Salesforce Salesforce-Certified-Administrator Questions - Say Goodbye To Exam An
Posted at 2/15/2026 11:07:12
BTW, DOWNLOAD part of VCEEngine Salesforce-Certified-Administrator dumps from Cloud Storage: https://drive.google.com/open?id=1o3z_NQhUrrFkePDUvTVawgaZa6rq_Maw
Here, we provide you with the best Salesforce-Certified-Administrator premium study files which will improve your study efficiency and give you right direction. The content of Salesforce-Certified-Administrator study material is the updated and verified by IT experts. Professional experts are arranged to check and trace the Salesforce Salesforce-Certified-Administrator update information every day. The Salesforce-Certified-Administrator exam guide materials are really worthy of purchase. The high quality and accurate Salesforce-Certified-Administrator questions & answers are the guarantee of your success.
Salesforce is a cloud-based software company that provides a range of customer relationship management (CRM) solutions. The Salesforce Certified Administrator certification is designed to test the knowledge and skills of individuals who work with Salesforce CRM. Salesforce Certified Administrator certification is offered by Salesforce and is recognized worldwide as a standard for measuring the competence of Salesforce administrators.
Salesforce-Certified-Administrator Reliable Test Cram & Knowledge Salesforce-Certified-Administrator PointsOur Salesforce Certified Administrator exam questions are totally revised and updated according to the changes in the syllabus and the latest developments in theory and practice. And the study materials are based on the past years of the exam really and industry trends through rigorous analysis and summary. We carefully prepare the Salesforce-Certified-Administrator test guide for the purpose of providing high-quality products. All the revision and updating of products can graduate the accurate information about the Salesforce-Certified-Administrator Guide Torrent you will get, let the large majority of student be easy to master and simplify the content of important information. Our product Salesforce-Certified-Administrator test guide delivers more important information with fewer questions and answers, in order to easy and efficient learning.
Salesforce Certified Administrator Sample Questions (Q149-Q154):NEW QUESTION # 149
Sales reps miss key fields when filling out on opportunity record through the process. Reps need to move forward Win unable to enter previous stage.
Which three options should the administrator use to address this need?
Choose Three answers
- A. Use Flow to mark fields required.
- B. Configure Opportunity Path.
- C. Enable guided selling.
- D. Use Validation Rules.
- E. Mark fields required on the page layout.
Answer: C,D,E
Guided selling, validation rules, and required fields on the page layout are three options that can be used to ensuresales reps fill out key fields when working on an opportunity through the process. Guided selling allows administrators to add prompts and guidance at each stage of the path to help reps move forward with confidence. Validation rules allow administrators to enforce data quality and business logic by preventing reps from saving records that do not meet certain criteria. Required fields on the page layout allow administrators to make certain fields mandatory for reps to enter before saving records. Configuring opportunity path can help reps visualize and update key fields at each stage, but it does not make them required or prevent them from moving forward without entering them. Using flow to mark fields required is not possible because flows cannot modify page layouts or field properties. References:
https://help.salesforce.com/s/ar ... ling.htm&type=5
https://help.salesforce.com/s/ar ... ules.htm&type=5https://help.salesforce.com/s/article
NEW QUESTION # 150
Ursa Major Solar has a path on Case. The Company wants to require its users to follow the status values as they are on the path. Agents should be prohibited from preventing the case back to a previous status.
Which Feature Should an administrator use to fulfill this request?
- A. Predefined field Values.
- B. Global Value Picklists
- C. Dependent Picklists.
- D. Validation rules.
NEW QUESTION # 151
Cloud Kicks wants to track shoe designs by products. Shoe designs should be unable to be deleted, and there can be multiple designs for one product across various stages.
Which two steps should the administrator configure to meet this requirement?
Choose 2 answers
- A. Add a custom master-detail field for shoe designs on the Product object,
- B. Use the standard object for designs.
- C. Configure a custom lookup field for shoe designs on the Product object.
- D. Create a custom object for shoe designs.
NEW QUESTION # 152
Cloud Kicks needs to change the owner of a case when it has been open for more than 7 days.
How should the administrator complete this requirement?
- A. Validation Rule
- B. Auto - Response Rules
- C. Escalation Rule
- D. Assignment Rule
An escalation rule is a tool that allows administrators to automatically escalate cases based on certain criteria and time triggers. For example, an escalation rule can change the owner of a case, send anemail notification, or update a field value when a case has been open for more than 7 days. An escalation rule consists of multiple rule entries that define the criteria and actions for each escalation scenario.
References:https://help.salesforce.com/s/ar ... tion.htm&type=5
NEW QUESTION # 153
Cloud Kicks has asked the administrator to test a new screen flow that create contacts.
What are two key components of testing the flow?
Choose 2 answers
- A. Use Debug to test the flow in Flow Builder.
- B. Run the flow using it to create contacts.
- C. Set Up a flow interview to test the flow.
- D. Test the flow in a sandbox.
Running the flow using it to create contacts and using debug to test the flow in Flow Builder are two key components of testing a new screen flow that creates contacts. Running the flow allows the administrator to see how the flow behaves in real time and check for any errors or unexpected results. Debugging the flow allows the administrator to simulate how the flow runs with different inputs and outputs and check for any logic or syntax errors. Setting up a flow interview or testing the flow in a sandbox are not necessary for testing a screen flow that creates contacts. References:
https://help.salesforce.com/s/ar ... test.htm&type=5
NEW QUESTION # 154
Will you feel nervous in the exam? If you do, just try us Salesforce-Certified-Administrator study materials, we will release your nerves as well build up your confidence for the exam. Salesforce-Certified-Administrator Soft test engine can stimulate the real exam environment, so that you can know the procedure of the real exam, and your nervous will be relieved. In addition, Salesforce-Certified-Administrator Study Materials are high quality, and they can help you pass the exam. They also contain both questions and answers, you can have a quickly check after practicing.
Salesforce-Certified-Administrator Reliable Test Cram: https://www.vceengine.com/Salesforce-Certified-Administrator-vce-test-engine.html
- Avail Marvelous Pdf Salesforce-Certified-Administrator Free to Pass Salesforce-Certified-Administrator on the First Attempt 🍀 ▷ [url]www.exam4labs.com ◁ is best website to obtain ➡ Salesforce-Certified-Administrator ️⬅️ for free download 🥂New Salesforce-Certified-Administrator Test Question[/url]
- Salesforce-Certified-Administrator Test Assessment 😫 Salesforce-Certified-Administrator Test Questions 😶 Latest Salesforce-Certified-Administrator Test Testking 🐬 The page for free download of ⇛ Salesforce-Certified-Administrator ⇚ on ⇛ [url]www.pdfvce.com ⇚ will open immediately 🔈New Salesforce-Certified-Administrator Test Question[/url]
- New Pdf Salesforce-Certified-Administrator Free | Pass-Sure Salesforce-Certified-Administrator Reliable Test Cram: Salesforce Certified Administrator 100% Pass 😩 Search for ( Salesforce-Certified-Administrator ) and download it for free immediately on ➥ [url]www.prepawaypdf.com 🡄 📬Salesforce-Certified-Administrator Exam Prep[/url]
- New Pdf Salesforce-Certified-Administrator Free | Pass-Sure Salesforce-Certified-Administrator Reliable Test Cram: Salesforce Certified Administrator 100% Pass 🎵 Enter ⏩ [url]www.pdfvce.com ⏪ and search for ☀ Salesforce-Certified-Administrator ️☀️ to download for free 🕯Salesforce-Certified-Administrator Test Assessment[/url]
- Avail Marvelous Pdf Salesforce-Certified-Administrator Free to Pass Salesforce-Certified-Administrator on the First Attempt 🖱 Immediately open ☀ [url]www.verifieddumps.com ️☀️ and search for ➤ Salesforce-Certified-Administrator ⮘ to obtain a free download 🌹Salesforce-Certified-Administrator Exam Preparation[/url]
- Professional Pdf Salesforce-Certified-Administrator Free - How to Download for Salesforce-Certified-Administrator Reliable Test Cram free 🧖 Search for ( Salesforce-Certified-Administrator ) and obtain a free download on { [url]www.pdfvce.com } 😹Salesforce-Certified-Administrator Latest Braindumps Sheet[/url]
- Test Salesforce-Certified-Administrator Result 🛴 Valid Salesforce-Certified-Administrator Test Guide 🐩 Salesforce-Certified-Administrator Test Questions 🥈 Search on ☀ [url]www.practicevce.com ️☀️ for ⇛ Salesforce-Certified-Administrator ⇚ to obtain exam materials for free download 🐛
DF Salesforce-Certified-Administrator VCE[/url] - Salesforce-Certified-Administrator Reliable Exam Sims 🍙 Exam Salesforce-Certified-Administrator Training 👛 Valid Salesforce-Certified-Administrator Dumps Demo 🌜 Search on ➥ [url]www.pdfvce.com 🡄 for ➠ Salesforce-Certified-Administrator 🠰 to obtain exam materials for free download 🚢Salesforce-Certified-Administrator Valid Braindumps Ebook[/url]
- Salesforce-Certified-Administrator Valid Braindumps Ebook 🍍 Salesforce-Certified-Administrator Test Questions ✅ Exam Salesforce-Certified-Administrator Training 📎 Search for ➽ Salesforce-Certified-Administrator 🢪 and download it for free on ( [url]www.dumpsmaterials.com ) website 🌰Salesforce-Certified-Administrator Reliable Exam Sims[/url]
- PDF Salesforce-Certified-Administrator VCE 🦧 Salesforce-Certified-Administrator Exam Prep 🎒 Salesforce-Certified-Administrator Test Questions 🚓 Open ✔ [url]www.pdfvce.com ️✔️ and search for ➡ Salesforce-Certified-Administrator ️⬅️ to download exam materials for free 📽Salesforce-Certified-Administrator Test Questions[/url]
- Avail Marvelous Pdf Salesforce-Certified-Administrator Free to Pass Salesforce-Certified-Administrator on the First Attempt 🥋 Search on “ [url]www.prepawaypdf.com ” for ➡ Salesforce-Certified-Administrator ️⬅️ to obtain exam materials for free download 🧬New Salesforce-Certified-Administrator Test Question[/url]
- www.stes.tyc.edu.tw, hashnode.com, www.stes.tyc.edu.tw, oneitech.com, kumu.io, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of VCEEngine Salesforce-Certified-Administrator dumps for free: https://drive.google.com/open?id=1o3z_NQhUrrFkePDUvTVawgaZa6rq_Maw
