[General] Free PDF Quiz 2026 Useful JN0-650: Valid Enterprise Routing and Switching, Profe
90
【General】 Free PDF Quiz 2026 Useful JN0-650: Valid Enterprise Routing and Switching, Profe
Posted at 2/16/2026 17:24:01      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
The Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) questions are in use by many customers currently, and they are preparing for their best future daily. Even the students who used it in the past to prepare for the Juniper Certification Exam have rated our practice questions as one of the best. You will receive updates till 365 days after your purchase, and there is a 24/7 support system that assists you whenever you are stuck in any problem or issues.
Juniper JN0-650 Exam Syllabus Topics:
  • IP Multicast: This domain addresses one-to-many communication using multicast routing, covering addressing, ASM vs SSM models, RPF, IGMP
  • snooping, PIM sparse-mode, rendezvous points, Anycast RP, MSDP, and routing policies.
  • IP Telephony Features: This section focuses on features supporting VoIP deployments including Power over Ethernet, LLDP
  • LLDP-MED protocols, and voice VLAN implementation.
  • BGP: This section focuses on Border Gateway Protocol operations including route selection, next hop resolution, BGP attributes, communities, load balancing, IPv4
  • IPv6 address families, advanced options, and routing policy implementation.
  • EVPN: This section addresses Ethernet VPN technology for Layer 2 over Layer 3 connectivity, covering EVPN route types, VXLAN encapsulation, and multi-homing configurations.
Topic 5
  • Ethernet Switching and Spanning Tree: This section covers advanced Layer 2 switching including filter-based VLANs, private VLANs, MVRP, Layer 2 tunneling via Q-in-Q and L2PT, plus MSTP and VSTP protocols.
Topic 6
  • Layer 2 Authentication and Access Control: This domain examines network access control mechanisms including 802.1x, MAC RADIUS, captive portal, server fail fallback, guest VLANs, and multi-method authentication considerations.
Topic 7
  • Class of Service (CoS): This domain covers QoS mechanisms in Junos including CoS processing, header fields, forwarding classes, classification, policers, schedulers, drop profiles, shaping, and rewrite rules.
JN0-650 New Study Questions - New JN0-650 DumpsYou won't need anything else if you prepare for the exam with our Juniper JN0-650 Exam Questions. Our experts have prepared Juniper JN0-650 dumps questions that will eliminate your chances of failing the exam.​​​​​​ We are conscious of the fact that most of the candidates have a tight schedule which makes it tough to prepare for the Juniper JN0-650 Exam Preparation.
Juniper Enterprise Routing and Switching, Professional (JNCIP-ENT) Sample Questions (Q38-Q43):NEW QUESTION # 38
For multicast traffic, what does the term 'scoping' refer to?
  • A. Prioritizing multicast traffic over unicast
  • B. Limiting the reach of the multicast stream within the network
  • C. Expanding the multicast group membership to include all hosts
  • D. Translating the multicast address to a unicast address
NEW QUESTION # 39
You are deploying IP phones in your enterprise networks. When plugged in. the IP phones must automatically be provided with their geographic location details by the EX Series switches.
In this scenario, which protocol should be used to enable this behavior?
  • A. MP-BGP
  • B. LLDP
  • C. CDP
  • D. LLDP-MED
To provide IP phones with geographic location details (such as civic addresses or coordinates) automatically, Juniper EX Series switches utilize theLLDP-MED (Link Layer Discovery Protocol - Media Endpoint Discovery)protocol.
* VoIP Specifics:While standard LLDP (C) is for general device discovery,LLDP-MEDis an enhancement specifically designed for network-to-endpoint communication for VoIP devices.
* Location IdentificationLDP-MED supportsLocation Identification TLVs(Type-Length-Values).
These allow a switch to push geographic or civic location data to an IP phone, which is critical for E911 services and asset tracking.
* Junos Implementation:On EX Series switches, this is typically configured under protocols lldp-med to ensure the switch advertises the necessary location information to connected endpoints.
NEW QUESTION # 40
Exhibit:
Your network has an unmanaged switch between the hosts and your EX Series switch. After the traffic enters the EX Series switch, each host must be on a separate VLAN. How would you accomplish this task?
  • A. Configure an input firewall filter on interface ge-0/0/3 to match the source MAC or IP address of the hosts to assign the VLANs.
  • B. Configure interface ge-0/0/3 to a mode trunk to assign the VLANs.
  • C. Configure VSTP on interface ge-0/0/1 to assign the VLANs.
  • D. Configure an output firewall filter on interface ge-0/0/1 to match the destination MAC or IP address of the hosts to assign the VLANs.
NEW QUESTION # 41
Which two statements are true regarding BGP route updates? (Choose two.)
  • A. BGP routes that have been sent are not refreshed by default.
  • B. Each path is advertised with a list of prefixes that share the same properties.
  • C. BGP routes that have been sent are refreshed at regular intervals by default.
  • D. Each prefix is advertised with all of its associated properties.
NEW QUESTION # 42
Which statement about LLDP and LLDP-MED operations on EX Series devices is correct?
  • A. LLDP-MED focuses on discovering network connectivity devices like routers and switches.
  • B. EX Series devices support LLDP-MED power negotiation, enabling dynamic allocation of PoE power based on endpoint device needs.
  • C. EX Series devices flood LLDP frames across a Layer 2 domain to calculate a network topology
  • D. LLDP only operates on interfaces configured for Layer 2
NEW QUESTION # 43
What are you waiting for? Unlock your potential and download Exams4Collection actual JN0-650 questions today! Start your journey to a bright future, and join the thousands of students who have already seen success by using Juniper Dumps of Exams4Collection, you too can achieve your goals and get the Juniper JN0-650 Certification of your dreams. Take the first step towards your future now and buy JN0-650 exam dumps. You won't regret it!
JN0-650 New Study Questions: https://www.exams4collection.com/JN0-650-latest-braindumps.html
