[General] Pass NSE7_OTS-7.2 Exam with Trustable NSE7_OTS-7.2 Simulations Pdf by ExamDiscus
89
【General】 Pass NSE7_OTS-7.2 Exam with Trustable NSE7_OTS-7.2 Simulations Pdf by ExamDiscus
Posted at 2/16/2026 08:00:52      View:112 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamDiscuss NSE7_OTS-7.2 dumps for free: https://drive.google.com/open?id=12kirkOaKLBYvwSlIaYcRL9IoGCJIuhZj
If you are worry about the coming NSE7_OTS-7.2 exam, our NSE7_OTS-7.2 study materials will help you solve your problem. In order to promise the high quality of our NSE7_OTS-7.2 exam questions, our company has outstanding technical staff, and has perfect service system after sale. More importantly, our good NSE7_OTS-7.2 Guide quiz and perfect after sale service are approbated by our local and international customers.
Fortinet NSE7_OTS-7.2 Certification Exam is intended for security professionals who have experience working in OT environments, such as industrial control systems (ICS) and supervisory control and data acquisition (SCADA) systems. It is also suitable for those who are responsible for designing, implementing, and managing OT security solutions.
NSE7_OTS-7.2 Exam Questions Vce & NSE7_OTS-7.2 Valid Vce DumpsAre you staying up for the NSE7_OTS-7.2 exam day and night? Do you have no free time to contact with your friends and families because of preparing for the exam? Are you tired of preparing for different kinds of exams? If your answer is yes, please buy our NSE7_OTS-7.2 exam questions, which is equipped with a high quality. We can make sure that our NSE7_OTS-7.2 Exam Questions have the ability to help you solve your problem, and you will not be troubled by these questions above. More importantly, if you purchase our NSE7_OTS-7.2 practice materials, we believe that your life will get better and better.
Fortinet NSE 7 - OT Security 7.2 Sample Questions (Q11-Q16):NEW QUESTION # 11
What can be assigned using network access control policies?
  • A. Profiling rules
  • B. Logical networks
  • C. FortiNAC device polling methods
  • D. Layer 3 polling intervals
NEW QUESTION # 12
An OT network architect needs to secure control area zones with a single network access policy to provision devices to any number of different networks. On which device can this be accomplished?
  • A. FortiNAC
  • B. FortiSwitch
  • C. FortiGate
  • D. FortiEDR
Network Access Policies are used to dynamically provision access to connecting endpoints, based on the matched user/host profiles associated with the network access configuration.
NEW QUESTION # 13
Which statement about the IEC 104 protocol is true?
  • A. IEC 104 uses non-TCP/IP standards.
  • B. IEC 104 is IEC 101 compliant in old SCADA systems.
  • C. IEC 104 is used for telecontrol SCADA in electrical engineering applications.
  • D. IEC 104 protects data transmission between OT devices and services.
NEW QUESTION # 14
With the limit of using one firewall device, the administrator enables multi-VDOM on FortiGate to provide independent multiple security domains to each ICS network.
Which statement ensures security protection is in place for all ICS networks?
  • A. Each traffic VDOM must have a direct connection to FortiGuard services to receive the required security updates.
  • B. The management VDOM must have access to all global security services.
  • C. Each VDOM must have an independent security license.
  • D. Traffic between VDOMs must pass through the physical interfaces of FortiGate to check for security incidents.
In a multi-VDOM setup, one VDOM typically acts as the management VDOM (often called "root") which manages global settings and security services like FortiGuard updates.
This management VDOM handles access to global security services that benefit all traffic VDOMs.
Individual traffic VDOMs process their own traffic and enforce security policies but rely on the management VDOM for centralized access to global security services.
Each VDOM does not need an independent security license; the license is for the device as a whole.
Traffic between VDOMs does not need to pass through physical interfaces to be inspected; inter- VDOM links and policies handle traffic inspection.
Each VDOM does not require direct FortiGuard connections; this can be centralized in the management VDOM.
NEW QUESTION # 15
An OT supervisor has configured LDAP and FSSO for the authentication. The goal is that all the users be authenticated against passive authentication first and, if passive authentication is not successful, then users should be challenged with active authentication. What should the OT supervisor do to achieve this on FortiGate?
  • A. Configure a firewall policy with LDAP users and place it on the top of list of firewall policies.
  • B. Enable two-factor authentication with FSSO.
  • C. Under config user settings configure set auth-on-demand implicit.
  • D. Configure a firewall policy with FSSO users and place it on the top of list of firewall policies.
The OT supervisor should configure a firewall policy with FSSO users and place it on the top of list of firewall policies in order to achieve the goal of authenticating users against passive authentication first and, if passive authentication is not successful, then challenging them with active authentication.
NEW QUESTION # 16
The great advantage of our NSE7_OTS-7.2 study prep is that we offer free updates for one year long. On one hand, these free updates can greatly spare your money since you have the right to free download NSE7_OTS-7.2 real dumps as long as you need to. On the other hand, we offer this after-sales service to all our customers to ensure that they have plenty of opportunities to successfully pass their NSE7_OTS-7.2 Actual Exam and finally get their desired certification of NSE7_OTS-7.2 practice materials.
NSE7_OTS-7.2 Exam Questions Vce: https://www.examdiscuss.com/Fortinet/exam/NSE7_OTS-7.2/
P.S. Free 2026 Fortinet NSE7_OTS-7.2 dumps are available on Google Drive shared by ExamDiscuss: https://drive.google.com/open?id=12kirkOaKLBYvwSlIaYcRL9IoGCJIuhZj
