Latest Test JN0-481 Discount, Braindumps JN0-481 Downloads
Posted at 2/15/2026 15:31:30      View:71 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-481 dumps are available on Google Drive shared by VerifiedDumps: https://drive.google.com/open?id=1qHWM0GNO_pIMDeyov1NghyXVmfgsg5U2
With the rapid development of the world economy and frequent contacts between different countries, the talent competition is increasing day by day, and the employment pressure is also increasing day by day. If you want to get a better job and relieve your employment pressure, it is essential for you to get the JN0-481 Certification. However, due to the severe employment situation, more and more people have been crazy for passing the JN0-481 exam by taking examinations, and our JN0-481 exam questions can help you pass the JN0-481 exam in the shortest time with a high score.
Availability in different formats is one of the advantages valued by Data Center, Specialist (JNCIS-DC) test candidates. It allows them to choose the format of Juniper JN0-481 Dumps they want. They are not forced to buy one format or the other to prepare for the Juniper JN0-481 Exam. VerifiedDumps designed Data Center, Specialist (JNCIS-DC) exam preparation material in Juniper JN0-481 PDF and practice test (online and offline). If you prefer PDF Dumps notes or practicing on the Juniper JN0-481 practice test software, use either.
Juniper - JN0-481 - The Best Latest Test Data Center, Specialist (JNCIS-DC) DiscountThere have been tens of thousands of our loyal customers who chose to buy our JN0-481 exam quetions and get their certification. These people have already had a good job opportunity and are running on their way to fulfilling their dreams after using JN0-481 practice quiz! Want to be like them, you must also act! Time and tide wait for no man. And you can free download the demos of the JN0-481 study guide, you can have a try before purchase.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q45-Q50):NEW QUESTION # 45
What is the function of the Revert button in the Juniper Apstra Ul?
  • A. The Revert button will undo the last change made to the configuration.
  • B. The Revert button will rollback to the previous configuration of a specified device.
  • C. The Revert button performs a rollback 0 on Juniper devices in the fabric.
  • D. The Revert button deletes any uncommitted changes within Apstra.
The Revert button is located on the Uncommitted tab of the blueprint page. The Uncommitted tab shows the changes that have been staged but not yet committed to the network. The Revert button allows you to discard any uncommitted changes and revert to the last committed state of the blueprint. This is useful if you want to cancel the changes that you have made or if you want to start over with a fresh slate.
NEW QUESTION # 46
You are working with a three-stage IP fabric using EBGP for peering. In this scenario, which two actions are required to implement ECMP? (Choose two.)
  • A. Use a load balancing policy applied lo BGP as an import policy.
  • B. Use a load balancing policy applied to BGP as an export policy.
  • C. Use the multipath multiple-as BGP parameter.
  • D. Use a load balancing policy applied to the forwarding table as an export policy.
To implement ECMP in IP fabric using EBGP, you need to enable BGP to install multiple equal- cost paths in the routing table and to advertise them to the peers.
NEW QUESTION # 47
Which two statements ate correct about the graph query output shown in the exhibit? (Choose two.)
  • A. The interface has an IP address assigned to it.
  • B. The interface has tags assigned to it.
  • C. The switch in the output is a Juniper device.
  • D. The output shows a LAG connection.
The graph query output shown in the exhibit is a JSON representation of an interface node and its properties in the Apstra graph database. Based on the output, we can infer the following statements:
The output shows a LAG connection. This is true because the interface node has a property called lag_mode which is set to lacp_active, indicating that the interface is part of a link aggregation group (LAG) that uses the Link Aggregation Control Protocol (LACP) to negotiate the link state and parameters.
The switch in the output is a Juniper device. This is true because the interface node has a property called if_name which is set to ae, indicating that the interface name follows the Juniper naming convention for aggregated Ethernet interfaces.
The interface has an IP address assigned to it. This is false because the interface node has properties called ipv4_addr and ipv6_addr which are both set to null, indicating that the interface does not have any IPv4 or IPv6 address configured.
The interface has tags assigned to it. This is false because the interface node has a property called tags which is set to null, indicating that the interface does not have any tags associated with it.
NEW QUESTION # 48
Which two statements are correct about Time Voyager? {Choose two.)
  • A. Time Voyager retains up to twenty-five saved revisions.
  • B. Time Voyager retains the five most recent blueprint commits.
  • C. Time Voyager retains all of the blueprint revisions from the last Juniper Apstra backup.
  • D. Time Voyager retains the last ten blueprint commits.
Time Voyager is a feature of Juniper Apstra that allows you to restore previous revisions of a blueprint, which is a logical representation of your network design and configuration. Time Voyager automatically saves the five most recent blueprint commits, which are the changes that you apply to the network. You can also manually save up to twenty-five revisions by keeping them, which prevents them from being overwritten by new commits.
NEW QUESTION # 49
Which two statements about ESI values are correct for the server connections to the fabric shown in the exhibit? (Choose two.)
  • A. A valid ESI value for Server A is 0x00.00.00.00.00.00.00.00.00.00.
  • B. A valid ESI value for Server B is 0x00.20.20.20.20.20.20.20.20.20.
  • C. A valid ESI value for Server A is 0x00.10.10.10.10.10.10.10.10.10.
  • D. A valid ESI value for Server B is 0x00.00.00.00.00.00.00.00.00.00.
To answer this question, we need to understand the concept of ESI values in EVPN LAGs. An ESI is a 10-byte value that identifies an Ethernet segment, which is a set of links that connect a multihomed device (such as a server) to one or more PE devices (such as leaf switches) in an EVPN network. The same ESI value must be configured on all the PE devices that connect to the same Ethernet segment. This allows the PE devices to form an EVPN LAG, which supports active-active or active-standby multihoming for the device. The ESI value can be manually configured (type 0) or automatically derived from LACP (type 1) or other methods. In the exhibit, Server A is connected to two leaf switches (QFX 5210) using a LAG with LACP enabled. Server B is connected to three leaf switches (QFX 5120) using a LAG with LACP enabled.
NEW QUESTION # 50
To attain all these you just need to enroll in the Juniper JN0-481 certification exam and put in all your efforts and prepare well to crack the Juniper JN0-481 exam easily. For the perfect and instant Juniper JN0-481 preparation, you can get help from Juniper JN0-481 Questions. The VerifiedDumps JN0-481 exam questions are real and will entirely assist you in JN0-481 exam preparation and you can easily pass the final Juniper JN0-481 certification exam.
Braindumps JN0-481 Downloads: https://www.verifieddumps.com/JN0-481-valid-exam-braindumps.html
You may have also seen on other sites related training materials, but will find their Source VerifiedDumps Braindumps JN0-481 Downloads of you carefully compare, They check the updating of JN0-481 advanced test engine every day and make sure the pdf study material customer bought is latest and valid, As you may know that the windows software of the JN0-481 study materials only supports windows operating system, They have built a clear knowledge frame in their minds before they begin to compile the JN0-481 actual test guide.
Assets will not save without a live connection JN0-481 to the Adobe Creative Cloud, My preference is to keep things online, but in a cvs repository, You may have also seen on other sites related Latest Test JN0-481 Discount training materials, but will find their Source VerifiedDumps of you carefully compare.
Free PDF Juniper - Unparalleled JN0-481 - Latest Test Data Center, Specialist (JNCIS-DC) DiscountThey check the updating of JN0-481 advanced test engine every day and make sure the pdf study material customer bought is latest and valid, As you may know that the windows software of the JN0-481 study materials only supports windows operating system.
They have built a clear knowledge frame in their minds before they begin to compile the JN0-481 actual test guide, By visit our website, the user can obtain an experimental demonstration, free after the user experience can choose the most appropriate and most favorite JN0-481 study materials download.
