[General] Plat-Arch-204 Certified Questions, Plat-Arch-204 Visual Cert Test
121
【General】 Plat-Arch-204 Certified Questions, Plat-Arch-204 Visual Cert Test
Posted at 2/16/2026 06:05:26      View:115 | Replies:2        Print      Only Author   [Copy Link] 1#
As far as our Plat-Arch-204 practice test is concerned, the PDF version brings you much convenience with regard to the following two aspects. On the one hand, the PDF version contains demo where a part of questions selected from the entire version of our Plat-Arch-204 test torrent is contained. In this way, you have a general understanding of our actual prep exam, which must be beneficial for your choice of your suitable exam files. On the other hand, our Plat-Arch-204 Preparation materials can be printed so that you can study for the exams with papers and PDF version. With such benefits, why don't you have a try?
Salesforce Plat-Arch-204 Exam Syllabus Topics:
  • Translate Needs to Integration Requirements: This domain involves converting business needs into technical specifications by documenting systems and patterns, evaluating constraints, defining security requirements, and determining performance needs like volumes, response times, and latency.
  • Maintain Integration: This domain focuses on monitoring integration performance, defining error handling and recovery procedures, implementing escalation processes, and establishing reporting needs for ongoing integration health monitoring.
  • Build Solution: This domain covers implementing integrations including API design considerations, choosing outbound methods, building scalable solutions, implementing error handling, creating security solutions, and ensuring resilience during system updates.
  • Design Integration Solutions: This domain centers on selecting integration patterns, designing complete solutions with appropriate components, understanding trade-offs and limitations, choosing correct Salesforce APIs, and determining required standards and security mechanisms.
Accurate Salesforce Plat-Arch-204 Practice Test - Pass The Exam QuicklyThe real and updated Easy4Engine Plat-Arch-204 exam dumps file, desktop practice test software, and web-based practice test software are ready for download. Take the best decision of your professional career and enroll in the Salesforce Certified Platform Integration Architect (Plat-Arch-204) certification exam and download Easy4Engine Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam questions and starts preparing today.
Salesforce Certified Platform Integration Architect Sample Questions (Q41-Q46):NEW QUESTION # 41
An integration architect has designed a mobile application for Salesforce users to get data while on the road using a custom user interface (UI). The application is secured with OAuth and is currently functioning well. There is a new requirement where the mobile application needs to obtain the GPS coordinates and store them on a custom geolocation field. The geolocation field is secured with field-level security, so users can view the value without changing it. What should be don4e to meet the requirement?
  • A. The mobil10e device makes a REST Apex inbound call.
  • B. The mobile device receives19 a REST Apex callout call.
  • C. The 15mobile device makes a REST API inboun16d call.
When a custom mobile application already secured with OAuth needs to update a record in Salesforce, the standard architectural recommendation is to use the REST API. The REST API is optimized for mobile environments because it uses lightweight JSON payloads and follows standard HTTP methods (such as PATCH for updates), which are highly compatible with mobile development frameworks.
In this specific scenario, the architect must address the Field-Level Security (FLS) constraint. Because the geolocation field is set to read-only for users, a standard UI-based update would typically fail. However, when using an inbound REST API call with a properly authorized integration user or via a "System Mode" context (if utilizing a custom Apex REST resource), the system can be configured to bypass UI-level restrictions while maintaining data integrity.
The mobile device captures the coordinates via the device's native GPS capabilities and initiates an inbound call to the Salesforce REST endpoint. Option A (Apex inbound call) is a subset of REST functionality but is only necessary if complex server-side logic is required that the standard REST API cannot handle. Option C is technically incorrect as mobile devices do not typically "receive" callouts from Salesforce in this pattern; they initiate the requests. By leveraging the standard REST API, the architect ensures a scalable, secure, and standardized integration that adheres to Salesforce's mobile-first integration principles.
NEW QUESTION # 42
Northern Trail Outfitters (NTO) has an affiliate company that would like immediate notifications of changes to opportunities in the NTO Salesforce instance. The affiliate company has a CometD client available.
Which solution is recommended in order to meet the requirement?
  • A. Create a connected app in the affiliate org and select "Accept CometD API Requests".
  • B. Implement a polling mechanism in the client that calls the SOAP API getUpdated method to get the ID values of each updated record.
  • C. Create a PushTopic update event on the Opportunity object to allow the subscriber to react to the streaming API.
To provide "immediate notifications" to a client that already supports CometD, the architect must utilize Salesforce's Streaming API. PushTopic Events are the classic Streaming API implementation for broadcasting changes to specific records.
A PushTopic is a definition that includes a SOQL query and a set of trigger events (Create, Update, Delete). When an Opportunity in NTO's instance is updated and matches the query, Salesforce automatically pushes a notification to the topic's channel. The affiliate's CometD client, having subscribed to this channel, receives the data payload instantly.12 Option A (Polling) is the architectural opposite of "immediate notifications". Polling is inefficient, consumes API limits, and int13roduces latency between the actual record change and the client's discovery of that change. Option C is incorrect as there is no "Accept CometD" setting in a Connected App; while a Connected App is used for OAuth authentication, the PushTopic is the mechanism that actually defines and delivers the stream. By using PushTopic, NTO provides a decoupled, event-driven architecture that fulfills the requirement for real-time visibility while minimizing the technical burden on the affiliate's infrastructure.
NEW QUESTION # 43
A subscription-based media company's system landscape forces many subscribers to maintain multiple accounts and to log in more than once. An Identity and Access Management (IAM) system, which supports SAML and OpenID, was recently implemented to improve the subscriber experience through self-registration and single sign-on (SSO). The IAM system must integrate with Salesforce to give new self-service customers instant access to Salesforce Community Cloud.
  • A. SAML SSO and Registration Handler
  • B. OpenID Connect Authentication Provider and Registration Handler2
  • C. OpenID Connect Authentication Provider and Just-in-Time (JIT) provisioning1
To provide "instant access" and a seamless experience for Community (Experience Cloud) users, the architect must choose an authentication and provisioning strategy that handles user creation on-the-fly. While both SAML and OpenID Connect (OIDC) are viable for SSO, OpenID Connect is the modern standard for consumer-facing "Social" or external identity integrations because it is built on OAuth 2.0.
The critical component for "self-service" is the Registration Handler. When an OpenID Connect Authentication Provider is configured in Salesforce, you must associate it with an Apex class that implements the Auth.RegistrationHandler interface. This handler is executed during the SSO flow if the user does not already exist. It provides the architect with full programmatic control to:
Match the incoming identity to an existing Contact or Account.
Create a new Contact record if one doesn't exist.
Provision a new User record with the correct Profile, Permission Sets, and Locale settings.
Link the User to the correct Account hierarchy, which is vital for Community security models.
Option A suggests Just-in-Time (JIT) provisioning, which is a declarative way to create users. However, JIT is often too rigid for Experience Cloud requirements, as it has limited ability to perform complex data lookups or handle the specific linking of Contacts to Accounts required for external users. Option C is technically mismatched in common Salesforce terminology; while SAML uses JIT, the Registration Handler is the native, specific mechanism designed to work with Authentication Providers (like OIDC). By using B, the company ensures that a subscriber logging in for the first time via the IAM system is instantly and accurately provisioned in Salesforce, eliminating the need for multiple accounts.
NEW QUESTION # 44
An architect decided to use Platform Events for integrating Salesforce with an external system for a company. What should an architect consider when proposing this type of integration mechanism?
  • A. External system needs to have the same uptime in order to be able to keep up with Salesforce Platform Events.
  • B. To subscribe to an event, the integration user in Salesforce needs Read access to the event entity.
  • C. Salesforce needs to be able to store information about the external system in order to know which event to send out.
When proposing Platform Events as an integration mechanism, an architect must ensure that the security model is correctly configured to allow for the publication and subscription of events. Unlike standard objects, Platform Events have specific permission requirements for the "Integration User" or any system entity interacting with the event bus.
For an external system to subscribe to a Platform Event stream (via CometD or the Pub/Sub API), the user account used to authenticate the connection must have the "Read" permission on the specific Platform Event entity. Similarly, if the external system needs to publish events back into Salesforce, the user must have "Create" permissions. These permissions are typically managed through a Profile or a Permission Set assigned to the Integration User.
Regarding the other options, Option A is incorrect because Platform Events are designed for asynchronous communication. They are inherently decoupled; the external system does not need the same uptime as Salesforce. High-volume platform events are stored in the event bus for 72 hours, allowing an external system to "catch up" using a Replay ID once it comes back online. Option C is also incorrect because Platform Events follow a Publish/Subscribe pattern. Salesforce "broadcasts" the event to the bus without needing to know which specific external systems are listening. This decoupling is a primary advantage of event-driven architecture, as it allows for a "one-to-many" distribution model where multiple systems can consume the same message without additional configuration within Salesforce. Thus, ensuring the correct object-level permissions (Read/Create) is the most critical technical consideration for the architect to guarantee successful message delivery.
NEW QUESTION # 45
Northern Trail Outfitters requires an integration to be set up between one of its Salesforce orgs and an External Data Source using Salesforce Connect. The External Data Source supports Open Data Protocol. Which configuration should an integration architect recommend be implemented in order to secure requests coming from Salesforce?
  • A. Configure a certificate for OData connection.
  • B. Configure Special Compatibility for OData connection.
  • C. Configure Identity Type for OData connection.
Salesforce Connect is a powerful tool for data virtualization, allowing users to view and manage data in external systems (via OData) as if it were stored natively in Salesforce. However, a critical security decision during the setup of an External Data Source is determining the Identity Type.
The Identity Type determines how the external system authenticates the Salesforce user. There are two primary options:
Named Principal: Every Salesforce user accesses the external system using the same set of credentials. This is easier to maintain but provides less granular security tracking in the target system.
Per User: Each individual Salesforce user must provide their own credentials for the external system. This ensures that the data visible in Salesforce respects the user's specific permissions in the external source.
Configuring the Identity Type is the fundamental way an architect secures OData requests because it defines the authentication boundary between the platforms. While certificates (Option A) can be used for transport layer security, the "Identity Type" configuration is the specific Salesforce Connect setting that governs how a session is authorized. Option B (Special Compatibility) is a technical setting used to handle non-standard OData implementations and does not directly relate to securing the request. By recommending the correct Identity Type, the architect ensures that the integration adheres to the "rinciple of Least Privilege," ensuring that users only see the external data they are authorized to access.
NEW QUESTION # 46
About the Plat-Arch-204 Exam Certification, reliability can not be ignored. Plat-Arch-204 exam training materials of Easy4Engine are specially designed. It can maximize the efficiency of your work. We are the best worldwide materials provider about this exam.
Plat-Arch-204 Visual Cert Test: https://www.easy4engine.com/Plat-Arch-204-test-engine.html
Posted at 2/24/2026 07:15:25        Only Author  2#
This article is brilliant, and I’ve gained many insights from it. Free DCPLA valid test format to help you enhance your IT skills. Wishing you good luck!
Posted at 3/7/2026 14:32:14        Only Author  3#
That article was nothing less than inspiring. I got a promotion and raise with the help of the Latest exam XSOAR-Engineer dumps materials. Now, I’m offering it for free. Wishing you all success in your career growth!
