[Hardware] Features of ECCouncil 312-50v13 Dumps PDF Format
116
Hardware Features of ECCouncil 312-50v13 Dumps PDF Format
Posted at 2/16/2026 02:08:32      View171 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamsLabs 312-50v13 dumps for free: https://drive.google.com/open?id=150AWs-OFHjTrtDPhi-PsNqwuXmGCYb2W
Questions in desktop-based mock exams are identical to the real ones. Our practice exams give you options to change their durations and questions' numbers to polish your skills. You can easily assess your readiness with the assistance of results produced by the practice exam. This Certified Ethical Hacker Exam (CEHv13) software records all your previous takes so you can identify your mistakes and overcome them before the final attempt. The Certified Ethical Hacker Exam (CEHv13) (312-50v13) desktop practice exam software works only on Windows operating system.
This way you will get familiar with Certified Ethical Hacker Exam (CEHv13) exam pattern and objectives. No additional plugins and software installation are indispensable to access this 312-50v13 Practice Test. Furthermore, all browsers and operating systems support this version of the ECCouncil 312-50v13 practice exam.
ECCouncil 312-50v13 Exam | 312-50v13 Well Prep - Help you Prepare for 312-50v13 Exam EfficientlyPassing the 312-50v13 certification can prove that and help you realize your goal and if you buy our 312-50v13 quiz prep you will pass the exam successfully. Our product is compiled by experts and approved by professionals with years of experiences. You can download and try out our laTest 312-50v13 Quiz torrent freely before your purchase. Our purchase procedures are safe and our products are surely safe without any virus. After you purchase our 312-50v13 exam guide is you can download the test bank you have bought immediately.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q311-Q316):NEW QUESTION # 311
The network administrator at Spears Technology, Inc has configured the default gateway Cisco router's access- list as below:
You are hired to conduct security testing on their network.
You successfully brute-force the SNMP community string using a SNMP crack tool.
The access-list configured at the router prevents you from establishing a successful connection.
You want to retrieve the Cisco configuration from the router. How would you proceed?
  • A. Send a customized SNMP set request with a spoofed source IP address in the range -192.168.1.0
  • B. Use the Cisco's TFTP default password to connect and download the configuration file
  • C. Run Generic Routing Encapsulation (GRE) tunneling protocol from your computer to the router masking your IP address
  • D. Run a network sniffer and capture the returned traffic with the configuration file from the router
NEW QUESTION # 312
A penetration tester was assigned to scan a large network range to find live hosts. The network is known for using strict TCP filtering rules on its firewall, which may obstruct common host discovery techniques. The tester needs a method that can bypass these firewall restrictions and accurately identify live systems. What host discovery technique should the tester use?
  • A. UDP Ping Scan
  • B. TCP SYN Ping Scan
  • C. ICMP Timestamp Ping Scan
  • D. lCMP ECHO Ping Scan
The host discovery technique that the tester should use is TCP SYN Ping Scan. This technique sends a TCP SYN packet to a specified port on the target host and waits for a response. If the host responds with a TCP SYN/ACK packet, it means the host is alive and the port is open. If the host responds with a TCP RST packet, it means the host is alive but the port is closed. If the host does not respond at all, it means the host is either dead or filtered by a firewall12. TCP SYN Ping Scan can bypass firewall restrictions because it mimics the initial stage of a TCP three-way handshake, which is a common and legitimate network activity. Therefore, most firewalls will allow TCP SYN packets to pass through and reach the target host, unless they are configured to block specific ports or IP addresses3. TCP SYN Ping Scan can also accurately identify live systems because it does not rely on ICMP, which may be blocked or rate-limited by some firewalls or routers.
The other options are not as effective or feasible as TCP SYN Ping Scan for the following reasons:
* A. UDP Ping Scan: This technique sends a UDP packet to a specified port on the target host and waits for a response. If the host responds with an ICMP Port Unreachable message, it means the host is alive but the port is closed. If the host does not respond at all, it means the host is either dead, the port is open, or the packet is filtered by a firewall12. UDP Ping Scan may not bypass firewall restrictions because some firewalls may block or drop UDP packets, especially if they are sent to uncommon or reserved ports. UDP Ping Scan may also not accurately identify live systems because it cannot distinguish between open ports and filtered packets, and it may generate false positives or negatives due to packet loss or rate-limiting.
* B. ICMP ECHO Ping Scan: This technique sends an ICMP ECHO Request packet to the target host and waits for an ICMP ECHO Reply packet. If the host responds with an ICMP ECHO Reply packet, it means the host is alive. If the host does not respond at all, it means the host is either dead or filtered by a firewall12. ICMP ECHO Ping Scan may not bypass firewall restrictions because some firewalls may block or drop ICMP packets, especially if they are sent to prevent ping sweeps or denial-of-service attacks. ICMP ECHO Ping Scan may also not accurately identify live systems because it may generate false positives or negatives due to packet loss or rate-limiting.
* C. ICMP Timestamp Ping Scan: This technique sends an ICMP Timestamp Request packet to the target host and waits for an ICMP Timestamp Reply packet. If the host responds with an ICMP Timestamp Reply packet, it means the host is alive. If the host does not respond at all, it means the host is either dead or filtered by a firewall12. ICMP Timestamp Ping Scan may not bypass firewall restrictions because some firewalls may block or drop ICMP packets, especially if they are sent to prevent ping sweeps or denial-of-service attacks. ICMP Timestamp Ping Scan may also not accurately identify live systems because it may generate false positives or negatives due to packet loss or rate-limiting.
* 1: Host Discovery in Nmap Network Scanning - GeeksforGeeks
* 2: nmap Host Discovery Techniques
* 3: TCP SYN Ping Scan - Nmap
* : Ping Sweep - an overview | ScienceDirect Topics
* : UDP Ping Scan - Nmap
* : UDP Ping Scan - an overview | ScienceDirect Topics
* : ICMP Ping Scan - Nmap
* : ICMP Ping Scan - an overview | ScienceDirect Topics
NEW QUESTION # 313
While analyzing logs, you observe a large number of TCP SYN packets sent to various ports with no corresponding ACKs. What scanning technique was likely used?
  • A. XMAS scan
  • B. SYN/ACK scan
  • C. TCP Connect scan
  • D. SYN scan (half-open scanning)
This activity clearly indicates a TCP SYN scan, also known as a half-open scan, which is a commonly used stealth scanning technique discussed in CEH v13 Reconnaissance and Network Scanning. In a SYN scan, the attacker sends TCP SYN packets to target ports and observes the responses without completing the TCP three-way handshake.
If the port is open, the target responds with a SYN/ACK packet. The scanner then immediately sends a RST packet instead of the final ACK, leaving the connection half-open. This behavior allows attackers to identify open ports while minimizing log entries and reducing detection by security monitoring tools.
The absence of ACK packets in logs supports this explanation, as the handshake is never completed.
Other options are incorrect because:
* XMAS scans send packets with multiple flags set.
* SYN/ACK scans are primarily used for firewall rule discovery.
* TCP Connect scans complete the full handshake and generate ACKs.
CEH v13 emphasizes that SYN scans are widely used because they balance accuracy and stealth, making them a preferred reconnaissance method for attackers.
NEW QUESTION # 314
An organization is performing a vulnerability assessment tor mitigating threats. James, a pen tester, scanned the organization by building an inventory of the protocols found on the organization's machines to detect which ports are attached to services such as an email server, a web server or a database server. After identifying the services, he selected the vulnerabilities on each machine and started executing only the relevant tests. What is the type of vulnerability assessment solution that James employed in the above scenario?
  • A. Tree-based assessment
  • B. Service-based solutions
  • C. Product-based solutions
  • D. inference-based assessment
In an inference-based assessment, scanning starts by building an inventory of the protocols found on the machine. After finding a protocol, the scanning process starts to detect which ports are attached to services, such as an email server, web server, or database server. After finding services, it selects vulnerabilities on each machine and starts to execute only those relevant tests.
NEW QUESTION # 315
What two conditions must a digital signature meet?
  • A. Has to be legible and neat.
  • B. Has to be unforgeable, and has to be authentic.
  • C. Must be unique and have special characters.
  • D. Has to be the same number of characters as a physical signature and must be unique.
NEW QUESTION # 316
With every ECCouncil 312-50v13 practice test attempt, you will see yourself improve gradually, and on ECCouncil 312-50v13 exam day, you will be able to finish the Certified Ethical Hacker Exam (CEHv13) 312-50v13 exam as far as possible and space enough time to do an entire check for careless mistakes. Download the full version of ExamsLabs 312-50v13 PDF Questions and practice tests and start your professional journey. We ensure you can pass the Certified Ethical Hacker Exam (CEHv13) 312-50v13 exam on the first attempt.
Hottest 312-50v13 Certification: https://www.examslabs.com/ECCouncil/CEH-v13/best-312-50v13-exam-dumps.html
After payment you can receive our complete 312-50v13 actual lab questions in a minute, ECCouncil 312-50v13 Well Prep The good reputation inspires us to do better, which is the ultimate objections of us, ECCouncil 312-50v13 Well Prep So this is your high time to flex your muscles this time, Pass the Hottest 312-50v13 Certification - Certified Ethical Hacker Exam (CEHv13) to establish your expertise in your field and receive certification, The ECCouncil Hottest 312-50v13 Certification certificate is an important way to test the ability of a worker.
WordPerfect opens the file into a new document 312-50v13 window, and you are ready to go, The Off slider button appears in the bluemenu bar at the top of the screen, After payment you can receive our complete 312-50v13 actual lab questions in a minute.
Pass 312-50v13 Exam with Professional 312-50v13 Well Prep by ExamsLabsThe good reputation inspires us to do better, which is the ultimate objections Hottest 312-50v13 Certification of us, So this is your high time to flex your muscles this time, Pass the Certified Ethical Hacker Exam (CEHv13) to establish your expertise in your field and receive certification.
The ECCouncil certificate is an important way to test the ability of a worker.
P.S. Free & New 312-50v13 dumps are available on Google Drive shared by ExamsLabs: https://drive.google.com/open?id=150AWs-OFHjTrtDPhi-PsNqwuXmGCYb2W
Posted at 3/9/2026 01:02:21        Only Author  2#
This is a truly magnificent article, thank you for sharing your thoughts. Thanks to the Dumps PCA reviews, I got promoted and received a raise. Now, its available for free. Wishing you all success in your career!
