[General] Fantastic Books MD-102 PDF & Leader in Qualification Exams & Pass-Sure M
87
【General】 Fantastic Books MD-102 PDF & Leader in Qualification Exams & Pass-Sure M
Posted at 2/16/2026 02:28:07      View:96 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsKing MD-102 PDF Dumps and MD-102 Exam Engine Free Share: https://drive.google.com/open?id=1uoaGBir_SCNLC4c8FtBWlGCGsR8sXcK4
DumpsKing MD-102 products are honored by thousands, considerably recognized across the industry. Successful candidates preferably suggest our products as they provide the best possible returns for your invested money. Our professionals have devoted themselves to deliver the required level of efficiency for our customers. Our well repute in industry highlights our tremendous success record and makes us incomparable choice for MD-102 Exams preparation. 100% guaranteed success for all MD-102 exams is offered at DumpsKing, marks key difference with competing brands. Your investment with DumpsKing never takes any down turn as we owe the whole responsibility for any kind of loss that occurs through your failure.
Microsoft MD-102 Exam Syllabus Topics:
  • Manage and maintain devices: This section deals with managing, troubleshooting, and safeguarding various devices. It also covers methods to ensure that they meet organizational policies and security standards.
  • Protect devices: In this topic, aspiring administrators get knowledge about configuration of endpoint security and management of device updates by using Intune.
  • Prepare infrastructure for devices: This topic focuses on adding devices to Microsoft Entra ID and enrolling devices to Microsoft Intune.
  • Manage applications: This section covers skills to manage application implementation, manage updates, and manage performance to support the performance of users to meet the needs of business organizations.
MD-102 Download Pdf - MD-102 Valid Test FeeYou can free download part of DumpsKing's practice questions and answers about Microsoft certification MD-102 exam online, as an attempt to test our quality. As long as you choose to purchase DumpsKing's products, we will do our best to help you pass Microsoft Certification MD-102 Exam disposably.
Microsoft Endpoint Administrator Sample Questions (Q83-Q88):NEW QUESTION # 83
You have a Microsoft 365 subscription and use Microsoft Intune.
You have the Endpoint Privilege Management (EPM) elevation settings policy shown in the following exhibit.
No EPM elevation rules policies are configured.
NEW QUESTION # 84
You have a Microsoft 365 ES subscription that includes Microsoft Intune.
The subscription contains Android Enterprise devices that are enrolled in Intune and have personally-owned work profiles. All the Android devices are members of a group named Group1.
You need to ensure that end users and Intune administrators receive an email message when an Android device does not have an up-to-date security provider Which actions should you perform from the Microsoft Intune admin center in sequence? To answer, drag the appropriate actions to the correct order. Each action may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 85
You have a Microsoft 365 subscription.
All users have Microsoft 365 apps deployed.
You need to configure Microsoft 365 apps to meet the following requirements:
* Enable the automatic installation of WebView2 Runtime.
* Prevent users from submitting feedback.
Which two settings should you configure in the Microsoft 365 Apps admin center? To answer, select the appropriate settings in the answer area.
You can enable automatic installation in the same setting as where you prevent it from being installed automatically:
To prevent the automatic installation of WebView2 Runtime, sign in to the Microsoft 365 Apps admin center (https://config.office.com) with an admin account. Then, go to Customization > Device Configuration > Modern Apps Settings. Select Microsoft Edge WebView2 and then clear the Enable automatic installation of WebView2 Runtime check box.
https://learn.microsoft.com/en-us/deployoffice/webview2-install
Prevent users from submitting feedback:
https://learn.microsoft.com/en-u ... k-ms-org?view=o365- worldwide
NEW QUESTION # 86
Your network contains an Active Directory domain.
You install the Microsoft Deployment Toolkit (MDT) on a server.
You have a custom image of Windows 11.
You need to deploy the image to 100 devices by using MDT.
Which three actions should you perform in sequence? To answer, move answer area and arrange them in the correct order.
To deploy the Windows 11 image to 100 devices by using MDT, you should perform the following three actions in sequence:
Install Windows Deployment Services (WDS) on the server. WDS is a role that enables you to deploy Windows operating systems over the network by using PXE boot and multicast technologies. You need to install WDS before you can enable multicast and configure the boot images for MDT. You can install WDS by using the Server Manager or PowerShell1.
Create a deployment share on the server. A deployment share is a folder that contains the MDT files, scripts, applications, drivers, operating systems, and task sequences that you use to deploy Windows. You need to create a deployment share by using the MDT Deployment Workbench2.
Add the Windows 11 image and create a task sequence in the deployment share. An image is a file that contains a snapshot of a Windows installation. A task sequence is a set of steps that MDT executes to install Windows and configure the settings. You need to add the Windows 11 image by importing it from a source folder or a WIM file, and create a task sequence by using a template or customizing your own3.
These are the basic steps to prepare for deploying Windows 11 with MDT. For more details and guidance, you can refer to the web search results I found for you by using search_web("deploy Windows 11 image with MDT").
NEW QUESTION # 87
You have computers that run Windows 10 and are configured by using Windows AutoPilot.
A user performs the following tasks on a computer named Computer1:
* Creates a VPN connection to the corporate network
* Installs a Microsoft Store app named App1
* Connects to a Wi-Fi network
You perform a Windows AutoPilot Reset on Computer1.
What will be the state of the computer when the user signs in? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
https://docs.microsoft.com/en-us ... ows-autopilot-reset
NEW QUESTION # 88
It is universally acknowledged that Microsoft certification can help present you as a good master of some knowledge in certain areas, and it also serves as an embodiment in showcasing one’s personal skills. However, it is easier to say so than to actually get the Microsoft certification. We have to understand that not everyone is good at self-learning and self-discipline, and thus many people need outside help to cultivate good study habits, especially those who have trouble in following a timetable. To handle this, our MD-102 test training will provide you with a well-rounded service so that you will not lag behind and finish your daily task step by step. At the same time, our MD-102 study torrent will also save your time and energy in well-targeted learning as we are going to make everything done in order that you can stay focused in learning our MD-102 study materials without worries behind. We are so honored and pleased to be able to read our detailed introduction and we will try our best to enable you a better understanding of our MD-102 test training better.
MD-102 Download Pdf: https://www.dumpsking.com/MD-102-testking-dumps.html
P.S. Free & New MD-102 dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1uoaGBir_SCNLC4c8FtBWlGCGsR8sXcK4
