2026 MS-102 Latest Test Fee: Microsoft 365 Administrator - The Best Microsoft MS
Posted at 2/15/2026 18:51:03
BONUS!!! Download part of ExamsTorrent MS-102 dumps for free: https://drive.google.com/open?id=1vVNJ_p-p9qzShbvAXWZvFdYbUSBzJkZ8
There are many benefits that make Exams. Microsoft is the best platform for study material. There is customer support available to solve any issues you may face. You can try a free demo version of the Microsoft MS-102 exam preparation material. In case of unsatisfactory results, we offer a full refund guarantee (terms and conditions apply). We also offer up to 12 months of free Valid MS-102 Exam Questions updates. Buy our product today and get these benefits.
Microsoft MS-102 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
| | Topic 2 | - Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
| | Topic 3 | - Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
| | Topic 4 | - Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
Pass Guaranteed 2026 Microsoft MS-102: Microsoft 365 Administrator Unparalleled Latest Test FeeThe APP online version of our MS-102 real exam boosts no limits for the equipment being used and it supports any electronic equipment and the off-line use. If only you open it in the environment with the network for the first time you can use our MS-102 Training Materials in the off-line condition later. It depends on the client to choose the version they favor to learn our MS-102 study materials.
Microsoft 365 Administrator Sample Questions (Q358-Q363):NEW QUESTION # 358
You have several devices enrolled in Microsoft Endpoint Manager.
You have a Microsoft Azure Active Directory (Azure AD) tenant that includes the users shown in the following table.
The device type restrictions in Endpoint Manager are configured as shown in the following table.
NEW QUESTION # 359
You have a Microsoft 365 E5 subscription that contains the groups shown in the following exhibit.
To which groups can you assign Microsoft 365 E5 licenses?
- A. Group 1, Group2. and Group3 only
- B. Group! and Group2 only
- C. Group3 and Group4 only
- D. Group2 and Group3 only
- E. Group2, Group3, and Group4 only
NEW QUESTION # 360
Your network contains an Active Directory domain.
You deploy an Azure AD tenant.
Another administrator configures the domain to synchronize to Azure AD.
You discover that 10 user accounts in an organizational unit (OU) are NOT synchronized to Azure AD. All the other user accounts synchronized successfully.
You review Azure AD Connect Health and discover that all the user account synchronizations completed successfully.
You need to ensure that the 10 user accounts are synchronized to Azure AD.
Solution: From the Synchronization Rules Editor, you create a new outbound synchronization rule.
Does this meet the goal?
The question states that "all the user account synchronizations completed successfully". Therefore, the synchronization rule is configured correctly. It is likely that the 10 user accounts are being excluded from the synchronization cycle by a filtering rule.
https://docs.microsoft.com/en-us ... configure-filtering
NEW QUESTION # 361
HOTSPOT
You have a Microsoft 365 E5 subscription.
From Azure AD Privileged Identity Management (PIM), you configure Role settings for the Global Administrator role as shown in the following exhibit.
Box 1: will lose the role after eight hours
From exhibit: Activation, Activation maximum duration (hours): 8 hour(s) Box 2: for up to three months We see from exhibit: Assignment, Expire eligible assignment after: 3 month(s)
NEW QUESTION # 362
Which report should the New York office auditors view?
- A. DLP policy matches
- B. Top Senders and Recipients
- C. DLP false positives and overrides
- D. DLP incidents
https://docs.microsoft.com/en-us ... prevention-policies This report also shows policy matches over time, like the policy matches report. However, the policy matches report shows matches at a rule level; for example, if an email matched three different rules, the policy matches report shows three different line items. By contrast, the incidents report shows matches at an item level; for example, if an email matched three different rules, the incidents report shows a single line item for that piece of content. Because the report counts are aggregated differently, the policy matches report is better for identifying matches with specific rules and fine tuning DLP policies. The incidents report is better for identifying specific pieces of content that are problematic for your DLP policies.
Topic 2, Contoso, Ltd
Overview
Contoso, Ltd. is a consulting company that has a main office in Montreal and two branch offices in Seattle and New York.
The company has the employees and devices shown in the following table.
Contoso recently purchased a Microsoft 365 ES subscription.
Existing Environment
Requirement
The network contains an on-premises Active Directory forest named contoso.com. The forest contains the servers shown in the following table.
All servers run Windows Server 2016. All desktops and laptops are Windows 10 Enterprise and are joined to the domain.
The mobile devices of the users in the Montreal and Seattle offices run Android. The mobile devices of the users in the New York office run iOS.
The domain is synced to Azure Active Directory (Azure AD) and includes the users shown in the following table.
The domain also includes a group named Group1.
Planned Changes
Contoso plans to implement the following changes:
*Implement Microsoft 365.
*Manage devices by using Microsoft Intune.
*Implement Azure Advanced Threat Protection (ATP).
*Every September, apply the latest feature updates to all Windows computers. Every March, apply the latest feature updates to the computers in the New York office only.
Technical Requirements
Contoso identifies the following technical requirements:
*When a Windows 10 device is joined to Azure AD, the device must enroll in Intune automaticity.
*Dedicated support technicians must enroll all the Montreal office mobile devices in Intune.
*User1 must be able to enroll all the New York office mobile devices in Intune.
*Azure ATP sensors must be installed and must NOT use port mirroring.
*Whenever possible, the principle of least privilege must be used.
*A Microsoft Store for Business must be created.
Compliance Requirements
Contoso identifies the following compliance requirements:
*Ensure that the users in Group1 can only access Microsoft Exchange Online from devices that are enrolled in Intune and configured in accordance with the corporate policy.
*Configure Windows Information Protection (W1P) for the Windows 10 devices.
NEW QUESTION # 363
Nowadays the knowledge capabilities and mental labor are more valuable than the manual labor because knowledge can create more wealth than the mental labor. If you boost professional knowledge capabilities in some area you are bound to create a lot of values and can get a good job with high income. Passing the test of MS-102 Certification can help you achieve that, and our MS-102 study materials are the best study materials for you to prepare for the test.
MS-102 Reliable Exam Answers: https://www.examstorrent.com/MS-102-exam-dumps-torrent.html
- MS-102 Download Free Dumps 🐭 MS-102 Latest Braindumps Ebook 🪐 MS-102 Latest Braindumps Ebook 🚟 ➽ [url]www.torrentvce.com 🢪 is best website to obtain { MS-102 } for free download 🥂MS-102 Pass Guide[/url]
- Quiz 2026 Microsoft MS-102 Accurate Latest Test Fee 🐥 Open ➠ [url]www.pdfvce.com 🠰 and search for ☀ MS-102 ️☀️ to download exam materials for free 🪑MS-102 Exam Success[/url]
- MS-102 Latest Test Fee - Certification Success Guaranteed, Easy Way of Training - MS-102 Reliable Exam Answers ☸ Open ▶ [url]www.pdfdumps.com ◀ enter ⇛ MS-102 ⇚ and obtain a free download 💛Exam MS-102 Topic[/url]
- Pass Guaranteed MS-102 - Useful Microsoft 365 Administrator Latest Test Fee 🥓 Open ⏩ [url]www.pdfvce.com ⏪ enter 【 MS-102 】 and obtain a free download 🐯MS-102 Pass Guide[/url]
- New MS-102 Exam Simulator 🔙 Exam MS-102 Topic 💬 MS-102 Test King 🥶 Open website ☀ [url]www.prep4sures.top ️☀️ and search for 【 MS-102 】 for free download 🍰MS-102 Mock Exams[/url]
- New MS-102 Exam Simulator 🤮 MS-102 Latest Braindumps Ebook 🥎 MS-102 Authorized Pdf 🦁 Download { MS-102 } for free by simply searching on [ [url]www.pdfvce.com ] 🔬MS-102 Exam Success[/url]
- MS-102 Download Free Dumps 🅿 MS-102 Latest Braindumps Ebook 🤠 MS-102 Authorized Pdf 📠 Search for ⇛ MS-102 ⇚ and obtain a free download on ➥ [url]www.validtorrent.com 🡄 😾New MS-102 Exam Simulator[/url]
- Free PDF Microsoft - MS-102 - Microsoft 365 Administrator –High-quality Latest Test Fee 🧴 Search for ➡ MS-102 ️⬅️ and download it for free on ▛ [url]www.pdfvce.com ▟ website ⏭MS-102 Pass Guide[/url]
- Latest MS-102 Braindumps Questions 🆚 Reliable MS-102 Study Materials 🧳 MS-102 Study Demo ✔️ Simply search for ⏩ MS-102 ⏪ for free download on 《 [url]www.prep4away.com 》 🎤MS-102 Reliable Test Materials[/url]
- [url=https://quangnamnet.com.vn/?s=New%20MS-102%20Exam%20Simulator%20%f0%9f%98%86%20MS-102%20Latest%20Exam%20Book%20%f0%9f%a5%8b%20MS-102%20PDF%20Questions%20%f0%9f%a6%a1%20Search%20on%20%e2%9e%a4%20www.pdfvce.com%20%e2%ae%98%20for%20[%20MS-102%20]%20to%20obtain%20exam%20materials%20for%20free%20download%20%f0%9f%8d%beTest%20MS-102%20King]New MS-102 Exam Simulator 😆 MS-102 Latest Exam Book 🥋 MS-102 PDF Questions 🦡 Search on ➤ www.pdfvce.com ⮘ for [ MS-102 ] to obtain exam materials for free download 🍾Test MS-102 King[/url]
- Test MS-102 Free 🎸 MS-102 Latest Braindumps Ebook 💳 MS-102 Pass Guide 🍊 The page for free download of ➽ MS-102 🢪 on ➠ [url]www.vce4dumps.com 🠰 will open immediately 🚮MS-102 Study Demo[/url]
- bbs.t-firefly.com, techwavedy.xyz, training.icmda.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, academia.2ffactor.com, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest ExamsTorrent MS-102 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1vVNJ_p-p9qzShbvAXWZvFdYbUSBzJkZ8
