New Fortinet NSE5_FNC_AD_7.6 Test Duration - NSE5_FNC_AD_7.6 New Dumps Questions
Posted at 2/15/2026 03:59:34
View226
Replies1
The Fortinet wants to become the first choice for quick and complete Fortinet NSE5_FNC_AD_7.6 exam preparation. To achieve this objective the Fortinet has hired a team of experienced and qualified NSE5_FNC_AD_7.6 Exam trainers. They have years of experience in verifying Fortinet NSE 5 - FortiNAC-F 7.6 Administrator exam practice test questions.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
| | Topic 2 | - Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
| | Topic 3 | - Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
| | Topic 4 | - Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
Fortinet NSE5_FNC_AD_7.6 New Dumps Questions | NSE5_FNC_AD_7.6 Exam TutorialsThe Fortinet NSE5_FNC_AD_7.6 desktop practice test software and web-based practice test software, both are the mock Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) exam that provides you real-time NSE5_FNC_AD_7.6 exam environment for quick and complete preparation. Whereas the Fortinet NSE5_FNC_AD_7.6 PDF Dumps file is concerned, this file is simply a collection of real, valid, and updated Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) exam questions that also help you in preparation. So choose the right "Exams-boost" exam questions format and start NSE5_FNC_AD_7.6 exam preparation today. Order your NSE5_FNC_AD_7.6 Dumps now to Avail 25% EXTRA Discount on the NSE5_FNC_AD_7.6 Exam Dumps learning material and get your dream certification.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q19-Q24):NEW QUESTION # 19
Refer to the exhibits.
Based on the given configurations and settings, on which date and time would a guest account created at 8:00 AM on 2025/09/12 expire?
- A. 2025/09/12 at 17:00:00
- B. 2025/09/13 at 17:00:00
- C. 2025/09/12 at 7:00 PM
- D. 2025/09/12 at 8:00 PM
Questio ns no: 22
Verified Answe r: D
Comprehensive and Detailed 250 to 300 words each Explanation with Exact Matched Extract from FortiNAC-F Administrator library and documentation for current versions (including F 7.2, 7.4, and 7.6) documents:
In FortiNAC-F, the expiration of a guest or contractor account is determined by the configuration settings within the Account Creation Wizard and the associated Guest/Contractor Template. While a template can define a default "Account Duration" (as seen in the 12-hour setting in the second exhibit), the Account Creation Wizard allows an administrator to manually specify or override the start and end parameters for a specific user session.
According to the FortiNAC-F Administration Guide regarding guest management, the Account End Date field in the creation wizard is the definitive timestamp for when the account object will be disabled or deleted from the system. In the provided exhibit (Account Creation Wizard), the administrator has explicitly set the Account Start Date to 2025/09/12 08:00:00 and the Account End Date to 2025/09/13 17:00:00.
Even though the template indicates an "Account Duration" of 12 hours, this value typically serves as a pre-populated default. When a manual date and time are entered into the wizard, those specific values take precedence for that individual account. The account will remain active and valid until 5:00 PM (17:00:00) on the following day, 2025/09/13. It is also important to note the "Login Availability" from the template (8:00 AM - 7:00 PM); while the account exists until the 13th at 17:00:00, the user would only be able to authenticate during the active hours defined by the login schedule on both days.
"When creating an account, the administrator can select a template to provide default settings. However, specific values such as the Account End Date can be modified within the Account Creation Wizard. The date and time specified in the 'Account End Date' field determines the absolute expiration of the account. Once this time is reached, the account is moved to an expired state and the user's network access is revoked." - FortiNAC-F Administration Guide: Guest and Contractor Account Management.
NEW QUESTION # 20
A network administrator is troubleshooting a network access issue for a specific host. The administrator suspects the host is being assigned a different network access policy than expected.
Where would the administrator look to identify which network access policy, if any, is being applied to a particular host?
- A. The Connections view
- B. The Policy Details view for the host
- C. The Policy Logs view
- D. The Port Properties view of the hosts port
When troubleshooting network access in FortiNAC-F, it is often necessary to verify exactly why a host has been granted a specific level of access. Since FortiNAC-F evaluates policies from the top down and assigns access based on the first match, an administrator needs a clear way to see the results of this evaluation for a specific live endpoint.
The Policy Details (C) view is the designated tool for this purpose. By navigating to the Hosts > Hosts (or Adapter View) in the Administration UI, an administrator can search for the specific MAC address or IP of the host in question. Right-clicking on the host record reveals a context menu from which Policy Details can be selected. This view provides a real-time "look" into the policy engine's decision for that specific host, showing the Network Access Policy that was matched, the User/Host Profile that triggered the match, and the resulting Network Access Configuration (VLAN/ACL) currently applied.
While Policy Logs (A) provide a historical record of all policy transitions across the system, they are often too high-volume to efficiently find a single host's current state. The Connections view (B) shows the physical port and basic status but lacks the granular policy logic breakdown. The Port Properties (D) view shows the configuration of the switch interface itself, which is only one component of the final access determination.
"To identify which policy is currently applied to a specific endpoint, use the Policy Details view. Navigate to Hosts > Hosts, select the host, right-click and choose Policy Details. This window displays the specific Network Access Policy, User/Host Profile, and Network Access Configuration currently in effect for that host record." - FortiNAC-F Administration Guide: Policy Details and Troubleshooting.
NEW QUESTION # 21
While deploying FortiNAC-F devices in a 1+1 HA configuration, the administrator has chosen to use the shared IP address option.
Which condition must be met for this type of deployment?
- A. The primary and secondary administrative interfaces are on the same subnet.
- B. The isolation network type is Layer 2.
- C. The isolation network type is layer 3.
- D. There is a direct cable link between FortiNAC-F devices.
In a 1+1 High Availability (HA) deployment, FortiNAC-F supports two primary methods for management access: individual IP addresses or a Shared IP Address (also known as a Virtual IP or VIP). The Shared IP option is part of a Layer 2 HA design, which simplifies administration by providing a single URL or IP that always points to whichever appliance is currently in the "Active" or "In Control" state.
For a Shared IP configuration to function correctly, the Primary and Secondary administrative interfaces (port1) must be on the same subnet. This requirement exists because the Shared IP is a logical address that is dynamically assigned to the physical interface of the active unit. Since only one unit can own the IP at a time, both units must reside on the same broadcast domain (Layer 2) to ensure that ARP requests for the Shared IP are correctly answered and that the gateway remains reachable regardless of which unit is active. If the appliances were on different subnets (a Layer 3 HA design), a shared IP could not be used because it cannot "float" across different network segments; instead, administrators would need to manage each unit via its unique physical IP or use a FortiNAC Manager.
"For L2 HA configurations, click the Use Shared IP Address checkbox and enter the Shared IP Address information... If your Primary and Secondary Servers are not in the same subnet, do not use a shared IP address. The shared IP address moves between appliances during a failover and recovery and requires both units to reside on the same network." - FortiNAC-F High Availability Reference Manual: Shared IP Configuration.
NEW QUESTION # 22
During an evaluation of state-based enforcement, an administrator discovers that ports that should not be under enforcement have been added to enforcement groups.
In which view would the administrator be able to identify who added the ports to the groups?
(Selected)
- A. The Event Management view
- B. The Admin Auditing view
- C. The Port Changes view
- D. The Security Events view
In FortiNAC-F, accountability and forensic tracking of configuration changes are managed through the Admin Auditing functionality. When an administrator performs an action that modifies the system state-such as creating a policy, changing a device's status, or adding a switch port to an Enforcement Group-the system generates an audit record. This record is essential for troubleshooting scenarios where unauthorized or accidental configuration changes have occurred, leading to unintended network behavior.
The Admin Auditing view (found under Logs > Admin Auditing) provides a comprehensive log of the "Who, What, and When" for every administrative session. Each entry includes the username of the administrator, the source IP address from which they accessed the FortiNAC-F console, a precise timestamp, and a detailed description of the modification. In the scenario described, where ports have been incorrectly added to enforcement groups, the Admin Auditing view allows a supervisor to filter by the specific "Port" or "Group" object to identify exactly which administrator executed the command.
In contrast, the Event Management view (B) is designed to monitor system and network events, such as RADIUS authentications, host connections, and SNMP trap arrivals. While it tracks system activity, it does not typically log the manual configuration changes performed by admins. The Port Changes view (C) tracks the operational history of a port (such as VLAN assignment changes and host movements) but does not attribute the administrative assignment of the port to a group. Finally, the Security Events view (D) is dedicated to alerts triggered by security rules and external threat feeds.
"Admin Auditing displays a record of all modifications made to the FortiNAC-F system by an administrator. This view includes the administrator's name, the date and time of the change, and a description of the action taken. It is the primary resource for determining which administrative user performed a specific configuration change, such as modifying port group memberships or altering policy settings." - FortiNAC-F Administration Guide: Logging and Auditing Section.
NEW QUESTION # 23
A FortiNAC-F N+1 HA configuration is shown.
What will occur if CA-2 fails?
- A. CA-3 will continue to operate as a secondary in an N+1 HA configuration.
- B. CA-1 and CA-3 will operate as a 1+1 HA cluster with CA-3 acting as a hot standby.
- C. CA-3 will be promoted to a primary and share management responsibilities with CA-1.
- D. CA-3 will be promoted to a primary and FortiNAC-F manager will load balance between CA-1 and CA-3.
In an N+1 High Availability (HA) configuration, a single secondary Control and Application (CA) server provides backup for multiple primary CA servers. The FortiNAC-F Manager (FortiNAC-M) acts as the centralized orchestrator for this cluster, monitoring the health of all participating nodes.
According to the FortiNAC-F 7.6.0 N+1 Failover Reference Manual, when a primary CA (such as CA-2 in the exhibit) fails, the secondary CA (CA-3) is automatically promoted by the Manager to take over the specific workload and database functions of that failed primary. Crucially, the documentation specifies that even after this promotion, the system architecture maintains its N+1 logic. The secondary CA effectively "assumes the identity" of the failed primary while continuing to operate within the N+1 framework established by the Manager.
It does not merge with CA-1 to form a traditional 1+1 active/passive cluster (A), nor does it engage in load balancing (D), as FortiNAC-F HA is designed for redundancy and failover rather than active traffic distribution. Furthermore, CA-3 does not "share" management with CA-1 (C); it independently handles the tasks originally assigned to CA-2. Throughout this failover state, the Manager continues to oversee the group, and CA-3 remains the designated secondary unit currently acting in a primary capacity for the downed node until CA-2 is restored.
"In an N+1 Failover Group, the Secondary CA is designed to take over the functionality of any single failed primary component within the group. The FortiNAC Manager monitors the primaries and initiates the failover to the secondary... Once failover occurs, the secondary continues to operate as the backup unit for the failed primary while remaining part of the managed N+1 HA configuration." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual: Failover Behavior Section.
NEW QUESTION # 24
Our experts make these demos very clearly to demonstrate the content in our NSE5_FNC_AD_7.6 torrent prep. For those customers who are not acquainted with our products, these demos can help you familiarize yourself with what our materials contain and they will give you a frank appraisal of our official NSE5_FNC_AD_7.6 Exam Questions. All wordings cannot describe the procession of our products, but if you get them and after checking the content, you will be determined to place order. What are you waiting for?
NSE5_FNC_AD_7.6 New Dumps Questions: https://www.exams-boost.com/NSE5_FNC_AD_7.6-valid-materials.html
- Pass Guaranteed Fortinet - NSE5_FNC_AD_7.6 - Authoritative New Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Test Duration 🕍 Search for ▶ NSE5_FNC_AD_7.6 ◀ and obtain a free download on [url]www.prepawayete.com 🤿Braindump NSE5_FNC_AD_7.6 Pdf[/url]
- Free PDF 2026 NSE5_FNC_AD_7.6: Fortinet NSE 5 - FortiNAC-F 7.6 Administrator CProfessional New Test Duration 🧷 Open [url]www.pdfvce.com enter ➡ NSE5_FNC_AD_7.6 ️⬅️ and obtain a free download 😁Test NSE5_FNC_AD_7.6 Dumps Free[/url]
- Valid Fortinet New NSE5_FNC_AD_7.6 Test Duration and Excellent NSE5_FNC_AD_7.6 New Dumps Questions 🆑 Open { [url]www.prepawayete.com } enter ➤ NSE5_FNC_AD_7.6 ⮘ and obtain a free download 👪Valid Dumps NSE5_FNC_AD_7.6 Pdf[/url]
- Online NSE5_FNC_AD_7.6 Test 🐐 Exam NSE5_FNC_AD_7.6 Book 🖊 Training NSE5_FNC_AD_7.6 Materials 🦞 Search on ⮆ [url]www.pdfvce.com ⮄ for ➽ NSE5_FNC_AD_7.6 🢪 to obtain exam materials for free download 🍵Study NSE5_FNC_AD_7.6 Material[/url]
- Pass Guaranteed 2026 Fortinet NSE5_FNC_AD_7.6: Pass-Sure New Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Test Duration 🧫 Search for ➽ NSE5_FNC_AD_7.6 🢪 and download it for free on ☀ [url]www.practicevce.com ️☀️ website ⏏Valid Dumps NSE5_FNC_AD_7.6 Pdf[/url]
- Valid Study NSE5_FNC_AD_7.6 Questions 🔻 Valid Dumps NSE5_FNC_AD_7.6 Pdf 🕌 Latest NSE5_FNC_AD_7.6 Test Cost 🤛 Simply search for [ NSE5_FNC_AD_7.6 ] for free download on { [url]www.pdfvce.com } 🚦Updated NSE5_FNC_AD_7.6 Testkings[/url]
- Valid Study NSE5_FNC_AD_7.6 Questions 👬 New NSE5_FNC_AD_7.6 Test Objectives 🙉 NSE5_FNC_AD_7.6 Download Fee 💮 Easily obtain NSE5_FNC_AD_7.6 for free download through ▷ [url]www.troytecdumps.com ◁ 🦥NSE5_FNC_AD_7.6 Reliable Exam Test[/url]
- Pass Guaranteed 2026 Fortinet NSE5_FNC_AD_7.6: Fortinet NSE 5 - FortiNAC-F 7.6 Administrator CTrustable New Test Duration 🧼 Easily obtain free download of ➽ NSE5_FNC_AD_7.6 🢪 by searching on ⏩ [url]www.pdfvce.com ⏪ 🎑NSE5_FNC_AD_7.6 Exam Dumps Pdf[/url]
- 100% Pass 2026 Fortinet Fantastic New NSE5_FNC_AD_7.6 Test Duration 🌠 Open website ➽ [url]www.pdfdumps.com 🢪 and search for ▶ NSE5_FNC_AD_7.6 ◀ for free download 🚾Training NSE5_FNC_AD_7.6 Materials[/url]
- Pass Guaranteed Fortinet - NSE5_FNC_AD_7.6 - Authoritative New Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Test Duration 🛹 Search for ▷ NSE5_FNC_AD_7.6 ◁ and download exam materials for free through ➽ [url]www.pdfvce.com 🢪 💭New NSE5_FNC_AD_7.6 Test Objectives[/url]
- 2026 Perfect New NSE5_FNC_AD_7.6 Test Duration | 100% Free NSE5_FNC_AD_7.6 New Dumps Questions ⚗ Easily obtain free download of ➠ NSE5_FNC_AD_7.6 🠰 by searching on ⮆ [url]www.exam4labs.com ⮄ 👟New NSE5_FNC_AD_7.6 Exam Prep[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, anweshon.com, www.ted.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, academy.saleshack.io, Disposable vapes
