[General] 2026 2V0-15.25–100% Free Test Dumps Demo | High Pass-Rate 2V0-15.25 Customizable
90
【General】 2026 2V0-15.25–100% Free Test Dumps Demo | High Pass-Rate 2V0-15.25 Customizable
Posted at 2/16/2026 17:53:42      View:134 | Replies:0        Print      Only Author   [Copy Link] 1#
Nowadays the requirements for jobs are higher than any time in the past. The job-hunters face huge pressure because most jobs require both working abilities and profound major knowledge. Passing 2V0-15.25 exam can help you find the ideal job. If you buy our 2V0-15.25 Test Prep you will pass the exam easily and successfully,and you will realize you dream to find an ideal job and earn a high income. Our product is of high quality and the passing rate and the hit rate are both high.
VMware 2V0-15.25 Exam Syllabus Topics:
  • VMware by Broadcom Solution: This section focuses on understanding VMware by Broadcom's virtualization and cloud infrastructure platform for managing modern enterprise workloads.
  • IT Architectures, Technologies, Standards: This domain covers fundamental frameworks, tools, and best practices for building scalable, secure, and interoperable enterprise IT systems.
  • Install, Configure, Administrate the VMware by Broadcom Solution: This area covers installing, configuring, and managing VMware solutions including VCF Fleet deployment, expansion, and reduction operations.
  • Plan and Design the VMware by Broadcom Solution: This domain addresses architectural planning and design principles for creating scalable, secure virtual environments aligned with business requirements.
Topic 5
  • Troubleshoot and Optimize the VMware by Broadcom Solution: This domain focuses on troubleshooting VCF deployment, upgrades, conversions, workload domains, fleet operations (certificates, passwords, identity), licensing, compute resources, storage (vSAN, supplemental storage), networking (VDS, NSX), VCF Operations tools, Identity Broker automation, and HCX workload migrations.
Authorized Test 2V0-15.25 Dumps Demo & Valuable 2V0-15.25 Customizable Exam Mode & Professional VMware VMware Cloud Foundation 9.0 SupportIf you want to pass the exam in the shortest time, our study materials can help you achieve this dream. 2V0-15.25 learning quiz according to your specific circumstances, for you to develop a suitable schedule and learning materials, so that you can prepare in the shortest possible time to pass the exam needs everything. If you use our 2V0-15.25 training prep, you only need to spend twenty to thirty hours to practice our 2V0-15.25 study materials and you are ready to take the exam.
VMware Cloud Foundation 9.0 Support Sample Questions (Q51-Q56):NEW QUESTION # 51
An administrator is attempting to activate a new vSphere Supervisor for use with VMware Cloud Foundation (VCF) Automation on a newly deployed cluster. In the VMware vSphere client, when going through the vSphere Supervisor activation having selected VCF Networking with VPC, the Virtual Private Cloud (VPC) Connectivity Profile dropdown is empty on the workload network page. The administrator verified that a Virtual Private Cloud (VPC) Connectivity Profile exists in NSX.
What is the cause of the issue?
  • A. The default VPC has not been created.
  • B. The vSphere Supervisor control plane is set to high-availability.
  • C. The TO gateway is in active/active mode.
  • D. The selected NSX Project is the Default Project.
When activating avSphere Supervisor using VCF Networking with VPC, theSupervisor Workload Networkmust use aVPC Connectivity Profile. These profiles arescoped to an NSX Project, andcannot be consumed from the Default Project.
VCF Automation requires that:
* Acustom NSX Projectbe used for VPC networking integrations.
* TheDefault Projectcannot host Connectivity Profiles or VPC constructs intended for Supervisor activation.
Even though the administrator verified that a VPC Connectivity Profileexistsin NSX, the Supervisor wizard will not display it if:
* The VPC Connectivity Profile belongs to adifferent project, or
* The current selection is theDefault Project, which blocks visibility.
This exact behavior-empty VPC Connectivity Profile dropdown-is documented when attempting Supervisor activation under the Default NSX Project.
Option A (T0 active/active) affects North-South routing but does not hide VPC profiles.
Option B (Supervisor HA mode) does not impact network profile selection.
Option D (missing default VPC) is incorrect because the wizard is complaining aboutavailability of Connectivity Profiles, not VPC instances.
NEW QUESTION # 52
An administrator is attempting to log into the vCenter using the vSphere Client but receives an error stating
"no healthy upstream" What are two possible causes for this? (Choose two.)
  • A. The administrator logged in with the root account.
  • B. The vmware-rbd-watchdog service is not running.
  • C. Port 443 is not opened between the local machine and the vCenter.
  • D. The vpxd service is not running.
  • E. The SSO Service is not running.
Answer: D,E
The vSphere Client "no healthy upstream" error is a classic indicator that one or morevCenter backend services are not running or responding, preventing the reverse proxy layer (envoy / nginx) from routing requests to the appropriate upstream services.
Two services in particular are known root causes:
A). vpxd service not running
vpxd is the core vCenter Server service responsible for inventory, host management, and client interaction. If vpxd is stopped, crashed, or restarting, the vSphere Client cannot communicate with backend APIs, resulting in the "no healthy upstream" condition.
B). SSO (vmware-stsd / identity service) not running
Authentication in vCenter depends on the SSO/Identity service. If SSO is unavailable, login sessions cannot be validated, and vCenter marks the upstream service as unhealthy.
Other options donotmatch the behavior:
* C (Port 443 closed)would produce a connection failure, not the upstream error.
* D (logging in with root)is fully supported and does not trigger this message.
* E (vmware-rbd-watchdog)relates to backup/restore health, not core authentication/management planes.
NEW QUESTION # 53
An administrator has received reports of high CPU ready times on several Virtual Machines (VMs) running within a VMware Cloud Foundation (VCF) with error" F.iain and has been tasked with collecting detailed metrics for all running Virtual Machines from each ESX host. com.vmware.esx.setungs_aaemon.sonware.
scan_spec.".
What is the cause of this error?
  • A. A component was removed from the image.
  • B. The cluster was not assigned a default image.
  • C. A vendor add-on was not provided in the image.
  • D. A device driver Is incompatible with the included firmware.
The error message com.vmware.esx.settings.daemon.software.scan_spec (reconstructed from the typo setungs_aaemon.sonware.scan_spec) is a specific failure generated by thevSphere Lifecycle Manager (vLCM)compliance engine on the ESXi host.
* Cause - Removed Component:This error is a documented known issue in vSphere 8.x/VCF 5.x+, specifically occurring when an administrator hasremoved a componentfrom the Cluster Image that the system validates as "required" or "structural" for the host's hardware configuration (common with hosts using DPUs or specific OEM add-ons).
* The Scenario:The mention of "High CPU ready times" likely implies the administrator attempted to streamline the host image byremovinga perceived "bloatware" component (like a vendor monitoring agent or unused driver) to improve performance.
* The Result:When vLCM attempts to build the "Scan Specification" (scan_spec) to validate the host against this modified image, the internal struct validation fails because the removed component creates an invalid dependency state, throwing the Invalid field software_spec... or scan_spec exception.
NEW QUESTION # 54
An administrator is planning to apply updates to a VMware vCenter instance.
What two actions can the administrator take to confirm the status of the vCenter services? (Choose two.)
  • A. Connect to the vCenter appliance shell and run the vim-top command.
  • B. Connect to the vSphere Client and review vCenter performance charts.
  • C. Connect to the vCenter Server Management console and review the services statuses.
  • D. Connect to the vCenter appliance shell and run the services-control -status command.
  • E. Connect to the ESX DCUI where the vCenter Appliance is running and run the services.sh script.
Before applying updates to a vCenter Server Appliance (VCSA), an administrator must validate that all vCenter services are healthy. VMware provides two supported and documented methods for checking vCenter service status:
1. Using the vCenter Appliance Shell
Running the command:
services-control --status
This command displays the status of all vCenter-related services (vmdird, vmcad, vpxd, vsan-health, etc.). It is the authoritative diagnostic tool embedded in the appliance for confirming whether services are running, stopped, or in a degraded state. This method is explicitly documented in vSphere 9.0 service management procedures.
This matchesOption B.
2. Using the vCenter Server Management Interface (VAMI)
Accessed at:
https://<vcenter-fqdn>:5480
The VAMI console provides a graphical interface underServices, showing the real-time health, status, and start/stop controls for all vCenter services. VMware documentation instructs administrators to review service status here before performing upgrades or maintenance operations.
This matchesOption C.
Incorrect Options Explained
* A. vSphere performance charts# These show workload data, not service health.
* D. vim-top command# Displays vSphere hosts' runtime metrics, not vCenter services.
* E. Running services.sh on ESXi DCUI# vCenter doesnotrun ESXi services; this script is for ESXi hosts only.
NEW QUESTION # 55
An administrator is responsible for managing a VMware Cloud Foundation (VCF) Fleet that is configured as follows:
* Single VCF instance with a single workload domain.
* The Workload Domain has a single 5-node VMware vSAN Express Storage Architecture (ESA) cluster.
* The vSAN Default Storage Policy is configured as RAID1.
The administrator is alerted to the fact that storage capacity is running low and, to improve space efficiency, attempts to change the vSAN storage policy on a number of large virtual machines to a 2 Failures - RAID-6 policy.
The policy change is immediately rejected.
What should the administrator do to reduce overall capacity usage while waiting for new storage devices to arrive?
  • A. Reconfigure the Virtual Machines to use a 1 Failure-RAID-5 Storage Policy.
  • B. Convert the Virtual Machines from thick provisioning to thin provisioning.
  • C. Enable encryption on the vSAN Default Storage Policy.
  • D. Enable compression on the vSAN Default Storage Policy.
In VMware Cloud Foundation 9.0 with vSAN ESA, storage policies must match the capabilities of the existing cluster. The scenario describes a5-node vSAN ESA clusterwhere the vSAN Default Storage Policy is RAID-1 (FTT=1). The administrator attempts to apply a2 Failures - RAID-6policy, which ESA supports only on clusters with at least 7 nodes. Because the cluster has only five nodes, the policy fails immediately- this is expected and documented in the vSAN ESA design specifications.
Since RAID-6 is not an option and capacity is low, the administrator must look for a method to reclaim storage usage without requiring additional nodes or unsupported policy changes. Converting VMs fromthick provisioning to thin provisioningis a safe and effective mitigation approach. Thin provisioning reduces consumed space by allowing disks to grow only as needed, immediately recovering unused blocks. This is a standard vSAN-supported method to temporarily alleviate capacity pressure.
Enabling encryption (A) or compression (D) doesnotreduce capacity usage retroactively and may actually increase overhead. Using RAID-5 (B) is also not possible because RAID-5 requiresat least 6 ESA-enabled hosts.
NEW QUESTION # 56
Our company abides by the industry norm all the time. By virtue of the help from professional experts, who are conversant with the regular exam questions of our latest real dumps. The VMware Cloud Foundation 9.0 Support exam dumps have summarized some types of questions in the qualification examination, so that users will not be confused when they take part in the exam, to have no emphatic answers. It can be said that the template of these questions can be completely applied. The user only needs to write out the routine and step points of the 2V0-15.25 test material, so that we can get good results in the exams.
2V0-15.25 Customizable Exam Mode: https://www.testsdumps.com/2V0-15.25_real-exam-dumps.html
