[General] Training NSE5_FNC_AD_7.6 Tools | New NSE5_FNC_AD_7.6 Exam Preparation
90
General Training NSE5_FNC_AD_7.6 Tools | New NSE5_FNC_AD_7.6 Exam Preparation
Posted at 2/16/2026 17:49:20      View113 | Replies0        Print      Only Author   [Copy Link] 1#
The Fortinet NSE5_FNC_AD_7.6 exam questions are being updated on a regular basis. As you know the NSE5_FNC_AD_7.6 exam syllabus is being updated on a regular basis. To add all these changes in the NSE5_FNC_AD_7.6 exam dumps we have hired a team of exam experts. They regularly update the Fortinet NSE5_FNC_AD_7.6 Practice Questions as per the latest Fortinet NSE5_FNC_AD_7.6 exam syllabus. So you have the option to get free NSE5_FNC_AD_7.6 exam questions update for up to 1 year from the date of Fortinet NSE5_FNC_AD_7.6 PDF dumps purchase.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:
  • Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
  • Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
  • Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
  • Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
Fantastic Training NSE5_FNC_AD_7.6 Tools & Leading Offer in Qualification Exams & Complete New NSE5_FNC_AD_7.6 Exam PreparationFortinet NSE5_FNC_AD_7.6 exam certification is widely recognized IT certifications. People around the world prefer NSE5_FNC_AD_7.6 exam certification to make their careers more strengthened and successful. Speaking of Fortinet NSE5_FNC_AD_7.6 exam, PassTestking Fortinet NSE5_FNC_AD_7.6 exam training materials have been ahead of other sites. Because PassTestking has a strong IT elite team, they always follow the latest Fortinet NSE5_FNC_AD_7.6 Exam Training materials, with their professional mind to focus on Fortinet NSE5_FNC_AD_7.6 exam training materials.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q17-Q22):NEW QUESTION # 17
An administrator wants to use FortiNAC-F to automatically provision printers throughout their organization. Each building uses its own local VLAN for printers.
Which FortiNAC-F feature would allow this to be accomplished with a single network access policy?
  • A. Device profiling rules
  • B. Dynamic host groups
  • C. Preferred VLAN designations
  • D. Logical networks
The FortiNAC-F Logical Network feature is specifically designed to provide an abstraction layer between high-level security policies and the underlying physical network infrastructure. In large-scale deployments where different physical locations (like Building 1, 2, and 3 in the exhibit) use different local VLAN IDs for the same type of device (e.g., VLAN 10, 20, and 30 for printers), managing separate policies for each building would create significant administrative overhead.
By using a Logical Network, an administrator can create a single entity-for example, a logical network named "Printers"-and use it as the "Access Value" in a single Network Access Policy. The mapping of this logical label to a specific physical VLAN occurs at the Model Configuration level for each network device. When a printer connects to a switch in Building 1, FortiNAC-F evaluates the policy, identifies that the printer should be in the "Printers" logical network, and checks the Model Configuration for that specific switch to see which VLAN ID is mapped to that label (VLAN 10). If the same printer moves to Building 3, the same single policy applies, but FortiNAC-F provisions it to VLAN 30 based on the local mapping for that building's switch.
This architectural approach ensures that policies remain consistent and easy to manage regardless of the complexity or variations in the local network topology.
"Logical Networks provide a way to define a network access requirement once and apply it across many different network devices that may use different VLAN IDs for that access... Each managed device can use different VLAN IDs for the same Logical Network label. You can define the Logical Networks based on requirements and then associate the network to a VLAN ID when the managed device is configured in the Model Configuration." - FortiNAC-F IoT Deployment Guide: Define the Logical Networks.
NEW QUESTION # 18
An administrator wants FortiNAC-F to return a group of user-defined RADIUS attributes in RADIUS responses.
Which condition must be true to achieve this?
  • A. Inbound RADIUS requests must contain the Calling-Station-ID attribute.
  • B. The requesting device must support RFC 5176.
  • C. The device models in the inventory view must be configured for proxy-based authentication.
  • D. RADIUS accounting must be enabled on the FortiNAC-F RADIUS server configuration.
In FortiNAC-F, the RADIUS Attribute Groups feature allows administrators to return customized RADIUS attributes (such as specific VLAN IDs, filter IDs, or vendor-specific attributes) in an Access-Accept packet sent back to a network device. This is particularly useful for supporting "Generic RADIUS" devices that are not natively supported but can be managed using standard AVPairs.
According to the FortiNAC-F Generic RADIUS Wired Cookbook and the RADIUS Attribute Groups section of the Administration Guide, there is one critical prerequisite for this feature to function: the inbound RADIUS request must contain the Calling-Station-ID attribute. The Calling-Station-ID typically contains the MAC address of the connecting endpoint. Because FortiNAC-F is a host-centric system, it uses the MAC address as the unique identifier to look up the host record, evaluate the associated Network Access Policy, and determine which Logical Network (and thus which Attribute Group) should be applied. If the incoming request lacks this attribute, FortiNAC-F cannot reliably identify the host and, as a safety mechanism, will not include any user-defined RADIUS attributes in the response. This ensures that unauthorized or unidentifiable devices do not receive privileged access through misapplied attributes.
"Configure a set of attributes that must be included in the RADIUS Access-Accept packet returned by FortiNAC... Requirement: Inbound RADIUS request must contain Calling-Station-Id. Otherwise, FortiNAC will not include the RADIUS attributes. This attribute is used to identify the host and its current state within the FortiNAC database." - FortiNAC-F 7.6.0 Generic RADIUS Wired Cookbook: Configure RADIUS Attribute Groups.
NEW QUESTION # 19
Which two requirements must be met to set up an N+1 HA cluster? (Choose two.)
  • A. A FortiNAC-F device designated as a secondary
  • B. A dedicated VLAN for primary and secondary synchronization
  • C. A FortiNAC-F manager
  • D. At least two FortiNAC-F devices designated as primary
The N+1 High Availability (HA) architecture was introduced in FortiNAC-F version 7.6 to provide a more scalable and flexible redundancy model compared to the traditional 1+1 active/passive setup. In an N+1 configuration, a single secondary (standby) appliance can provide coverage for multiple primary (active) Control and Application (CA) appliances.
To set up an N+1 HA cluster, there are two fundamental structural requirements:
A FortiNAC-F Manager (FortiNAC-M): Unlike standard 1+1 HA, which can be configured directly between two CAs, N+1 management is centralized. The FortiNAC-M acts as the orchestrator that manages the failover groups, monitors the health of the primaries, and coordinates the promotion of the secondary server if a primary fails.
A FortiNAC-F device designated as a Secondary: The cluster must have one appliance explicitly configured with the Secondary failover role. This device remains in a standby state, receiving database replications from all N primaries in its group until it is called upon to take over the functions of a failed unit.
While a cluster can support multiple primaries (D), it does not strictly require "at least two" to function as an N+1 group; it simply requires N primaries (where N 1). Additionally, N+1 is typically a Layer 3 managed solution via the Manager, meaning it does not mandate a "dedicated VLAN" for synchronization like some Layer 2 HA deployments.
"In FortiNAC-F 7.6, FortiNAC-M functions as a manager to manage the N+1 Failover Groups... enabling N+M high availability for CAs. To create an N+1 Failover group, you should add the secondary CA to the FortiNAC-M first, then add the primary CAs. The secondary CA is designed to take over the functionality of any single failed primary component." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual.
NEW QUESTION # 20
When FortiNAC-F is managing VPN clients connecting through FortiGate, why must the clients run a FortiNAC-F agent?
  • A. To transparently update The client IP address upon successful authentication
  • B. To validate the endpoint policy compliance
  • C. To collect user authentication details
  • D. To collect the client IP address and MAC address
When FortiNAC-F manages VPN clients through a FortiGate, the agent plays a fundamental role in device identification that standard network protocols cannot provide on their own. In a standard VPN connection, the FortiGate establishes a Layer 3 tunnel and assigns a virtual IP address to the client. While the FortiGate sends a syslog message to FortiNAC-F containing the username and this assigned IP address, it typically does not provide the hardware (MAC) address of the remote endpoint's physical or virtual adapter.
FortiNAC-F relies on the MAC address as the primary unique identifier for all host records in its database. Without the MAC address, FortiNAC-F cannot correlate the incoming VPN session with an existing host record to apply specific policies or track the device's history. By running either a Persistent or Dissolvable Agent, the endpoint retrieves its own MAC address and communicates it directly to the FortiNAC-F service interface. This allows the "IP to MAC" mapping to occur. Once FortiNAC-F has both the IP and the MAC, it can successfully identify the device, verify its status, and send the appropriate FSSO tags or group information back to the FortiGate to lift network restrictions.
Furthermore, while the agent can also perform compliance checks (Option D), the architectural requirement for the agent in a managed VPN environment is primarily driven by the need for session data correlation-specifically the collection of the IP and MAC address pairing.
"Session Data Components: * User ID (collected via RADIUS, syslog and API from the FortiGate). * Remote IP address for the remote user connection (collected via syslog and API from the FortiGate and from the FortiNAC agent). * Device IP and MAC address (collected via FortiNAC agent). ... The Agent is used to provide the MAC address of the connecting VPN user (IP to MAC)." - FortiNAC-F FortiGate VPN Integration Guide: How it Works Section.
NEW QUESTION # 21
While discovering network infrastructure devices, a switch appears in the inventory topology with a question mark (?) on the icon. What would cause this?
  • A. The SNMP ObjectlD is not recognized by FortiNAC-F.
  • B. A read-only SNMP community siring was used.
  • C. SNMP is not enabled on the switch.
  • D. The wrong SNMP community string was entered during discovery.
In FortiNAC-F, the Inventory topology uses specific icons to represent the status and model of discovered network infrastructure. When a switch or other network device is discovered via SNMP, FortiNAC-F retrieves its System ObjectID (sysObjectID) to identify the specific make and model. This OID is then compared against the internal database of supported device mappings.
A question mark (?) icon appearing on a discovered switch indicates that while the discovery process successfully communicated with the device (meaning SNMP credentials were correct), the SNMP ObjectID is not recognized or mapped in the current version of FortiNAC-F. This essentially means the device is "unsupported" by the current software out-of-the-box. Because the OID is unknown, FortiNAC-F does not know which CLI or SNMP command set to use for critical functions like L2 polling (host visibility) or VLAN switching (enforcement). To resolve this, an administrator can manually "Set Device Mapping" to a similar existing model or a "Generic SNMP Device" if only basic L3 visibility is required.
"Discovered devices displaying a '?' icon indicate the currently running version does not have a mapping for that device's System OID (device is not supported). Device mappings are used to manage the device by performing functions such as L2/L3 Polling, Reading, and Switching VLANs." - Fortinet Technical Tip: Options for devices unable to be modeled in Inventory.
NEW QUESTION # 22
To help you prepare well, we offer three formats of our Fortinet NSE5_FNC_AD_7.6 exam product. These formats include Fortinet NSE5_FNC_AD_7.6 PDF dumps, Desktop Practice Tests, and web-based Fortinet NSE5_FNC_AD_7.6 practice test software. Your selection on the riht tool to help your pass the NSE5_FNC_AD_7.6 Exam and get the according certification matters a lot for the right NSE5_FNC_AD_7.6 exam braindumps will spread you a lot of time and efforts.
New NSE5_FNC_AD_7.6 Exam Preparation: https://www.passtestking.com/Fortinet/NSE5_FNC_AD_7.6-practice-exam-dumps.html
