C-S4CFI-2504考古題更新,C-S4CFI-2504學習指南
89
Posted at 2/15/2026 21:19:38      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的Testpdf C-S4CFI-2504 PDF版考試題庫:https://drive.google.com/open?id=1nosDa-nSg0VCKFw6DZDzQbV7QPGdEnwW
有了Testpdf的C-S4CFI-2504考古題,即使你只用很短的時間來準備考試,你也可以順利通過考試。因為Testpdf的考古題包含了在實際考試中可能出現的所有問題,所以你只需要記住C-S4CFI-2504考古題裏面出現的問題和答案,你就可以輕鬆通過考試。這是通過考試最快的捷徑了。如果你工作很忙實在沒有時間準備考試,但是又想取得C-S4CFI-2504的認證資格,那麼,你絕對不能錯過Testpdf的C-S4CFI-2504考古題。因為這是你通過考試的最好的,也是唯一的方法。
SAP C-S4CFI-2504 考試大綱:
主題簡介
主題 1
  • Data Migration and Business Process Testing: This domain measures the skills of SAP Application Consultants and focuses on transferring data to SAP and testing processes to ensure system readiness.
主題 2
  • Implementing with a Cloud Mindset, Building the Team, and Conducting Fit-to-Standard Workshops: This section measures the skills of SAP Project Managers and introduces the principles of cloud implementation, team roles, and Fit-to-Standard workshop execution.
主題 3
  • Extensibility and Integration: This domain measures the skill of application consultants and covers how to customize SAP applications and integrate them with external systems.
主題 4
  • Payables Management: This section includes handling vendor-related transactions such as invoicing and payments.
主題 5
  • Record-to-Report: This exam section measures the skills of SAP Application Consultants and focuses on the end-to-end financial reporting cycle, from data recording to final reports.
主題 6
  • Configuration and the SAP Fiori Launchpad: This section focuses on Fiori Professionals and deals with basic system configuration and navigating the SAP Fiori Launchpad interface.
主題 7
  • Asset Accounting: This section covers tracking and managing the lifecycle of fixed assets within SAP.
最好的C-S4CFI-2504考古題更新 & 可靠的C-S4CFI-2504學習指南在短短幾年內,SAP C-S4CFI-2504 認證考試已經成為比較有影響力電腦能力認證考試。然而如何簡單順利地通過SAP C-S4CFI-2504認證考試?我們的Testpdf在任何時間下都可以幫您快速解決這個問題。我們在Testpdf中為您提供了可以成功通過C-S4CFI-2504認證考試的培訓工具。C-S4CFI-2504認證考試培訓工具的內容是由IT行業專家帶來的最新的考試研究材料組成
最新的 SAP Certified Associate C-S4CFI-2504 免費考試真題 (Q68-Q73):問題 #68
Which of the following are captured in a completed Digital Discovery Assessment?
  • A. SAP Fiori application extensions
  • B. Business role permission requirements
  • C. Known integration requirements
  • D. Target customer go-live date
答案:C,D
解題說明:
Comprehensive and Detailed in Depth Explanation:
The Digital Discovery Assessment scopes implementation needs.
B: Correct. Includes go-live timeline.
D: Correct. Captures integration requirements.
A, C: Incorrect. These are detailed later in configuration.
問題 #69
When do you perform the goods and invoice receipt reconciliation process?
  • A. When a purchase order is posted but no goods receipt has been received
  • B. When an invoice is posted, but no relevant purchase order is available
  • C. When an invoice is posted but no goods receipt has been received
  • D. When a purchase order is posted but no invoice has been received
答案:C
解題說明:
Reconciliation in SAP S/4HANA Cloud ensures goods and invoices align with POs.
* D: Correct. This scenario requires reconciliation to resolve discrepancies (e.g., via GR/IR clearing).
References: SAP Help Portal - "GR/IR Reconciliation."
問題 #70
Where are the manual test cases created for customer User Acceptance Testing?
  • A. Test Automation Tool
  • B. SAP Signavio Process Navigator
  • C. SAP Solution Manager
  • D. SAP Cloud ALM
答案:D
解題說明:
In SAP S/4HANA Cloud Public Edition, User Acceptance Testing (UAT) is supported through tools aligned with its cloud-first strategy.
* Option B (SAP Cloud ALM): Correct. SAP Cloud ALM is the standard application lifecycle management tool for SAP S/4HANA Cloud, where manual test cases for UAT are created, managed, and executed. It integrates with the SAP Activate methodology and supports end-to-end testing processes.
* Option A (SAP Solution Manager): Incorrect. Solution Manager is primarily used for on-premise SAP systems, not the Public Cloud Edition, where SAP Cloud ALM takes precedence.
* Option C (SAP Signavio Process Navigator): Incorrect. Signavio is a process modeling tool, not designed for creating or managing test cases.
* Option D (Test Automation Tool): Incorrect. This tool focuses on automated testing, not manual UAT test case creation.
References: SAP Cloud ALM for Implementation, "Testing in SAP S/4HANA Cloud" (SAP Help Portal).
問題 #71
What are the effects of a goods issue posting?
  • A. It generates an invoice for approval
  • B. It increases the inventory value
  • C. It posts an accounting document
  • D. It reduces the inventory values
答案:C,D
解題說明:
A goods issue in SAP S/4HANA Cloud (e.g., via "Post Goods Issue" app) impacts inventory and accounting.
A: Correct. It generates an accounting document (e.g., Dr. COGS, Cr. Inventory).
B: Correct. Inventory value decreases due to stock reduction.
C: Incorrect. Invoices are linked to billing, not goods issue.
D: Incorrect. Goods issue reduces, not increases, inventory value.
問題 #72
When do you specify the data retention period in SAP S/4HANA Migration Cockpit?
  • A. When the project status is "In progress"
  • B. When the project status is "Completed"
  • C. When the project status is "Not started"
  • D. When the project status is "Finished"
答案:C
解題說明:
In the SAP S/4HANA Migration Cockpit, the data retention period determines how long migration data (e.g., staging tables or files) is retained before being archived or deleted, aligning with data governance and compliance requirements.
Option A (When the project status is "Not started"): Correct. The retention period is defined during the initial setup of a migration project in the Migration Cockpit, before any data is loaded or processed. This is part of the project configuration in the "Create Project" step, ensuring clarity on data lifecycle management from the outset.
Option B (When the project status is "Finished"): Incorrect. By the "Finished" stage, migration activities are complete, and the retention period is already in effect-changes are no longer allowed.
Option C (When the project status is "In progress"): Incorrect. While adjustments can be made during "In progress," the retention period is a foundational setting established earlier.
Option D (When the project status is "Completed"): Incorrect. "Completed" is not a standard status in the Migration Cockpit; "Finished" is the final status, and retention is predefined.
問題 #73
為什麼我們領先於行業上的其他網站? 因為我們提供的資料覆蓋面更廣,品質更高,準確性也更高。所以Testpdf是你參加SAP C-S4CFI-2504 認證考試的最好的選擇,也是你成功的最好的保障。
C-S4CFI-2504學習指南: https://www.testpdf.net/C-S4CFI-2504.html
