[General] DEA-C02 Training Courses - New DEA-C02 Test Labs
103
【General】 DEA-C02 Training Courses - New DEA-C02 Test Labs
Posted at 2/15/2026 00:11:51      View:165 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New DEA-C02 dumps are available on Google Drive shared by TestkingPDF: https://drive.google.com/open?id=148juHlWv4dLgaNzNKeDlk50Vu80ZDbZf
Taking the SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 test and beginning SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 exam preparation with the suggested DEA-C02 exam preparation materials is the best and quickest course of action. You can rely on Snowflake DEA-C02 Exam Questio SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 for thorough DEA-C02 exam preparation.
Our DEA-C02 learning quiz has accompanied many people on their way to success and they will help you for sure. And you will learn about some of the advantages of our DEA-C02 training prep if you just free download the demos to have a check. You will understand that this is really a successful DEA-C02 Exam Questions that allows you to do more with less. With our DEA-C02 study materials for 20 to 30 hours, we can claim that you will pass the exam and get what you want.
New DEA-C02 Test Labs & Reliable DEA-C02 Test AnswersOne of the biggest challenges of undertaking a Snowflake DEA-C02 exam is managing your time effectively. This means setting aside enough time to stud. Many students struggle with this challenge because they are not able to set aside enough time to study and end up rushing through the material at the last minute. Our Snowflake DEA-C02 Pdf Dumps offer an alternate way by providing relevant Snowflake DEA-C02 questions and answers to prepare in the shortest possible time.
Snowflake SnowPro Advanced: Data Engineer (DEA-C02) Sample Questions (Q199-Q204):NEW QUESTION # 199
A Snowflake data engineer is troubleshooting a performance issue with a query that retrieves data from a large table (TRANSACTIONS). The table has a VARIANT column containing semi-structured JSON data representing transaction details. The query uses several LATERAL FLATTEN functions to extract specific fields from the JSON and filters the data based on these extracted values. Despite having adequate virtual warehouse resources, the query is running slower than expected. Identify the MOST effective strategy to improve the performance of this query:
  • A. Convert the VARIANT column to a VARCHAR column and store the JSON data as a string.
  • B. Rewrite the query to use regular expressions instead of LATERAL FLATTEN for extracting the fields from the JSON data.
  • C. Increase the virtual warehouse size to provide more memory for processing the JSON data.
  • D. Create a new table with pre-extracted fields from the VARIANT column and use this table in the query instead of the LATERAL FLATTEN operations.
  • E. Create a search optimization service on the TRANSACTIONS table for the VARIANT column.
Pre-extracting the required fields from the VARIANT column into separate columns in a new table significantly improves query performance by eliminating the need for expensive LATERAL FLATTEN operations at query time. Option A might help slightly, but pre-extraction is more impactful. Option C is unlikely to be faster. Option D, while applicable to VARIANT columns, is better suited for point lookups, not large-scale extraction and filtering. Option E would negate the benefits of the VARIANT data type.
NEW QUESTION # 200
You have an external table in Snowflake pointing to data in Azure Blob Storage. The data consists of customer transactions, and new files are added to the Blob Storage daily You want to ensure that Snowflake automatically picks up these new files and reflects them in the external table without manual intervention. However, you are observing delays in Snowflake detecting the new files. What are the potential reasons for this delay and how can you troubleshoot them? (Choose two)
  • A. The storage integration associated with the external table does not have sufficient permissions to access the Blob Storage.
  • B. The Azure Event Grid notification integration is not properly configured to notify Snowflake about new file arrivals in the Blob Storage.
  • C. Snowflake's internal cache is not properly configured; increasing the cache size will solve the problem.
  • D. The file format used for the external table is incompatible with the data files in Blob Storage.
  • E. The external table's 'AUTO_REFRESH' parameter is set to 'FALSE', which disables automatic metadata refresh.
Answer: B,E
The two primary reasons for delays in Snowflake detecting new files in an external table are: 1) Incorrect configuration of the cloud provider's notification service (Azure Event Grid in this case). Snowflake relies on these notifications to be informed about new file arrivals. If the integration isn't set up correctly, Snowflake won't know when to refresh the metadata. 2) The parameter must be set to ' TRUE' for automatic metadata refresh to occur. If it's set to FALSE , manual refreshes are required using 'ALTER EXTERNAL TABLE ... REFRESH". Options D and E, although possible issues, won't directly cause a delay in detecting new files, but rather cause issues accessing files after detection. Option C is irrelevant as Snowflake's caching mechanism does not directly impact external table metadata refresh.
NEW QUESTION # 201
You are designing a data pipeline to load JSON data from an AWS S3 bucket into a Snowflake table. The JSON files have varying schemas, and you want to use schema evolution to handle changes. You are using a named external stage with 'AUTO REFRESH = TRUE. You notice that some files are not being ingested, and the COPY HISTORY shows 'Invalid JSON' errors. Which of the following actions would BEST address this issue while minimizing manual intervention?
  • A. Create a separate landing stage for potentially invalid JSON files and use a task to validate the files before moving them to the main stage for ingestion into Snowflake.
  • B. Modify the COPY INTO statement to include 'ON ERROR = SKIP FILE' to ignore files with invalid JSON and continue loading other files. This ensures the pipeline continues without interruption.
  • C. Implement a pre-processing step using a Snowpark Python UDF to cleanse the JSON files in the stage before the COPY INTO command is executed. This UDF should handle schema variations and correct any invalid JSON structures.
  • D. Adjust the file format definition associated with the stage to be more permissive, allowing for variations in the JSON structure. For example, use 'STRIP OUTER ARRAY = TRUE and configure error handling within the file format.
  • E. Re-create the stage with the 'AUTO REFRESH = FALSE parameter and manually refresh the stage metadata after each file is uploaded. This gives more control over which files are processed.
The best approach is to use a Snowpark Python UDF (option C) to pre-process and cleanse the JSON files. This allows for handling schema variations and correcting invalid JSON structures before loading them into Snowflake. 'ON ERROR = SKIP FILE might skip important data without proper investigation. A landing stage (option B) adds complexity and requires additional automation. Making the file format too permissive (option D) may lead to incorrect data loading. Disabling auto-refresh (option E) defeats the purpose of a continuous data pipeline.
NEW QUESTION # 202
You have created an external table in Snowflake that points to a large dataset stored in Azure Blob Storage. The data consists of JSON files, and you've noticed that query performance is slow. Analyzing the query profile, you see that Snowflake is scanning a large number of unnecessary files. Which of the following strategies could you implement to significantly improve query performance against this external table?
  • A. Create a materialized view on top of the external table to pre-aggregate the data.
  • B. Increase the size of the Snowflake virtual warehouse to provide more processing power.
  • C. Create an internal stage, copy all JSON Files, create and load the target table, and drop external table
  • D. Convert the JSON files to Parquet format and recreate the external table to point to the Parquet files.
  • E. Partition the data in Azure Blob Storage based on a relevant column (e.g., date) and define partitioning metadata in the external table definition using PARTITION BY.
Answer: D,E
Partitioning the data (B) allows Snowflake to prune unnecessary files during query execution, significantly improving performance. Converting to Parquet (C) provides a columnar storage format that is more efficient for analytical queries compared to JSON, reducing 1/0 and processing time. Increasing warehouse size (A) might help but is not the most effective strategy. Materialized views (D) are not directly applicable to external tables. Copying all files and creating internal tables is not using the external table functionality (E).
NEW QUESTION # 203
You need to create a development environment from a production schema called 'PRODUCTION SCHEMA. You decide to clone the schema'. Which of the following statements are correct regarding the impact of cloning a schema in Snowflake? (Select all that apply)
  • A. Cloned schemas consume twice the storage as the source schema immediately after cloning as the underlying data is duplicated.
  • B. External tables are also cloned when cloning a schema, but the underlying data files in cloud storage are not duplicated.
  • C. Sequences in the cloned schema will continue from where they left off in the original 'PRODUCTION SCHEMA' if no operations are performed on sequence object, if the sequence is updated after cloning then these sequences are fully independent.
  • D. All tables, views, and user-defined functions (UDFs) within the 'PRODUCTION_SCHEMX will be cloned to the new development schema.
  • E. Cloning a schema automatically clones all tasks and streams associated with tables in the schema but only if the clone is executed at the Database Level.
Answer: B,C,D
Cloning a schema clones all objects within it (tables, views, UDFs, etc.). Cloning uses metadata cloning initially, so it doesn't immediately duplicate the data. Sequences resume from where they left off (if not used cloned schema). Tasks and streams are not cloned when cloning a schema, unless the clone is done at the database level. External tables are cloned, but the data files remain in their original cloud storage location.
NEW QUESTION # 204
In the world of industry, SnowPro Advanced certification is the key to a successful career. If you have achieved credential such as Snowflake then it means a bright future is waiting for you. Avail the opportunity of DEA-C02 dumps at TestkingPDF that helps you in achieving good scores in the exam. Due to these innovative methodologies students get help online. The DEA-C02 Exam Questions Answers are very effective and greatly helpful in increasing the skills of students. They can easily cover the exam topics with more practice due to the unique set of DEA-C02 exam dumps. The DEA-C02 certification learning is getting popular with the passage of time.
New DEA-C02 Test Labs: https://www.testkingpdf.com/DEA-C02-testking-pdf-torrent.html
We focus on the study of DEA-C02 valid test for many years and enjoy a high reputation in IT field by latest DEA-C02 valid vce, updated information and, most importantly, DEA-C02 vce dumps with detailed answers and explanations, So our Snowflake DEA-C02 valid study vce are not stereotypes in the past at all, but are brand-new with fresh and important knowledge in it, You think your investment on the products are worth and may do some help to your New DEA-C02 Test Labs - SnowPro Advanced: Data Engineer (DEA-C02) exam test.
Rich explores alternative word processing apps, and discusses why they may DEA-C02 or may not better meet your needs, When you know that a port is open, you can use other utilities to determine what program opened the port.
2026 Authoritative DEA-C02 Training Courses | DEA-C02 100% Free New Test LabsWe focus on the study of DEA-C02 valid test for many years and enjoy a high reputation in IT field by latest DEA-C02 valid vce, updated information and, most importantly, DEA-C02 vce dumps with detailed answers and explanations.
So our Snowflake DEA-C02 valid study vce are not stereotypes in the past at all, but are brand-new with fresh and important knowledge in it, You think your investment Reliable DEA-C02 Test Answers on the products are worth and may do some help to your SnowPro Advanced: Data Engineer (DEA-C02) exam test.
The passing rate of our DEA-C02 exam guide is high, We guarantee that you can pass the exam easily.
DOWNLOAD the newest TestkingPDF DEA-C02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=148juHlWv4dLgaNzNKeDlk50Vu80ZDbZf
Posted at 2/17/2026 03:15:46        Only Author  2#
Loved it immediately, clicking that like. Excited but nervous for the HPE2-E84 regular updates exam. Hope I ace it!
Posted at 5/14/2026 10:47:37        Only Author  3#
Your article is truly amazing, I appreciate you sharing it. The SPLK-1003 exam study guide exam questions are available for free! Good luck on your exams!
