Free PDF 2026 Salesforce Arch-303 Updated Latest Test Format
Posted at 2/15/2026 02:08:25
View182
Replies1
After cracking the Salesforce Certified B2C Commerce Architect (Arch-303) exam you will receive the credential badge. It will pave your way toward well-paying jobs or promotions in any reputed tech company. At PassExamDumps have customizable Salesforce Arch-303 practice exams for the students to review and improve their preparation. The Salesforce Arch-303 Practice Test material product of PassExamDumps are created by experts with the dedication to help customers crack the Salesforce Arch-303 exam on the first attempt.
According to our investigation, the test syllabus of the Arch-303 exam is changing every year. Some new knowledge will be added into the annual real exam. Some old knowledge will be deleted. So you must have a clear understanding of the test syllabus of the Arch-303 study materials. Now, you can directly refer to our study materials. Our experts have carefully researched each part of the test syllabus of the Arch-303 Study Materials. Then they compile new questions and answers of the study materials according to the new knowledge parts.
Pass Guaranteed Quiz Arch-303 - Efficient Latest Salesforce Certified B2C Commerce Architect Test FormatMany people prefer to buy our Arch-303 valid study guide materials because they deeply believe that if only they buy them can definitely pass the test. The reason why they like our Arch-303 guide questions is that our study materials' quality is very high. For years we always devote ourselves to perfecting our Arch-303 Study Materials. We boost the leading research team and the top-ranking sale service. We boost the expert team to specialize in the research and production of the Arch-303 guide questions and professional personnel to be responsible for the update of the Arch-303 study materials.
Salesforce Certified B2C Commerce Architect Sample Questions (Q10-Q15):NEW QUESTION # 10
An Order Management System (OMS) handles orders from multiple brandspecific sites, as part of the processing, the OMS sends the processing detail to be added at notes to the orders in B2C Commerce. These processing details are captured temporarily in custom objects, and are later processed by a batch Job that:
* Processes the custom object to extract the orderid and note data.
* Tries to load the order.
* If the order is not found, it deletes the custom object and moves on.
* If the order is found, it updates notes In the Order, upon successful update of this order, it deletes the custom object.
There is an Issue reported that the job is constantly failing and custom objects are growing in number. On investigating the production look the message below is being logged on each failure:
What are three solution The Architect can take to fix this issue without losing meaningful data?
Choose 3 answers
- A. Take the backup of the Order as XML and delete the Order to ensure on the next job run, the custom objects are getting processed.
- B. Take the backup of the custom object and delete the custom object to ensure on the next job run the custom objects are getting processed.
- C. Using BM site import/export, softenthe<quota id=''object.orderPo.relation,notes''> <custom- action>warn<custom-action> </quots>to make sure that neither order notes are lost and custom object is processed.
- D. Take the backup of the Order as XML and delete the notes from Order to ensure on the next jobrun the custom objects are getting processed.
- E. Engage B2C Commerce Support Team to soften the quota limit for ''object.OrderPO.relation.notes''
Answer: B,D,E
When facing an issue with a growing number of custom objects due to the exceeded quota limit for order notes, effective solutions include:
* Option C (Take the backup of the custom object and delete the custom object): This ensures that the data is preserved while freeing up space for new processes and reducing the load, allowing the job to continue running without the impediment of quota limits.
* Option D (Engage B2C Commerce Support Team to soften the quota limit for 'object.OrderPO.
relation.notes'): Increasing the quota limit can resolve the root cause of the issue by accommodating the actual business needs without compromising the integrity of order processing and note addition.
* Option E (Take the backup of the Order as XML and delete the notes from Order): This allows the job to process the custom objects as intended in subsequent runs by clearing out space while ensuring the order data remains intact for business needs.
These steps address the quota limit issue effectively without losing valuable order or note data, ensuring continuity and integrity of business operations.
NEW QUESTION # 11
A third party survey provider offers both an API endpoint for individual survey data and an SFTP server endpoint that can accept batch survey data. The initial implementation of the integration includes
1.Marking the order as requiring a survey before order placement
2. On the order confirmation pace, the survey form is displayed for the customer to fill
3. The data is sent to the survey provider API, and the order it marked as not requiring a survey Later it was identified that this solution is not fit for purpose as the following issues and additional requirements were identified:
1. If the API call fails, the corresponding survey data is lost. The Business requires to avoid data loss.
2. Some customers skipped the form. The Business require sending a survey email to such customers.
3. The Order Management System (OMS) uses a non-standard XML parser it did not manage to parse orders with the survey, until the survey attribute was manually removedfrom the xml.
How should the Architect address the issues and requirements described above?
- A. Create a custom session attribute when the survey is required. Send to the API endpoint in real-time. On failure, capture the survey data in the session and reprocess, use me session attribute to send emails for the cases when survey was skipped.
- B. Send the survey data to the API endpoint in real-time until the survey data is successfullycaptured.Instruct the OMS development team to update their XML parser, use the Order survey attribute to send emails for the cases when the survey was skipped.
- C. Create a custom object to store the survey data. Send to the API endpoint using a job. On success, remove the custom object. On failure, send the survey data with APIfrom the next execution of the same job. Use the custom object to send emails for the cases when the survey was skipped.
- D. Create a custom object when the survey is required Send to the API endpoint in real-time. On success, remove the object. Onfailure, capture the survey data in the custom object and later reprocess with a job. Use the custom object to send emails for the cases when survey was skipped.
This approach addresses all concerns: data retention, reattempt on failure, and follow-up communication. By storing survey data in a custom object, data is preserved even if the API call fails, allowing for reprocessing.
This method also facilitates sending follow-up emails by querying custom objects for surveys that were skipped, ensuring comprehensive coverage and reliability in data handling and customer engagement.
NEW QUESTION # 12
The storefront integrates with a REST based Address verification service (AVS) that uses token based security. The sequence of calls in the API documentation for this AVS looks like the following
1. Client authentication call, which contains the merchantId and secret in a GET request and returns a token in the response.
2. Address verification call, which contains the token and the address to verify in a POST request.
Once the token is obtained, it is valid for hours and it is not needed to request a new one for subsequent address verification calls, the AVS charges for every request made no matter if it is client authentication call or address verificationcall.
Which three strategies could be applied to allow for efficient use of the service without compromising security? Choose 3 answers
- A. Obtain the token from a custom cache before making the client authentication call.
- B. Use a job to store and update the token in a customobject that is used from the storefront code
- C. Apply page caching to the client authentication controller that is used with AJAX.
- D. Obtain the token from local storage of the browser and update it once It expires.
- E. Use HTTPService caching for the client authentication call.
Answer: A,B,E
To efficiently use the REST-based Address Verification Service (AVS) while maintaining security, it is crucial to manage token usage and refresh effectively. Using a custom cache to store the token (Answer C) prevents unnecessary authentication calls by reusing the valid token, thus reducing the number of chargeable requests. Implementing HTTPService caching for the client authentication call (Answer D) optimizes the performance by caching the response, thereby avoiding repetitive and unnecessary calls. Lastly, employing a scheduled job to regularly update and store the token in a custom object (Answer E) ensures that the token is always up-to-date and available for use without repeated authentication, thus optimizing the cost and efficiency of using the AVS.
NEW QUESTION # 13
Northern Trail Outfitters (NTO) operate 200 physical stores. NTO has products that are available in some of the physical stores and not available in others. The closest physical store is determined based on customer s post zip code when they are shopping online. Only the products that are available in the customer's closest physical store should be presented to the customer to the search results.
What are the two feasible technical approaches to meet these requirements?
Choose 2 answers
- A. Create a separate category per physical store use post/Tip code with a mapping to determine the relevant category. Show only the products from this category.
- B. Create a separate shipping method per physical store. Use post/zip code to determine the applicable shipping method. Show only the products that are not excludedfrom the shipping method.
- C. Create a separate pricebook per physical store. Use post/zip code to activate this pricebook through a customer group. Show only the products with price by applying price refinement.
- D. Create a separate site per physical store. Use post/zip code to redirect the customer to the relevant site.
Show the products from the site navigation catalog.
For Northern Trail Outfitters to ensure that only products available in a customer's closest physical store are shown:
* Option B is effective because it organizes inventory by store-specific categories, which can then be dynamically linked to a customer's location via their postal/zip code. This allows the system to filter search results based on the relevant category that corresponds to the closest store.
* Option D leverages separate pricebooks that are specific to each store, enabling product availability to be managed through price refinements. This method also uses the customer's zip code to activate the appropriate pricebook, ensuring that only products priced (and thus available) in the nearest store are displayed.
Both methods are scalable and integrate seamlessly with the existing infrastructure of the Salesforce B2C Commerce platform.
NEW QUESTION # 14
A company that is a shoe-producer is doing Salesforce B2C Commerce implementation. In their Enterprise Resource Warning (ERP) system, the products are marked as being one of three types: boots, sandals, and sneakers. The business requirements based on the type are:
* The messaging on Product Detail page is different
* Customers are able to filler their Product Search Results
The customer's operations team asks about the format in which to send this value in the catalog.
Which data type should the Architect specify for this attribute In the Data Mapping document?
- A. A custom attribute of type enum-of-string (multiselect able value).
- B. A custom attribute of type enum-of-string (single selectable value)
- C. A custom attribute of type string containing comma separated values.
- D. A custom attribute type set-of-string containing multiple values.
For the shoe producer implementing Salesforce B2C Commerce, the attribute used to specify the type of shoes (boots, sandals, sneakers) should be set as a single selectable value, hence the use of an enum-of-string type. This data type allows for the selection of one option from a predefined list, which is ideal for cases where each product can only be categorized into one type. This ensures that data integrity is maintained while providing clear and distinct categorization that can easily be used for filtering on the Product Search Results page and for customized messaging on the Product Detail page.
NEW QUESTION # 15
Arch-303 exam is a new turning point in the IT industry. Get this examination certification, you will become the IT industry's professional high-end person. With the spread and progress of information technology, you will see hundreds of online resources which provide Salesforce Arch-303 Questions and answers. While PassExamDumps ahead. The reason people choose PassExamDumps Salesforce Arch-303 exam training materials is that it can really bring benefits to them, and to help you come true your dreams as soon as possible!
Arch-303 Test Sample Online: https://www.passexamdumps.com/Arch-303-valid-exam-dumps.html
Choosing our Arch-303 exam bootcamp, 100% pass exam, On the other hand, if you decide to use the online version of our Arch-303 study materials, you don't need to worry about no network, Salesforce Latest Arch-303 Test Format And price is affordable, Salesforce Latest Arch-303 Test Format So every customer purchased VUE exam questions all need to study technology ,not just recite our exam questions, Both theories of knowledge as well as practice of the questions in the Arch-303 practice quiz will help you become more skillful when dealing with the exam.
Copying Only the Subtotal Rows, Once again, as this is a synchronous Arch-303 pattern, acknowledgements that arrive other than when the client is waiting for them specifically are discarded.
Choosing our Arch-303 Exam Bootcamp, 100% pass exam, On the other hand, if you decide to use the online version of our Arch-303 study materials, you don't need to worry about no network.
High Hit-Rate Latest Arch-303 Test Format | 100% Free Arch-303 Test Sample OnlineAnd price is affordable, So every customer purchased Reliable Arch-303 Exam Cost VUE exam questions all need to study technology ,not just recite our exam questions, Both theories of knowledge as well as practice of the questions in the Arch-303 practice quiz will help you become more skillful when dealing with the exam.
- Latest Arch-303 Test Format | Arch-303 100% Free Test Sample Online 🧔 Download ▷ Arch-303 ◁ for free by simply entering [ [url]www.pdfdumps.com ] website 🏇New Arch-303 Exam Papers[/url]
- Arch-303 Reliable Test Online 🏆 Interactive Arch-303 Practice Exam 💳 Latest Arch-303 Exam Format 😬 Open [url]www.pdfvce.com and search for ✔ Arch-303 ️✔️ to download exam materials for free 🧿New Arch-303 Test Answers[/url]
- New Arch-303 Test Answers 🎑 Arch-303 Certification Questions 🕣 Arch-303 Certification Questions 🟣 Search on [ [url]www.testkingpass.com ] for ▛ Arch-303 ▟ to obtain exam materials for free download 📺Arch-303 Mock Exam[/url]
- Latest Arch-303 Test Format | Arch-303 100% Free Test Sample Online 🧏 Simply search for Arch-303 for free download on ▶ [url]www.pdfvce.com ◀ 🤓Latest Arch-303 Exam Format[/url]
- Easiest and Quick Way to Pass Salesforce Arch-303 Exam 📃 Immediately open [url]www.prep4away.com and search for ⇛ Arch-303 ⇚ to obtain a free download 🍺New Arch-303 Test Objectives[/url]
- Pass Guaranteed Quiz Arch-303 - Salesforce Certified B2C Commerce Architect High Hit-Rate Latest Test Format 🍲 ➡ [url]www.pdfvce.com ️⬅️ is best website to obtain ▷ Arch-303 ◁ for free download ✒Arch-303 Reliable Test Price[/url]
- Arch-303 Dump 🏑 New Arch-303 Exam Papers ✌ Arch-303 Reliable Dump 🤫 Open website ⇛ [url]www.practicevce.com ⇚ and search for ➽ Arch-303 🢪 for free download 💻Online Arch-303 Lab Simulation[/url]
- Free PDF 2026 Salesforce Arch-303: Professional Latest Salesforce Certified B2C Commerce Architect Test Format 🩳 Search for ☀ Arch-303 ️☀️ and download exam materials for free through ➠ [url]www.pdfvce.com 🠰 🥗Arch-303 Positive Feedback[/url]
- Desktop Salesforce Arch-303 Practice Test Software By [url]www.pdfdumps.com 🩲 Search for Arch-303 and download exam materials for free through www.pdfdumps.com 🌔New Arch-303 Test Objectives[/url]
- Arch-303 Valid Test Fee 🥫 Online Arch-303 Lab Simulation 🐄 Fresh Arch-303 Dumps 🙆 Search for Arch-303 and download exam materials for free through [url]www.pdfvce.com 🆚Composite Test Arch-303 Price[/url]
- Pass Guaranteed Quiz Arch-303 - Salesforce Certified B2C Commerce Architect High Hit-Rate Latest Test Format 🎡 Search for ⮆ Arch-303 ⮄ and obtain a free download on [url]www.pdfdumps.com ♥New Exam Arch-303 Braindumps[/url]
- www.stes.tyc.edu.tw, catchyclassroom.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, willysforsale.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
