[General] AZ-104 Sample Questions Pdf & Latest AZ-104 Dumps Ppt
100
【General】 AZ-104 Sample Questions Pdf & Latest AZ-104 Dumps Ppt
Posted at 2/15/2026 17:11:21      View:146 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest VCE4Dumps AZ-104 PDF Dumps and AZ-104 Exam Engine Free Share: https://drive.google.com/open?id=1kSt1-rDVs5Gt106TTvVfBRf5pTyok_GU
If you want to enjoy the real exam environment, the software version of our AZ-104 exam questions will help you solve your problem, because the software version of our AZ-104 test torrent can simulate the real exam environment. The AZ-104 study materials from our company can help you get your certification easily, and if you use our AZ-104 Study Materials, it will be very easy for you to save a lot of time, we believe our AZ-104 learning guide will be the most suitable choice for you,
Passing the Microsoft AZ-104 Exam is a prerequisite for earning the Microsoft Certified: Azure Administrator Associate certification. Microsoft Azure Administrator certification is highly valued in the industry and can lead to better job opportunities and higher salaries. Microsoft Azure Administrator certification is valid for two years, and candidates can renew it by passing a recertification exam or completing a specific set of courses.
Latest AZ-104 Dumps Ppt | AZ-104 Trustworthy Exam TorrentThe Microsoft Azure Administrator (AZ-104) exam questions are real, valid, and verified by Microsoft AZ-104 certification exam trainers. They work together and put all their efforts to ensure the top standard and relevancy of AZ-104 Exam Dumps all the time. So we can say that with Microsoft AZ-104 exam questions you will get everything that you need to make the AZ-104 exam preparation simple, smart, and successful.
Microsoft Azure Administrator Sample Questions (Q16-Q21):NEW QUESTION # 16
You plan to move services from your on-premises network to Azure.
You identify several virtual machines that you believe can be hosted in Azure. The virtual machines are shown in the following table.
Which two virtual machines can you access by using Azure migrate? Each correct answer presents a complete solution.
  • A. Hou-NW01
  • B. NYC-FS01
  • C. Sea-CA01
  • D. Sea-DC01
  • E. BOS-DB01
Answer: B,E
Azure Migrate provides a centralized hub to assess and migrate to Azure on-premises servers, infrastructure, applications, and data. It provides the following:
- Unified migration platform: A single portal to start, run, and track your migration to Azure.
- Range of tools: A range of tools for assessment and migration. Azure Migrate tools include Azure Migrate: Discovery and assessment and Azure Migrate: Server Migration. Azure Migrate also integrates with other Azure services and tools, and with independent software vendor (ISV) offerings.
- Assessment and migration: In the Azure Migrate hub, you can assess and migrate:
Servers, databases, and web apps: Assess on-premises servers including web apps and SQL
Server instances and migrate them to Azure virtual machines or Azure VMware Solution (AVS) (Preview).
Databases: Assess on-premises databases and migrate them to Azure SQL Database or to
SQL Managed Instance.
Web applications: Assess on-premises web applications and migrate them to Azure App
Service.
Virtual desktops: Assess your on-premises virtual desktop infrastructure (VDI) and migrate it to
Windows Virtual Desktop in Azure.
Data: Migrate large amounts of data to Azure quickly and cost-effectively using Azure Data Box
products.
Based on this information let's analyze each option:
NYC-FS01 : Its role "Server" fall under above categories. Hence it can be accessed by using Azure migrate.
BOS-DB01 : Its role "server" fall under above categories. Hence it can be accessed by using Azure migrate.
Sea-CA01 : Its role "CA" does not fall under above categories. Hence it can not be accessed by using Azure migrate.
Hou-NW01 : Its role "DNS" does not fall under above categories. Hence it can not be accessed by using Azure migrate.
Sea-DC01 : Its role "DC" does not fall under above categories. Hence it can not be accessed by using Azure migrate.
https://docs.microsoft.com/en-us ... e-services-overview
NEW QUESTION # 17
You have a deployment template named Template1 that is used to deploy 10 Azure web apps.
You need to identify what to deploy before you deploy Template1. The solution must minimize Azure costs.
What should you identify?
  • A. one Azure Traffic Manager
  • B. 10 App Service plans
  • C. one Azure Application Gateway
  • D. five Azure Application Gateways
  • E. one App Service plan
Answer: E
You create Azure web apps in an App Service plan.
https://docs.microsoft.com/en-us ... rview-hosting-plans
NEW QUESTION # 18
You have an Azure subscription that contains a virtual network named VNet1. VNet1 contains four subnets named Gateway, Perimeter, NVA, and Production.
The NVA subnet contains two network virtual appliances (NVAs) that will perform network traffic inspection between the Perimeter subnet and the Production subnet.
You need to implement an Azure load balancer for the NVAs. The solution must meet the following requirements:
* The NVAs must run in an active-active configuration that uses automatic failover.
* The NVA must load balance traffic to two services on the Production subnet. The services have different IP addresses.
Which three actions should you perform? Each correct answer presents part of the solution.
  • A. Add two load balancing rules that have HA Ports enabled and Floating IP disabled
  • B. Add a frontend IP configuration, two backend pools, and a health probe
  • C. Add two load balancing rules that have HA Ports and Floating IP enabled
  • D. Deploy a basic load balancer
  • E. Deploy a standard load balancer
  • F. Add a frontend IP configuration, a backend pool, and a health probe
Answer: B,C,E
A standard load balancer is required for the HA ports.
Two backend pools are needed as there are two services with different IP addresses.
Floating IP rule is used where backend ports are reused.
Incorrect Answers:
E: HA Ports are not available for the basic load balancer.
https://docs.microsoft.com/en-us ... r-standard-overview
https://docs.microsoft.com/en-us ... r-multivip-overview
NEW QUESTION # 19
You have an Azure subscription that contains a user account named User1.
You need to ensure that User1 can assign a policy to the tenant root management group.
What should you do?
  • A. Assign the Global administrator role to User1, and then instruct User1 to configure access management for Azure resources.
  • B. Assign the Global administrator role to User1, and then modify the default conditional access policies.
  • C. Assign the Owner role to User1. and then modify the default conditional access policies.
  • D. Assign the Owner role to User1. and then instruct User1 to configure access management for Azure resources.
NEW QUESTION # 20
You are creating an Azure Kubernetes Services (AKS) cluster as shown in the following exhibit.
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic NOTE; Each correct selection is worth one point.
NEW QUESTION # 21
If you don't have an electronic product around you, or you don't have a network, you can use a printed PDF version of our AZ-104 training materials. We also strongly recommend that you print a copy of the PDF version of your AZ-104 study materials in advance so that you can use it as you like. And you can also take notes on the printale AZ-104 Exam Questions whenever you had a better understanding. Of course, which kind of equipment to choose to study will ultimately depend on your own preference.
Latest AZ-104 Dumps Ppt: https://www.vce4dumps.com/AZ-104-valid-torrent.html
P.S. Free & New AZ-104 dumps are available on Google Drive shared by VCE4Dumps: https://drive.google.com/open?id=1kSt1-rDVs5Gt106TTvVfBRf5pTyok_GU
Posted at 2/18/2026 12:46:28        Only Author  2#
This article is brilliant, thank you for this incredible share. The New testcollection SOL-C01 questions are shared for free. Good luck on your exams!
