[General] FCSS_SDW_AR-7.6 Training Materials: FCSS - SD-WAN 7.6 Architect & FCSS_SDW_A
117
【General】 FCSS_SDW_AR-7.6 Training Materials: FCSS - SD-WAN 7.6 Architect & FCSS_SDW_A
Posted at 2/15/2026 15:55:30      View:116 | Replies:0        Print      Only Author   [Copy Link] 1#
You can study FCSS_SDW_AR-7.6 exam engine anytime and anyplace for the convenience our three versions of our FCSS_SDW_AR-7.6 study questions bring. What is more, it is our mission to help you pass the exam. Our study materials will provide you with 100% assurance of passing the professional qualification FCSS_SDW_AR-7.6 Exam. We are very confident in the quality of FCSS_SDW_AR-7.6 guide dumps. Our pass rate is high as 98% to 100%. You can totally rely on us.
Fortinet FCSS_SDW_AR-7.6 Exam Syllabus Topics:
  • SD-WAN Basic Setup: This domain covers initial SD-WAN configuration, member and zone setup, and Performance SLA creation for link monitoring.
  • Advanced IPsec: This section covers hub-and-spoke topologies, ADVPN configuration, and scalable multihub and multiregion IPsec deployments.
  • Centralized Management: This domain addresses FortiManager-based SD-WAN deployment, branch configuration implementation, and overlay orchestration using SD-WAN Manager.
  • SD-WAN Troubleshooting: This domain focuses on diagnosing SD-WAN rule behavior, routing issues, and ADVPN tunnel problems.
Topic 5
  • Rules and Routing: This section focuses on configuring SD-WAN rules for traffic steering and routing policies for path selection and failover.
Pass Guaranteed Fortinet FCSS_SDW_AR-7.6 Fantastic Complete Exam DumpsIf you are preparing for the practice exam, we can make sure that the FCSS_SDW_AR-7.6 study materials from our company will be the best choice for you, and you cannot find the better study materials than our company’. There are a lot of advantages of our FCSS_SDW_AR-7.6 Study Materials, and then, I am going to introduce the special functions of our FCSS_SDW_AR-7.6 study materials in detail to you. We are hopeful that you will like our products.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q77-Q82):NEW QUESTION # 77
An MSSP uses FortiManager to manage the FortiGate devices of its customers. The administrator grouped the devices for each customer in different ADOMs. For customer A, you configured one SD-WAN overlay template that applies to all devices in the ADOM. For customer B, you configured SD-WAN for DIA at the device level, with a different configuration for each FortiGate. You onboard customer C, a car manufacturer, who requests to have a single-hub SD- WAN topology for its retail points, and a dual-hub topology for the FortiGate devices installed in its factories. Which statement best describes how you should handle this request?
  • A. You can place all the devices in the same ADOM and define two topologies with the SD-WAN overlay template.
  • B. You can place all the devices in the same ADOM and you can create multiple SD-WAN templates, but you cannot use the SD-WAN overlay template.
  • C. You can place all the devices in the same ADOM, but you must use the SD-WAN overlay template to define only one topology.
  • D. You must assign the devices to different ADOMs to avoid conflicts between the single-hub and dual-hub SD-WAN topologies.
FortiManager uses SD-WAN overlay templates per ADOM to define the SD-WAN topology.
Within a single ADOM, you can only define one SD-WAN overlay template topology that applies to all devices in that ADOM.
If different topologies are needed (e.g., single-hub for retail, dual-hub for factories), the devices cannot share multiple overlay topologies within the same ADOM.
Therefore, to handle multiple topologies, devices must be separated into different ADOMs or use separate device-level configurations outside the overlay template.
NEW QUESTION # 78
Refer to the exhibit, which shows an SD-WAN zone configuration on the FortiGate GUI. What can you conclude about the zone and member configuration on this device?
  • A. The underlay zone contains three members.
  • B. You can move HUB1-VPN3 from the HUB1 zone to the overlay-shops zone.
  • C. The overlay-factories zone contains no member.
  • D. You can delete the virtual-wan-link zones.
The VPN members under HUB1 (HUB1-VPN1, HUB1-VPN2, HUB1-VPN3) are all SD-WAN interfaces that can be reassigned to a different zone, such as overlay-shops. FortiGate allows reassigning members between zones.
NEW QUESTION # 79
Which statement best describe the role of the ADVPN device in handling traffic?
  • A. This is a spoke that has received a shortcut query from a remote hub.
  • B. This is a hub that has received a shortcut query from a spoke and has forwarded it to another spoke.
  • C. This is a hub, and two spokes, 192.2.0.1 and 10.0.3.101, establish a shortcut.
  • D. This is a spoke that has received a direct shortcut query from a remote spoke.
The log shows messages on HUB1-VPN1 where the device processes a SHORTCUT_QUERY and performs NAT hole punching (peer at 192.2.0.1:4500). This indicates that the device is acting as a hub, helping two spokes (192.2.0.1 and 10.0.3.101) establish a direct ADVPN shortcut tunnel between each other, instead of routing their traffic through the hub.
NEW QUESTION # 80
(Refer to the exhibit.
The administrator configured two SD-WAN rules to load balance traffic.
Which interfaces does FortiGate use to steer the traffic from 10.0.1.124 to 10.0.0.254? Choose one answer.)
  • A. FortiGate routes the traffic according to the FIB.
  • B. HUB1-VPN2
  • C. Any interface in the HUB1 or HUB2 zones
  • D. port1 or port2
NEW QUESTION # 81
An administrator is troubleshooting SD-WAN on FortiGate. A device behind branch1_fgt generates traffic to the 10.0.0.0/8 network.
The administrator expects the traffic to match SD-WAN rule ID 1 and be routed over HUB1-VPN1. However, the traffic is routed over HUB1-VPN3.
Based on the output shown in the exhibit, which two reasons, individually or together, could explain the observed behavior? (Choose two.)
  • A. HUB1-VPN3 has a lower route priority value (higher priority) than HUB1-VPN1.
  • B. The traffic matches a regular policy route configured with HUB1-VPN3 as the outgoing device
  • C. HUB1-VPN1 does not have a valid route to the destination
  • D. HUB1-VPN3 has a higher member configuration priority than HUB1-VPN1.
NEW QUESTION # 82
Compared with the education products of the same type, some users only for college students, some only provide for the use of employees, these limitations to some extent, the product covers group, while our FCSS_SDW_AR-7.6 research material absorbed the lesson, it can satisfy the different study period of different cultural levels of the needs of the audience. For example, if you are a college student, you can study and use online resources through the student column of our FCSS_SDW_AR-7.6 Study Materials, and you can choose to study in your spare time.
FCSS_SDW_AR-7.6 Reliable Test Bootcamp: https://www.examdumpsvce.com/FCSS_SDW_AR-7.6-valid-exam-dumps.html
