[General] CompTIA 220-1201 Latest Dumps Book, 220-1201 Latest Dumps Ebook
87
【General】 CompTIA 220-1201 Latest Dumps Book, 220-1201 Latest Dumps Ebook
Posted at 2/16/2026 09:00:34      View:105 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Real4exams 220-1201 PDF Dumps and 220-1201 Exam Engine Free Share: https://drive.google.com/open?id=10ozoK57YWIbgCzUM3hRTjquQx4Jk_zb1
If you are preparing for 220-1201 exam and upset without accurate exam torrent and practice materials, Real4exams guarantees you to pass exam at first attempt absolutely. Our 220-1201 exam torrent is edited by latest official examination knowledge. Once official department change questions we will release new version of 220-1201 Exam Torrent accordingly. We provide one year free update and service warranty for all products. You will have sufficient time to take part in exams.
If you buy the 220-1201 study materials of us, we ensure you to pass the exam. Since the 220-1201 study materials have the quality and the accuracy, and it will help you pass exam just one time. Buying 220-1201 exam dumps are pass guaranteed and money back guaranteed for the failure. Furthermore, we choose international confirmation third party for payment for the 220-1201 Exam Dumps, therefore we can ensure you the safety of your account and your money. The refund money will return to your payment account.
High-quality CompTIA 220-1201 Latest Dumps Book Are Leading Materials & Free PDF 220-1201 Latest Dumps EbookWe keep a close watch at the most advanced social views about the knowledge of the test CompTIA certification. Our experts will renovate the test bank with the latest 220-1201 study materials and compile the latest knowledge and information into the questions and answers. In the answers, our experts will provide the authorized verification and detailed demonstration so as to let the learners master the latest information timely and follow the trend of the times. All we do is to integrate the most advanced views into our 220-1201 Study Materials.
CompTIA A+ Certification Exam: Core 1 Sample Questions (Q163-Q168):NEW QUESTION # 163
A third-party contractor recently installed a new switch, router, and cabling for a small corporate office. After the installation, users started experiencing issues connecting to resources over the network.
INSTRUCTIONS
Click on each PC and server to review outputs. From the remediation section on the right, select an issue and solution for each device.
See the Explanation and detailed steps below.
Looking at the network configurations and outputs from both PCs and servers, here are the possible issues and solutions:
1. PC 1
Issue: The IP address for PC1 is 192.168.1.1, which conflicts with Server 1 (which also uses 192.168.1.1).
Solution: Change the IP address on PC1 to a unique one within the range, like 192.168.1.3.
2. PC 2
Issue: PC 2 is configured with 192.168.1.2, which conflicts with Server 2 that has the same IP address.
Solution: Update the IP address on PC 2 to something unique, like 192.168.1.4.
3. Server 1
Issue: The IP address for Server 1 is 192.168.1.1, which conflicts with PC1.
Solution: Since Server 1 and PC1 are using the same IP address, change one of them. For Server 1, you could change the IP address to 192.168.1.5.
4. Server 2
Issue: Server 2 is using the IP address 192.168.1.2, which conflicts with PC2.
Solution: Update Server 2 to use a different IP address, such as 192.168.1.6.
General Remediation:
The primary problem here is overlapping IP addresses, leading to connectivity issues. Each device on the network must have a unique IP address. After making these changes, ensure that all devices can communicate properly by testing the connection between devices and verifying they can access shared resources.
NEW QUESTION # 164
A technician is configuring a new office network for a customer. Which of the following subnets should the technician use for the local network?
  • A. 172.31.88.0/24
  • B. 85.159.80.0/26
  • C. 195.205.143.160/27
  • D. 52.84.52.0/25
The 172.31.88.0/24 subnet falls within the private IP address range (172.16.0.0-172.31.255.255), which is reserved for internal network use. The other options are public IP ranges and should not be used for local networks.
NEW QUESTION # 165
All VoIP phone users at a call center report that they get distorted audio and drops in conversations during peak working hours. A technician updates the firmware on the phones, but the issue persists. Which of the following should the technician do next?
  • A. Verify that the users' extensions are in the correct call groups.
  • B. Reset the phones to factory settings and provision them.
  • C. Replace all the patch cables.
  • D. Ask the network team to check the VLAN for QoS.
Distorted audio and dropped calls affecting all users during peak hours indicate network congestion rather than device configuration issues. Verifying that the voice VLAN has proper Quality of Service ensures VoIP traffic is prioritized over other network traffic, preventing packet loss and latency that degrade call quality.
NEW QUESTION # 166
An IT specialist sets up a wireless router in a SOHO environment. Afterward, several devices cannot access the internet and are assigned IP addresses starting with 169.254. Which of the following is the best action to resolve this issue?
  • A. Increase the DHCP pool size.
  • B. Shorten the lease time.
  • C. Reboot the wireless router.
  • D. Use static IP addresses.
Addresses in the 169.254.x.x range indicate the clients were unable to contact a DHCP server and fell back to APIPA. Since the router provides DHCP in a SOHO setup, restarting it will restore the DHCP service so devices can obtain valid IP addresses again.
NEW QUESTION # 167
A technician purchases a device that connects directly to the rear of a laptop and provides a one-to-one match for every peripheral connection. Which of the following best describes this device?
  • A. Docking station
  • B. USB hub
  • C. KVM switch
  • D. Port replicator
A device that connects directly to a laptop and provides a one-to-one duplication of the laptop's existing ports is known as a port replicator. According to CompTIA Core 1 (220-1201) mobile device and laptop accessories objectives, a port replicator extends the available connections by mirroring the laptop's built-in ports, such as USB, HDMI, Ethernet, and audio. This allows users to quickly connect peripherals like monitors, keyboards, mice, and network cables without plugging each device in individually.
Port replicators are typically passive devices and do not add new functionality beyond duplicating existing ports. They are commonly used in office environments where users frequently dock and undock laptops.
A docking station, by contrast, often provides additional or enhanced functionality, such as extra video outputs, higher-power charging, expansion slots, or proprietary connectors. A USB hub only expands USB connectivity and does not replicate all peripheral connections. A KVM switch is used to control multiple computers with a single keyboard, video display, and mouse, which is unrelated to laptop port expansion.
CompTIA distinguishes port replicators as simple port-duplication devices, making them the correct answer in this scenario.
CompTIA A+ Core 1 (220-1201) Official Study Guide - Mobile Device Accessories and Laptop Hardware
NEW QUESTION # 168
If people buy and use the 220-1201 study materials with bad quality to prepare for their exams, it must do more harm than good for their exams, thus it can be seen that the good and suitable 220-1201 study materials is so important for people’ exam that people have to pay more attention to the study materials. In order to help people pass the exam and gain the certification, we are glad to the 220-1201 Study Materials from our company for you.
220-1201 Latest Dumps Ebook: https://www.real4exams.com/220-1201_braindumps.html
The price for 220-1201 training materials is reasonable, and no matter you are a student at school or an employee in the company, you can afford it, Real4exams 220-1201 Latest Dumps Ebook's approach is highly acknowledged by educationists and experts, CompTIA 220-1201 Latest Dumps Book Written and checked by our professional experts, And only studying with our 220-1201 exam questions for 20 to 30 hours, you can confidently pass the 220-1201 exam for sure.
Are the customers happy, The requirements provided 220-1201 by customers stated requirements) are not the real requirements, The price for 220-1201 training materials is reasonable, and 220-1201 Reliable Real Test no matter you are a student at school or an employee in the company, you can afford it.
Preparation Material with Free Demos and Updates [2026]Real4exams's approach is highly acknowledged 220-1201 Reliable Real Test by educationists and experts, Written and checked by our professional experts, And only studying with our 220-1201 Exam Questions for 20 to 30 hours, you can confidently pass the 220-1201 exam for sure.
Skip the A+ 220-1201 audio exams and select the one package that gives it all to you at your discretion: CompTIA 220-1201 Study Materials featuring the exam engine.
BTW, DOWNLOAD part of Real4exams 220-1201 dumps from Cloud Storage: https://drive.google.com/open?id=10ozoK57YWIbgCzUM3hRTjquQx4Jk_zb1
