[General] Quiz 2026 Salesforce Mule-Dev-301: Salesforce Certified MuleSoft Developer II–Th
86
【General】 Quiz 2026 Salesforce Mule-Dev-301: Salesforce Certified MuleSoft Developer II–Th
Posted at 2/16/2026 12:20:29      View:109 | Replies:1        Print      Only Author   [Copy Link] 1#
When you choose to attempt the mock exam on the Salesforce Mule-Dev-301 practice software by ExamTorrent, you have the leverage to custom the questions and attempt it at any time. Keeping a check on your Salesforce Certified MuleSoft Developer II exam preparation will make you aware of your strong and weak points. You can also identify your speed on the practice software by ExamTorrent and thus manage time more efficiently in the actual Salesforce exam.
Stop hesitating. If you want to experience our Mule-Dev-301 exam dumps, hurry to click ExamTorrent.com to try our pdf real questions and answers. You can free download a part of the dumps. Before you make a decision to buy ExamTorrent exam questions and answers, you can visit ExamTorrent to know more details so that it can make you understand the website better. In addition, about FULL REFUND policy that you fail the Mule-Dev-301 Exam, you can understand that information in advance. ExamTorrent.com is the website which absolutely guarantees your interests and can imagine ourselves to be in your position.
Mule-Dev-301 Updated Test Cram - Hot Mule-Dev-301 Exam Collection and Effective Exam Dumps Salesforce Certified MuleSoft Developer II CollectionIf you decide to buy a Mule-Dev-301 exam braindumps, you definitely want to use it right away! Mule-Dev-301 training guide’s powerful network and 24-hour online staff can meet your needs. First of all, we can guarantee that you will not encounter any obstacles in the payment process. After your payment is successful, we will send you an email within 5 to 10 minutes. As long as you click on the link, you can use Mule-Dev-301 Learning Materials to learn.
Salesforce Certified MuleSoft Developer II Sample Questions (Q58-Q63):NEW QUESTION # 58
Which pattern can a web API use to notify its client of state changes as soon as they occur?
  • A. Schedule Event Publisher
  • B. Shared database trigger
  • C. ETL data load
  • D. HTTP Webhock
A web API can use HTTP Webhook to notify its client of state changes as soon as they occur. A webhook is an HTTP callback that allows an API to send real-time notifications to another system or application when an event happens. The client registers a URL with the API where it wants to receive notifications, and then the API sends an HTTP request to that URL with information about the event. Reference: https://docs.mulesoft.com/connectors/webhook/webhook-connector
NEW QUESTION # 59
A system API that communicates to an underlying MySQL database is deploying to CloudHub. The DevOps team requires a readiness endpoint to monitor all system APIs.
Which strategy should be used to implement this endpoint?
  • A. Create a dedicated endpoint that responds with the API status and health of the server
  • B. Use an existing resource endpoint of the API
  • C. Create a dedicated endpoint that responds with the API status and reachability of the underlying systems
  • D. Create a dedicated endpoint that responds with the API status only
To implement a readiness endpoint to monitor all system APIs, the developer should create a dedicated endpoint that responds with the API status and reachability of the underlying systems. This way, the DevOps team can check if the system API is ready to receive requests and if it can communicate with its backend systems without errors. Reference: https://docs.mulesoft.com/mule-r ... es#readiness-probes
NEW QUESTION # 60
A Mule implementation uses a HTTP Request within an Unit Successful scope to connect to an API.
How should a permanent error response like HTTP:UNAUTHORIZED be handle inside Until Successful to reduce latency?
  • A. Put the HTTP Request inside a try scope in Unit Successful.
    In the error handler, use On Error Continue to catch permanent errors like HTTP UNAUTHORIZED.
  • B. Put the HTTP Request inside a try scope in Unit Successful.
    In the error handler, use On Error Propagate to catch permanent errors like HTTP UNAUTHORIZED.
  • C. In Until Successful configuration, set the retry count to 1 for error type HTTP: UNAUTHORIZED.
  • D. Configure retrying until a MULERETRY_EXHAUSTED error is raised or the API responds back with a successful response.
To handle a permanent error response like HTTP:UNAUTHORIZED inside Until Successful, the developer should put the HTTP Request inside a try scope in Unit Successful, and use On Error Continue to catch permanent errors like HTTP UNAUTHORIZED in the error handler. This way, the developer can avoid retrying requests that will always fail due to a permanent error, and reduce latency. On Error Continue allows the flow to continue processing after handling the error. Reference: https://docs.mulesoft.com/mule-runtime/4.3/until-successful-scope https://docs.mulesoft.com/mule-r ... or-continue-concept
NEW QUESTION # 61
Which configurations are required for HTTP Listener to enable mTLS authentication?
  • A. Set an appropriate keystore configuration and use persistent connections for the listener
  • B. Set an appropriate reconnection strategy and use persistent connections for the listener
  • C. Set an appropriate truststore configuration and reconnection strategy for the listener
  • D. Set an appropriate keystore and truststore configuration for the listener
To enable mTLS authentication for HTTP Listener, the developer needs to set an appropriate keystore and truststore configuration for the listener. The keystore contains the certificate and private key of the Mule application that are used to prove its identity to clients. The truststore contains the certificates of trusted clients that are allowed to access the Mule application. Reference: https://docs.mulesoft.com/mule-r ... tual-authentication
NEW QUESTION # 62
A scatter-gather router is configured with four routes:Route A, B, C and D.
Route C false.
  • A. Payload failures['2']
  • B. Payload ['2']
  • C. Error,errorMessage,payload.failures['2']
  • D. Error,errorMesage.payload.results ['2']
The result of accessing route C failure is Error,errorMessage,payload.failures['2']. This is because a scatter-gather router returns an aggregated message that contains an array of results from each route and an array of failures from each route. The failures array contains error objects with information about each failed route execution. To access route C failure, which is the third route (index 2), the developer needs to use Error.errorMessage.payload.failures['2'] expression. Reference: https://docs.mulesoft.com/mule-r ... atter-gather-output
NEW QUESTION # 63
If you are a child's mother, with Mule-Dev-301 test answers, you will have more time to stay with your child; if you are a student, with Mule-Dev-301 exam torrent, you will have more time to travel to comprehend the wonders of the world. In the other worlds, with Mule-Dev-301 guide tests, learning will no longer be a burden in your life. You can save much time and money to do other things what meaningful. You will no longer feel tired because of your studies, if you decide to choose and practice our Mule-Dev-301test answers. Your life will be even more exciting.
Mule-Dev-301 Exam Collection: https://www.examtorrent.com/Mule-Dev-301-valid-vce-dumps.html
And our Mule-Dev-301 exam simulation has quick acquisition, The professional experts of our company are responsible for designing every Mule-Dev-301question and answer, The advantages of our ExamTorrent Mule-Dev-301 Exam Collection, I have recently passed the Salesforce MuleSoft exam (Mule-Dev-301) thanks to the premium VCE, Mule-Dev-301 instant download file is a pioneer in the Mule-Dev-301 exam certification preparation.
Using both the Ctrl key and the mouse enables you to select many controls at once, How to Test When You Don't Have the Devices, And our Mule-Dev-301 Exam simulation has quick acquisition.
The professional experts of our company are responsible for designing every Mule-Dev-301question and answer, The advantages of our ExamTorrent, I have recently passed the Salesforce MuleSoft exam (Mule-Dev-301) thanks to the premium VCE.
Valid Mule-Dev-301 Updated Test Cram by ExamTorrentMule-Dev-301 instant download file is a pioneer in the Mule-Dev-301 exam certification preparation.
Posted at 2/20/2026 03:47:39        Only Author  2#
Your article is brilliant, thank you for providing this amazing share! Wishing you all the best in your exams—DP-900 reliable test camp test questions are free to download!
