Authentic Salesforce Mule-Dev-201 Exam Questions with Answers
Posted at 2/16/2026 17:45:45      View:70 | Replies:0        Print      Only Author   [Copy Link] 1#
The key trait of our product is that we keep pace with the changes of syllabus and the latest circumstance to revise and update our Mule-Dev-201 study materials, and we are available for one-year free updating to assure you of the reliability of our service. Our company has established a long-term partnership with those who have purchased our Mule-Dev-201 Exam guides. We have made all efforts to update our product in order to help you deal with any change, making you confidently take part in the exam.
PDFBraindumps owns the most popular reputation in this field by providing not only the best ever Mule-Dev-201 study guide but also the most efficient customers' servers. We can lead you the best and the fastest way to reach for the Mule-Dev-201 certification and achieve your desired higher salary. Our Mule-Dev-201 Exam Preparation can improve your grade and change your states of life for our Mule-Dev-201 Learning Questions are the accumulation of professional knowledge. You will be more successful with our Mule-Dev-201 braindump.
Mule-Dev-201 Prep Guide - Mule-Dev-201 Test Dumps DemoCustomer first, service first is our principle of service. If you buy our Mule-Dev-201 study guide, you will find our after sale service is so considerate for you. We are glad to meet your all demands and answer your all question about our Mule-Dev-201 Training Materials. So do not hesitate and buy our Mule-Dev-201 study guide, we believe you will find surprise from our products. you should have the right to enjoy the perfect after sale service and the high quality products!
Salesforce Certified MuleSoft Developer Sample Questions (Q140-Q145):NEW QUESTION # 140
Refer to the exhibit. The Batch Job processes, filters and aggregates records, What is the expected output from the Logger component?
  • A. [20, 40, 60]
  • B. [20. 40] [60]
  • C. [10. 20] [30, 40] [50, 60]
  • D. [10. 20, 30. 40, 50, 60]
*Batch scope has filter criteria which says paylod mod 2 = 0 whch means only 2, 4 and 6 will be in batch scope.
* So payload for each of these will be incremented by 10.
* Aggregator has batch size defined as 2. So it will process in batch of two records.
* Hence option 3 is correct answer.
[20,40]
[60]
Behavior with aggregator configured with fixed size
In this scenario, the batch step sends the processed records to an aggregator, which starts processing the records and buffering them until the configuredaggregator's size is reached. After that, the aggregator sends the aggregated records to the stepping queue.
Diagram Description automatically generated
The batch job builds record blocks of the configured block size and sends them to their corresponding batch step for processing. Each batch stepreceives one or more record blocks and starts processing them in parallel.
After the batch step processes a record, the batch step sends the record to the aggregator for further processing. The aggregator continues processing records until the number of aggregated records reaches the configured aggregator's size.
https://docs.mulesoft.com/mule-r ... -processing-concept
NEW QUESTION # 141
Refer to the exhibits.
The Set Payload transformer In the addltem subflow uses DataWeave to create an order object.
What is the correct DataWeave code for the Set Payloadtransformer in the createOrder flow to use the addltem subflow to add a router cable with the price of 100 to the order?
  • A. lookupf "addltem", { payload: { price: "100", item: "router", itemType: "cable" } } )
  • B. addltemf { payload: { price: "100", item: "router", itemType: "cable" } > )
  • C. addltemf { price: "100", item: "router", itemType: "cable" })
  • D. lookupf "addltem", { price: "100", item: "router", itemType: "cable" } )
NEW QUESTION # 142
A web client sends one GET request to the test flow's HTTP Listener, which causes the test flow to call the updateTemp flow After the test flow returns a response, the web client then sends a different GET request to trie getTemp flow's HTTP Listener The test flow is not called a second time.
What response is returned from the request to the getTemp flow's HTTP Listener?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 143
All three of thecondition for the Choice router are true. What log messages are written?
  • A. Route1, Route2
  • B. Route1, Route2, Default
  • C. Route2
  • D. Route 1
NEW QUESTION # 144
The Batch Job scope contains two BatchStep scopes with different accept expressions.
The input payload is passed to the Batch Job scope.
After the entire payload is processed by the Batch Job scope, what messages have been logged by the Logger components?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 145
Our Mule-Dev-201 training materials are famous for instant access to download. You can receive your downloading link and password within ten minutes, so that you can start your learning as early as possible. In order to build up your confidence for Mule-Dev-201 exam materials, we are pass guarantee and money back guarantee, and if you fail to pass the exam, we will give you full refund. In addition, Mule-Dev-201 test materials cover most of knowledge points for the exam, therefore you can mater the major points for the exam as well as improve your professional ability in the process of learning.
Mule-Dev-201 Prep Guide: https://www.pdfbraindumps.com/Mule-Dev-201_valid-braindumps.html
If you want to know the more details about our Mule-Dev-201 training guide materials please email us any time, Salesforce Mule-Dev-201 Trustworthy Dumps In a word, Wwe have data protection act for you to avoid information leakage, In order to let all people have the opportunity to try our products, the experts from our company designed the trial version of our Mule-Dev-201 prep guide for all people, Thousands of people are interested in earning the Salesforce Certified MuleSoft Developer (Mule-Dev-201) certification exam because it comes with multiple career benefits.
We went to Hursley and we talked to a whole bunch of folks, Mike Ogrinz Mule-Dev-201 and John Checco demonstrate the significant benefits involved in this red-hot topic and how to get the most out of your automation platforms.
Free PDF Salesforce - Mule-Dev-201 - Salesforce Certified MuleSoft Developer –High-quality Trustworthy DumpsIf you want to know the more details about our Mule-Dev-201 training guide materials please email us any time, In a word, Wwe have data protection act for you to avoid information leakage!
In order to let all people have the opportunity to try our products, the experts from our company designed the trial version of our Mule-Dev-201 prep guide for all people.
Thousands of people are interested in earning the Salesforce Certified MuleSoft Developer (Mule-Dev-201) certification exam because it comes with multiple career benefits, It feels just like taking a real Mule-Dev-201 exam, but without the stress!
