ITCertMagic VMware 2V0-13.25 Questions PDF Format
Posted at 2/15/2026 18:27:04
View153
Replies2
We are aimed to improve customer satisfaction and always put customers first. Our experts check daily whether there is an update to the VMware Cloud Foundation 9.0 Architect torrent prep, and if there is an update system, we will automatically send it to you. So it can guarantee latest knowledge and keep up with the pace of change. Many people are worried that online shopping electronics have viruses. But you dont have to worry about our products. Our 2V0-13.25 Exam Questions are absolutely safe and virus-free. If you have any questions during the installation process, we will arrange professional staff on guidance of your installation and use. We always put your needs first.
Quality of 2V0-13.25 practice materials you purchased is of prior importance for consumers. Our 2V0-13.25 practice materials make it easier to prepare exam with a variety of high quality functions. Their quality function is observably clear once you download them. We have three kinds of 2V0-13.25 practice materials moderately priced for your reference. All these three types of 2V0-13.25 practice materials win great support around the world and all popular according to their availability of goods, prices and other term you can think of.
Pass Guaranteed VMware - The Best 2V0-13.25 - Pdf Demo VMware Cloud Foundation 9.0 Architect DownloadAre you planning to appear in the VMware Cloud Foundation 9.0 Architect (2V0-13.25) certification test and need to know where to get updated practice questions? Then you are at the right place because VMware Cloud Foundation 9.0 Architect (2V0-13.25) has made the learning material for the applicants to prepare successfully for the certfication exam in a short time.
VMware Cloud Foundation 9.0 Architect Sample Questions (Q40-Q45):NEW QUESTION # 40
Which statement would the architect document as a design decision within the logical design?
- A. Service Levels will align with the defined Business Impact Analysis findings.
- B. The VMware Distributed Resource Scheduler (DRS) latency sensitivity value will be set to high for the workload cluster.
- C. The solution must provide the ability to patch an existing template.
- D. vSphere High Availability (HA) will be enabled.
NEW QUESTION # 41
What is the primary purpose of VMware's Distributed Resource Scheduler (DRS)?
- A. Optimize resource allocation
- B. Configure storage policies
- C. Monitor VM performance
- D. Enable high availability
DRS optimizes resource allocation across cluster hosts.
NEW QUESTION # 42
A VMware Cloud Foundation (VCF) architect is planning for the expansion of an existing VCF instance.
The existing VCF instance is deployed with a single workload domain. The number of ESXi hosts has grown to the maximum number the existing vCenter can support.
Which design decision would the architect need to make to allow the existing VCF Instance to add more ESXi hosts?
- A. Deploy a second VCF Instance within the existing VCF Fleet
- B. Deploy a second workload domain within the existing VCF Instance
- C. Deploy a second cluster within the existing vCenter
- D. Deploy a second vCenter server appliance within the existing workload domain
Asingle workload domain in VCFmaps to a single vCenter instance. When the host limit for that vCenter is reached (typically ~1000 hosts per vCenter), thecorrect and supported scale-out designis to deploy asecond VI workload domain, which comes with its own dedicated vCenter instance, allowing continued expansion without affecting the existing domain.
Reference:VMware Cloud Foundation 9.0 Design Guide - Workload Domain Scaling ConsiderationsVMware Configuration Maximums for vCenter Server
NEW QUESTION # 43
A customer has stated the following requirements for Aria Automation within their VCF implementation:
Users must have access to specific resources based on their company organization.
Developers must only be able to provision to the Development environment.
Production workloads can be placed on DMZ or Production clusters.
What two design decisions must be implemented to satisfy these requirements? (Choose two.)
- A. Separate cloud zones will be configured for Development and Production.
- B. Users' access to resources will be controlled by tenant membership.
- C. Users' access to resources will be controlled by project membership.
- D. Separate tenants will be configured for Development and Production.
In VMware Cloud Foundation (VCF) 5.2, Aria Automation (formerly vRealize Automation) manages resource provisioning and access control. The requirements involve role-based access, environment isolation, and workload placement flexibility. Let's analyze each option:
Option A: Separate tenants will be configured for Development and Production Aria Automation in VCF 5.2 operates as a single-tenant application by default, integrated with SDDC Manager and vCenter. Multi-tenancy (separate tenants) is an advanced configuration typically used for service providers, not standard VCF private cloud designs. The VMware Aria Automation Installation Guide notes that multi-tenancy adds complexity and isn't required for environment segregation within a single organization. Instead, projects and cloud zones handle these needs, making this unnecessary.
Option B: Users' access to resources will be controlled by tenant membership Tenant membership applies in multi-tenant setups, where users are assigned to distinct tenants (e.g., Dev vs. Prod). Since VCF 5.2 typically uses a single tenant, and the requirements can be met with projects (group-based access), this isn't a must-have decision. The VCF 5.2 Architectural Guide favors project-based access over tenant separation for organizational control, rendering this optional.
Option C: Users' access to resources will be controlled by project membership Projects in Aria Automation group users and define their access to resources (e.g., cloud zones, policies). To meet the first requirement (access based on company organization) and the second (developers provisioning only to Development), projects can restrict developers to a "Dev" project linked to a Development cloud zone, while other teams (e.g., ops) access Production/DMZ via separate projects. The VMware Aria Automation Administration Guide confirms projects as the primary mechanism for role-based access in VCF, making this a required decision.
Option D: Separate cloud zones will be configured for Development and Production Cloud zones in Aria Automation map to vSphere clusters or resource pools (e.g., Development, Production, DMZ clusters). To satisfy the second requirement (developers limited to Development) and the third (Production workloads on DMZ or Production clusters), separate cloud zones ensure environment isolation and placement flexibility. The VCF 5.2 Architectural Guide mandates cloud zones for workload segregation, tying them to projects for access control, making this essential.
Conclusion:
C: Project membership enforces user access per organization and restricts developers to Development, meeting the first two requirements.
D: Separate cloud zones isolate Development from Production/DMZ, enabling precise workload placement per the third requirement.
These decisions align with Aria Automation's design in VCF 5.2.
Reference: VMware Cloud Foundation 5.2 Architectural Guide (docs.vmware.com): Aria Automation Design and Cloud Zones.
VMware Aria Automation Administration Guide (docs.vmware.com): Projects and Access Control.
VMware Aria Automation Installation Guide (docs.vmware.com): Tenancy Options in VCF.
NEW QUESTION # 44
During a requirements gathering workshop, several Business and Technical requirements were captured from the customer.
Which requirement will be classified as a Business Requirement?
- A. Reduce processing time for service requests by 30%.
- B. Data must be encrypted using AES-256 encryption.
- C. The system must support 10,000 concurrent users.
- D. The application must be compatible with Windows, macOS, and Linux operating systems.
In VMware's design methodology (aligned with VCF 5.2), requirements are categorized as Business Requirements (goals tied to organizational outcomes, often non-technical) or Technical Requirements (specific system capabilities or constraints). Let's classify each option:
Option A: Reduce processing time for service requests by 30%
This is a Business Requirement. It focuses on a business outcome-improving service request efficiency by a measurable percentage-without specifying how the system achieves it. The VMware Cloud Foundation 5.2 Architectural Guide classifies such high-level, outcome-driven goals as business requirements, as they reflect the customer's operational or strategic priorities rather than technical implementation details.
Option B: The system must support 10,000 concurrent users
This is a Technical Requirement. It specifies a measurable system capability (supporting 10,000 concurrent users), directly tied to performance and capacity. VMware documentation treats such quantifiable system behaviors as technical, focusing on "what" the system must do functionally.
Option C: Data must be encrypted using AES-256 encryption
This is a Technical Requirement. It mandates a specific technical implementation (AES-256 encryption) for security, a non-functional attribute. The VCF 5.2 Design Guide categorizes encryption standards as technical constraints or requirements, not business goals.
Option D: The application must be compatible with Windows, macOS, and Linux operating systems This is a Technical Requirement. It defines a functional capability-cross-platform compatibility- specifying technical details about the system's operation. VMware classifies such compatibility needs as technical, per the design methodology.
Conclusion:
Option A is the Business Requirement, as it aligns with a business goal (efficiency improvement) rather than a technical specification.
Reference: VMware Cloud Foundation 5.2 Architectural Guide (docs.vmware.com): Section on Requirements Gathering and Classification.
VMware Cloud Foundation 5.2 Design Guide (docs.vmware.com): Business vs. Technical Requirements.
NEW QUESTION # 45
If you like to practice 2V0-13.25 exam dumps on paper, you should choose us. Our 2V0-13.25 PDF version is printable, and you can print them into hard one and take some notes on them. Therefore you can study in anytime and at anyplace. Besides, free demo is available for 2V0-13.25 PDF version, and you can have a try before buying. After your payment, you can receive the downloading link and password for 2V0-13.25 Exam Dumps within ten minutes, and if you dont receive, you can contact us, we will solve the problem for you as quickly as possible.
2V0-13.25 Pass Test Guide: https://www.itcertmagic.com/VMware/real-2V0-13.25-exam-prep-dumps.html
Also if you order our 2V0-13.25 exam guide we will serve for you one year, It is not difficult thing to obtain 2V0-13.25 Certification with our help, If you are interested in 2V0-13.25 exams questions and answers we DumpExams will be your best choice, It is well known that VMware 2V0-13.25 passleader vce exam is an international recognition certification test, which is equivalent to a passport to enter a higher position, VMware Pdf Demo 2V0-13.25 Download It is done to erase the confusion among the students that is to whether to use their services or not.
Just Following Orders, This Fall you'll also be able to import document files directly from iCloud with the tap of an icon, Also if you order our 2V0-13.25 Exam Guide we will serve for you one year.
2026 Pdf Demo 2V0-13.25 Download | Pass-Sure VMware Cloud Foundation 9.0 Architect 100% Free Pass Test GuideIt is not difficult thing to obtain 2V0-13.25 Certification with our help, If you are interested in 2V0-13.25 exams questions and answers we DumpExams will be your best choice.
It is well known that VMware 2V0-13.25 passleader vce exam is an international recognition certification test, which is equivalent to a passport to enter a higher position.
It is done to erase the confusion 2V0-13.25 among the students that is to whether to use their services or not.
- 2V0-13.25 Exam Duration 🧲 Latest 2V0-13.25 Exam Tips 🎲 2V0-13.25 Pdf Torrent 🤣 Go to website [url]www.practicevce.com open and search for ▛ 2V0-13.25 ▟ to download for free 🗣Latest 2V0-13.25 Test Materials[/url]
- Hot Pdf Demo 2V0-13.25 Download | Efficient 2V0-13.25: VMware Cloud Foundation 9.0 Architect 100% Pass 🦊 Easily obtain [ 2V0-13.25 ] for free download through [url]www.pdfvce.com 🦖Latest 2V0-13.25 Test Materials[/url]
- 2V0-13.25 Detail Explanation 🧒 Exam 2V0-13.25 Tests 🦯 Exam 2V0-13.25 Passing Score 🥌 Search for 2V0-13.25 and download exam materials for free through ➠ [url]www.dumpsmaterials.com 🠰 🏓2V0-13.25 Pdf Torrent[/url]
- 2V0-13.25 Exam Preview 🎉 Practice 2V0-13.25 Questions 🩱 Certification 2V0-13.25 Exam ⚜ Search for ➥ 2V0-13.25 🡄 and download it for free on ▷ [url]www.pdfvce.com ◁ website 🤑2V0-13.25 Exam Preview[/url]
- Real 2V0-13.25 PDF Questions [2026]-The Greatest Shortcut Towards Success 🪁 Download ➡ 2V0-13.25 ️⬅️ for free by simply searching on [url]www.pdfdumps.com 📯Certification 2V0-13.25 Exam[/url]
- 3 formats of updated Pdfvce VMware 2V0-13.25 Exam Questions 🏓 [url]www.pdfvce.com is best website to obtain 2V0-13.25 for free download 🆚2V0-13.25 Exam Preview[/url]
- 2V0-13.25 Practice Questions ✨ New 2V0-13.25 Exam Bootcamp 🛃 2V0-13.25 Top Dumps 🌖 Immediately open [ [url]www.troytecdumps.com ] and search for 2V0-13.25 to obtain a free download ➕2V0-13.25 Exam Preview[/url]
- 2V0-13.25 Pass4sure Torrent - 2V0-13.25 Valid Pdf - 2V0-13.25 Testking Exam ⌛ Search for { 2V0-13.25 } and download it for free immediately on ➠ [url]www.pdfvce.com 🠰 🔇2V0-13.25 Exam Duration[/url]
- 2V0-13.25 Pdf Torrent ⚒ Certification 2V0-13.25 Exam 🍭 New Exam 2V0-13.25 Materials 🕖 The page for free download of { 2V0-13.25 } on ⏩ [url]www.prep4away.com ⏪ will open immediately 🗻2V0-13.25 Detail Explanation[/url]
- New 2V0-13.25 Exam Bootcamp 🌃 Certification 2V0-13.25 Exam 😡 2V0-13.25 Exam Duration 🏂 The page for free download of ⇛ 2V0-13.25 ⇚ on [url]www.pdfvce.com will open immediately 🦽2V0-13.25 Top Dumps[/url]
- Exam 2V0-13.25 Tests 🎏 New 2V0-13.25 Exam Bootcamp 🌞 Exam 2V0-13.25 Format 📁 [url]www.testkingpass.com is best website to obtain ➽ 2V0-13.25 🢪 for free download 🐦New Exam 2V0-13.25 Materials[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, qudurataleabqariu.online, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, lmsacademy.binsys.id, darussalamonline.com, Disposable vapes
