[General] Salesforce Integration-Architect Pdf Format Practice Program
92
【General】 Salesforce Integration-Architect Pdf Format Practice Program
Posted at 2/16/2026 06:41:02      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeDump Integration-Architect PDF Dumps and Integration-Architect Exam Engine Free Share: https://drive.google.com/open?id=1XtGl4WRVeHGZ4lp-b9yBfQjiM26eGKvy
If you have PracticeDump Integration-Architect Exam Questions, you don't need a person to help you with reading and explaining the facts. This Salesforce Integration-Architect exam questions material is available in pdf so that anyone can study it without any difficulty. On the other hand, to understand real exam's format, you can easily take PracticeDump Integration-Architect Practice Exams. These Salesforce Certified Integration Architect (Integration-Architect) practice tests help you know how much you can score and if is it the right time to apply for the Salesforce Certified Integration Architect (Integration-Architect) certification exam or if you should wait for a little.
You choosing PracticeDump to help you pass Salesforce certification Integration-Architect exam is a wise choice. You can first online free download PracticeDump's trial version of exercises and answers about Salesforce Certification Integration-Architect Exam as a try, then you will be more confident to choose PracticeDump's product to prepare for Salesforce certification Integration-Architect exam. If you fail the exam, we will give you a full refund.
New Integration-Architect Test Voucher & Integration-Architect Relevant Exam DumpsThe time and energy are all very important for the office workers. In order to get the Integration-Architect certification with the less time and energy investment, you need a useful and valid Integration-Architect study material for your preparation. Integration-Architect free download pdf will be the right material you find. The comprehensive contents of Integration-Architect practice torrent can satisfied your needs and help you solve the problem in the actual test easily. Now, choose our Integration-Architect study practice, you will get high scores.
Salesforce Certified Integration Architect Sample Questions (Q69-Q74):NEW QUESTION # 69
Northern Trail Outfitters (NTO) has an integration set up between a Salesforce org and a quoting system. NTO would like to show a notification to all sales representatives that use Salesforceanytime the quoting system will be taken down for maintenance.
Which Salesforce API should an Integration Architect use to fulfill this requirement?
  • A. Connect REST API
  • B. Streaming API
  • C. REST API
  • D. Tooling API
Streaming API is the best option for sending real-time notifications of changes to Salesforce data. Streaming API uses a publish-subscribe model to push relevant data to subscribers without polling. Streaming API supports PushTopic events, which are based on SOQL queries that define the data changes to listen for. The affiliate company can subscribe to a PushTopic event on the NTO Salesforce org and receive notifications whenever the data that matches the query changes. This way, the affiliate company can be informed of any updates to the opportunities in the NTO Salesforce instance.
NEW QUESTION # 70
An architect recommended using Apex code to make callouts to an external system to process insurance quote.
What should the integration architect consider to make sure this is the right option for the integration?
  • A. The limit on long-running requests (total execution time).
  • B. The maximum number of parallel Apex callouts in a single continuation.
  • C. The maximum callouts in a single Apex transaction.
  • D. The limit of pending operations in the same transaction.
NEW QUESTION # 71
Which three considerations should an Integration Architect consider when recommending Platform Event as a Integration solution?
Choose 3 answers
  • A. Inability to query event messages using SOQL
  • B. When you delete an event definition, it's permanently removed and can't be restored.
  • C. Inability to create a Lightning record page for platform events.
  • D. Subscribe to an AssetToken Event stream to monitor OAuth 2.0 authentication activity. C
  • E. You can use Event Monitoring to track user activity, such as logins and running reports.
Answer: A,B,C
NEW QUESTION # 72
Northern Trail Outfitters needs to make synchronous callouts "available to promise"services to query product availability and reserve inventory during customer checkout process.
Which two considerations should an integration architect make when building a scalable integration solution?
Choose 2 answers
  • A. The number batch jobs that can run concurrently.
  • B. The typical and worst-case historical response times.
  • C. How many concurrent service calls are being placed.
  • D. The maximum query cursors open per user on the service.
The typical and worst-case historical response times, and how many concurrent service calls are being placed are two considerations that an integration architect should makewhen building a scalable integration solution for synchronous callouts to "available to promise" services. These two factors can affect the performance, reliability, and availability of the integration solution, as well as the user experience of the customer checkout process. Theintegration architect should design the solution to handle high volumes of service calls, optimize the response times, handle errors and timeouts, and avoid hitting governor limits or service quotas.
References: Certification - Integration Architect - Trailhead, [Callout Limits and Limitations], [Integration Patterns and Practices]
NEW QUESTION # 73
Northern Trail Outfitters (NTO) has hired an Integration Architect to design the integrations between existing systems and a new instance of Salesforce. NTO has the following requirements:
1. Initial load of 2M Accounts, 5.5M Contacts, 4.3M Opportunities, and 45k Products into the new org.
2. Notification of new and updated Accounts andContacts needs to be sent to 3 external systems.
3. Expose custom business logic to 5 external applications in a highly secure manner.
4. Schedule nightly automated dataflows, recipes and data syncs.
Which set of APIs are recommended in order to meet the requirements?
  • A. Bulk API, Chatter REST API, Apex SOAP API, Tooling API
  • B. Bulk API, Chatter REST API, Apex REST API, Analytics REST API
  • C. Bulk API, Streaming API, Apex REST API, Analytics REST API
  • D. Bulk API, Streaming API, Apex SOAP API, Analytics REST API
The set of APIs recommended to meet the requirements are Bulk API, Streaming API, Apex REST API, and Analytics REST API. Bulk API is a RESTful API that allows you to quickly load large amounts of data into Salesforce. Bulk API is suitable for the initial load of millions of records into the new org. Streaming API is a type of streaming event that notifies subscribers of changes to Salesforce records that match a SOQL query.
Streaming API is suitable for sending notifications of new and updated Accounts and Contacts to external systems. Apex REST API is an API that allows you to expose custom business logic as RESTful web services that can be accessed by external applications. Apex REST API is suitable for exposing custom business logic in a highly secure manner. Analytics REST API is an API that allows you to access analytics features, such as dashboards, lenses, datasets, and dataflows. Analytics REST API is suitable for scheduling nightly automated dataflows, recipes and data syncs. The other sets of APIs are not suitable for meeting all the requirements.
Chatter REST API is an API that allows you to access Chatter feeds and social data such as users, groups, followers, and files. Chatter REST API is not relevant for this scenario. Apex SOAP API is an API that allows you to expose custom business logic as SOAP web services that can be accessed by external applications. ApexSOAP API is less preferable than Apex REST API because it requires more bandwidth and processing time due to the XML format. Tooling API is an API that allows you to build custom development tools or apps for Salesforce applications. Tooling API is not relevant for this scenario.
NEW QUESTION # 74
Are you sometimes nervous about the coming Integration-Architect exam and worried that you can't get used to the condition? Never worry, we can offer 3 different versions for you to choose: PDF, Soft and APP versions. You can use the Soft version of our Integration-Architect study materials to stimulate the exam to adjust yourself to the atmosphere of the real exam and adjust your speed to answer the questions. The other 2 versions also boost their own strength and applicable method and you could learn our Integration-Architect training quiz by choosing the most suitable version to according to your practical situation.
New Integration-Architect Test Voucher: https://www.practicedump.com/Integration-Architect_actualtests.html
Salesforce Integration-Architect Latest Exam Dumps The layout is simple and the content is clear, Money will be a great factor that influences your selection of the Salesforce Integration-Architect test engine, If you have any questions about the exam, Integration-Architect training study pdf will help you to solve them, Salesforce Integration-Architect Latest Exam Dumps Everything is changing so fast, Why Buy From PracticeDump New Integration-Architect Test Voucher?
They plan to buy a condo there, And yet, there were clearly more than Integration-Architect a few designers who weren't interested in designing for anyone besides themselves, The layout is simple and the content is clear.
Latest Updated Salesforce Integration-Architect Latest Exam Dumps: Salesforce Certified Integration ArchitectMoney will be a great factor that influences your selection of the Salesforce Integration-Architect test engine, If you have any questions about the exam, Integration-Architect training study pdf will help you to solve them.
Everything is changing so fast, Why Buy From PracticeDump?
P.S. Free 2026 Salesforce Integration-Architect dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=1XtGl4WRVeHGZ4lp-b9yBfQjiM26eGKvy
