumps and Industries-CPQ-Developer Exam Engine Free Share: https://drive.google.com/open?id=1nJks2iC2Ir16XhCxQai3VkXXIhu9GVAn
Are you still worried about not passing the Industries-CPQ-Developer exam? Do you want to give up because of difficulties and pressure when reviewing? You may have experienced a lot of difficulties in preparing for the exam, but fortunately, you saw this message today because our well-developed Industries-CPQ-Developer Study Materials will help you tide over all the difficulties. As a multinational company, our Industries-CPQ-Developer study materials serve candidates from all over the world. No matter which country you are currently in, you can be helped by our Industries-CPQ-Developer study materials.
Salesforce Industries-CPQ-Developer Exam consists of 60 multiple-choice questions, which must be completed within 105 minutes. Industries-CPQ-Developer exam covers a range of topics, including CPQ pricing and quoting, product configuration, product rules, and discounting. Candidates must achieve a passing score of 68% or higher to become certified.
New Release Industries-CPQ-Developer Questions - Salesforce Industries-CPQ-Developer Exam DumpsSalesforce Industries-CPQ-Developer certification is indeed a better idea before you start with the interviews. Salesforce Industries-CPQ-Developer certification will add up to your excellence in your field and leave no space for any doubts in the mind of the hiring team. But, have you thought about how can you prepare for the Salesforce Industries-CPQ-Developer Exam Questions? Do you have any idea how we can crack the nut to give wings to our dreams?
Salesforce Industries-CPQ-Developer Certification Exam covers a range of topics related to Salesforce CPQ and its application in the Industries domain, including product configuration, pricing and discounting, quote management, and integration with other Salesforce products. Candidates are expected to have a strong understanding of the capabilities and limitations of Salesforce CPQ, as well as the ability to design and implement solutions that meet specific business requirements. Successful completion of the exam demonstrates that an individual possesses the skills and knowledge required to develop and configure Salesforce CPQ solutions in the Industries domain, making them a valuable asset to any organization seeking to leverage this powerful technology.
Salesforce Certified Industries CPQ Developer Sample Questions (Q242-Q247):NEW QUESTION # 242
What type of parameter is being used in this example API call:
vlocity_cmt/v3/catalogs/Phonesyoffers?context=fStatus":"Active"J
  • A. Specifying a particular logged-in user
  • B. Specifying a context
  • C. Specifying page size
  • D. No parameters are used
NEW QUESTION # 243
The ProductAttributesBatchProcessor job copies the filterable product attributes across the product catalog to a specialized cached sObject for use in Vlocity Cart.
  • A. False
  • B. True
NEW QUESTION # 244
In Vlocity Context Rules, only one rule set can apply to a promotion.
  • A. False
  • B. True
In Vlocity Context Rules, it is possible for multiple rule sets to apply to a single promotion. This flexibility allows for more granular and specific targeting of promotions based on different criteria set within each rule set. By designing the system this way, Vlocity allows administrators to create complex promotional structures that can adapt to various customer scenarios, thereby enhancing the effectiveness of promotional campaigns within the Vlocity CPQ environment.
NEW QUESTION # 245
Vlocity Picklists can be assigned to attributes at which of the following        levels?
Note: This question displayed answer options in random order when taking this Test.
  • A. Attributes and Object Types
  • B. Attributes, Attribute Categories and Products
  • C. Attributes and Products
  • D. Attributes, Object Types, and Products
NEW QUESTION # 246
A developer has updated the price of a product but still sees the previous price in the Digital Commerce API response.
What job should the developer run to correct this issue?
  • A. Regenerate Cached API Records job
  • B. Delete Expired API Cache job
  • C. Migrate Cache Records job
  • D. Populate API Cache job
* Purpose of the Job:The Regenerate Cached API Records job rebuilds the cached records stored in the SBQQ__APICache__c object. This ensures that the latest data (e.g., updated prices, configurations, or rules) is reflected in API responses.
* It forces Salesforce CPQ to re-evaluate and re-cache all records based on the current configuration and pricing data.
* This job is explicitly designed to address scenarios where changes are not visible in API responses due to stale cache.
* When to Use It:
* After updating product prices, discount schedules, configuration rules, or attribute changes.
* When troubleshooting discrepancies between Salesforce CPQ data and API responses.
* How It Works:
* The job iterates through all relevant records (products, quotes, etc.) and regenerates their cached representations.
* This process updates the SBQQ__APICache__c table with fresh data, ensuring the Digital Commerce API returns accurate results.
https://help.salesforce.com/s/ar ... ords.htm&type=5 When updates to product prices or configurations are made in Salesforce CPQ, the changes may not immediately reflect in the Digital Commerce API response due to cached data. The Regenerate Cached API Records job forces the system to rebuild the cached records with the latest data, ensuring the API returns updated values. Other jobs like "Populate API Cache" (initial population) or "Delete Expired API Cache" (cleanup) do not refresh existing cached records with new data. Why Regenerate Cached API Records (Option D) is Correct:
* A. Populate API Cache Job:
* This job initializes the cache for the first time (e.g., during CPQ setup).
* It does not update existing cached records after changes are made.
* B. Migrate Cache Records Job:
* This job transfers cached records between Salesforce orgs (e.g., during sandbox-to-production migrations).
* It is unrelated to refreshing data within the same org.
* C. Delete Expired API Cache Job:
* This job removes old cached records that are no longer valid (e.g., expired quotes).
* It does not regenerate or update active cached records with new data.
Why Other Options Are Incorrect:
* Salesforce CPQ Administration Guide:
* Explains the role of caching in CPQ and states:"The Regenerate Cached API Records job updates the cached data used by the Digital Commerce API. Run this job after making changes to products, prices, or rules to ensure the API reflects the latest configurations."(Source: Salesforce Help - Manage Cached Data for APIs) Explains the role of caching in CPQ and states:"The Regenerate Cached API Records job updates the cached data used by the Digital Commerce API. Run this job after making changes to products, prices, or rules to ensure the API reflects the latest configurations."(Source: Salesforce Help - Manage Cached Data for APIs)
* API Cache Object (SBQQ__APICache__c):
* The SBQQ__APICache__c object stores precomputed JSON representations of CPQ data for API efficiency.
* Regenerating this object ensures that API responses align with the latest data model.(Source:
Salesforce CPQ Developer Guide - APICache Object)
* Troubleshooting Stale Data:
* Salesforce recommends running the Regenerate Cached API Records job as a first step when API responses do not match CPQ configurations.(Source: Salesforce Knowledge Article
- Troubleshoot CPQ API Cache Issues)
Key References from Salesforce CPQ Documentation:
* Navigate to Setup # CPQ Settings # API Cache Jobs.
* Select Regenerate Cached API Records.
* Specify filters (e.g., products, quotes) or run it for all records.
* Monitor progress in the Jobs tab.
Steps to Run the Job:
NEW QUESTION # 247
Industries-CPQ-Developer Valid Exam Online: https://www.latestcram.com/Industries-CPQ-Developer-exam-cram-questions.html
P.S. Free & New Industries-CPQ-Developer dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1nJks2iC2Ir16XhCxQai3VkXXIhu9GVAn
Posted at 3/9/2026 05:27:59        Only Author  2#
It provided me with a fresh perspective. This C-THR81-2505 dumps download helped me get promoted and receive a salary increase. Now, its free for everyone. Wishing you success in your career journey!
