[Hardware] 100% Pass Quiz JN0-224 - Reliable Automation and DevOps, Associate (JNCIA-DevOps
87
Hardware 100% Pass Quiz JN0-224 - Reliable Automation and DevOps, Associate (JNCIA-DevOps
Posted at 2/16/2026 02:59:06      View202 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepAwayPDF JN0-224 dumps for free: https://drive.google.com/open?id=1MuA0OwkmhWpH6WbVbQJBBqqGdv0Rby3d
Keep making progress is a very good thing for all people. If you try your best to improve yourself continuously, you will that you will harvest a lot, including money, happiness and a good job and so on. The JN0-224 preparation exam from our company will help you keep making progress. Choosing our JN0-224 Study Material, you will find that it will be very easy for you to overcome your shortcomings and become a persistent person. Our JN0-224 exam dumps will lead you to success!
In order to facilitate the wide variety of users' needs the JN0-224 study guide have developed three models with the highest application rate in the present - PDF, software and online. No matter you are a student, a office staff or even a housewife, you can always find your most situable way to study our JN0-224 Exam Q&A. Generally speaking, these three versions of our JN0-224 learning guide can support study on paper, computer and all kinds of eletronic devices. They are quite convenient.
JN0-224 Questions Exam | JN0-224 CertificationYou may be get refused by so many JN0-224 study dumps in thehe present market, facing so many similar JN0-224 study guide , so how can you distinguish the best one among them? We will give you some suggestions, first of all, you need to see the pass rate, for all the efforts we do to the JN0-224 Study Dumps is to pass . Our company guarantees the high pass rate. Second, you need to see the feedback of the customers, since the customers have used it, and they have the evaluation of the JN0-224 study guide.
Juniper JN0-224 Exam Syllabus Topics:
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
Topic 5
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q38-Q43):NEW QUESTION # 38
Which two programming languages are used for Junos on-box scripting? (Choose two.)
  • A. SLAX
  • B. Perl
  • C. Ruby
  • D. XSLT
Junos on-box scripting supports the following programming languages:
SLAX (C): SLAX (Structured Language for XML) is a scripting language designed specifically for Junos devices. It allows for easy manipulation of XML data, making it ideal for creating Junos scripts that interact with device configurations.
XSLT (D): XSLT (Extensible Stylesheet Language Transformations) is another language used for transforming XML documents into other formats. It is commonly used in Junos for transforming XML data into different views or outputs.
Options A (Perl) and B (Ruby) are not used for Junos on-box scripting. While these languages are popular in other contexts, Junos scripting relies heavily on XML-based languages like SLAX and XSLT.
Junos XML API and Scripting Guide: Describes the use of SLAX and XSLT for on-box scripting.
Juniper Networks Automation Documentation: Provides examples and best practices for using SLAX and XSLT in Junos scripting.
NEW QUESTION # 39
Which statement is correct about Ansible playbooks?
  • A. A playbook contains one or more tasks written in XML
  • B. A playbook can contain multiple tasks and execute multiple Python modules
  • C. A playbook is a configuration file that defines the Ansible related parameters
  • D. A playbook is a specific Python module that is executed on a host
NEW QUESTION # 40
You are asked to use the REST API to retrieve interface configuration information from your Junos device. You decide to use a cURL HTTP GET command to retrieve this information.
In this scenario, which statement is correct?
  • A. The request is handled by the isrpd process running on the Junos device.
  • B. The request is handled by the rpd process running on the Junos device.
  • C. The request is handled by the mod process running on the Junos device.
  • D. The request is handled by the isd process running on the Junos device
When using the REST API on a Junos device, the isrpd (Integrated Service Routing Process Daemon) process is responsible for handling REST API requests. This process listens for incoming HTTP requests and processes them accordingly, including retrieving interface configuration information when a GET request is made.
Option B is correct because the isrpd process handles the REST API requests on a Junos device.
Options A (mod process), C (rpd process), and D (isd process) are incorrect in this context as they either do not exist or serve different purposes on a Junos device.
Supporting Reference:
Juniper Networks REST API Documentation: Provides insights into how REST API requests are managed and processed by the isrpd process on Junos devices.
NEW QUESTION # 41
Which Python operator is used to test if two variables are equal?
  • A. !=
  • B. %
  • C. =
  • D. ==
In Python, the == operator is used to test whether two variables are equal. It returns True if the variables are equal and False if they are not.
Option B (==) is correct because it is the equality operator in Python.
Option A (!=) is used for inequality, Option C (%) is the modulus operator, and Option D (=) is used for assignment, not for testing equality.
Python Documentation on Operators: The official Python documentation covers the use of == for equality checks.
NEW QUESTION # 42
Which two statements about Junos automation are correct? (Choose two.)
  • A. Junos automation does not allow for device provisioning throuqh the console port.
  • B. Junos automation allows for device provisioning through the console port.
  • C. The Junos REST API client is on-box.
  • D. The Junos REST API client is off-box.
A). The Junos REST API client is on-box:
The Junos REST API is on-box, meaning it is hosted directly on the Junos OS device. This allows you to interact with the device through RESTful API calls without needing an external client to act as an intermediary. With the on-box REST API, users can manage and automate configuration and operational tasks directly from the Junos device itself using HTTP/HTTPS protocols. This simplifies automation and remote management since the API server is embedded within the device.
Key Automation Capabilities of On-box REST API:
Supports configuration, monitoring, and operational commands.
Allows for direct device interaction via tools like curl, or through custom-built automation scripts.
C . Junos automation allows for device provisioning through the console port:
Junos automation does indeed allow for device provisioning through the console port, especially in the context of Zero Touch Provisioning (ZTP). When network interfaces are not initially configured, or when remote access is not possible, devices can be provisioned via the console port. This method is commonly used during the initial setup process, enabling administrators to deploy configurations even without network access. ZTP automates initial configurations, including system setup and software installation, which can be triggered via the console.
Key Advantages of Console-based Provisioning:
Useful in environments where network interfaces are unavailable or not yet configured.
Essential for the initial bootstrapping of devices in remote locations.
Why the Other Options Are Incorrect:
B . Junos automation does not allow for device provisioning through the console port: This statement is incorrect because Junos automation does allow for provisioning via the console port, particularly during initial device setups.
D . The Junos REST API client is off-box: This is incorrect because the REST API client can be directly on the Junos device, providing local API functionality (on-box).
Juniper Automation in DevOps Context: Junos automation, especially with on-box REST API and console-based provisioning, enhances the flexibility and accessibility of device management in DevOps environments. These capabilities simplify remote configuration, monitoring, and device setup even in cases where direct network access is unavailable.
NEW QUESTION # 43
Our JN0-224 study materials are the best choice in terms of time and money. And all contents of JN0-224 training prep are made by elites in this area. Furthermore, JN0-224 Quiz Guide gives you 100 guaranteed success and free demos. To fit in this amazing and highly accepted JN0-224 Exam, you must prepare for it with high-rank practice materials like our JN0-224 study materials. We can ensure your success on the coming exam and you will pass the JN0-224 exam just like the others.
JN0-224 Questions Exam: https://www.prepawaypdf.com/Juniper/JN0-224-practice-exam-dumps.html
P.S. Free 2026 Juniper JN0-224 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=1MuA0OwkmhWpH6WbVbQJBBqqGdv0Rby3d
Posted at 4/20/2026 05:56:42        Only Author  2#
Mit der Hilfe von ITZert brauchen Sie nicht so viel Geld fr die Kurse oder viel Zeit und Energie fr die Prfung auszugeben. Sie können ganz einfach die EMC D-UN-DY-23 (Dell Unity Deploy 2023 Exam)Prfung erfolgreich ablegen. Die Software zur EMC D-UN-DY-23 Zertifizierungsprfung wird ITZert nach den echten Prfungen in den letzten Jahren erforscht. Die Fragen und Antworten zur EMC D-UN-DY-23 Zertifizierungsprfung von ITZert sind den realen Fragen und Antworten sehr ähnlich.
