[General] 新版ITIL-4-Practitioner-Release-Management題庫 - ITIL-4-Practitioner-Release-Managem
100
【General】 新版ITIL-4-Practitioner-Release-Management題庫 - ITIL-4-Practitioner-Release-Managem
Posted at 2/16/2026 09:16:54      View:152 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 NewDumps最新的ITIL-4-Practitioner-Release-Management PDF版考試題庫和ITIL-4-Practitioner-Release-Management考試問題和答案免費分享:https://drive.google.com/open?id=1qLme_KrMJ1gsizfi9OX553uiPDsGlE2i
您是否感興趣想通過ITIL-4-Practitioner-Release-Management考試,然后開始您的高薪工作?NewDumps擁有最新研發的題庫問題及答案,可以幫助數百萬的考生通過ITIL-4-Practitioner-Release-Management考試并獲得認證。我們提供給您最高品質的Peoplecert ITIL-4-Practitioner-Release-Management題庫問題及答案,覆蓋面廣,可以幫助考生進行有效的考前學習。所有購買ITIL-4-Practitioner-Release-Management題庫的客戶都將得到一年的免費升級服務,這讓您擁有充裕的時間來完成考試。我們會100%為您提供方便以及保障,請記住能讓您100%通過考試的題庫就是我們的Peoplecert ITIL-4-Practitioner-Release-Management考古題。
Peoplecert ITIL-4-Practitioner-Release-Management 考試大綱:
主題簡介
主題 1
  • Change: This section of the exam measures the skills of DevOps Engineers and focuses on how to manage and control changes within IT environments. It includes planning, executing, monitoring, and communicating changes to ensure minimal disruption while keeping stakeholders informed about the progress and impact of changes.
主題 2
  • Service Design: This section of the exam measures the skills of IT Release Managers and covers the principles and practices involved in designing services and products that are practical, useful, and aligned with stakeholder expectations. It focuses on ensuring that services are designed in a way that they can be effectively delivered and supported by the organization and its partners.
主題 3
  • AI and Automation: This section of the exam measures the skills of IT Operations Managers and addresses the use of AI and automation in delivering IT systems and applications that align with user needs. It ensures that software releases meet quality standards, are delivered on time, and stay within budget, using modern tools and intelligent technologies.
最受歡迎的新版ITIL-4-Practitioner-Release-Management題庫,免費下載ITIL-4-Practitioner-Release-Management考試題庫幫助妳通過ITIL-4-Practitioner-Release-Management考試NewDumps是個很好的為Peoplecert ITIL-4-Practitioner-Release-Management 認證考試提供方便的網站。根據過去的考試練習題和答案的研究,NewDumps能有效的捕捉Peoplecert ITIL-4-Practitioner-Release-Management 認證考試試題內容。NewDumps提供的Peoplecert ITIL-4-Practitioner-Release-Management考試練習題真實的考試練習題有緊密的相似性。
最新的 ITIL Practitioner Level ITIL-4-Practitioner-Release-Management 免費考試真題 (Q11-Q16):問題 #11
An organization manually checks that releases of new or changed products/services have been successfully completed. Which tools should be used to automate this process?
  • A. Enterprise architecture tools
  • B. Analysis and reporting tools
  • C. Workflow management and collaboration tools
  • D. Monitoring and event management tools
答案:D
解題說明:
Automating the verification of release success involves tracking the performance and stability of the released services. TheITIL 4 Practitioner: Release Managementdocument notes:"Monitoring and event management tools can automate the verification of release success by tracking system performance and detecting anomalies post-release, ensuring the release meets its objectives"(Section 4.2).
* Option A (Monitoring and event management tools) is correct, as these tools can automatically check system health and performance after a release, replacing manual checks.
* Option B (Workflow management and collaboration tools) focuses on process coordination, not post- release verification.
* Option C (Enterprise architecture tools) is used for dependency mapping, not release verification.
* Option D (Analysis and reporting tools) provides retrospective insights but doesn't automate real-time verification.
The correct answer is A, as monitoring tools are best suited for automating release verification.
問題 #12
An organization invested in the development and adoption of a common approach to release management.
Which metric will help the organization to understand if this initiative has been successful?
  • A. The number of releases that were implemented after the target implementation date
  • B. The percentage of releases that do not result in incidents
  • C. The satisfaction rating given by service consumers of individual releases
  • D. Alignment of release management procedures between the organization and its suppliers
答案:B
解題說明:
A common approach to release management aims to improve the reliability and stability of releases. The ITIL 4 Practitioner: Release Managementdocument highlights key metrics for evaluating the success of release management:"Key metrics for release management often include the percentage of releases that do not result in incidents, as this indicates the stability and reliability of the release process"(Section 5.3).
* Option A (Alignment with suppliers) is a process improvement metric but doesn't directly measure the success of the release outcomes.
* Option B (The percentage of releases that do not result in incidents) directly measures the effectiveness of the release process by assessing its impact on service stability, aligning with the goal of a common approach to reduce errors and disruptions.
* Option C (Satisfaction rating) is a valuable metric but is more subjective and less directly tied to the operational success of a common approach.
* Option D (Number of delayed releases) measures timeliness but not the quality or stability of the releases.
The best metric to assess the success of a standardized release management approach is the reduction in incidents, making B the correct answer.
問題 #13
A retail organization is hiring a new release manager. The vacancy description indicates that successful candidates should have good knowledge of technologies and platforms used by the organization, good knowledge of ITIL and DevOps, and experience in retail. What other skill is important to the release management role?
  • A. Project planning and coordination
  • B. Understanding of the organization's business
  • C. Technical expertise
  • D. Knowledge of service management frameworks
答案:A
解題說明:
The release management role in ITIL 4 requires a range of competencies to ensure effective coordination and execution of releases. TheITIL 4 Practitioner: Release Managementdocument states:"A release manager must have strong project planning and coordination skills to manage the scheduling, communication, and execution of releases, ensuring alignment with organizational goals and minimal disruption"(Section 3.3).
* Option A (Knowledge of service management frameworks) is already covered by the requirement of ITIL knowledge in the vacancy description, so it's not an additional skill.
* Option B (Project planning and coordination) is a critical skill for release managers, as they need to orchestrate complex release activities, manage timelines, and coordinate with stakeholders, which isn't explicitly covered by the listed requirements.
* Option C (Technical expertise) is implied by the requirement for knowledge of technologies and platforms, so it's not an additional skill.
* Option D (Understanding of the organization's business) is important but less specific to release management compared to project planning, and the retail experience requirement already covers business context.
The correct answer is B, as project planning and coordination is a key additional skill for effective release management.
問題 #14
Which is a key input to the release planning and coordination process?
  • A. Documented findings on the success of a release
  • B. Details about the users who will be affected
  • C. Updates to the continual improvement register
  • D. Notifications to stakeholders about the release status
答案:B
解題說明:
The release planning and coordination process in ITIL 4 Release Management requires inputs toensure effective planning and execution of releases. TheITIL 4 Practitioner: Release Managementdocument specifies:"Key inputs to release planning and coordination include details about the users who will be affected, as this helps in scheduling and communicating the release to minimize disruption"(Section 3.2.1).
* Option A (Documented findings on the success of a release) is an output of a release evaluation, not an input to planning.
* Option B (Updates to the continual improvement register) may inform long-term improvements but isn' t a direct input to planning a specific release.
* Option C (Details about the users who will be affected) is a critical input, as understanding the user base helps tailor the release schedule, communication, and impact mitigation strategies.
* Option D (Notifications to stakeholders about the release status) is an output of the release process, not an input to planning.
The correct answer is C, as user details are essential for effective release planning and coordination.
問題 #15
A new release manager wants to explain to the organization's service consumers the purpose of a new release management practice. What should the release manager say to the service consumers to help them realize the value of release management?
  • A. The release management practice will ensure that new service features are available to the service operations team to reduce business losses.
  • B. The release management practice will ensure that new service features are available to the service operations team to enable them to perform tests.
  • C. The release management practice will ensure that new service features are available to users to mitigate the service provider's risks.
  • D. The release management practice will ensure the quick use of improved services after new service features have been made available.
答案:D
問題 #16
NewDumps Peoplecert的ITIL-4-Practitioner-Release-Management的考試資料是特別設計,它是一項由專業的IT精英團隊專門為你們量身打造的考題資料,針對性特別強。通過了認證你在IT行業將體現國際價值。有許多轉儲和培訓材料的供應商,將保證你通過 Peoplecert的ITIL-4-Practitioner-Release-Management的考試使用他們的產品,而NewDumps與所有的網站相比,這已經成為歷史了,我們用事實說話,讓見證奇跡的時刻來證明我們所說的每一句話。
ITIL-4-Practitioner-Release-Management考題寶典: https://www.newdumpspdf.com/ITIL-4-Practitioner-Release-Management-exam-new-dumps.html
順便提一下,可以從雲存儲中下載NewDumps ITIL-4-Practitioner-Release-Management考試題庫的完整版:https://drive.google.com/open?id=1qLme_KrMJ1gsizfi9OX553uiPDsGlE2i
Posted at 2/17/2026 21:16:21        Only Author  2#
I appreciate this thought-provoking article, thank you for sharing! Questions and answers DA0-002 free has fantastic resources available to you at no charge.
