Arch-301通過考試考題全覆蓋–高通過率的Salesforce Salesforce Certified B2B Solution Architect
Posted at 2/15/2026 12:18:43
PDFExamDumps提供的培訓資料和正式的考試內容是非常接近的。你經過我們短期的特殊培訓可以很快的掌握IT專業知識,為你參加考試做好準備。我們承諾將盡力幫助你通過Salesforce Arch-301 認證考試。
親愛的廣大考生,你有沒有想過參與任何Salesforce的Arch-301考試的培訓課程嗎?其實你可以採取措施一次通過認證,PDFExamDumps Salesforce的Arch-301考試題培訓資料是個不錯的選擇,本站虛擬的網路集訓和使用課程包涵大量你們需要的考題集,完全可以讓你們順利通過認證。
最新Arch-301題庫資訊 & Arch-301最新題庫PDFExamDumps 擬真試題覆蓋範圍可以達到近98%,含蓋PDF格式。成功的幫助你在短時間內通過 Arch-301 考試,取得 Salesforce 認證。我們的 Arch-301 擬真試題已經被很多考生使用,并得到了眾多的好評。而且現在購買還有機會贈送打折碼哦。作為臺灣地區最專業的IT認證題庫提供商,我們對所有購買 Arch-301 題庫的客戶提供跟蹤服務,在您購買後享受半年的免費升級考題服務。
最新的 Architect Exams Arch-301 免費考試真題 (Q85-Q90):問題 #85
Ohana Cirrus (OC) has around 1,500 support agents working in its global support center operating 24/7 across multiple channels. This center handles around 30,000 cases per day. OC currently uses a custom-developed solution to manage customer complaints and is planning to replace it with a new Salesforce solution. The current system contains more than 250 million records including some still being processed.
Which three recommendations should a Solution Architect suggest to migrate to the new application in the most efficient manner?
Choose 3 answers
- A. Use an EU tool that uses the Salesforce Bulk API to migrate the data from the legacy system to the new system.
- B. Migrate archived data to Heroku and active and semi-active data to Salesforce.
- C. Use an interface to copy data from the legacy complaint system to Salesforce using a scheduled MuleSoft batch.
- D. Use Deferred Sharing Calculations to avoid record sharing calculations during data migration.
- E. Migrate all complaint records m the Case object to provide a 360-degree customer view.
答案:A,B,D
解題說明:
* Data migration is the process of transferring data from one system toanother1.
* Data migration in Salesforce requires careful planning, preparation, and execution234.
* Data migration best practices include setting up a data governance plan, focusing on data quality, creating templates, verifying proper transfer, and using appropriate tools2356.
For Ohana Cirrus' transition to Salesforce from a custom solution, efficiently managing the migration of a large volume of complaint records is crucial. Migrating archived data to Heroku provides a scalable storage solution while keeping active and semi-active data in Salesforce ensures accessibility and integration with service processes. Using Deferred Sharing Calculations during migration helps maintain system performance by temporarily suspending real-time sharing rule calculations. Utilizing an ETL (Extract, Transform, Load) tool with Salesforce Bulk API facilitates efficient data transfer, minimizing system downtime and ensuring data integrity. This strategic approach to data migration aligns with Salesforce's best practices for handling large datasets and complex migrations, ensuring a smooth transition to the new Salesforce solution.
問題 #86
Universal Containers has recently provided its call center team the ability to troubleshoot issues coming from its B2B Commerce customers. Currently, the team utilises Service Cloud and, specifically, the Service Console. The CIO s concern is now different the experience will be as it relates to B2B Commerce for Visualforce versus what the team sees today within the Service Console.
Which recommendation should the Solution Architect voice to the CIO to ensure higher adoption by the call center team?
- A. Implement an embedded web view of B2B Commerce within the Service Console.
- B. Implement Experience Cloud login as user so that call center agents can log in as the buyer within B2B Commerce and see their cart.
- C. Implement the CSR flow so that call center agents can log m as the buyer within B2B Commerce and see their cart.
- D. Provide access to B2B Commerce data within the Service Console so they can see the cart.
答案:D
解題說明:
To ensure high adoption by the call center team and maintain consistency in their experience, providing direct access to B2B Commerce data, such as customer carts, within the Service Console is essential. This approach allows agents to view relevant B2B Commerce information seamlessly within their familiar Service Console environment, enabling efficient issue resolution and enhancing customer support. This solution leverages the integrated capabilities of Salesforce to unify customer data across platforms, aligning with best practices for a cohesive user experience and efficient service delivery.
問題 #87
Universal Containers (UC) is evaluating Salesforce for a Lead to Invoice solution, as its current process for getting payments from customers is incredibly laborious. UC knows now its current invoice process runs through its back-office ERP, and is unsure how it would work within a front-office tool going from a lead all the way to an invoice. UC is looking to purchase Revenue Cloud, Sales Cloud, Marketing Cloud Account engagement, and MuleSoft to work with its CRP. The CIO also wants to make sure UC is utilizing the data across these clouds in the most automated way possible without a lot of manual data intervention as is required today within its back- office CRP What should thesteps in the business process look like when creating a multi-cloud Lead to Invoice solution in Salesforce if UC's CRP will be the system of record for invoices?
- A. Lead, Opportunity, Quote, Order, Invoice, Payment, ERP
- B. Opportunity, Quote. Invoice, Payment, CRP
- C. Lead, Quote, Opportunity, Order, Invoice. ERP, Payment
- D. Lead, Opportunity, Quote, Order,ERP
答案:D
解題說明:
This option would follow the lead-to-invoice process that Salesforce Billing supports2, which involves creating an invoice from an order and then sending it to theERP system for payment processing. This option would also leverage Revenue Cloud and Sales Cloud features such as CPQ and Billing to automate and streamline the quoting and invoicing process.
Since UC's CRP will be the system of record for invoices, the order information will need to be passed to the back-office ERP for invoice creation and processing. Therefore, the business process should include Lead, Opportunity, Quote, Order, and then directly into the back-office ERP system. Payment processing can behandled within the back-office system or potentially integrated back into Salesforce with appropriate consideration for data security and compliance.
問題 #88
Universal Containers (UC) sells automotive spare parts through a large network of partner retail outlets. UC's business model relies on partners (retail outlets) reaching out toUC to get access to its product catalog, selecting the product(s) they require, and then making bulk purchases. The partners occasionally reach out to UC sales representatives for advice or clarifications regarding particular SKUs on an opportunity on which they are co-sellers.
UC wants to offer discounts to partners who make large purchases. Further, UC wants to provide its partners with reports detailing their sales, including reports that summarize sales by partner, to help UC classify its partners accordingly.
Which solution should a Solution Architect recommend to meet UC's requirements?
- A. Sales Cloud, B2B Commerce, and Customer Community
- B. Sales Cloud, B2B Commerce, and Partner Relationship Management
- C. Sales Cloud, Service Cloud, and Partner Relationship Management
- D. Sales Cloud, Partner Relationship Management, and Einstein
答案:B
解題說明:
Sales Cloud provides the CRM capabilities needed to track opportunities and sales processes, B2B Commerce provides the platform for partners to make bulk purchases, and Partner Relationship Management (PRM) enables the management of partner relationships, including offering discounts for large purchases and providing reports to partners. This integrated solution meets all of UC's requirements for sales, bulk purchasing, and partner management. Salesforce documentation supports the use of PRM alongside Sales Cloud and B2B Commerce for managing complex partner relationships and sales processes.
問題 #89
Northern Trail Outfitters (WO) istransforming its service experience. NTO has created a RACI matrix to understand the key stakeholders' responsibilities for activities and decisions during a Salesforce Field Service discovery workshop.
Which three NTO stakeholders should a Solution Architect recommend be defined as Consulted during the discovery workshop?
Choose 3 answers
- A. NTO employee representing a typical customer
- B. Field Service Manager
- C. Business Analyst
- D. Field Service Agent
- E. Project Manager
答案:B,C,D
解題說明:
During the discovery workshop for Salesforce Field Service, consulting with the Field Service Manager, Business Analyst, and Field Service Agent is essential. The Field Service Manager provides insight into operational needs and challenges, the Business Analyst contributes an understanding of technical requirements and process optimizations, and the Field Service Agent offers a frontline perspective on service delivery and customer interactions. Involving these stakeholders ensures that the solution architect gathers comprehensive insights into the service operations, aligning the Salesforce Field Service implementation with the actual needs and workflows of the organization, consistent with Salesforce's best practices for stakeholder engagement in discovery sessions.
問題 #90
PDFExamDumps Salesforce 的 Arch-301 題庫全面更新,是全球暢銷書籍、讀者公認 Salesforce 認證考試必備參考書。能讓您充滿信心地面對 Salesforce Arch-301 認證考試。這更新版反映了 Salesforce 考試的最新變動, 不僅涵蓋了各項重要問題, 還加上了最新的考試知識。你的第一次嘗試使用我們的 Arch-301 的培訓材料,這可能會極大地促進你的事業打開新的視野的就業機會。
最新Arch-301題庫資訊: https://www.pdfexamdumps.com/Arch-301_valid-braindumps.html
一般的Salesforce 最新Arch-301題庫資訊認證考試是IT專家利用專業經驗研究出來的考試題和答案,通過看書,我們學會一個Arch-301知識點很容易就能實現,但想要運用它來解決實際問題就會非常難,Salesforce Arch-301通過考試 因為只有這樣你才能更好地準備考試,PDFExamDumps 最新Arch-301題庫資訊會給你很好的指導,能確保你通過考試,只要您選擇了訂購PDFExamDumps Arch-301考試題庫參考資料,PDFExamDumps將竭盡所能為您提供最優服務,PDFExamDumps感到最自豪的是能幫助考生通過很難的Salesforce Arch-301考試,我們過去五年的成功率極高,可以讓您在職業生涯里有更好的發展前景,讓你無障礙通過Salesforce的Arch-301考試認證。
可惜他們不知道,自己根本不會在乎他們,柳傳雄面色壹冷,厲聲喝道,一般的Salesforce認證考試是IT專家利用專業經驗研究出來的考試題和答案,通過看書,我們學會一個Arch-301知識點很容易就能實現,但想要運用它來解決實際問題就會非常難。
最實用的Arch-301認證考試的參考資料因為只有這樣你才能更好地準備考試,PDFExamDumps會給你很好的指導,能確保你通過考試,只要您選擇了訂購PDFExamDumps Arch-301考試題庫參考資料,PDFExamDumps將竭盡所能為您提供最優服務。
- 最新Arch-301考題 🪑 Arch-301考試資訊 🎒 Arch-301指南 🐎 到( [url]www.pdfexamdumps.com )搜索{ Arch-301 }輕鬆取得免費下載Arch-301考題套裝[/url]
- Arch-301題庫 🐃 Arch-301 PDF 🧄 Arch-301指南 👱 透過➽ [url]www.newdumpspdf.com 🢪輕鬆獲取▛ Arch-301 ▟免費下載Arch-301試題[/url]
- 最新Arch-301考題 🦑 Arch-301指南 📿 Arch-301考試資訊 💄 立即打開{ tw.fast2test.com }並搜索⮆ Arch-301 ⮄以獲取免費下載Arch-301證照指南
- Arch-301通過考試:Salesforce Certified B2B Solution Architect確定通過考試,Salesforce 最新Arch-301題庫資訊 🐢 到➤ [url]www.newdumpspdf.com ⮘搜尋✔ Arch-301 ️✔️以獲取免費下載考試資料最新Arch-301考題[/url]
- Arch-301通過考試:Salesforce Certified B2B Solution Architect確定通過考試,Salesforce 最新Arch-301題庫資訊 🎮 開啟⇛ tw.fast2test.com ⇚輸入▷ Arch-301 ◁並獲取免費下載Arch-301考題免費下載
- 高效的Arch-301通過考試 |高通過率的考試材料|精心準備的最新Arch-301題庫資訊 🐠 開啟▶ [url]www.newdumpspdf.com ◀輸入☀ Arch-301 ️☀️並獲取免費下載最新Arch-301考題[/url]
- Arch-301題庫下載 🎽 Arch-301考題免費下載 🥒 最新Arch-301題庫資訊 🏸 ➠ [url]www.vcesoft.com 🠰最新➽ Arch-301 🢪問題集合Arch-301考題寶典[/url]
- 最真實的Arch-301考古題 🐶 ▷ [url]www.newdumpspdf.com ◁上搜索「 Arch-301 」輕鬆獲取免費下載Arch-301考題寶典[/url]
- 實用的Arch-301通過考試擁有模擬真實考試環境與場境的軟件VCE版本和確定通過的最新Arch-301題庫資訊 🏏 到“ [url]www.newdumpspdf.com ”搜尋⏩ Arch-301 ⏪以獲取免費下載考試資料Arch-301考試資訊[/url]
- Arch-301考題免費下載 ℹ Arch-301通過考試 🚎 Arch-301考題寶典 🙃 來自網站⮆ [url]www.newdumpspdf.com ⮄打開並搜索✔ Arch-301 ️✔️免費下載Arch-301考試資訊[/url]
- Arch-301題庫更新資訊 👋 Arch-301考題寶典 🍺 Arch-301題庫下載 ⛺ 透過☀ [url]www.newdumpspdf.com ️☀️搜索➤ Arch-301 ⮘免費下載考試資料免費下載Arch-301考題[/url]
- padhaipar.eduquare.com, learn-step.com, bbs.t-firefly.com, camanda.academy, nextlevel.com.bd, dl.instructure.com, www.stes.tyc.edu.tw, www.athworthacademy.in, courses.g-race.in, www.stes.tyc.edu.tw, Disposable vapes
