Valid Test Project-Planning-Design Test - Simulations Project-Planning-Design Pd
87
Posted at 2/16/2026 02:54:45      View92 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 NCARB Project-Planning-Design dumps are available on Google Drive shared by CramPDF: https://drive.google.com/open?id=1G6YRsOow-mhCJ20BcnXMhLCT9J3yT6_3
Just like the old saying goes, motivation is what gets you started, and habit is what keeps you going. A good habit, especially a good study habit, will have an inestimable effect in help you gain the success. The Project-Planning-Design Study Materials from our company will offer the help for you to develop your good study habits. If you buy and use our study materials, you will cultivate a good habit in study.
NCARB Project-Planning-Design Exam Syllabus Topics:
  • Environmental Conditions & Context: This section of the exam measures skills of architectural designers and covers how to use site analysis information to determine building placement and environmental planning decisions. It emphasizes applying sustainable principles and considering the neighborhood context to guide project design.
  • Project Integration of Program & Systems: This section of the exam measures skills of project architects and focuses on integrating decisions about environmental conditions, codes, and building systems into one cohesive project design. It highlights how to configure the building and incorporate both program requirements and contextual conditions in a unified design approach.
  • Building Systems, Materials, & Assemblies:  This section of the exam measures skills of architectural designers and covers the understanding of building systems such as mechanical, electrical, and plumbing, along with structural and specialty systems. It also involves selecting appropriate materials and assemblies to align with program needs, budgets, and regulations.
  • Project Costs & Budgeting: This section of the exam measures skills of architectural designers and assesses the ability to evaluate design alternatives based on program goals, perform cost evaluations, and manage cost considerations throughout the design process.
Topic 5
  • Codes & Regulations: This section of the exam measures the skills of project architects and focuses on applying zoning laws, environmental rules, and building codes during the planning stage. Candidates are tested on how to integrate multiple regulatory requirements into a projects design effectively.
Simulations Project-Planning-Design Pdf - Official Project-Planning-Design Practice TestOur website offer you the latest Project-Planning-Design dumps torrent in pdf version and test engine version, which selected according to your study habit. You can print our Project-Planning-Design practice questions out and share the materials with your classmates and friends. The test engine version is a way of exam simulation that helps you get used to the atmosphere of Project-Planning-Design Real Exam and solve the problems with great confidence.
NCARB ARE 5.0 Project Planning & Design (PPD) Sample Questions (Q19-Q24):NEW QUESTION # 19
The zoning approval process may involve obtaining which of the following? Check the four that apply.
  • A. Grading permit
  • B. Building permit
  • C. Variance
  • D. Undue hardship exemption
  • E. Conditional use
  • F. Special exception
Answer: A,C,E,F
Zoning approval can involve:
Variance (A): Permission to deviate from zoning requirements.
Grading permit (C): Approves site grading related to zoning.
Conditional use (D): Allows use under specific conditions.
Special exception (E): Permits uses not normally allowed but granted under certain circumstances.
Building permits (B) are separate from zoning.
Undue hardship exemption (F) is legal but not typically a zoning approval term.
ARE 5.0 PPD - Codes and Regulations, Zoning
The Architect's Handbook of Professional Practice, 15th Edition - Land Use Controls
NEW QUESTION # 20
An elementary school requires a renovation, selective demolition, and a major addition in order to accommodate a growing student population. An architectural firm has prepared schematic design plans incorporating the school's increased programmatic needs, including an enlarged library, cafeteria, and gymnasium; a secure courtyard; and additional space for administrative offices and classrooms. The main entrance was relocated in order to improve the traffic and pedestrian flow at the beginning and end of the school day, and additional parking was provided to comply with current zoning requirements.
The existing single-story masonry building was built in 1950. Two small additions were built later: the north addition will be kept and repurposed, but the south addition will be demolished. The building contains asbestos and lead in roof soffits, floor tiles, pipe insulation, and window paint. All existing mechanical systems need to be replaced; new systems have not been selected.
Considerations for the renovation include:
* The relocated front entrance must be easily recognizable, highly visible, and secure.
* Interior and exterior materials need to be durable and maintainable in order to withstand frequent student abuse, but also economical due to strict budget limitations.
* Good indoor air quality and increased energy efficiency are priorities for the selection of mechanical equipment.
After completion, the entire school should look uniform, without a distinctive difference between the existing building and new addition.
Building information:
* Construction Type is II-B.
The following resources are available for your reference:
* Existing Plans, including site and floor plans
* Proposed Plans, including site and floor plans
* Cost Analysis
* Zoning Ordinance Excerpts, for off-street parking requirements
* IBC Excerpts, showing relevant code sections
* ADA Standards Excerpts, showing relevant sections from the ADA Standards for Accessible Design Which of the following is the maximum height the platform can be above the gymnasium floor per the proposed design?
  • A. 1'-6"
  • B. 1'-9"
  • C. 2'-6"
Per building and accessibility codes (such as ADA and IBC), raised platforms or stages in assembly areas like gymnasiums are limited in height to ensure safe access and egress. A maximum height of 1 foot 6 inches (18 inches) without requiring additional stairs or ramps is common to allow easy transition and avoid additional egress requirements.
Heights above 18 inches typically require stairs or ramps per ADA.
1'-9" or 2'-6" exceed these limits and would trigger additional code requirements.
IBC Chapter 10 - Means of Egress
NEW QUESTION # 21
Heavy steel columns and rigid connections between columns and beams
Vertical steel trusses in the external walls
Light steel columns and flexible connections between columns and beams
Vertical steel trusses in the internal walls
Which structural design concept minimizes the cost of steel structure needed to resist wind and earthquake loads in high-rise buildings?
  • A. Light steel columns and flexible connections between columns and beams
  • B. Vertical steel trusses in the internal walls
  • C. Heavy steel columns and rigid connections between columns and beams
  • D. Vertical steel trusses in the external walls
Using vertical steel trusses in the external walls (B) allows for efficient lateral load resistance by creating a stiff, braced perimeter that resists wind and seismic forces with less material compared to internal bracing or heavy columns.
Heavy steel columns and rigid connections (A) require more steel and complex joints, increasing cost.
Light steel columns with flexible connections (C) provide less stiffness and require more members.
Internal steel trusses (D) reduce usable space and complicate architectural layouts.
External vertical trusses optimize structural efficiency and cost, as supported in NCARB PPD guidelines for high-rise construction.
ARE 5.0 PPD - Structural Systems
The Architect's Handbook of Professional Practice, 15th Edition - Steel Structures
NEW QUESTION # 22
An architect is working with a developer to determine which of three available sites should be the preferred location for a new office building that will primarily utilize passive energy systems. All three sites are located in a cold, northern climate with winter winds predominantly from the north and west.
Site descriptions:
Site A: Located at the top of a hill; small vegetation and brush; expansive views in all directions.
Site B: Located along a river; heavily wooded area on the north side; coniferous trees shading the southern face of the building.
Site C: Located on a rocky, south-facing slope; wooded on the eastern edge; native grasses on southern boundary.
Primary goal: maximize solar energy potential while maintaining winter wind protection.
Which site should be selected?
  • A. Site A
  • B. Site B
  • C. Site C
Site C offers a south-facing slope, which maximizes solar exposure-crucial in cold climates for passive solar heating. The wooded eastern edge provides wind protection from cold morning winds, and native grasses on the south reduce erosion while minimally shading.
Site A, on a hilltop with sparse vegetation, lacks wind protection.
Site B has coniferous trees shading the southern face, reducing solar gain, which is counterproductive for passive solar design.
Thus, Site C optimizes both solar potential and wind protection.
ARE 5.0 PPD - Environmental Conditions and Context, Passive Solar Design The Architect's Handbook of Professional Practice, 15th Edition - Sustainable Site Planning
NEW QUESTION # 23
An architect is selecting a mechanical system for the first floor of a hotel in a temperate climate. They must consider the following:
* The building footprint covers 95% of the small urban site.
* The first floor has an open floor plan that includes a lobby, bar, and restaurant.
* The plan can only accommodate one 500 sf mechanical room.
What mechanical system should the architect recommend?
  • A. Geothermal heat pump
  • B. Packaged terminal air conditioners
  • C. Variable refrigerant flow system
Variable Refrigerant Flow (VRF) systems are ideal for buildings with space constraints and diverse internal loads. They provide zoned heating and cooling from a compact mechanical room and allow flexibility with open floor plans by serving multiple zones with variable refrigerant volumes.
Geothermal heat pumps (A) require larger mechanical or ground loop spaces and are less practical in tight urban footprints.
Packaged terminal air conditioners (B) serve individual rooms and require space for multiple units and wall penetrations, which may not be feasible in this context.
Hence, VRF systems balance space efficiency, energy performance, and zoning flexibility.
ARE 5.0 PPD - Building Systems and Assemblies, HVAC Systems
The Architect's Handbook of Professional Practice, 15th Edition - Mechanical Systems
________________________________________
NEW QUESTION # 24
CramPDF offers you a full refund if you are not able to pass the Project-Planning-Design certification exams after preparing with our products. The high quality of Project-Planning-Design certification exam preparation products increases your success probability and reduces the chances of failure. The Project-Planning-Design exam preparation products contain all the features to make you ready for embracing success in a first attempt. These Project-Planning-Design Exam Preparation products are updated regularly for guaranteed success. Free demo is also offered to the users for checking the Project-Planning-Design exam preparation products quality.
Simulations Project-Planning-Design Pdf: https://www.crampdf.com/Project-Planning-Design-exam-prep-dumps.html
2026 Latest CramPDF Project-Planning-Design PDF Dumps and Project-Planning-Design Exam Engine Free Share: https://drive.google.com/open?id=1G6YRsOow-mhCJ20BcnXMhLCT9J3yT6_3
Posted at 4/20/2026 04:26:22        Only Author  2#
The article is outstanding, thank you for sharing! Wishing myself success as I prepare for the Well JN0-224 prep exam!
