AEE CEM Web-Based Practice Test Software
102
Posted at 2/16/2026 04:25:47      View82 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4cram CEM dumps now are free: https://drive.google.com/open?id=1dlOHa4xs83f8QnUGKT_SvI8NDywFjoVs
Downloading the CEM free demo doesn't cost you anything and you will learn about the pattern of our practice exam and the accuracy of our CEM test answers. We constantly check the updating of CEM vce pdf to follow the current exam requirement and you will be allowed to free update your pdf files one-year. Don't hesitate to get help from our customer assisting.
We know that every user has their favorite. Therefore, we have provided three versions of CEM practice guide: the PDF, the Software and the APP online. You can choose according to your actual situation. If you like to use computer to learn, you can use the Software and the APP online versions of the CEM Exam Questions. If you like to write your own experience while studying, you can choose the PDF version of the CEM study materials. Our PDF version can be printed and you can take notes as you like.
Pass Guaranteed Quiz AEE - CEM - Certified Energy Manager (CEM) CValid Pass ExamPrep4cram expect to design such an efficient study plan to help you build a high efficient learning attitude for your further development. Our CEM study torrent are cater every candidate no matter you are a student or office worker, a green hand or a staff member of many years' experience. Therefore, you have no need to worry about whether you can pass the CEM Exam, because we guarantee you to succeed with our technology strength. The language of our CEM exam questions are easy to follow and the pass rate of our CEM learning guide is as high as 99% to 100%.
AEE Certified Energy Manager (CEM) Sample Questions (Q138-Q143):NEW QUESTION # 138
In a typical compressed air system, energy can be saved by which of the following actions?
  • A. Decreasing supply air pressure
  • B. Move the inlet air filter to a warmer location
  • C. Reducing the air distribution pipe size
  • D. Raising the air pressure
  • E. Reducing the capacity of the compressed air receiver tanks
NEW QUESTION # 139
The temperature in an unconditioned mechanical room is found to typically be around 23C warmer than ambient air. If the air intake of an air compressor located in the mechanical room is routed through a nearby wall so that ambient air is fed directly to the air compressor's intake, what impact can be expected on the air compressor's energy requirement?
  • A. No measureable change in energy use
  • B. Decrease energy use by 7.6%
  • C. Increase energy use by 3.8%
  • D. Decrease energy use by 3.8%
  • E. Increase energy use by 7.6%
NEW QUESTION # 140
A 7 bar (gauge pressure) compressed air system has 5 leaks that are 3 mm in diameter and 3 leaks that are 6 mm in diameter. The compressed-air system is pressurized 8,760 hours per year. Electricity cost is $0.10
/kWh. What is the annual cost of the leaks in the compressed air system?
  • A. $18,150/yr
  • B. $25,220/yr
  • C. $48,480/yr
  • D. $30,910/yr
  • E. $56,500/yr
NEW QUESTION # 141
A high-pressure steam system passes 180C condensate (saturated liquid) through a steam trap to an atmospherically vented condensate receiver tank. If the steam trap is working properly, how much of the condensate mass can be lost out the vent of the receiver tank in the form of flash steam?
  • A. 6%
  • B. 25%
  • C. 66%
  • D. 15%
  • E. 100%
NEW QUESTION # 142
Electricity costs SO. 10 per kWh. if an electric water heater has an efficiency of 95*6. what is the equivalent price of natural gas per Gigajoule for a natural gas water heater? The natural gas water heater has an efficiency of 95*t based on lower-heating value.
[Natural gas has an energy content of 36.400 K|/m3 (higher-heating value) and 32-760 K/m3 (lower-heating value).] SELECT THE CORRECT ANSWER
  • A. $33 /GJ
  • B. $15/GJ
  • C. $25 /GJ
  • D. $21 /GJ
To determine the equivalent price of natural gas per gigajoule (GJ) for a natural gas water heater, we compare the cost of electricity and natural gas on an energy-equivalent basis.
Step 1: Convert Electricity Cost to Cost per GJ
* Electricity cost0.10/kWh
* 1 GJ =277.8 kWh
A table with numbers and equations AI-generated content may be incorrect.
NEW QUESTION # 143
Let me tell the advandages of using the CEM practice engine. First of all, CEM exam materials will combine your fragmented time for greater effectiveness, and secondly, you can use the shortest time to pass the exam to get your desired certification. Our CEM Study Materials allow you to improve your competitiveness in a short period of time. With the help of our CEM guide prep, you will be the best star better than others.
CEM Valid Exam Practice: https://www.prep4cram.com/CEM_exam-questions.html
We are devoted to provide candidates with the most reliable CEM valid vce and CEM test questions, Please trust our CEM exam torrent, After received your CEM exam dumps, you just need to spend your spare time to practice CEM real questions and remember CEM exam answers, (CEM pass-sure torrent) In the old days, we mainly use the paper learning and read lots of reference books, which is rather hard task that takes plenty of time and consumes much more energy.
Adding an ActiveX Control in FrontPage, Many CEM understand the necessity for continued communication as the application takes shape, We are devoted to provide candidates with the most reliable CEM Valid Vce and CEM test questions.
CEM exam study guidePlease trust our CEM exam torrent, After received your CEM exam dumps, you just need to spend your spare time to practice CEM real questions and remember CEM exam answers.
You should know that God helps people who help themselves.
P.S. Free & New CEM dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=1dlOHa4xs83f8QnUGKT_SvI8NDywFjoVs
