[General] C-S4EWM-2023 Pdf Exam Dump | Valid C-S4EWM-2023 Exam Review
80
【General】 C-S4EWM-2023 Pdf Exam Dump | Valid C-S4EWM-2023 Exam Review
Posted at 2/14/2026 22:44:28      View:126 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Itcertking C-S4EWM-2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Hm4i32LO7ImXNDID_XFaGEuMNO94ymz2
Almost those who work in the IT industry know that it is very difficult to prepare for C-S4EWM-2023. Although our Itcertking cannot reduce the difficulty of C-S4EWM-2023 exam, what we can do is to help you reduce the difficulty of the exam preparation. Once you have tried our technical team carefully prepared for you after the test, you will not fear to C-S4EWM-2023 Exam. What we have done is to make you more confident in C-S4EWM-2023 exam.
The passing rate is the best test for quality of our C-S4EWM-2023 study materials. And we can be very proud to tell you that the passing rate of our C-S4EWM-2023 Exam Questions is almost 100%. That is to say, as long as you choose our study materials and carefully review according to its content, passing the C-S4EWM-2023 Exam is a piece of cake. We're definitely not exaggerating. If you don't believe, you can give it a try.
Valid SAP C-S4EWM-2023 Exam Review, C-S4EWM-2023 ExamsWithout bothering to stick to any formality, our SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management C-S4EWM-2023 learning quiz can be obtained within five minutes. No need to line up or queue up to get our C-S4EWM-2023 practice materials. They are not only efficient on downloading aspect, but can expedite your process of review. No harangue is included within SAP C-S4EWM-2023 Training Materials and every page is written by our proficient experts with dedication.
SAP C-S4EWM-2023 Exam Syllabus Topics:
  • Warehouse Structure, Resource Management and SAP EWM Master Data: This topic encompasses defining the warehouse structure and setting up resource management, along with creating SAP EWM master data like storage bins and products, packaging specifications, supply chain units, and business partners.
  • Shipping and Receiving: It focuses on configuring Yard Management, SAP Dock Appointment Scheduling, and using the Shipping Cockpit.
  • Warehouse Management (Monitor - Cockpit): This topic involves monitoring warehouse activities using the Warehouse Management Monitor, Warehouse Cockpit, and analytical apps.
  • Managing Clean Core: It covers evaluating and applying clean core principles to ERP to maximize business process agility, reduce adaptation efforts, and accelerate innovation.
Topic 5
  • Process and Layout Oriented Storage Control: It covers creating customizing settings and using Process and Layout-Oriented Storage Control.
Topic 6
  • Outbound Processes (Wave Management, Cross-docking, Production Integration): This topic covers combining outbound deliveries using wave management, packing and kitting in outbound processes, and staging products for production.
Topic 7
  • System Integration, Master Data and Delivery Document Customizing: This focuses on setting up system integration, distributing master data, and customizing delivery documents.
Topic 8
  • Internal processing (Physical Inventory, Replenishment): This topic involves defining physical inventory processes and setting up and executing replenishment.
Topic 9
  • Warehouse Processing, Warehouse Task and Order Creation, Strategies: This topic includes defining warehouse process types and setting up determination, as well as defining putaway and picking strategies.
Topic 10
  • Cross Topics (Labor Management, Exception Handling, Batches, Serial Numbers): This topic includes setting up labor management and exception handling, and working with additional product information.
SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management Sample Questions (Q32-Q37):NEW QUESTION # 32
Your customer wants to implement the material flow system (MFS) to control conveyors and the automated high rack storage are a. Which standard options do you have to communicate with the programmable logic controllers (PLC)? Note: There are 2 correct answers to this question.
  • A. Use the ALE interface to send an IDoc to a 3rd party software
  • B. Use an RFC adaptor (e.g., SAP Plant Connectivity)
  • C. Directly integrate to the PLC using ABAP Push Channels
  • D. Send an IDoc through a Post Processing Framework action to the PLC
Comprehensive and Detailed In-Depth Explanation:
The Material Flow System (MFS) in SAP EWM integrates with PLCs for automation. Option B ("Directly integrate to the PLC using ABAP Push Channels") is correct as it enables real-time communication via WebSockets, configured in SPRO: SCM Extended Warehouse Management > Material Flow System > Communication. Option D ("Use an RFC adaptor (e.g., SAP Plant Connectivity)") is correct because SAP Plant Connectivity (PCo) uses RFC to connect EWM to PLCs. Option A (ALE/IDoc) and option C (PPF/IDoc) are not standard for direct PLC communication; they're more suited for system-to-system data exchange.
NEW QUESTION # 33
Your customer wants to use batch management in SAP Extended Warehouse Management (SAP EWM). When do you have to create a batch during the inbound process?
  • A. Before the inbound delivery is created in SAP ERP
  • B. Before the goods receipt is posted in SAP EWM
  • C. Before the inbound delivery is created in SAP EWM
  • D. Before the inbound delivery is distributed from SAP ERP to SAP EWM
NEW QUESTION # 34
Which of the following can be elements of an inspection rule? Note: There are 2 correct answers to this question.
  • A. Work center
  • B. Inspection procedure
  • C. Sample drawing procedure
  • D. EWM stock type
NEW QUESTION # 35
Which of the following can you include in a storage type search sequence for stock removal? Note: There are
  • A. A list of storage types
  • B. A list of storage type groups
  • C. A list of storage bin types
  • D. A list of storage sections
The storage type search sequence in SAP EWM defines the order for stock removal (e.g., picking). Option C ("A list of storage sections") is correct as sections within a storage type can be prioritized, and option D ("A list of storage types") is correct because multiple storage types (e.g., high rack, picking area) are sequenced, both configured in SPRO: SCM Extended Warehouse Management > Goods Issue Process > Strategies > Define Storage Type Search Sequence. Option A (storage type groups) is used for putaway, not removal, and option B (bin types) is too granular for this sequence.
NEW QUESTION # 36
What do you need to configure before you can create warehouse tasks for an outbound delivery order or an inbound delivery? Note: There are 2 correct answers to this question.
  • A. Warehouse process type determination
  • B. Putaway control indicator or stock removal control indicator
  • C. Warehouse process types
  • D. Warehouse order creation rules
Creating warehouse tasks in SAP EWM requires foundational configuration. Option B ("Warehouse process type determination") is correct because it defines how the system assigns a process type (e.g., putaway, picking) to a delivery item, configured in SPRO: SCM Extended Warehouse Management > Cross-Process Settings > Warehouse Task > Define Warehouse Process Type Determination. Option D ("Warehouse process types") is correct as it specifies the process flow (e.g., "PICK" for picking), set up in SPRO: SCM Extended Warehouse Management > Cross-Process Settings > Warehouse Task > Define Warehouse Process Type. Option A (indicators) influences task execution but isn't a prerequisite for creation, and option C (order creation rules) applies to warehouse orders, not tasks directly.
NEW QUESTION # 37
The trial version of our C-S4EWM-2023 practice test is also available for free on our website. Students can go and check it out to get an idea of the content they wish to pay for. Our prices are also very low in comparison to our competitors as we know that students cannot afford high-budget practice materials. Just choose the right Itcertking SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management Questions formats and download quickly and start C-S4EWM-2023 Exam Preparation without wasting further time.
Valid C-S4EWM-2023 Exam Review: https://www.itcertking.com/C-S4EWM-2023_exam.html
P.S. Free 2026 SAP C-S4EWM-2023 dumps are available on Google Drive shared by Itcertking: https://drive.google.com/open?id=1Hm4i32LO7ImXNDID_XFaGEuMNO94ymz2
