[General] Pass Guaranteed 2026 CMMC-CCA: Certified CMMC Assessor (CCA) Exam Pass-Sure Pass
116
【General】 Pass Guaranteed 2026 CMMC-CCA: Certified CMMC Assessor (CCA) Exam Pass-Sure Pass
Posted at 2/16/2026 02:12:36      View:98 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PracticeDump CMMC-CCA dumps from Cloud Storage: https://drive.google.com/open?id=1Oi512NtnvYCaghnr_RygXN-eY1p682j3
With our CMMC-CCA study materials, all your agreeable outcomes are no longer dreams for you. And with the aid of our CMMC-CCA exam preparation to improve your grade and change your states of life and get amazing changes in career, everything is possible. It all starts from our CMMC-CCA learning questions. Come and buy our CMMC-CCA practice engine, you will be confident and satisfied with it and have a brighter future.
We believe you will also competent enough to cope with demanding and professorial work with competence with the help of our CMMC-CCA exam braindumps. Our experts made a rigorously study of professional knowledge about this CMMC-CCA exam. So do not splurge time on searching for the perfect practice materials, because our CMMC-CCA Guide materials are exactly what you need to have. Just come and buy our CMMC-CCA practice guide, you will be a winner!
CMMC-CCA Certification Cost - Certification CMMC-CCA Exam InforPracticeDump CMMC-CCA study torrent is popular in IT candidates, why does this CMMC-CCA training material has attracted so many pros? Now, if you receive CMMC-CCA prep torrent, you will be surprised by available, affordable, updated and best valid Cyber AB CMMC-CCA Download Pdf dumps. After using the CMMC-CCA latest test collection, you will never be fair about the CMMC-CCA actual test. The knowledge you get from CMMC-CCA dumps cram can bring you 100% pass.
Cyber AB Certified CMMC Assessor (CCA) Exam Sample Questions (Q150-Q155):NEW QUESTION # 150
When assessing an OSC's compliance with IR requirements, you realize they have deployed a system that tracks incidents, documents details, and updates the status throughout the incident response process. Personnel to whom incidents must be reported are identified and designated. While examining their documentation, you come across an incident response template that they use to capture all relevant information and ensure consistency in reporting to the identified authorities and organizational officials. Interviewing the IR team, you learn there is an escalation process that the contractor's cybersecurity team can use to address more serious incidents. From the scenario,the contractor has met all the required objectives for CMMC practice IR.
L2-3.6.2 - Incident Reporting, meaning its implementation of the said practice will be scored MET with a total of 5 points. For how long must the OSC retain the incident records?
  • A. 90 days
  • B. 72 days
  • C. 90 hours
  • D. 72 hours
Comprehensive and Detailed In-Depth Explanation:
IR.L2-3.6.2 requires "tracking and documenting incidents." While CMMC doesn't specify retention, DFARS
252.204-7012 mandates retaining incident records for 90 days (B) to support DoD investigations, a common baseline for CMMC-aligned contractors. Other options (A, C, D) lack regulatory grounding. The CMMC guide references DFARS for practical guidance.
Extract from Official CMMC Documentation:
* CMMC Assessment Guide Level 2 (v2.0), IR.L2-3.6.2: "Document incidents; retention per applicable regulations."
* DFARS 252.204-7012: "Retain records for 90 days."
Resources:
* https://dodcio.defense.gov/Porta ... AG_Level2_MasterV2.
0_FINAL_202112016_508.pdf
NEW QUESTION # 151
CMMC practice PS.L2-3.9.1 - Screen Individuals requires individuals to be screened before authorizing access to organizational systems containing CUI. However, in the assessment you are currently conducting, there is no physical evidence confirming the completion of personnel screens, such as background checks, only affirmations derived from an interview session. In an interview with the HR Manager, they informed you that before an individual is hired, they submit their information through a service that performs criminal and financial checks. How would you score the OSC's implementation of CMMC practice PS.L2-3.9.1 - Screen Individuals, objective [a]?
  • A. Not Met
  • B. Not Applicable
  • C. Met
  • D. More information is needed
PS.L2-3.9.1, objective [a], requires "screening individuals prior to authorizing access to CUI systems." The HR Manager's affirmation suggests a process, but without physical evidence (e.g., screening records), compliance can't be confirmed. More information (A) is needed to verify, per CMMC's evidence-based assessment. Met (D) requires proof, Not Met (B) assumes failure prematurely, and N/A (C) doesn't apply.
* CMMC Assessment Guide Level 2 (v2.0), PS.L2-3.9.1: "Examine screening records; interviews support but don't replace evidence."
* NIST SP 800-171A, 3.9.1: "Verify with documentation."
Resources:
NEW QUESTION # 152
A CCA is reviewing an OSC's evidence for a CMMC practice and finds that the documentation is in draft form, marked "For Internal Use Only," and lacks final approval. The OSC insists it is actively used. How should the CCA evaluate this evidence?
  • A. Accept the draft documentation as sufficient since it is actively used.
  • B. Request the OSC to finalize the documentation before continuing the assessment.
  • C. Reject the draft documentation and score the practice as "NOT MET."
  • D. Document the lack of final approval as an evidence gap and assess based on all available evidence, including usage confirmation.
Comprehensive and Detailed in Depth Explanation:
The CAP requires noting deficiencies like lack of approval as gaps while assessing all evidence (Option B).
Options A, C, and D misapply CAP procedures.
Extract from Official Document (CAP v1.0):
* Section 2.2 - Conduct Assessment (pg. 25):"Document lack of final approval as an evidence gap and assess based on all available evidence." References:
CMMC Assessment Process (CAP) v1.0, Section 2.2.
NEW QUESTION # 153
During a CMMC assessment, the Lead Assessor, Emily, notices that one of the CCAs on her team, Alex, seems overly critical and skeptical of the evidence presented by the OSC. Although the OSC demonstrates compliance with the required CMMC practices, Alex repeatedly questions the validity of the evidence and suggests the OSC is not meeting the criteria. Concerned that Alex's behavior may be influenced by bias, Emily decides to address the issue directly. She recalls a previous incident in which Alex took a similar approach, and shortly afterward, the OSC experienced a data breach. What steps should Emily and, most importantly, the C3PAO have taken to prevent this eventuality?
  • A. Rely on the Lead Assessor to mitigate any potential bias
  • B. Identify and manage assessor bias to deliver objective assessments
  • C. Avoid working with assessors who have previous experience with the OSC
  • D. Undergo additional training in the CMMC requirements
Bias in assessors, whether positive or negative, can compromise the objectivity and integrity of a CMMC assessment, as outlined in the CMMC Assessment Process (CAP). The CAP emphasizes that C3PAOs are responsible for ensuring assessors maintain impartiality and deliver fair evaluations based on evidence, not preconceptions. Alex's overly critical stance, potentially influenced by past experiences, indicates a negative bias that could skew findings, even if the OSCdemonstrates compliance.
Option A (avoiding experienced assessors) is impractical and ignores the value of expertise. Option B (relying solely on the Lead Assessor) shifts responsibility but doesn't address systemic bias prevention. Option C (additional training) may enhance knowledge but doesn't directly tackle bias management. Option D (identifying and managing bias) aligns with CAP guidance, requiring C3PAOs to proactively screen for bias, train assessors on objectivity, and implement oversight mechanisms. This ensures consistent, evidence-based assessments, making it the correct answer.
Reference Extract:
* CMMC Assessment Process (CAP) v1.0, Section 2.3:"C3PAOs must ensure assessors are free from bias and capable of delivering objective assessments... Bias management is critical to assessment integrity." Resources:https://cyberab.org/Portals/0/Do ... Assessment-Process- CAP-v1.0.pdf
NEW QUESTION # 154
A contractor allows for the use of mobile devices in contract performance. Some employees access designs and specifications classified as CUI on such devices like tablets and smartphones. After assessing AC.L2-
3.1.18 - Mobile Device Connection, you find that the contractor maintains a meticulous record of mobile devices that connect to its information systems. AC.L2-3.1.19 - Encrypt CUI on Mobile requires that the contractor implements measures to encrypt CUI on mobile devices and mobile computing platforms. The contractor uses device-based encryption where all the data on a mobile device is encrypted. Which of the following is a reason why would you recommend container-based over full-device-based encryption?
  • A. Full-device encryption is not compatible with modern mobile operating systems
  • B. It is more user-friendly and easier to deploy on a large scale
  • C. Container-based encryption offers granular control over sensitive data, improves device performance by encrypting selectively, and enhances security in Bring-Your-Own-Device (BYOD) environments
  • D. Container-based encryption is more cost-effective
AC.L2-3.1.19 requires "encrypting CUI on mobile devices." Full-device encryption secures all data, but container-based encryption (A) offers granularity (protecting only CUI), performance (less overhead), and BYOD compatibility (separating work/personal data), enhancing security and usability. Cost (B) and ease (C) aren't primary drivers, and full-device encryption (D) is compatible with modern OSes, per CMMC discussion.
* CMMC Assessment Guide Level 2 (v2.0), AC.L2-3.1.19: "Container-based encryption provides granular control, performance, and BYOD support."
* NIST SP 800-171A, 3.1.19: "Assess encryption methods for effectiveness." Resources:
NEW QUESTION # 155
If you would like to create a second steady stream of income and get your business opportunity in front of more qualified people, please pay attention to Cyber AB CMMC-CCA latest study dumps. CMMC-CCA useful exam torrents are valid and refined from the previous actual test. You will find the PracticeDump CMMC-CCA valid and reliable questions & answers are all the key questions, unlike other vendors offering the dumps with lots of useless questions, wasting the precious time of candidates. PracticeDump Cyber AB free demo is available and you can download and have a try, then you can make decision to buy the Cyber AB exam dumps. Do study plan according to the Cyber AB exam study material, and arrange your time and energy reasonably. I believe that an efficiency and reasonable exam training can help you to pass the CMMC-CCA Exam successfully.
CMMC-CCA Certification Cost: https://www.practicedump.com/CMMC-CCA_actualtests.html
PracticeDump You can modify settings of practice test in terms of Certified CMMC Assessor (CCA) Exam CMMC-CCA practice questions types and mock exam duration, Cyber AB Pass CMMC-CCA Guarantee You just need download the content you wanted, and then you can learn it whenever, even you are on offline state, Cyber AB Pass CMMC-CCA Guarantee While, when a chance comes, do you have enough advantage to grasp it, If you buy our Software version of the CMMC-CCA study questions, you can enjoy the similar real exam environment for that this version has the advantage of simulating the real exam.
Multiple channels to the same object, First, it sits at the intersection of Pass CMMC-CCA Guarantee a number of interesting technology trends location awareness, mobile computing, social media, social commerce, the real time web and social games.
100% Pass Quiz 2026 Cyber AB High Pass-Rate CMMC-CCA: Pass Certified CMMC Assessor (CCA) Exam GuaranteePracticeDump You can modify settings of practice test in terms of Certified CMMC Assessor (CCA) Exam CMMC-CCA Practice Questions types and mock examduration, You just need download the content CMMC-CCA you wanted, and then you can learn it whenever, even you are on offline state.
While, when a chance comes, do you have enough advantage to grasp it, If you buy our Software version of the CMMC-CCA study questions, you can enjoy the similar real exam Pass CMMC-CCA Guarantee environment for that this version has the advantage of simulating the real exam.
Notices You consent to receive notices from us by e-mail at CMMC-CCA Valid Exam Notes the addresses included in the contact information you submit to the Company, or by adding notices on this site.
P.S. Free 2026 Cyber AB CMMC-CCA dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=1Oi512NtnvYCaghnr_RygXN-eY1p682j3
