[General] Plat-Arch-204 Pass Test, Plat-Arch-204 Exam Reviews
93
【General】 Plat-Arch-204 Pass Test, Plat-Arch-204 Exam Reviews
Posted at 2/15/2026 05:43:32      View:110 | Replies:0        Print      Only Author   [Copy Link] 1#
The pass rate is 98.65%, and we can ensure you pass the exam if you choose Plat-Arch-204 training materials from us. In addition, we have professional experts to compile and verify Plat-Arch-204 questions and answers, therefore you can just use them at ease. We also pass guarantee and money back guarantee if you fail to pass the exam. Free update for Plat-Arch-204 Training Materials is available, namely, in the following year, you don’t need to spend a cent, but you can get the latest information of the exam. And the latest version for Plat-Arch-204 exam briandumps will send to your email automatically.
Salesforce Plat-Arch-204 Exam Syllabus Topics:
  • Build Solution: This domain covers implementing integrations including API design considerations, choosing outbound methods, building scalable solutions, implementing error handling, creating security solutions, and ensuring resilience during system updates.
  • Evaluate the Current System Landscape: This domain covers analyzing existing technical environments to understand current systems, their standards, protocols, limitations, and boundaries, while identifying constraints and authentication
  • authorization requirements.
  • Evaluate Business Needs: This domain addresses gathering functional and non-functional requirements, classifying data by sensitivity, identifying CRM success factors, and understanding how business growth and regulations impact integration choices.
Plat-Arch-204 Exam Reviews - Plat-Arch-204 Reliable Exam CampIf you cannot complete the task efficiently, we really recommend using Plat-Arch-204 learning materials. Through the assessment of your specific situation, we will provide you with a reasonable schedule, and provide the extensible version of Plat-Arch-204 exam training guide you can quickly grasp more knowledge in a shorter time. In the same time, you will do more than the people around you. This is what you can do with Plat-Arch-204 Test Guide. Our Plat-Arch-204 learning guide is for you to improve your efficiency and complete the tasks with a higher quality.
Salesforce Certified Platform Integration Architect Sample Questions (Q76-Q81):NEW QUESTION # 76
What is the first thing an integration architect should validate if a callout from a Lightning web component to an external endpoint is failing?
  • A. The endpoint domain has been added to Cross-Origin Resource Sharing.
  • B. The endpoint URL has been added to Remote Site Settings.
  • C. The endpoint URL has been added to Content Security Policies.
When an integration callout initiated from a Lightning Web Component (LWC) fails, the architect must distinguish between client-side and server-side security layers. Unlike Apex callouts, which are governed by Remote Site Settings at the server level, LWC requests originate directly from the user's browser. Consequently, they are subject to the browser's Content Security Policy (CSP).
CSP is a security layer that helps detect and mitigate certain types of attacks, including Cross-Site Scripting (XSS) and data injection attacks. It prevents a website from loading content from a third party unless that domain is explicitly safe-listed. If an LWC attempts to connect to an external API endpoint that is not listed in the CSP Trusted Sites in Salesforce Setup, the browser will block the request before it is even sent, often returning a "Refused to connect because it violates the document's Content Security Policy" error. While Cross-Origin Resource Sharing (CORS) is also a browser-level security mechanism, it must be configured on the external server to allow the browser to access its resources; however, the first validation step within the Salesforce environment for a failing LWC callout is ensuring the domain is allowed by the org's CSP.
NEW QUESTION # 77
A company uses Customer Community for course registration. The payment gateway takes more than 30 seconds to process transactions. Students want results in real time to retry if errors occur. What is the recommended integration approach?
  • A. Use Continuation to process payment to the payment gateway
  • B. Use Platform Events to process payment to the payment gateway.
  • C. Use Request and Reply to make an API call to the payment gateway.
Standard synchronous Apex callouts have a timeout limit, and more importantly, Salesforce limits the number of long-running requests (those lasting longer than 5 seconds) that can execute concurrently. If a payment gateway consistently takes 30 seconds, a few simultaneous users could easily exhaust the org's concurrent request limit, causing the entire system to stop responding.
The Continuation pattern (Option C) is designed specifically for this "long-wait" scenario. It allows the Apex request to be suspended while waiting for the external service to respond, freeing up the Salesforce worker thread to handle other users. Once the gateway responds, the suspended process resumes and returns the result to the student's browser. This provides the "real-time" experience required for the student to retry immediately without the risk of bringing down the entire community due to thread exhaustion.
NEW QUESTION # 78
Northern Trail Outfitters needs to make synchronous callouts "available-to-promise" services to query product availability and reserve inventory during the customer checkout process. What should an integration architect consider when building a scalable integration solution?
  • A. The typical and worst-case historical response times
  • B. The number of batch jobs that can run concurrently
  • C. The maximum query cursors open per user on the service
In a Synchronous Request-Reply pattern, the user's experience is directly tied to the performance of the external service. For a mission-critical "Available-to-Promise" (ATP) service during checkout, the most vital scalability consideration is the typical and worst-case historical response times of the target system.
Salesforce imposes strict Governor Limits on synchronous callouts to protect platform health. Specifically, if an ATP callout takes longer than 120 seconds, the transaction will time out. More importantly, Salesforce limits the number of long-running requests (those lasting longer than 5 seconds). If multiple users are checking out simultaneously and the external inventory system begins to respond slowly (worst-case), those requests can quickly occupy all available slots in the concurrent request queue, leading to "Concurrent Request Limit Exceeded" errors for all users in the org.
By analyzing historical response times, the architect can determine if the service is reliable enough for a synchronous callout. If the worst-case response time frequently exceeds 5 seconds, the architect should consider a more resilient pattern, such as the Continuation pattern or an asynchronous approach, to prevent blocking the UI thread and hitting platform limits. Options A and C are irrelevant to synchronous checkout performance; query cursors relate to database state, and batch jobs are asynchronous background processes that do not impact real-time user checkout latency.
NEW QUESTION # 79
Considering Salesforce capabilities, what should the integration architect evaluate when integrating Salesforce with the current system landscape?
  • A. Integrate Salesforce with Order Management System, Data Warehouse and Case Management System.
  • B. Integrate Salesforce with Email Management System, Order Management System and Case Management System.
  • C. Integrate Salesforce with Data Warehouse, Order Management and Email Management System.
When evaluating a current system landscape for a Salesforce implementation, an Integration Architect's primary goal is to align the platform's native capabilities with the existing architecture to determine which systems will be replaced, retired, or integrated. Based on the provided diagram (image_69c0fd.png), the landscape consists of an Email Management System, an Order Management System, a Case Management System, and a Data Warehouse used for Business Intelligence.
In a scenario where an enterprise is implementing Salesforce to support Case Management (Service Cloud), Salesforce natively provides the robust capabilities required to serve as the new "System of Record" for customer support interactions. Consequently, the legacy Case Management System is typically targeted for retirement. The architect's evaluation therefore focuses on the necessary integration points with the systems that will coexist with the new Salesforce instance to ensure a unified agent experience.
As outlined in standard Salesforce Integration Architecture frameworks, the following evaluations are critical:
Order Management System (OMS): Salesforce must integrate with the OMS so that service agents can view real-time order history, shipping status, and line items directly within the Case record, often using patterns like Request-Reply or Data Virtualization.
Email Management System (EMS): To support Omni-Channel service, Salesforce needs to integrate with the EMS (via Email-to-Case or a Marketing Cloud connector) to ensure that all customer communications are captured and tracked against the appropriate Case records.
Data Warehouse: For long-term historical reporting and cross-functional analytics, Salesforce must push its transactional data to the enterprise Data Warehouse. This ensures the Analytics and Business Intelligence Tool can continue to provide a holistic view of company performance.
By selecting Option C, the architect recognizes that Salesforce replaces the legacy case management function while requiring strategic integration with the Data Warehouse, Order Management, and Email Management systems to achieve a true 360-degree view of the customer.
NEW QUESTION # 80
Northern Trail Outfitters uses a custom Java application to display code coverage and test results for all enterprise applications. Which Salesforce API should an integration architect use to include Salesforce in this application?
  • A. Metadata API
  • B. Analytics REST API
  • C. Tooling API
The Tooling API is specifically designed for developer-centric tools that need fine-grained access to Salesforce metadata and runtime information. It exposes specialized objects like ApexCodeCoverage, ApexCodeCoverageAggregate, and ApexTestResult. These objects allow external applications to query the results of test runs and specific line-by-line coverage metrics. While the Metadata API (Option A) is used for deployments, it does not provide the same granular query access to test execution results. The Tooling API is the industry standard for integrating Salesforce into enterprise CI/CD pipelines and quality dashboards.
NEW QUESTION # 81
In use process, if you have some problems on our Plat-Arch-204 study materials provide 24 hours online services, you can email or contact us on the online platform. In addition, our backstage will also help you check whether the Plat-Arch-204 exam prep is updated in real-time. If there is an update, our system will send to the customer automatically. Our Plat-Arch-204 Learning Materials also provide professional staff for remote assistance, to help users immediate effective solve the existing problems if necessary. So choosing our Plat-Arch-204 study materials make you worry-free.
Plat-Arch-204 Exam Reviews: https://www.test4cram.com/Plat-Arch-204_real-exam-dumps.html
