New Pure Storage FAAA_005 Test Answers - Reliable FAAA_005 Exam Registration
Posted at 2/15/2026 02:49:34
What's more, part of that Prep4sureExam FAAA_005 dumps now are free: https://drive.google.com/open?id=1O0f72eUX0KGQAmk4ttWl7GaIXmrluGwk
The countless candidates have already passed their FAAA_005 certification exam and they all used the real, valid, and updated Prep4sureExam FAAA_005 exam questions. So, why not, take a decision right now and ace your FAAA_005 Exam Preparation with top-notch FAAA_005 exam questions?
We stress the primacy of customers’ interests, and make all the preoccupation based on your needs on the FAAA_005 study materials. We assume all the responsibilities that our FAAA_005 practice braindumps may bring. They are a bunch of courteous staff waiting for offering help 24/7. You can definitely contact them when getting any questions related with our FAAA_005 Preparation quiz. And you will be satified by their professional guidance.
Buy Pure Storage FAAA_005 Valid Dumps Today and Get Free Updates for 1 yearPrep4sureExam has gained the reputation of the many certification industry, because we have a lot of high-quality Pure Storage FAAA_005 Exam FAAA_005 study guide, FAAA_005 exam, FAAA_005 exam answer. As the most professional supplier on the site of IT certification test currently, we provide a comprehensive after-sales service. We provide tracking services to all customers. Within one year of your purchase, enjoy free upgrades examination questions service. During this period, if Pure Storage's FAAA_005 Test Questions are modified, We will be free to provide customers with protection. Pure Storage FAAA_005 certification exam is carefully crafted by our Prep4sureExam IT experts. With the Prep4sureExam of Pure Storage FAAA_005 exam materials, I believe that your tomorrow will be better.
Pure Storage FlashArray Architect Associate Sample Questions (Q34-Q39):NEW QUESTION # 34
A customer is experiencing latency in the VMware environment connected to this array.
What should the SE recommend?
- A. Check the ESXi host
- B. Add network cards to alleviate network congestion
- C. Upgrade the controllers
- D. Add DirectFlash Modules as the system is disk bound
The exhibit shows latency in the VMware environment connected to the FlashArray. When troubleshooting latency issues in a VMware environment, the first step is to identify whether the issue originates from the storage array, the network, or the ESXi host. In this case, the SE should recommend checking the ESXi host, as it is often the source of latency problems in VMware environments.
Why This Matters:
ESXi Host Issues:
The ESXi host could be experiencing resource contention (e.g., CPU, memory, or network bottlenecks) or misconfigurations (e.g., improper queue depth settings or multipathing policies).
High latency on the ESXi host can impact the performance of virtual machines and appear as storage latency, even if the FlashArray itself is functioning optimally.
Why Not the Other Options?
A). Add DirectFlash Modules as the system is disk bound:
Pure Storage FlashArray uses DirectFlash Modules, which are NVMe-based and provide extremely low latency. If the array were disk-bound, it would indicate a hardware limitation, but this is unlikely with FlashArray's architecture. The issue is more likely related to the ESXi host or network.
B). Upgrade the controllers:
Controller upgrades are typically unnecessary unless the array is nearing its performance limits. Since the exhibit does not indicate any signs of controller saturation, this is not the correct recommendation.
C). Add network cards to alleviate network congestion:
While network congestion can cause latency, the issue is more likely related to the ESXi host configuration. Adding network cards should only be considered after confirming network bottlenecks through diagnostics.
Key Points:
ESXi Host Diagnostics: Start by checking the ESXi host for resource contention, misconfigurations, or improper settings.
Storage Array Health: Verify that the FlashArray is not experiencing any performance issues (e.g., high queue depths or latency).
Network Analysis: Only after ruling out the ESXi host and storage array should network-related issues be investigated.
Reference: Pure Storage FlashArray Documentation: "Troubleshooting Latency in VMware Environments" VMware Best Practices Guide: "Optimizing ESXi Host Performance" Pure Storage Knowledge Base: "Diagnosing and Resolving Latency Issues"
NEW QUESTION # 35
A customer has a requirement for 450 TB of block storage to support their tier2 environment where latency is not a concern. The workload is expected to achieve a 4-to-l data reduction.
Which array and capacity configuration is the minimum required to meet their needs?
- A. FlashArray//C60R3 366 TB
- B. FlashArray//X70R3 228 TB
- C. FlashArray//C40R3 247 TB
- D. FlashArray//C60R3 878 TB
To meet the customer's requirement for 450 TB of block storage with a 4:1 data reduction ratio, we need to calculate the effective usable capacity required and select the appropriate array configuration.
Step-by-Step Calculation:
Effective Usable Capacity Needed:
The workload requires 450 TB of logical storage.
With a 4:1 data reduction ratio, the physical storage required is:
Array Selection:
The selected array must provide at least 112.5 TB of usable capacity after accounting for overhead and RAID protection.
Let's evaluate the options:
A). FlashArray//C40R3 247 TB:
The FlashArray//C40R3 provides 247 TB of raw capacity. After accounting for overhead (typically ~20%), the usable capacity is approximately:Usable Capacity=247TB×0.8=197.6TB.
This exceeds the required 112.5 TB, making it a valid option.
B). FlashArray//C60R3 878 TB:
The FlashArray//C60R3 provides 878 TB of raw capacity, which is significantly larger than needed.
While it meets the requirement, it is not the minimum configuration.
C). FlashArray//X70R3 228 TB:
The FlashArray//X70R3 provides 228 TB of raw capacity. After overhead, the usable capacity is approximately:Usable Capacity=228TB×0.8=182.4TB.
While this also meets the requirement, it is more expensive than the C40R3.
D). FlashArray//C60R3 366 TB:
The FlashArray//C60R3 with 366 TB of raw capacity is overkill for this requirement and not cost-effective.
Recommendation:
The FlashArray//C40R3 247 TB provides the minimum required usable capacity while meeting the customer's needs.
Final Recommendation:
The correct answer is
A). FlashArray//C40R3 247 TB.
Reference: FlashArray//C Series Product Overview:
Details the capacity and use cases for FlashArray//C models.
Capacity Planning Guide:
Pure Storage Capacity Planning
Provides guidance on calculating usable capacity based on data reduction ratios.
NEW QUESTION # 36
A System Administrator has a FlashArray//X70R3. They need to add a backup element as part of their data protection strategy.
They have the following requirements:
* The solution should be offsite
* Cost needs to be kept as low as possible
* The backup needs to be stored in a different location from their current FlashArray
* Restore times are not a concern
Which solution should the SE recommend to the System Administrator?
- A. CloudSnap to a public cloud provider
- B. ActiveCluster to a FlashArray//C60
- C. ActiveDR to a FlashArray//C60
The System Administrator requires an offsite backup solution that is cost-effective, stores data in a different location from the current FlashArray, and does not prioritize restore times. The best solution to recommend is CloudSnap to a public cloud provider.
Why This Matters:
CloudSnap:
CloudSnap is a feature that offloads snapshots to cloud storage providers like AWS S3 or Azure Blob.
It is highly cost-effective because customers only pay for the cloud storage they use, and it eliminates the need for additional on-premises hardware.
Since restore times are not a concern, CloudSnap's slower restore process compared to on-premises solutions is acceptable.
A). ActiveCluster to a FlashArray//C60:
ActiveCluster provides synchronous replication for high availability but does not meet the requirement for an offsite backup solution. Additionally, it is more expensive than CloudSnap.
B). ActiveDR to a FlashArray//C60:
ActiveDR provides asynchronous replication for disaster recovery but requires additional hardware (FlashArray//C60), which increases costs. It is less cost-effective than CloudSnap for backup purposes.
Key Points:
Cost Efficiency: CloudSnap leverages cloud storage, minimizing upfront and ongoing costs. Offsite Storage: Ensures backups are stored in a different location from the primary FlashArray. Restore Times: CloudSnap's slower restore process is acceptable given the customer's requirements.
Reference: Pure Storage FlashArray Documentation: "CloudSnap for Offsite Backups" Pure Storage Whitepaper: "Cost-Effective Backup Strategies with FlashArray" Pure Storage Knowledge Base: "Choosing the Right Backup Solution for Your Workload"
NEW QUESTION # 37
Which two public cloud storage services are supported as offload targets for Purity CloudSnap? (Choose two.)
- A. Amazon AWS S3
- B. Azure Blob Storage
- C. IBM Object Storage
- D. Amazon AWS EBS
Purity CloudSnap is a feature of Pure Storage FlashArray that enables customers to offload snapshots to public cloud storage for long-term retention or disaster recovery purposes. To determine which public cloud storage services are supported as offload targets, let's analyze the options:
Analysis of Options:
A). Amazon AWS S3:
Amazon S3 (Simple Storage Service) is one of the most widely used object storage services in the public cloud.
Purity CloudSnap supports AWS S3 as an offload target, making it a valid choice.
B). IBM Object Storage:
IBM Object Storage is not currently supported as an offload target for Purity CloudSnap.
Pure Storage focuses on integration with major cloud providers like AWS and Azure.
C). Amazon AWS EBS:
Amazon EBS (Elastic Block Store) is a block storage service designed for use with EC2 instances.
However, CloudSnap does not support AWS EBS as an offload target because it is intended for object storage services like S3.
D). Azure Blob Storage:
Azure Blob Storage is Microsoft's object storage service, similar to AWS S3.
Purity CloudSnap supports Azure Blob Storage as an offload target, making it a valid choice.
Recommendation:
The correct answers are
A). Amazon AWS S3 and
D). Azure Blob Storage, as these are the supported public cloud storage services for CloudSnap.
Reference: Pure Storage CloudSnap Documentation:
CloudSnap Overview
Explains how CloudSnap integrates with public cloud storage services.
Supported Cloud Providers:
CloudSnap Supported Targets
Lists AWS S3 and Azure Blob Storage as supported offload targets.
NEW QUESTION # 38
What is the total amount of usable storage space consumed on this FlashArray system?
- A. 4.36 T
- B. 3.87 T
- C. 5.58 T
- D. 1.22 T
Why This Matters:
Usable Storage Space Consumed:
The "usable storage space consumed" refers to the actual physical capacity used on the array after accounting for RAID overhead but before applying data reduction techniques like deduplication and compression.
This value represents the raw space utilized by the data stored on the array, excluding any logical space savings from data reduction.
B). 5.58 T:
This value likely represents the logical capacity provisioned or consumed after applying data reduction techniques (e.g., deduplication and compression). However, the question specifically asks for the usable storage space consumed, which excludes logical space savings.
C). 1.22 T:
This value might represent the raw capacity of the drives or some other metric unrelated to the usable storage space consumed. It does not align with the definition of usable storage space.
D). 4.36 T:
This value could represent an intermediate calculation or another metric, but it does not match the usable storage space consumed as shown in the exhibit.
Key Points:
Usable Storage Space Consumed: Represents the physical capacity used on the array after RAID overhead but before data reduction.
Logical vs. Physical Capacity: Logical capacity reflects space savings from deduplication and compression, while usable storage space reflects the actual physical usage.
Exhibit Analysis: Carefully interpret the metrics provided in the exhibit to identify the correct value.
Reference: Pure Storage FlashArray Documentation: "Understanding Array Capacity Metrics" Pure Storage Whitepaper: "Capacity Management and Data Reduction" Pure Storage Knowledge Base: "What is Usable Space vs. Raw Space?"
NEW QUESTION # 39
If you are determined to purchase our Pure Storage FlashArray Architect Associate FAAA_005 valid exam collection materials for your companies, if you pursue long-term cooperation with site, we will have some relate policy. Firstly we provide one-year service warranty for every buyer who purchased Pure Storage FAAA_005 valid exam collection materials.
Reliable FAAA_005 Exam Registration: https://www.prep4sureexam.com/FAAA_005-dumps-torrent.html
Pure Storage New FAAA_005 Test Answers Our company has considered that different people have different preferences, and that is why we have set three kinds of demo versions in our website, namely, PDF Version demo, PC Test Engine and Online Test Engine, you can choose to download any one of them as you like, Except of high quality of FAAA_005 VCE dumps our customer service is satisfying so that we have many regular customers and many new customers are recommended by other colleagues or friends.
It is important for you to always be aware FAAA_005 Free Exam Questions of exceptions to the norm, Unless you have a fully staffed software developmentorganization and are expecting no growth New FAAA_005 Study Notes or turnover, you should be concerned about recruiting and hiring the best talent.
High Hit-Rate New FAAA_005 Test Answers | FAAA_005 100% Free Reliable Exam RegistrationOur company has considered that different people FAAA_005 have different preferences, and that is why we have set three kinds of demo versions in our website, namely, PDF Version demo, PC Test Reliable FAAA_005 Exam Registration Engine and Online Test Engine, you can choose to download any one of them as you like.
Our Prep4sureExam always updates the exam dumps and the content of our exam software in order to ensure the FAAA_005 exam software that you have are the latest and comprehensive version.
Our FAAA_005 test questions answers will provide the best valid and accurate knowledge for you and give you right reference, So the FAAA_005 questions & answers are valid and reliable to use.
- FAAA_005 Cheap Dumps 😭 FAAA_005 Reliable Exam Labs 🤓 Exam FAAA_005 Passing Score 🍴 Easily obtain ⇛ FAAA_005 ⇚ for free download through ☀ [url]www.troytecdumps.com ️☀️ 🐱FAAA_005 Reliable Exam Braindumps[/url]
- Latest updated New FAAA_005 Test Answers - Leader in Qualification Exams - Professional FAAA_005: Pure Storage FlashArray Architect Associate 💖 Search on “ [url]www.pdfvce.com ” for ⇛ FAAA_005 ⇚ to obtain exam materials for free download 🕧FAAA_005 Latest Test Vce[/url]
- 2026 Updated FAAA_005: New Pure Storage FlashArray Architect Associate Test Answers 🏪 Search for “ FAAA_005 ” and easily obtain a free download on ⮆ [url]www.verifieddumps.com ⮄ 🦖New FAAA_005 Test Papers[/url]
- 2026 New FAAA_005 Test Answers | Efficient Pure Storage Reliable FAAA_005 Exam Registration: Pure Storage FlashArray Architect Associate ☣ Search for 【 FAAA_005 】 and download it for free immediately on [ [url]www.pdfvce.com ] 🛣FAAA_005 Dumps Discount[/url]
- Latest FAAA_005 Exam Torrent Must Be a Great Beginning to Prepare for Your Exam - [url]www.prepawaypdf.com ⏭ Search for 「 FAAA_005 」 and download exam materials for free through “ www.prepawaypdf.com ” 🧼FAAA_005 Exam Labs[/url]
- Practice FAAA_005 Exam Online 🚉 Valid FAAA_005 Study Plan 📹 FAAA_005 Latest Exam Registration 🔚 Easily obtain free download of ➠ FAAA_005 🠰 by searching on 「 [url]www.pdfvce.com 」 🍑FAAA_005 Examcollection Dumps Torrent[/url]
- Quiz Pure Storage - FAAA_005 - Updated New Pure Storage FlashArray Architect Associate Test Answers 🔯 Search for [ FAAA_005 ] and obtain a free download on ⏩ [url]www.testkingpass.com ⏪ 🚃Valid FAAA_005 Study Plan[/url]
- Quiz Pure Storage - FAAA_005 - Updated New Pure Storage FlashArray Architect Associate Test Answers 🦊 Easily obtain free download of { FAAA_005 } by searching on ☀ [url]www.pdfvce.com ️☀️ 👘FAAA_005 Latest Exam Registration[/url]
- FAAA_005 valid vce collection - FAAA_005 latest training dumps 🥌 Search for ( FAAA_005 ) and obtain a free download on ⇛ [url]www.prepawayexam.com ⇚ 😤Valid FAAA_005 Study Plan[/url]
- Updated New FAAA_005 Test Answers - Win Your Pure Storage Certificate with Top Score 🛐 Open website ▛ [url]www.pdfvce.com ▟ and search for ➥ FAAA_005 🡄 for free download 🧑FAAA_005 Examcollection Dumps Torrent[/url]
- 2026 Newest New FAAA_005 Test Answers | FAAA_005 100% Free Reliable Exam Registration 💨 Go to website ( [url]www.prep4sures.top ) open and search for “ FAAA_005 ” to download for free 🔨FAAA_005 Exam Labs[/url]
- daedaluscs.pro, bbs.t-firefly.com, www.stes.tyc.edu.tw, anonup.com, danthemannj.alboompro.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.kickstarter.com, Disposable vapes
2026 Latest Prep4sureExam FAAA_005 PDF Dumps and FAAA_005 Exam Engine Free Share: https://drive.google.com/open?id=1O0f72eUX0KGQAmk4ttWl7GaIXmrluGwk
