PL-400ԇ} - PL-400JCԇ
Posted at 2/15/2026 06:13:49
View184
Replies0
⣬@ЩTestpdf PL-400ԇ}IJփݬFMģhttps://drive.google.com/open?id=1JPN3rXQ-GH8SeX5pLSFlr5A1GTC-9Bxw
TestpdfĽSČ҈F_lᘌMicrosoft PL-400 JCԇЧӖӋmυMicrosoft PL-400 JCԇĿTestpdfṩĶǸƷ|ĮaƷㅢMicrosoft PL-400 JCԇ֮ǰģMԇԞㅢӿԇõĜʂ䡣
HƴWcˇ^Čֱِˮʡx˚ Microsoft PL-400 JCԇõ@ԇJCYԵõܴĺ̎Ҫ PL-400 JCԇMicrosoft PL-400 }õĜʂ乤ߡ@YϿԎpͨ^ԇ@һurܸߵYϣͲٓĿԇˡ
PL-400JCԇPL-400}dMicrosoftPL-400ԇ䌍һgҿԇ MicrosoftPL-400ԇԎʹMITˆTһITIģ˺õIģȻͿԞIԴԴ棬ĶȥMҽlչеITˆT@ӣNt҂Testpdf MicrosoftPL-400ԇӖYϿԎITˆT_@һĿģC100%@JCҪ˼߀Qx҂Testpdf MicrosoftPL-400ԇӖYϡ
Microsoft PL-400 ԇ_lˆTչʾʹ Power Platform Q֪RͼܵĽ^;ͨ^˿ԇIʿԫ@ Microsoft JCģPower Platform _lˆTJC@ӿչʾژ Power Platform QČI֪R@NJCИIзdzܵҕԞ錣IʿµIC
µ Microsoft Certified: Power Platform Developer Associate PL-400 Mԇ} (Q341-Q346):} #341
You need to improve the efficiency of counting warehouse inventory.
What should you create?
- A. a flow that updates the warehouse counts as the worker performs the count
- B. a canvas app that scans barcodes to allow a warehouse worker to select inventory counts
- C. a Power BI dashboard that shows the inventory counting variances
- D. a model-driven app that allows the user to key in inventory counts
𰸣B
}f
Scenario: Warehouse counting is performed manually by using a counting journal. All warehouse boxes and items are barcoded.
Barcode scanner control for canvas apps: Scans barcodes, QR codes, and data-matrix codes on an Android or iOS device.
Description
The control opens a native scanner on an Android or iOS device. The scanner automatically detects a barcode, a QR code, or a data-matrix code when in view.
https://docs.microsoft.com/en-us ... new-barcode-scanner
} #342
You need to determine the cause for the issue reported by the interviewers. What is the root cause of the issue?
- A. The plug-in used to synchronize the Person of Interest field from Contact to Interview was not triggered.
- B. There is no plug-in registered to run when an interview record is created.
- C. There was an error in the event pipeline and the entire transaction was rolled back.
𰸣B
}f
Topic 5, Northwind Traders
Case study
Background
Northwind Traders uses Microsoft Dynamics 365 Sales to manage its sales process. To better understand its customers, Northwind Traders invests in a team of researchers who gather data from multiple sources. The company stores the data it collects in a Microsoft Azure SQL Database. The company plans to use the data to enrich account records and make the sales team more effective.
Environment
* The company has three Microsoft Power Platform environments with Dynamics 365 Sales installed. The environments are named development, test, and production.
* Each environment has an application user that can be used for integrations.
* The company must use solutions to perform all customization and configuration deployment.
Data
* Researchers are responsible for creating account records.
* Researchers have permissions on the Account table to create records, read all records, and update records they own.
* A synchronous plug-in runs when an account record is created and could reassign the record to a different user.
* Users must access data as themselves to enforce security and audit changes.
* A column named new_dataid is added to the Account table. The column uniquely identifies which data it should receive.
* Researchers have researched only the top 20 percent of account records.
Web API
* The company creates an Azure Function to run a RESTful .NET Web API.
o Data can be retrieved by placing a GET request to the URL
https://dataservice-tENVIRONMENT ... .net/enrich/IDATAID].
[ENVIRONMENTNAME] is the name of the Microsoft Power Platform environment that requests the data.
[DATAID] is the new.dataid column in the Account table.
o The Web API response will return a 200 response plus data if the Datald is found. Otherwise, a 404 response is returned.
* Developers plan to create a custom connector from the Web API to make it accessible from Microsoft Power Platform.
Custom connector
* The Web API definition used to create The custom connector must be generated based on a low-code technology.
* The URL used by the custom connector must incorporate the current environment name without hardcoding values.
* Errors generated by the custom connector must not cause downstream processes to fail.
* Text descriptions and field placeholder text that describe the use of the custom connector must appear for non-developers.
Process
* All account records must be updated with data from the Web API once automatically.
* Only account records that contain a Datald should be updated by the Web API.
* Researchers must create Power Automate flows to specify data analysis priority.
* The researchers require a process that repurposes a set of identical steps of parameterized Microsoft Dataverse queries from a Power Automate flow for use in other flows that have different parameters. The researchers want to avoid recreating the steps manually each time they create a flow to save time and avoid errors.
Issues
* A tester attempts to connect to the production instance of the Web API with a Datald that should return data.
The tester receives an error stating that the remote name could not be resolved.
* A missing component causes an error to occur when importing the solution that contains the Power Automate flow to update account records in a test environment.
} #343
A company has two development instances, two test instances, two staging instances, and one production instance.
The test team reports connection issues with the test and staging instances.
You need to identify which of the instances the testing team currently has access.
Which two URLs can you use? Each correct answer presents a complete solution.
𰸣D,E
}f
Organization information is stored in the Instance entity of the Discovery service. To see the kind of information contained in that entity, send an HTTP GET request to the service for one of your instances.
GET Error! Hyperlink reference not valid.
Example: Get the details of a specific instance. If you leave out the GUID, all instances that the authenticated user has access to are returned.
https://docs.microsoft.com/en-us ... rganization-web-api
} #344
You create the following Fetch XML query to determine the number of interviews where there are no recommendations for an applicant.
For each of the following statements, select yes if the statements is true, Otherwise select No.
NOTE: Each correct selectin is worth one pint.
𰸣
}f
} #345
You develop the following code for a console application that performs the data import to Microsoft Dataverse.
For each of the following statements, select Yes if the statement is true. Otherwise, select No. NOTE: Each correct selection is worth one point.
𰸣
}f
} #346
Testpdf MicrosoftPL-400ԇӖYԵõµMicrosoftPL-400ԇԇ}𰸣ʹͨ^MicrosoftPL-400ԇJCMicrosoftPL-400ԇJCIģͬĭhoһܣMicrosoftPL-400ԇϸʹã҂Testpdf MicrosoftPL-400ԇӖYϴ_ȫ↖}}ĸԎpɿԇKһͨ^
PL-400JCԇ: https://www.testpdf.net/PL-400.html
Microsoft PL-400ԇ} ͨ^𰸁Mзƣںܶr_܉҂ҵ_Ľ}˼·҂ṩIȵȫITg@PL-400JCԇԇC3Microsoft PL-400ĿԇĿ׃ȡĸ£ṩµĿԇݣ㱻JCһMicrosoft PL-400JCԇW·˾Čң͕ɞ@I֪RČ֮һMicrosoft PL-400ԇ} ֪Rc_85%ҵĸwʣMicrosoft JCҸPL-400} ԇ}ӆmȫĿʹã߿ͨ^ʣMicrosoft PL-400 ԇ} ͑ѽo朽ӣxx
ЦʲЦÁʎ[c^^Xø춞˳ɺ҂PL-400锳ɣͨ^𰸁Mзƣںܶr_܉҂ҵ_Ľ}˼·҂ṩIȵȫITg@Microsoft Certified: Power Platform Developer AssociateԇC
µPL-400JCԇYυR3Microsoft PL-400ĿԇĿ׃ȡĸ£ṩµĿԇݣ㱻JCһMicrosoftW·˾Čң͕ɞ@I֪RČ֮һ֪Rc_85%ҵĸwʡ
- ֵهMicrosoft PL-400Microsoft Power Platform Developerԇ} - [url]www.pdfexamdumps.com PL-400JCԇ 🤔 ➥ www.pdfexamdumps.com 🡄ϵMd➡ PL-400 ️⬅️_PL-400TJC[/url]
- PL-400JCY 🕎 PL-400T} 🍓 PL-400Cָ 🛅 ▛ [url]www.newdumpspdf.com ▟ь▶ PL-400 ◀ԫ@ȡMdԇYPL-400 PDF}[/url]
- dPL-400ԇ}죬pͨ^PL-400ԇ 📪 _ [url]www.vcesoft.com ݔ루 PL-400 K@ȡMd°PL-400}Ͼ[/url]
- PL-400 PDF} ❕ PL-400ԇ俼 🙎 PL-400ھ} 💹 ^▶ [url]www.newdumpspdf.com ◀p@ȡ➡ PL-400 ️⬅️MdPL-400yԇ[/url]
- PL-400 PDF ⬛ PL-400} 🟦 PL-400ָ 🌗 ☀ [url]www.pdfexamdumps.com ️☀️ϵMd PL-400 _PL-400T}[/url]
- õPL-400ԇ}YԇIc`Microsoft Microsoft Power Platform Developer 🎹 ➥ [url]www.newdumpspdf.com 🡄{ PL-400 }p@ȡMdPL-400Wָ[/url]
- PL-400TJC 🐒 PL-400ָ 🌘 PL-400} 🚄 ⮆ tw.fast2test.com ⮄ṩM PL-400 }ռPL-400Cָ
- ڙPL-400JCԇYԇIṩ̺|PL-400ԇ} 🔏 ^ [url]www.newdumpspdf.com p@ȡ PL-400 MdPL-400ԇ}[/url]
- õPL-400ԇ}YԇIc`Microsoft Microsoft Power Platform Developer 🗽 ^➽ tw.fast2test.com 🢪p@ȡ⮆ PL-400 ⮄MdPL-400ԇV
- PL-400ԇ}죺Microsoft Power Platform Developer100ͨ^ԇPL-400JCԇ ⛺ ڡ [url]www.newdumpspdf.com µġ PL-400 }PL-400JC[/url]
- ֵهMicrosoft PL-400Microsoft Power Platform Developerԇ} - tw.fast2test.com PL-400JCԇ 👛 tw.fast2test.com ➤ PL-400 ⮘pȡMdPL-400}
- www.stes.tyc.edu.tw, www.courtpractice.com, www.intensedebate.com, bbs.t-firefly.com, alexisimport.com, www.stes.tyc.edu.tw, github.com, learning.d6driveresponsibly.it, www.stes.tyc.edu.tw, www.fanart-central.net, Disposable vapes
2026 TestpdfµPL-400 PDF濼ԇ}PL-400ԇ}ʹMhttps://drive.google.com/open?id=1JPN3rXQ-GH8SeX5pLSFlr5A1GTC-9Bxw
