[General] Plat-Dev-301 Valid Test Pattern | Plat-Dev-301 New Test Bootcamp
108
General Plat-Dev-301 Valid Test Pattern | Plat-Dev-301 New Test Bootcamp
Posted at 2/16/2026 16:01:49      View119 | Replies0        Print      Only Author   [Copy Link] 1#
Achieving the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) certification can significantly impact your career progression and earning potential. This certification showcases your expertise and knowledge to employers, making you a valuable asset in the Salesforce Plat-Dev-301 industry. With the rapidly evolving nature of the Salesforce world, staying up-to-date with the latest technologies and trends is crucial. The Plat-Dev-301 Certification Exam enables you to learn these changes and ensures you remain current in your field.
We are not exaggerating that if you study with our Plat-Dev-301 exam questions, then you will pass the exam for sure because this conclusion comes from previous statistics. The pass rate of our customers is high as 98% to 100% with our Plat-Dev-301 Practice Engine. We believe you are also very willing to become one of them, then why still hesitate? Just come in and try our Plat-Dev-301 study materials, and we can assure you that you will not regret your choice.
Desktop Salesforce Plat-Dev-301 practise exam software - Pass Certification Exam ConfidentlyPlat-Dev-301 questions & answers cover all the key points of the real test. With the Plat-Dev-301 training pdf, you can get the knowledge you want in the actual test, so you do not need any other study material. If the Plat-Dev-301 exam is coming and the time is tense, it is better to choose our Plat-Dev-301 Test Engine dumps. Plat-Dev-301 test engine can simulate the actual test during the preparation and record the wrong questions for our reviewing. You just need 20-30 hours for preparation and feel confident to face the Plat-Dev-301 actual test.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q194-Q199):NEW QUESTION # 194
A developer sees test failures in the sandbox but not in production. No code or metadata changes have been actively made to either environment since the sandbox was created.
Which consideration should be checked to resolve the issue?
  • A. Ensure the Apex classes are on the same API version.
  • B. Ensure the sandbox Is on the same release as production.
  • C. Ensure test classes are using SeeAllData = true.
  • D. Ensure that Disable Parallel Apex Testing Is unchecked.
If test failures are occurring in a sandbox but not in production and there have been no active code or metadata changes, it could be due to differences in the Salesforce release versions between the two environments. Sandboxes can be on preview instances which get upgraded to new releases before production instances. This can lead to differences in behavior and could affect test executions. Ensuring that both the sandbox and production are on the same release can resolve such issues. API version differences and parallel testing settings typically do not cause discrepancies if the code hasn't changed, and while using SeeAllData=true is generally not recommended due to its dependence on the organization's data, it's unlikely to be the cause if the issue is related to the environment rather than the data.
Sandbox Preview Instructions
Understand the Salesforce Release Process
NEW QUESTION # 195
A Salesforce Platform Developer is leading a team that is tasked with deploying a new application to production. The team has used source-driven development, and they want to ensure that the application is deployed successfully.
What tool or mechanism should be used to verify that the deployment is successful?
  • A. Apex Test Execution
  • B. Force.com Migration Tool
  • C. Salesforce Inspector
  • D. Salesforce DX CLI
The Salesforce CLI with Salesforce DX can be used to execute and verify the deployment of metadata to production. It allows the developer to run specified tests and ensure that the deployment meets all required conditions for success.
NEW QUESTION # 196
Universal Containers develops a Visualforce page that requires the inclusion of external JavaScript and C55 files. They want to ensure efficient loading and caching of the page.
Which feature should be utilized to achieve this goal?
  • A. Static resources
  • B. ActionFunction
  • C. RemoteAction
  • D. PageBlockTable
Static resources are ideal for efficient loading and caching of external files in Visualforce. They allow bundling and minimizing HTTP requests.
NEW QUESTION # 197
A developer is trying to decide between creating a Visualforce component or a Lightning component for a custom screen.
Which functionality consideration impacts the final decision?
  • A. Does the screen need to be accessible from the Lightning Experience UI?
  • B. Will the screen be accessed via a mobile app?
  • C. Will the screen make use of a JavaScript framework?
  • D. Does the screen need to be rendered as a PDF without using a thirdparty application?
Visualforce can render pages as PDFs, which Lightning Components cannot do. This functionality is crucial if PDF rendering is required.
NEW QUESTION # 198
A developer created the following test method:
The developer org has five accounts where the name starts with "Test". The developer executes this test in the Developer Console. After the test code runs, which statement is true?
  • A. The test will fail.
  • B. There will be no accounts where the name starts with "Test".
  • C. There will be five accounts where the name starts with "Test".
  • D. There will be six accounts where the name starts with "Test".
Since the SeeAllData=true annotation is used, the test class does not have its own test data and is relying on the data in the org. The org already has accounts with the name starting with "Test", so the assertion that no accounts should exist after the deletion will fail because the test method only deletes the account that was created within its scope.
Apex Developer Guide
NEW QUESTION # 199
Professional Plat-Dev-301 exam using BraindumpsPass free exam discussions. Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam discussions provide a supportive environment where you can discuss difficult concepts and ask questions of your peers. In a free exam discussions, you'll have the opportunity to learn from a certified Plat-Dev-301 instructor who has extensive experience in Plat-Dev-301 studies. The instructor can also provide you with tips and best practices for taking the exam.
Plat-Dev-301 New Test Bootcamp: https://www.braindumpspass.com/Salesforce/Plat-Dev-301-practice-exam-dumps.html
BraindumpsPass provides Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) preparation material at very low prices compared to other platforms, And we have developed our Plat-Dev-301 exam questions in three different versions: the PDF, Software and APP online, By communicating with other former customers, we know that our Plat-Dev-301 New Test Bootcamp - Salesforce Certified Platform Developer II - Multiple Choice practice materials are the most popular Plat-Dev-301 New Test Bootcamp free demo in the market, Our Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice Dumps study guide is the most reliable and popular exam product in the marcket for we only sell the latest Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice Dumps practice engine to our clients and you can have a free trial before your purchase.
With help from Lightroom, you can overcome that Plat-Dev-301 New Test Bootcamp limitation by applying one of Lightroom's metadata presets at import, Its attributes are then also created, BraindumpsPass provides Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) preparation material at very low prices compared to other platforms.
Salesforce Plat-Dev-301 Desktop-Based Practice ProgramAnd we have developed our Plat-Dev-301 exam questions in three different versions: the PDF, Software and APP online, By communicating with other former customers, we know that our Plat-Dev-301 Salesforce Certified Platform Developer II - Multiple Choice practice materials are the most popular Salesforce Developer free demo in the market.
Definitely, Failure may seem intimidating, but if you choose our Plat-Dev-301 test bootcamp materials, thing will be different.
