[General] Pass-Sure Data-Architect Exam Actual Tests & Passing Data-Architect Exam is
95
【General】 Pass-Sure Data-Architect Exam Actual Tests & Passing Data-Architect Exam is
Posted at 2/15/2026 20:10:23      View:104 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpExam Data-Architect PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1juXm10oVG3XF-VI47Fca2H47qbZdMaiO
In this fast-changing world, the requirements for jobs and talents are higher, and if people want to find a job with high salary they must boost varied skills which not only include the good health but also the working abilities. We provide timely and free update for you to get more Data-Architect Questions torrent and follow the latest trend. The Data-Architect exam torrent is compiled by the experienced professionals and of great value.
By analyzing the syllabus and new trend, our Data-Architect practice engine is totally in line with this exam for your reference. So grapple with this chance, our Data-Architect learning materials will not let you down. With our Data-Architect Study Guide, not only that you can pass you exam easily and smoothly, but also you can have a wonderful study experience based on the diversed versions of our Data-Architect training prep.
Pass Data-Architect Guaranteed & New Data-Architect Test FeeAs a professional multinational company, we fully take into account the needs of each user when developing products. For example, in order to make every customer can purchase at ease, our Data-Architect study materials will provide users with three different versions for free trial, corresponding to the three official versions. You can feel the characteristics of our Data-Architect Study Materials and whether they are suitable for you from the trial. After your payment, we'll send you a connection of our Data-Architect study materials in 5 to 10 minutes and you can download immediately without wasting your valuable time.
Salesforce Data-Architect (Salesforce Certified Data Architect) Exam is a certification program designed to validate the skills and knowledge of professionals in the Salesforce platform. It is an advanced-level certification test that assesses the abilities of individuals to design and implement complex data architectures and management strategies using Salesforce products and solutions.
Salesforce Certified Data Architect Sample Questions (Q130-Q135):NEW QUESTION # 130
North Trail Outfitters (NTO) operates a majority of its business from a central Salesforce org, NTO also owns several secondary orgs that the service, finance, and marketing teams work out of, At the moment, there is no integration between central and secondary orgs, leading to data-visibility issues.
Moving forward, NTO has identified that a hub-and-spoke model is the proper architect to manage its data, where the central org is the hub and the secondary orgs are the spokes.
Which tool should a data architect use to orchestrate data between the hub org and spoke orgs?
  • A. Develop custom APIs to poll the spoke for change data and push into the org.
  • B. A backup and archive solution that extracts and restores data across orgs.
  • C. Develop custom APIs to poll the hub org for change data and push into the spoke orgs.
  • D. A middleware solution that extracts and distributes data across both the hub and spokes.
According to the Salesforce documentation, a hub-and-spoke model is an integration architecture pattern that allows connecting multiple Salesforce orgs using a central org (hub) and one or more secondary orgs (spokes).
The hub org acts as the master data source and orchestrates the data flow between the spoke orgs. The spoke orgs act as the consumers or producers of the data and communicate with the hub org.
To orchestrate data between the hub org and spoke orgs, a data architect should use:
A middleware solution that extracts and distributes data across both the hub and spokes (option A). This means using an external service or tool that can connect to multiple Salesforce orgs using APIs or connectors, and perform data extraction, transformation, and distribution operations between the hub and spoke orgs. This can provide a scalable, flexible, and reliable way to orchestrate data across multiple orgs.
Developing custom APIs to poll the hub org for change data and push into the spoke orgs (option B) is not a good solution, as it can be complex, costly, and difficult to maintain. It may also not be able to handle large volumes of data or complex transformations efficiently. Developing custom APIs to poll the spoke orgs for change data and push into the hub org (option C) is also not a good solution, as it can have the same drawbacks as option B. It may also not be able to handle conflicts or errors effectively. Using a backup and archive solution that extracts and restores data across orgs (option D) is also not a good solution, as it can incur additional costs and dependencies. It may also not be able to handle real-time or near-real-time data orchestration requirements.
NEW QUESTION # 131
The architect is planning a large data migration for Universal Containers from their legacy CRM system to Salesforce. What three things should the architect consider to optimize performance of the data migration?
Choose 3 answers
  • A. Remove custom indexes on the data being loaded.
  • B. Determine if the legacy system is still in use.
  • C. Review the time zones of the User loading the data.
  • D. Defer sharing calculations of the Salesforce Org.
  • E. Deactivate approval processes and workflow rules.
Answer: A,D,E
Removing custom indexes on the data being loaded will prevent unnecessary index maintenance and improve the data load speed. Deferring sharing calculations of the Salesforce Org will avoid frequent sharing rule evaluations and reduce the load time. Deactivating approval processes and workflow rules will prevent triggering any automation logic that might slow down or fail the data load.
NEW QUESTION # 132
A customer is facing locking issued when importing large data volumes of order records that are children in a master-detail relationship with the Account object. What is the recommended way to avoid locking issues during import?
  • A. Import Account records first followed by order records after sorting order by OrderID.
  • B. Change the relationship to Lookup and update the relationship to master-detail after import.
  • C. Import Order records and Account records separately and populate AccountID in orders using batch Apex.
  • D. Import Account records first followed by order records after sorting orders by AccountID.
NEW QUESTION # 133
Northern Trail Outfitters (NTO) has multiple Salesforce orgs based on regions. Users need read-only access to customers across all Salesforce orgs.
Which feature in Salesforce can be used to provide access to customer records across all NTO orgs?
  • A. Salesforce Connect
  • B. External APIs
  • C. Salesforce 2 Salesforce
  • D. Federated Search
NEW QUESTION # 134
Northern Trail Outfitters (NTO) has recently implemented Salesforce to track opportunities across all their regions. NTO sales teams across all regions have historically managed their sales process in Microsoft Excel. NTO sales teams are complaining that their data from the Excel files were not migrated as part of the implementation and NTO is now facing low Salesforce adoption.
What should a data architect recommend to increase Salesforce adoption?
  • A. Create a chatter group and upload all Excel files to the group.
  • B. Load data in external database and provide access to database to sales users.
  • C. Define a standard mapping and train sales users to import opportunity data.
  • D. Use the Excel connector to Salesforce to sync data from individual Excel files.
NEW QUESTION # 135
Because many users are first taking part in the exams, so for the exam and test time distribution of the above lack certain experience, and thus prone to the confusion in the examination place, time to grasp, eventually led to not finish the exam totally. In order to avoid the occurrence of this phenomenon, the Salesforce Certified Data Architect study question have corresponding products to each exam simulation test environment, users log on to their account on the platform, at the same time to choose what they want to attend the exam simulation questions, the Data-Architect Exam Questions are automatically for the user presents the same as the actual test environment simulation test system, the software built-in timer function can help users better control over time, so as to achieve the systematic, keep up, as well as to improve the user's speed to solve the problem from the side with our Data-Architect test guide.
Pass Data-Architect Guaranteed: https://www.dumpexam.com/Data-Architect-valid-torrent.html
P.S. Free 2026 Salesforce Data-Architect dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1juXm10oVG3XF-VI47Fca2H47qbZdMaiO
