Valid AZ-104 Exam Vce & AZ-104 Pdf Exam Dump
Posted at 2/14/2026 21:58:14
BONUS!!! Download part of Pass4cram AZ-104 dumps for free: https://drive.google.com/open?id=1N9JNBwIq0BESw-0Tc7N3SkmJnmqL9AfG
Another thing you will get from using the AZ-104 Exam study material is free to support. If you encounter any problem while using the AZ-104 material, you have nothing to worry about. The solution is closer to you than you can imagine, just contact the support team and continue enjoying your study with the Microsoft Azure Administrator preparation material.
To become a certified Microsoft Azure Administrator, the candidate needs to pass the AZ-104 Certification Exam. AZ-104 exam consists of multiple-choice questions and is intended for IT professionals with at least six months of experience in Azure administration. AZ-104 exam is designed to test the candidate's knowledge of Azure services and their ability to implement them in real-world scenarios.
Microsoft AZ-104 Exam Syllabus Topics:| Topic | Details | | Manage Azure identities and governance (15-20%) | | Manage Azure Active Directory (Azure AD) objects | -create users and groups
-create administrative units
-manage user and group properties
-manage device settings
-perform bulk user updates
-manage guest accounts
-configure Azure AD Join
-configure self-service password reset | | Manage role-based access control (RBAC) | -create a custom role
- provide access to Azure resources by assigning roles at different scopes
-interpret access assignments | | Manage subscriptions and governance | -configure Azure policies
-configure resource locks
-apply and manage tags on resources
- manage resource groups
-manage subscriptions
- manage costs
-configure management groups | | Implement and manage storage (15-20%) | | Secure storage | -configure network access to storage accounts
-create and configure storage accounts
-generate shared access signature (SAS) tokens
-manage access keys
-configure Azure AD Authentication for a storage account
- Configure access to Azure Files | | Manage Storage | -export from Azure job
-import into Azure job
-install and use Azure Storage Explorer
-copy data by using AZCopy
- implement Azure Storage replication
- configure blob object replication | | Configure Azure files and Azure blob storage | - create an Azure file share
-create and configure Azure File Sync service
-configure Azure Blob Storage
-configure storage tiers
- configure blob lifecycle management | | Deploy and manage Azure compute resources (20-25%) | | Automate deployment of virtual machines (VMs) by using Azure Resource Manager templates | - modify an Azure Resource Manager template
-configure a virtual hard disk (VHD) template
- deploy from a template
-save a deployment as an Azure Resource Manager template
- deploy virtual machine extensions | | Configure VMs | -configure Azure Disk Encryption
-move VMs from one resource group to another
-manage VM sizes
-add data disks
-configure networking
-redeploy VMs
- configure high availability
- deploy and configure scale sets |
Microsoft AZ-104 Exam | Valid AZ-104 Exam Vce - Latest updated of AZ-104 Pdf Exam DumpAPP test engine of Microsoft AZ-104 exam is popular with at least 60% candidates since all most certification candidates are fashion and easy to adapt to this new studying method. Someone thinks that APP test engine of AZ-104 exam is convenient to use any time anywhere. Also part of candidates thinks that this version can simulate the real scene with the real test. If you can open the browser you can learn. Also if you want to learn offline, you should not clear the cache after downloading and installing the APP test engine of AZ-104 Exam.
Microsoft Azure Administrator Sample Questions (Q291-Q296):NEW QUESTION # 291
SIMULATION
Overview
The following section of the exam is a lab. In this section, you will perform a set of tasks in a live environment. While most functionality will be available to you as it would be in a live environment, some functionality (e.g., copy and paste, ability to navigate to external websites) will not be possible by design.
Scoring is based on the outcome of performing the tasks stated in the lab. In other words, it doesn't matter how you accomplish the task, if you successfully perform it, you will earn credit for that task.
Labs are not timed separately, and this exam may have more than one lab that you must complete. You can use as much time as you would like to complete each lab. But, you should manage your time appropriately to ensure that you are able to complete the lab(s) and all other sections of the exam in the time provided.
Please note that once you submit your work by clicking the Next button within a lab, you will NOT be able to return to the lab.
To start the lab
You may start the lab by clicking the Next button.
You recently created a virtual machine named Web01.
You need to attach a new 80-GB standard data disk named Web01-Disk1 to Web01.
What should you do from the Azure portal?
See below explanation
Add a data disk
Step 1. In the Azure portal, from the menu on the left, select Virtual machines.
Step 2. Select the Web01 virtual machine from the list.
Step 3. On the Virtual machine page, , in Essentials, select Disks.
Step 4. On the Disks page, select the Web01-Disk1 from the list of existing disks.
Step 5. In the Disks pane, click + Add data disk.
Step 6. Click the drop-down menu for Name to view a list of existing managed disks accessible to your Azure subscription. Select the managed disk Web01-Disk1 to attach:
https://docs.microsoft.com/en-us ... /attach-disk-portal
NEW QUESTION # 292
You have an Azure subscription that contains a virtual network named VNet1. VNet1 uses an IP address space of 10.0.0.0/16 and contains the subnets in the following table.
Subnet1 contains a virtual appliance named VM1 that operates as a router.
You create a routing table named RT1.
You need to route all inbound traffic to VNet1 through VM1.
How should you configure RT1? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... reate-a-route-table
https://docs.microsoft.com/en-us ... r-next-hop-overview
NEW QUESTION # 293
You have an Azure virtual machine named VM1 and a Recovery Services vault named Vault1.
You create a backup Policy1 as shown in the exhibit. (Click the Exhibit tab.)
You configure the backup of VM1 to use Policy1 on Thursday, January 1.
You need to identify the number of available recovery points for VM1.
How many recovery points are available on January 8 and on January 15? To answer, select the appropriate options in the answer area.
Box 1: 6
4 daily + 1 weekly + monthly
Box 2: 8
4 daily + 2 weekly + monthly + yearly
NEW QUESTION # 294
You have an Azure Active Directory (Azure AD) tenant named contoso.onmicrosoft.com.
You hire a temporary vendor. The vendor uses a Microsoft account that has a sign-in of user1@outlook.com.
You need to ensure that the vendor can authenticate to the tenant by using user1@outlook.com.
What should you do?
- A. From the Azure portal, add a new guest user, and then specify user1@outlook.com as the email address.
- B. From Azure Cloud Shell, run the New-AzureADUser cmdlet and specify the -UserPrincipalName user1@outlook.com parameter.
- C. From Windows PowerShell, run the New-AzureADUser cmdlet and specify the -UserPrincipalName user1@outlook.com parameter.
- D. From the Azure portal, add a custom domain name, create a new Azure AD user, and then specify user1@outlook.com as the username.
UserPrincipalName - contains the UserPrincipalName (UPN) of this user. The UPN is what the user will use when they sign in into Azure AD. The common structure is @, so for Abby Brown in Contoso.com, the UPN would be AbbyB@contoso.com Example:
To create the user, call the New-AzureADUser cmdlet with the parameter values:
powershell New-AzureADUser -AccountEnabled $True -DisplayName "Abby Brown" -PasswordProfile$PasswordProfile -MailNickName "AbbyB" -UserPrincipalName "AbbyB@contoso.com" References:
https://docs.microsoft.com/bs-cy ... ?view=azureadps-2.0
NEW QUESTION # 295
You have an Azure subscription named Sub1.
You plan to deploy a multi-tiered application that will contain the tiers shown in the following table.
You need to recommend a networking solution to meet the following requirements:
* Ensure that communication between the web servers and the business logic tier spreads equally across the virtual machines.
* Protect the web servers from SQL injection attacks.
Which Azure resource should you recommend for each requirement? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
Box 1: an internal load balancer
Azure Internal Load Balancer (ILB) provides network load balancing between virtual machines that reside inside a cloud service or a virtual network with a regional scope.
Box 2: an application gateway that uses the WAF tier
Azure Web Application Firewall (WAF) on Azure Application Gateway provides centralized protection of your web applications from common exploits and vulnerabilities. Web applications are increasingly targeted by malicious attacks that exploit commonly known vulnerabilities. Application gateway which uses WAF tier.
NEW QUESTION # 296
Our AZ-104 exam questions are unlike other study materials that are available on the market, AZ-104 guide quiz specially proposed different versions to allow you to learn not only on paper, but also to use mobile phones to learn. And if you buy the value pack, you have all of the three versions, the price is quite preferential and you can enjoy all of the study experiences. This means you can AZ-104 Practice Engine anytime and anyplace for the convenience these three versions bring.
AZ-104 Pdf Exam Dump: https://www.pass4cram.com/AZ-104_free-download.html
- Free PDF Microsoft - Efficient Valid AZ-104 Exam Vce 🥈 Easily obtain free download of 《 AZ-104 》 by searching on ⇛ [url]www.troytecdumps.com ⇚ ❤️New AZ-104 Test Prep[/url]
- New AZ-104 Test Prep 📤 AZ-104 Reliable Exam Materials 🦗 AZ-104 Reliable Braindumps 🧧 Easily obtain 【 AZ-104 】 for free download through ✔ [url]www.pdfvce.com ️✔️ 👧AZ-104 Reliable Exam Materials[/url]
- AZ-104 Valuable Feedback 🤦 AZ-104 Related Content ☢ Sample AZ-104 Questions Pdf 🚗 Immediately open ➥ [url]www.examcollectionpass.com 🡄 and search for 「 AZ-104 」 to obtain a free download ❕AZ-104 Real Exam Questions[/url]
- Pass AZ-104 Exam with Latest Valid AZ-104 Exam Vce by Pdfvce 😸 Open ➥ [url]www.pdfvce.com 🡄 enter { AZ-104 } and obtain a free download 🥰New AZ-104 Test Prep[/url]
- AZ-104 Valid Exam Question 💓 New AZ-104 Test Prep 🤝 AZ-104 Free Download Pdf 😱 Copy URL ➡ [url]www.examcollectionpass.com ️⬅️ open and search for ➠ AZ-104 🠰 to download for free 🐦AZ-104 Real Exam Questions[/url]
- AZ-104 Real Exam Questions 🏕 AZ-104 Exam Labs 🪀 AZ-104 Free Download Pdf ⛪ Download ▶ AZ-104 ◀ for free by simply entering ➤ [url]www.pdfvce.com ⮘ website ⭕
ractice AZ-104 Online[/url] - AZ-104 valid exam format - AZ-104 free practice pdf - AZ-104 latest study material 🥢 Open ➽ [url]www.prep4sures.top 🢪 enter [ AZ-104 ] and obtain a free download 🗾AZ-104 Valid Exam Question[/url]
- Certification AZ-104 Exam Infor 💕 New AZ-104 Test Prep 💨 New AZ-104 Exam Prep 🦰 Search for ✔ AZ-104 ️✔️ and download exam materials for free through 「 [url]www.pdfvce.com 」 🔷AZ-104 Reliable Braindumps[/url]
- Practice AZ-104 Online 🐇 AZ-104 Free Download Pdf 👲 AZ-104 Reliable Braindumps 🪂 Download “ AZ-104 ” for free by simply searching on 【 [url]www.pdfdumps.com 】 🐲AZ-104 Free Download Pdf[/url]
- AZ-104 Vce Format ⭐ AZ-104 Valid Test Review 🆗 Certification AZ-104 Exam Infor 🎵 Download ▛ AZ-104 ▟ for free by simply searching on ▶ [url]www.pdfvce.com ◀ 🚀
ractice AZ-104 Online[/url] - Microsoft AZ-104 Preparation Materials Available In Different Formats 🥢 Download ➠ AZ-104 🠰 for free by simply entering ▶ [url]www.pdfdumps.com ◀ website 🍌AZ-104 Valuable Feedback[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, nextlevel.com.bd, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that Pass4cram AZ-104 dumps now are free: https://drive.google.com/open?id=1N9JNBwIq0BESw-0Tc7N3SkmJnmqL9AfG
