[Hardware] New Customized CRT-450 Lab Simulation Free PDF | Reliable CRT-450 Best Vce: Sale
96
【Hardware】 New Customized CRT-450 Lab Simulation Free PDF | Reliable CRT-450 Best Vce: Sale
Posted at 2/15/2026 08:58:34      View:158 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce CRT-450 dumps are available on Google Drive shared by TestBraindump: https://drive.google.com/open?id=1yxkw-yIg0XlnDbgkGjg_QoOsWtr7oUyN
All these three TestBraindump Salesforce Certified Platform Developer I (CRT-450) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the CRT-450 Exam Dumps you will get everything that you need to learn, prepare and pass the challenging CRT-450 exam with good scores.
I wonder if you noticed that there are three versions of our CRT-450 test questions—PDF, software on pc, and app online, which can bring you the greatest convenience. Imagine that if you feel tired or simply do not like to use electronic products to learn, the PDF version of CRT-450 Test Torrent is best for you. Just like reading, you can print it, annotate it, make your own notes, and read it at any time.
CRT-450 Best Vce & CRT-450 New APP SimulationsTestBraindump can lead you the best and the fastest way to reach for the certification and achieve your desired higher salary by getting a more important position in the company. Because we hold the tenet that low quality CRT-450 exam materials may bring discredit on the company. Our CRT-450 learning questions are undeniable excellent products full of benefits, so our CRT-450 exam materials can spruce up our own image. Meanwhile, our CRT-450 exam materials are demonstrably high effective to help you get the essence of the knowledge which was convoluted.
Salesforce CRT-450 certification exam is designed for professionals who are interested in building custom applications on the Salesforce platform. CRT-450 exam covers a wide range of topics, including the Salesforce development environment, data modeling and management, Apex programming language, Visualforce user interface framework, and testing and deployment. CRT-450 Exam aims to test the candidates' understanding of the Salesforce development process and their ability to design, develop, test, and deploy custom applications.
Salesforce Certified Platform Developer I Sample Questions (Q86-Q91):NEW QUESTION # 86
An org has two custom objects:
* Plan_c, that has a master-detail relationship to the Account object.
* Plan_item_c, that has a master-detail relationship to the plan_C object.
What should a developer use to create a Visualforce section in the Account page layout that displays all of the plan.. Account and all of the Plan_item_c records related to those plan_c records.
  • A. A custom controller by itself
  • B. A standard controller with a controller extension
  • C. A standard controller with a custom controller
  • D. A controller extension with a custom controller
NEW QUESTION # 87
What is a valid way of loading external JavaScript files into a Visualforce page? (Choose 2)
  • A. Using a (script)* tag.
  • B. Using a (link)* tag.
  • C. Using an (apex:includeScript)* tag. >
  • D. Using an (apex:define)* tag.
NEW QUESTION # 88
A developer created a custom order management app that uses an Apex class. The order is represented by an Order object and an Orderltem object that has a master-detail relationship to Order. During order processing, an order may be split into multiple orders.
What should a developer do to allow their code to move some existing Orderltem records to a new Order record?
  • A. Create a junction object between Orderltem and Order.
  • B. Add without sharing to the Apex class declaration.
  • C. Change the master-detail relationship to an external lookup relationship.
  • D. Select the Allow reparenting option on the master-detail relationship.
NEW QUESTION # 89
A developer is creating an application to track engines and their parts. An individual part can be used in different types of engines.What data model should be used to track the data and to prevent orphan records?
  • A. Create a junction object to relate many engines to many parts through a lookup relationship
  • B. Create a master-detail relationship to represent the one-to-many model of engines to parts.
  • C. Create a junction object to relate many engines to many parts through a master-detail relationship
  • D. Create a lookup relationship to represent how each part relates to the parent engine object.
NEW QUESTION # 90
Universal Containers recently transitioned from Classic to Lightning Experience.
One of its business processes requires certain values from the Opportunity cbject to be sent via an HTTP REST callout to its external order management system when the user presses a custom button on the Opportunity detail page. Example values are as follows:
* Name
* Amount
* Account
Which two methods should the developer implement to fulfill the business requirement?
Choose 2 answers
  • A. Create a Remote Action on the Opportunity object that executes an Apex immediate action to perform the HTTP REST callout whenever the Opportunity Is updated.
  • B. Create a custom Visualforce quick action that performs the HTTP REST callout, and use a Visualforce quick action to expose the component on the Opportunity detail page.
  • C. Create a Lightning component quick action that performs the HTTP REST callout, and use a Lightning Action to expose the component on the Opportunity detail page.
  • D. Create an after update trigger on the Opportunity object that calls a helper method using @Future (Callour=true) to perform the HTTP REST callout.
To send Opportunity values via an HTTP REST callout when a user presses a custom button in Lightning Experience:
Option B: Create a custom Visualforce quick action
A Visualforce page with a custom controller can perform the callout.
The Visualforce page can be added as a quick action on the Opportunity page.
A Lightning component can perform the callout when invoked.
The component can be added to the Opportunity page as a quick action.
"You can use Visualforce to create custom quick actions."
- Salesforce Help: Quick Actions
Option C: Create a Lightning component quick action
"Use Lightning components to create custom actions that can be added to Lightning Experience and the Salesforce mobile app."
- Salesforce Help: Lightning Component Actions
Why Other Options Are Incorrect:
Option A:
Remote Actions are used in Visualforce for client-side calls and are not applicable here.
Performing the callout whenever the Opportunity is updated does not meet the requirement of initiating the action via a button click.
Option D:
An after-update trigger would execute on every update, not just when the user presses a button.
Using @future methods may not execute immediately and can't be invoked directly by the user action.
NEW QUESTION # 91
We are professional in this career to help all our worthy customers to obtain the CRT-450 certification for years. You can get prepared with our CRT-450 exam materials only for 20 to 30 hours before you go to attend your exam. we can claim that you will achieve guaranteed success with our CRT-450 Study Guide for that our high pass rate is unmarched 98% to 100%. And all the warm feedback from our clients proved our strength, you can totally relay on us with our CRT-450 practice quiz!
CRT-450 Best Vce: https://www.testbraindump.com/CRT-450-exam-prep.html
DOWNLOAD the newest TestBraindump CRT-450 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1yxkw-yIg0XlnDbgkGjg_QoOsWtr7oUyN
Posted at 3/10/2026 09:06:09        Only Author  2#
This article has really touched me, thank you for sharing! The 300-815 valid real test exam questions are available for free. Wishing you the best in your exams!
