[General] CAS-004 Valid Braindumps Ppt | Exam CAS-004 Collection
109
General CAS-004 Valid Braindumps Ppt | Exam CAS-004 Collection
Posted at 2/15/2026 18:06:56      View147 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA CAS-004 dumps are available on Google Drive shared by ExamsTorrent: https://drive.google.com/open?id=1b5czyfBV6U6X70BGjjDS-1VPSYIahN5p
Our CAS-004 exam preparation materials have a higher pass rate than products in the same industry. If you want to pass CAS-004 certification, then it is necessary to choose a product with a high pass rate. Our CAS-004 study materials guarantee the pass rate from professional knowledge, services, and flexible plan settings. The 99% pass rate is the proud result of our CAS-004 Study Materials. I believe that pass rate is also a big criterion for your choice of products, because your ultimate goal is to obtain CAS-004 certification.
CompTIA CAS-004 is a certification exam designed for IT professionals who are looking to validate their advanced-level security skills and knowledge. CAS-004 exam is called the CompTIA Advanced Security Practitioner (CASP+), and it is a globally recognized credential that demonstrates proficiency in the field of cybersecurity.
Exam CompTIA CAS-004 Collection - CAS-004 Reliable Test QuestionsExamsTorrent CompTIA CAS-004 exam preparation material is designed to help you pass the CompTIA CAS-004 exam on your first attempt. The formats mentioned above can be used right away after buying the product. So what are waiting for, get our CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) study material today and start your constructive progress towards your goals. The rest is assured by us when you give it your all.
CompTIA Advanced Security Practitioner (CASP+) Exam Sample Questions (Q617-Q622):NEW QUESTION # 617
Given the following log snippet from a web server:
Which of the following BEST describes this type of attack?
  • A. Cross-site scripting
  • B. Brute-force
  • C. SQL injection
  • D. Cross-site request forgery
NEW QUESTION # 618
A security administrator at a global organization wants to update password complexity rules for a system containing personally identifiable information. Which of the following would be the best resource for this information?
  • A. COPPA
  • B. NIST
  • C. CMMI
  • D. GDPR
Step by Step Explanation:
* NIST (National Institute of Standards and Technology): Provides comprehensive password guidelines (e.g., SP 800-63B) widely used for securing systems, including handling PII.
* GDPR (General Data Protection Regulation): Focuses on data privacy laws rather than technical password policies.
* CMMI (Capability Maturity Model Integration): Addresses process improvement, not password complexity.
* COPPA (Children's Online Privacy Protection Act): Focuses on child data privacy, not password rules.
Reference: CASP+ Exam Objectives 5.3 - Implement security controls and best practices using NIST standards.
NEW QUESTION # 619
After a server was compromised an incident responder looks at log files to determine the attack vector that was used The incident responder reviews the web server log files from the time before an unexpected SSH session began:
Which of the following is the most likely vulnerability that was exploited based on the log files?
  • A. A SQL injection was used during the ordering process to compromise the database server
  • B. The root password was easily guessed and used as a parameter lo open a reverse shell
  • C. Directory traversal revealed the hashed SSH password, which was used to access the server.
  • D. An outdated third-party PHP plug-in was vulnerable to a known remote code execution
The logs indicate a directory traversal attempt (/../..//.etc/shadow), which is a type of attack that exploits insufficient security validation/sanitization of user-supplied input file names, so that characters representing
"traverse to parent directory" are passed through to the file APIs. The /etc/shadow file on Unix systems contains password hashes. If an attacker successfully exploited this vulnerability, they could potentially access the hashed SSH password. This information could then be used to gain unauthorized access to the server if the hash was cracked.
NEW QUESTION # 620
An organization is planning for disaster recovery and continuity of operations.
INSTRUCTIONS
Review the following scenarios and instructions. Match each relevant finding to the affected host.
After associating scenario 3 with the appropriate host(s), click the host to select the appropriate corrective action for that finding.
Each finding may be used more than once.
If at any time you would like to bring back the initial state of the simulation, please click the Reset All button.
NEW QUESTION # 621
A company has decided that only administrators are permitted to use PowerShell on their Windows computers. Which of the following is the BEST way for an administrator to implement this decision?
  • A. Monitor the Application and Services Logs group within Windows Event Log.
  • B. Provide user education and training.
  • C. Uninstall PowerSheII from all workstations.
  • D. Block PowerSheII via HIDS.
  • E. Configure user settings in Group Policy.
Answer: E
Configuring user settings in Group Policy is the best way for an administrator to implement the decision to restrict PowerShell access to only administrators. Group Policy is a feature of Windows that allows administrators to manage and enforce settings for users and computers in a domain. By using Group Policy, an administrator can create a policy that blocks or disables PowerShell for all users except for a particular group, such as administrators. This policy can be applied to all computers in the domain or to specific organizational units. This method is more effective and manageable than uninstalling PowerShell, monitoring event logs, providing user education, or blocking PowerShell via HIDS. Verified Reference:
https://www.windowscentral.com/how-disable-powershell-windows-10
https://learn.microsoft.com/en-u ... all-users-except-fo
https://windowsloop.com/block-disable-powershell/
NEW QUESTION # 622
So no matter what kinds of CAS-004 Test Torrent you may ask, our after sale service staffs will help you to solve your problems in the most professional way. Since our customers aiming to CAS-004 study tool is from different countries in the world, and there is definitely time difference among us, we will provide considerate online after-sale service twenty four hours a day, seven days a week, please just feel free to contact with us anywhere at any time.
Exam CAS-004 Collection: https://www.examstorrent.com/CAS-004-exam-dumps-torrent.html
DOWNLOAD the newest ExamsTorrent CAS-004 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1b5czyfBV6U6X70BGjjDS-1VPSYIahN5p
Posted at 2/24/2026 08:04:46        Only Author  2#
Xhs1991ǤPMIPMI-PBA-JPN}ُ뤹趨Τ뤪͘ϺΤ|С饤֥åȤȤ`ȤҡTϴäƤ|؏ͤޤȻُ뤷ᡢʤϤɤɆȡΡ˶˷ǤޤʤŤZӭƤޤʤФ줤`ӥṩǤΤҡҤǤ
