[General] AZ-120 Exam Learning | AZ-120 Brain Dumps
109
【General】 AZ-120 Exam Learning | AZ-120 Brain Dumps
Posted at 2/15/2026 01:35:32      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamDumpsVCE AZ-120 dumps for free: https://drive.google.com/open?id=14cv0klSXZUVCZ5PVYkuGzKr0XcDx9588
The experts in our company are always keeping a close eye on even the slightest change in the field. Therefore, we can assure that you will miss nothing needed for the AZ-120 exam. What's more, the latest version of our AZ-120 study materials will be a good way for you to broaden your horizons as well as improve your skills. So with our AZ-120 Exam Questions, not only you can pass the exam with ease with 100% pass guarantee, but also you can learn the most professional and specilized knowledge in this field!
Microsoft AZ-120 is a certification exam designed for professionals who want to demonstrate their skills in planning and administering Microsoft Azure for SAP workloads. AZ-120 exam is part of the Microsoft Certified: Azure for SAP Workloads Specialty certification track, which focuses on the deployment, migration, and management of SAP workloads on the Azure platform.
Exam AZ-120: Planning and Administering Microsoft Azure for SAP WorkloadsCandidates for this exam should be architects or engineers with extensive experience and knowledge of the SAP system landscape and industry standards that are specific to the initial migration or integration and the long-term operation of an SAP solution on Microsoft Azure.
Responsibilities for an architect or an engineer for Azure for SAP Workloads include making recommendations on services and adjusting resources as appropriate for optimal resiliency, performance, scale, provision, size, and monitoring.
Architects or engineers for Azure for SAP Workloads partner with cloud administrators, cloud database administrators, and clients to implement solutions.
A candidate for this exam should have extensive experience and knowledge of SAP applications: SAP HANA, S/4HANA, SAP NetWeaver, SAP BW/4HANA, OS servers for SAP applications and databases, Azure portal, Azure Marketplace, Azure Resource Manager templates (ARM templates), virtualization, cloud infrastructure, storage structures, high availability design, disaster recovery design, data protection concepts, and networking.
For this exam, we strongly recommended that you have an Azure Administrator Associate or Azure Solutions Architect Expert certification, in addition to SAP certifications.
Part of the requirements for:  Microsoft Certified: Azure for SAP Workloads Specialty
   Download exam skills outline
AZ-120 Brain Dumps, AZ-120 Valid Braindumps FreeThe key trait of our product is that we keep pace with the changes of syllabus and the latest circumstance to revise and update our AZ-120 study materials, and we are available for one-year free updating to assure you of the reliability of our service. Our company has established a long-term partnership with those who have purchased our AZ-120 Exam guides. We have made all efforts to update our product in order to help you deal with any change, making you confidently take part in the exam.
Career OpportunitiesThe certification that you will obtain after passing the Microsoft AZ-120 test is an advanced one. Therefore, the individuals with this certificate can take up the job roles, such as a Sales Manager, an Azure Platform & Data Engineer, a Support Engineer, a Solution Specialist, an Azure Platform Lead, a Digital Sales Specialist, a Cloud Solution Architect, and a Cloud Ops Engineer, among others. The average annual salary for these positions is $98,500, which is a very attractive option.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q127-Q132):NEW QUESTION # 127
You plan to deploy multiple SAP HANA virtual machines to Azure by using an Azure Resource Manager template.
How should you configure Accelerated Networking and Write Accelerator in the template? To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NOTE:Each correct selection is worth one point.
Box 1: true
enableAcceleratedNetworking: If the network interface is accelerated networking enabled.
To further reduce network latency between Azure VMs, we [Micorosoft] recommend that you choose Azure Accelerated Networking. Use it when you deploy Azure VMs for an SAP workload, especially for the SAP application layer and the SAP DBMS layer.
Box 2: true
Write Accelerator should be used for the volumes that contain the transaction log or redo logs of a DBMS. It is not recommended to use Write Accelerator for the data volumes of a DBMS as the feature has been optimized to be used against log disks.
https://docs.microsoft.com/en-us ... /dbms_guide_general
NEW QUESTION # 128
You have a Recovery Services vault backup policy for SAP HANA on an Azure virtual machine as shown in the following exhibit.
Answer selected as in image below.
Graphical user interface, text, application, email Description automatically generated
NEW QUESTION # 129
You have an on-premises network and an Azure subscription.
You plan to deploy a standard three-tier SAP architecture to a new Azure virtual network.
You need to configure network isolation for the virtual network. The solution must meet the following requirements:
* Allow client access from the on-premises network to the presentation servers.
* Only allow the application servers to communicate with the database servers.
* Only allow the presentation servers to access the application servers.
* Block all other inbound traffic.
What is the minimum number of network security groups (NSGs) and subnets required? To answer, drag the appropriate number to the correct targets. Each number may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NOTE Each correct selection is worth one point.
NEW QUESTION # 130
You have an SAP development landscape on Azure.
NEW QUESTION # 131
Your on-premises network contains SAP and non-SAP applications.
You have JAVA-based SAP systems that use SPNEGO for single-sign on (SSO) authentication.
Your external portal uses multi-factor authentication (MFA) to authenticate users.
You plan to extend the on-premises authentication features to Azure and to migrate the SAP applications to Azure.
Box 1: No
Need AD FS for MF
Note: Azure Active Directory (Azure AD) Pass-through Authentication allows your users to sign in to both on-premises and cloud-based applications using the same passwords. This feature is an alternative to Azure AD Password Hash Synchronization (see Box 2).
Box 2: Yes
Password hash synchronization is one of the sign-in methods used to accomplish hybrid identity. Azure AD Connect synchronizes a hash, of the hash, of a users password from an on-premises Active Directory instance to a cloud-based Azure AD instance.
Password hash synchronization is an extension to the directory synchronization feature implemented by Azure AD Connect sync. You can use this feature to sign in to Azure AD services like Office 365. You sign in to the service by using the same password you use to sign in to your on-premises Active Directory instance.
Box 3: Yes
If your organization is federated with Azure AD, you can use Azure Multi-Factor Authentication to secure AD FS resources, both on-premises and in the cloud. Azure MFA enables you to eliminate passwords and provide a more secure way to authenticate.
https://docs.microsoft.com/en-us ... y/hybrid/whatis-phs
https://docs.microsoft.com/en-us ... ad-fs-and-azure-mfa
NEW QUESTION # 132
AZ-120 Brain Dumps: https://www.examdumpsvce.com/AZ-120-valid-exam-dumps.html
What's more, part of that ExamDumpsVCE AZ-120 dumps now are free: https://drive.google.com/open?id=14cv0klSXZUVCZ5PVYkuGzKr0XcDx9588
