[General] 1z0-1033-25 Instant Discount - 1z0-1033-25 Exam Actual Tests
103
General 1z0-1033-25 Instant Discount - 1z0-1033-25 Exam Actual Tests
Posted at 2/15/2026 00:16:16      View155 | Replies1        Print      Only Author   [Copy Link] 1#
What we attach importance to in the transaction of latest 1z0-1033-25 quiz prep is for your consideration about high quality and efficient products and time-saving service. We treasure time as all customers do. Therefore, fast delivery is another highlight of our latest 1z0-1033-25 quiz prep. We are making efforts to save your time and help you obtain our product as quickly as possible. We will send our 1z0-1033-25 Exam Guide within 10 minutes after your payment. You can check your mailbox ten minutes after payment to see if our 1z0-1033-25 exam guide are in.
In order to meet the needs of all customers, our company employed a lot of leading experts and professors in the field. These experts and professors have designed our 1z0-1033-25 exam questions with a high quality for our customers. We can promise that our 1z0-1033-25 training guide will be suitable for all people, including students and workers and so on. You can use our 1z0-1033-25 study materials whichever level you are in right now. And we can promise you will get success by our products.
1z0-1033-25 Exam Actual Tests, Test 1z0-1033-25 Guide OnlineOur study materials are choosing the key from past materials to finish our 1z0-1033-25 torrent prep. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the 1z0-1033-25 Exam Torrent. Then, you will have enough confidence to pass it. So start with our 1z0-1033-25 torrent prep from now on. We can succeed so long as we make efforts for one thing.
Oracle CPQ 2025 Implementation Professional Sample Questions (Q19-Q24):NEW QUESTION # 19
Where would you navigate to view the attribute mappings for the CX Sales Import Lines Integration?
  • A. Admin > Integrations > click the OSC-REST Import Lines integration > click Attribute Mappings
  • B. Admin > Process Definition > Integrations > click the OSC-REST Import Lines integration > click edit
  • C. Admin > Integrations > click the OSC-REST Import Lines integration > edit
  • D. Integrations > click the OSC-REST Import Lines integration > Process Definition
NEW QUESTION # 20
When implementing Subscription Ordering according the Subscription Ordering Implementation Guide, you are asked to modify the formula for the Price (List) line level attribute.
What must you do to properly modify the formula?
  • A. Add an initial condition that tests for a valid entry in a specific Subscription Ordering price book with a true value of zero.
  • B. Add an initial condition that tests for a valid price value in the Price field of the BOM Item Definition table with a true value of the valid price value.
  • C. Add an initial condition that tests for the Action Code to be either DELETE or TERMINATE with a true value of Part Base Price.
  • D. Add an initial condition that tests for a valid price value in the Price field of the BOM Item Mapping table with a true value of the valid price value.
  • E. Add an initial condition that tests for the Action Code to be either DELETE or TERMINATE with a true value of zero.
NEW QUESTION # 21
Along with Part Number, Quantity, and Price, you also want to send additional recommended item details from Configuration to Commerce by using a Recommended Item rule.
Which two options enable you to achieve this? (Choose two.)
  • A. Use BOM Mapping rules.
  • B. Use the Comment field to pass additional details.
  • C. This is not feasible. Only Part Number, Quantity, and Price can be passed from Config to Commerce by using Recommended Item rules.
  • D. Pass the additional details by storing them in a Price Book.
  • E. Concatenate the additional details to Part Number.
NEW QUESTION # 22
A partner user approves a quote. However, the status in the CRM does not get updated.
Which two can be reasons for this?
  • A. Integrations are not associated with the approve action.
  • B. The partner user does not have the correct partner info credentials.
  • C. The partner user does not have access to the attribute "status" in the pending step within CPQ.
  • D. The partner user approved the quote through mobile approvals.
NEW QUESTION # 23
Which is the correct procedure for adding multiple files to File Manager in a single step?
  • A. Click File Manager on the Admin home page, select the folder, where you want to store the new files, click the Browse button next to "Browse for ZIP File:", and click the Add/Update Files button.
  • B. Click File Manager on the Admin home page, select the folder, where you want to store the new files, click the Browse button next to "Browse for ZIP File:", identify the zip file to upload, and click the Add File button.
  • C. Click File Manager on the Admin home page, select the folder, where you want to store the new files, click the Browse button next to "Browse for ZIP File:", identify the zip file to upload, and click the Add File button.
  • D. Click File Manager on the Admin home page, click the Browse button next to "Browse for ZIP File", identify the zip file to upload, and click the Add/Update Files button.
  • E. Click File Manager on the Admin home page, select the folder where you want to store the new files, click the Browse button next to "Browse for ZIP File:", identify the zip file to upload, and click the Add
Answer: E
NEW QUESTION # 24
Our website aimed to helping you and fully supporting you to pass 1z0-1033-25 actual test with high passing score in your first try. So we prepared top 1z0-1033-25 pdf torrent including the valid questions and answers written by our certified professionals for you. Our 1z0-1033-25 Practice Exam available in three modes, pdf files, and PC test engine and online test engine, which apply to any level of candidates.
1z0-1033-25 Exam Actual Tests: https://www.getcertkey.com/1z0-1033-25_braindumps.html
With the help of our 1z0-1033-25 actual lab questions: Oracle CPQ 2025 Implementation Professional, you can feel assured that you can pass the exam as well as obtaining the certification, On the one hand our Oracle study engine is a simulated environment which is 100% based on the real test, there are variety of core questions and detailed answers in our 1z0-1033-25 learning materials, Recently, Oracle 1z0-1033-25 certification, attaching more attention from more and more people in the industry, has become an important standard to balance someone's capability.
Each window has a collection of views, each of which 1z0-1033-25 is responsible for a rectangle of the window, Establishing canonical schemas as part of services delivered by different project teams at different times requires 1z0-1033-25 PDF Question that each project team agrees to use the same pre-defined data models for common business documents.
Easy to Use and Compatible Oracle 1z0-1033-25 Practice Test FormatsWith the help of our 1z0-1033-25 actual lab questions: Oracle CPQ 2025 Implementation Professional, you can feel assured that you can pass the exam as well as obtaining the certification, On the one hand our Oracle study engine is a simulated environment which is 100% based on the real test, there are variety of core questions and detailed answers in our 1z0-1033-25 learning materials.
How do you pass for sure, As the questions of our 1z0-1033-25 exam Prep are more or less involved with heated issues and for customers who prepare for the 1z0-1033-25 exam.
Posted at 2/17/2026 19:08:35        Only Author  2#
Thank you for sharing this motivational and inspiring article! I used the BAPv5 exam dumps collection to secure a promotion and raise. Now, Im offering it for free. Wishing you all success in your careers!
