[General] IDP Valid Exam Practice | New IDP Practice Questions
85
General IDP Valid Exam Practice | New IDP Practice Questions
Posted at 2/15/2026 14:53:01      View142 | Replies1        Print      Only Author   [Copy Link] 1#
Dear customers, if you are prepared to take the exam with the help of excellent IDP learning materials on our website, the choice is made brilliant. Our IDP training materials are your excellent choices, especially helpful for those who want to pass the exam without bountiful time and eager to get through it successfully. Let us take a try of our amazing IDP Exam Questions and know the advantages first!
PDFBraindumps also has a CrowdStrike Practice Test engine that can be used to simulate the genuine IDP exam. This online practice test engine allows you to answer questions in a simulated environment, giving you a better understanding of the exam's structure and format. With the help of this tool, you may better prepare for the CrowdStrike Certified Identity Specialist(CCIS) Exam (IDP) test.
New IDP Practice Questions | New Guide IDP FilesOur experts have the best experience of developing and compiling the content and the displays of the IDP exam questions. Hence, they have created three different versions of the IDP study guide for you to choose: the PDF,Software and APP online which offered by us to provide you practice at any time and condition. All these three versions of our IDP Training Materials contain the best information you require to prapare and pass the exam. Don't hesitate, our IDP practice engine won't let you down!
CrowdStrike Certified Identity Specialist(CCIS) Exam Sample Questions (Q29-Q34):NEW QUESTION # 29
Which of the following Falcon rolesCANNOTenable and disable policy rules?
  • A. Identity Protection Administrator
  • B. Identity Protection Domain Administrator
  • C. Falcon Administrator
  • D. Identity Protection Policy Manager
Falcon Identity Protection enforcesrole-based access control (RBAC)to ensure that only authorized users can create, modify, or manage policy rules. Policy rules directly impact identity enforcement actions, making proper role separation critical.
According to the CCIS documentation, the ability toenable and disable policy rulesis granted to theIdentity Protection Policy Managerand theFalcon Administratorroles. These roles are explicitly designed to manage enforcement logic, triggers, and automated identity controls.
TheIdentity Protection Domain Administratorrole, however, is limited todomain-level visibility and management, such as reviewing domain configurations, monitoring risks, and assessing posture. This role doesnothave permissions to modify or control policy enforcement behavior.
This separation prevents accidental or unauthorized changes to identity enforcement rules. Therefore,Option Ais the correct and verified answer.
NEW QUESTION # 30
By using compromised credentials, threat actors are able to bypass theExecutionphase of the MITRE ATT&CK framework and move directly into:
  • A. Weaponization
  • B. Discovery
  • C. Initial Access
  • D. Lateral Movement
The CCIS curriculum highlights a critical identity-security concept: when attackers usecompromised credentials, they often bypass traditional malware-based attack phases, including theExecutionphase of the MITRE ATT&CK framework. Because no malicious code needs to be executed, attackers can immediately begin interacting with the environment as a legitimate user.
As a result, threat actors move directly into theDiscoveryphase. During Discovery, attackers enumerate users, groups, privileges, systems, domain relationships, and trust paths to understand the environment and plan further actions. This behavior is commonly observed in identity-based attacks and living-off-the-land techniques.
Falcon Identity Protection is specifically designed to detect this behavior by monitoring authentication traffic, privilege usage, and anomalous identity activity-areas where traditional EDR tools may have limited visibility.
The other options are incorrect:
* Initial Access has already occurred via credential compromise.
* Weaponization and Execution are not required.
* Lateral Movement typically follows Discovery.
Because compromised credentials allow attackers to jump straight intoDiscovery,Option Cis the correct and verified answer.
NEW QUESTION # 31
Which option can be selected from the Threat Hunter menu to open the current Threat Hunter query in a new window as Graph API format?
  • A. Open Query in API Builder
  • B. Save as Custom Report
  • C. Export to API Builder
  • D. Save as Custom Query
Falcon Threat Hunter provides a direct integration with theAPI Builderto support advanced investigation workflows and automation. According to the CCIS curriculum, analysts can take an existing Threat Hunter query and convert it into aGraphQL-compatible formatby selectingOpen Query in API Builderfrom the Threat Hunter menu.
This option opens the current query in a new window within API Builder, automatically translating the query structure into GraphQL syntax where applicable. This enables security teams to reuse validated hunting logic for automation, reporting, or external integrations without rewriting queries from scratch.
The other menu options serve different purposes:
* Export to API Builderis not a valid menu action.
* Save as Custom Querystores the query for reuse inside Threat Hunter.
* Save as Custom Reportgenerates a reporting artifact, not an API query.
BecauseOpen Query in API Builderis the only option that opens the query in GraphQL format in a new window,Option Dis the correct and verified answer.
NEW QUESTION # 32
Which of the following IDaaS connectors will allow Identity to ingest cloud activity along with applying SSO Policy?
  • A. Azure NPS
  • B. Okta SSO
  • C. ADFS
  • D. SAML
Falcon Identity Protection integrates withIdentity-as-a-Service (IDaaS)providers to ingest cloud authentication activity and enforce identity-based policies. According to the CCIS curriculum,Okta SSOis a supported IDaaS connector that enables Falcon to ingestcloud authentication eventswhile also applying Single Sign-On (SSO) policies.
Okta SSO provides rich identity telemetry, including login attempts, device context, and authentication outcomes. This data allows Falcon Identity Protection to correlate on-premises and cloud-based identity activity, extending identity risk analysis beyond Active Directory.
* ADFSis an on-premises federation service, not a cloud IDaaS.
* Azure NPSis used for RADIUS-based MFA, not SSO ingestion.
* SAMLis a protocol, not an IDaaS connector.
Because Okta SSO provides both cloud activity ingestion and SSO enforcement,Option Bis the correct and verified answer.
NEW QUESTION # 33
The NIST SP 800-207 framework for Zero Trust Architecture defines validation and authentication standards for users in which network locations?
  • A. Only those users accessing the network remotely over VPN
  • B. All users both inside and outside of the network
  • C. Only those users outside the network
  • D. Only those users inside the network
TheNIST SP 800-207 Zero Trust Architectureframework fundamentally rejects the concept of implicit trust based on network location. As outlined in both NIST guidance and reinforced in the CCIS curriculum,all users must be continuously validated and authenticated regardless of whether they are inside or outside the network perimeter.
Zero Trust assumes that threats can originate from anywhere, including internal networks. Therefore, authentication and authorization decisions must be made dynamically using identity, device posture, behavior, and risk signals-not network placement.
Falcon Identity Protection aligns directly with this principle by continuously evaluating identity behavior for all users, whether they authenticate from internal corporate networks, remote locations, or cloud environments.
Because Zero Trust applies universally,Option Cis the correct and verified answer.
NEW QUESTION # 34
Now, our IDP exam questions have gained wide popularity among candidates. Almost all customers are willing to introduce our IDP practice quiz to their classmates and friends. And sometimes, they may buy our exam products together. After they have tried our study materials, most of them have successfully passed the IDP Exam and made a lot of money. There are a lot of the feedbacks that they have left on our website to praise the good quality of our exam materials.
New IDP Practice Questions: https://www.pdfbraindumps.com/IDP_valid-braindumps.html
When qualified by the IDP certification, you will get a good job easily with high salary, But our IDP real exam is high efficient which can pass the IDP exam during a week, Want to pass in IDP, CrowdStrike IDP Valid Exam Practice If you want to get a higher salary or a promotion on your position, you need to work harder, As long as you are determined to succeed, our IDP study quiz will be your best reliance.
High-quality, bright staff all working to the same set of IDP methods was the cornerstone of Arthur Andersen  Co.s early success and a formula for growth and profitability.
It gives you the rules in simple and concise language so that armed with IDP Free Pdf Guide this information, you can make an intelligent and confident decision as to whether annuities should be a part of your retirement planning.
Free PDF Quiz Unparalleled CrowdStrike - IDP - CrowdStrike Certified Identity Specialist(CCIS) Exam Valid Exam PracticeWhen qualified by the IDP Certification, you will get a good job easily with high salary, But our IDP real exam is high efficient which can pass the IDP exam during a week.
Want to pass in IDP, If you want to get a higher salary or a promotion on your position, you need to work harder, As long as you are determined to succeed, our IDP study quiz will be your best reliance.
Posted at 2/19/2026 17:05:23        Only Author  2#
Thank you for sharing such a powerful article! Wishing you all the best on your exams! Free New NCSF-CPT test fees in global questions available now!
