[Hardware] FCSS_LED_AR-7.6 Most Reliable Questions & New FCSS_LED_AR-7.6 Braindumps Que
【Hardware】 FCSS_LED_AR-7.6 Most Reliable Questions & New FCSS_LED_AR-7.6 Braindumps Que
Posted at 2/16/2026 19:22:14      View:74 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Prep4sureGuide FCSS_LED_AR-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1fcN4ghZ4OclNDBKUJNkCaMKYmSjd0KfH
Are you tired of studying for the Fortinet FCSS_LED_AR-7.6 certification test without seeing any results? Look no further than Prep4sureGuide! Our updated FCSS_LED_AR-7.6 Dumps questions are the perfect way to prepare for the exam quickly and effectively. With study materials available in three different formats, including desktop and web-based practice exams, you can choose the format that works best for you. With customizable exams and a real exam environment, our practice tests are the perfect way to prepare for the test pressure you will face during the final exam. Choose Prep4sureGuide for your Fortinet FCSS_LED_AR-7.6 Certification test preparation today!
Fortinet FCSS_LED_AR-7.6 Exam Syllabus Topics:
  • Monitoring and Troubleshooting: This section covers configuring quarantine mechanisms, managing FortiAIOps, troubleshooting FortiGate communication with FortiSwitch and FortiAP, and using monitoring tools for wireless connectivity.
  • Authentication: This domain covers advanced user authentication using RADIUS and LDAP, two-factor authentication with digital certificates, and configuring syslog and RADIUS single sign-on on FortiAuthenticator.
  • Central Management: This section addresses managing FortiSwitch via FortiManager over FortiLink, implementing zero-touch provisioning, configuring VLANs, ports, and trunks, and setting up FortiExtender and FortiAP devices.
  • Zero-Trust LAN Access: This domain covers machine authentication, MAC Authentication Bypass, NAC policies for wireless security, guest portal deployment, and advanced solutions like FortiLink NAC, dynamic VLAN, and VLAN pooling.
New FCSS_LED_AR-7.6 Braindumps Questions & Passing FCSS_LED_AR-7.6 ScoreDo not worry because Fortinet FCSS_LED_AR-7.6 exams are here to provide you with the exceptional Fortinet FCSS_LED_AR-7.6 Dumps exams. Fortinet FCSS_LED_AR-7.6 dumps Questions will help you secure the Fortinet FCSS_LED_AR-7.6 certificate on the first go. As stated above, FCSS - LAN Edge 7.6 Architect resolve the issue the aspirants encounter of finding reliable and original certification Exam Questions.
Fortinet FCSS - LAN Edge 7.6 Architect Sample Questions (Q27-Q32):NEW QUESTION # 27
Refer to the exhibits.
Examine the FortiGate RSSO configuration shown in the exhibit.
FortiGate is set up to use RSSO for user authentication. It is currently receiving RADIUS accounting messages through port3. The incoming RADIUS accounting messages contain the username in the User- Name attribute and group membership in the Class attribute. You must ensure that the users are authenticated through these RADIUS accounting messages and accurately mapped to their respective RSSO user groups.
Which three critical configurations must you implement on the FortiGate device? (Choose three.)
  • A. The sso-attribute CLI setting in the RSSO agent configuration should be set to Class.
  • B. Device detection and Security Fabric Connection should be enabled on port3
  • C. The rsso-endpoint-attribute CLI setting in the RSSO agent configuration should be set to User-Name.
  • D. RSSO user groups should be assigned to all firewall policies.
  • E. The RADIUS Attribute Value setting configured for an RSSO user group should match the class RADIUS attribute value in the RADIUS accounting message.
Answer: A,C,E
The problem states:
* FortiGate receivesRADIUS accounting messagesonport3.
* User-Nameattribute contains the username.
* Classattribute contains the group membership.
* Goal: authenticate users through RSSO and map them to the correct user groups.
To achieve this, three critical components must be configured:
#A. RADIUS Attribute Value in the RSSO group must match the Class attribute This is mandatory because:
* RSSO user groups on FortiGate match users based onthe value inside the RADIUS attribute(usually Class).
* For group assignment to work, FortiGate must compare:
RSSO User Group # RADIUS Class Attribute Value
This isexactly how FortiGate maps RSSO users to groups.
#D. RSSO agent's sso-attribute must be set to Class
Thesso-attributedefineswhich RADIUS attribute contains the group information.
Because group membership is carried in:
#Class attribute
You must configure:
config user radius
set sso-attribute Class
end
This tells FortiGate:
"Use the Class attribute to derive user group membership."
#E. rsso-endpoint-attribute must be set to User-Name
This identifieswhich RADIUS attributecarries the actualusername.
In this scenario:
* RADIUS accounting messages contain the username inUser-Name.
* So the correct setting is:
config user radius
set rsso-endpoint-attribute User-Name
end
This ensures the RSSO user object uses the correct username.
#Incorrect Options Explained
B). Assign RSSO user groups to all firewall policies
Not required.
You only assign them to policies where RSSO authentication is used.
C). Device detection and Security Fabric Connection should be enabled on port3 Totally irrelevant to RSSO.
RSSO only needs RADIUS accounting, not device detection or Fabric services.
NEW QUESTION # 28
You are configuring machine authentication on a FortiAuthenticator. Which settings must be enabled?
Response:
  • A. set machine-auth enable
  • B. define endpoint compliance profile
  • C. set radius-auth enable
  • D. bind LDAP group to policy
NEW QUESTION # 29
A network administrator connects a new FortiGate to the network, allowing it to automatically discover andI register with FortiManager.
What occurs after FortiGate retrieves the FortiManager address?
  • A. The device needs to be manually authorized on FortiManager.
  • B. FortiGate sends a discovery request to all devices on the local network using UDP port 1068.
  • C. FortiGate establishes a secure tunnel to FortiManager over TCP port 541.
  • D. FortiGate configures its interface settings based on a DHCP response from FortiManager.
When a FortiGate is deployed usingZero Touch Provisioning (ZTP)or auto-discovery:
* FortiGate retrieves theFortiManager IP address(from DHCP Option 240, FortiCloud/ZTNA provisioning, or manual set).
* The next step isnot UI authorizationor DHCP changes-it immediately attempts to form aFGFM (FortiGate-FortiManager) tunnel.
* The FGFM protocol usesTCP port 541to establish a secure management channel.
FortiManager will still require manual authorization of the deviceinside FortiManager, but this occursafter the tunnel is established.
Therefore, the first automatic action after retrieving the FMG address iscreating the secure FGFM tunnel on TCP/541.
NEW QUESTION # 30
Which of the following components are involved in Fortinet Zero-Touch Provisioning architecture?
(Choose three)
Response:
  • A. FortiSwitch
  • B. FortiManager
  • C. FortiCloud
  • D. FortiDeploy
Answer: B,C,D
NEW QUESTION # 31
Which configuration elements are required to assign a VLAN to a FortiSwitch port?
(Choose two)
Response:
  • A. Enable DHCP relay on VLAN
  • B. Create a static route
  • C. Assign VLAN to switch port profile
  • D. Define VLAN ID in FortiGate
NEW QUESTION # 32
The FCSS - LAN Edge 7.6 Architect (FCSS_LED_AR-7.6) questions are in use by many customers currently, and they are preparing for their best future daily. Even the students who used it in the past to prepare for the Fortinet Certification Exam have rated our practice questions as one of the best. You will receive updates till 365 days after your purchase, and there is a 24/7 support system that assists you whenever you are stuck in any problem or issues.
New FCSS_LED_AR-7.6 Braindumps Questions: https://www.prep4sureguide.com/FCSS_LED_AR-7.6-prep4sure-exam-guide.html
BONUS!!! Download part of Prep4sureGuide FCSS_LED_AR-7.6 dumps for free: https://drive.google.com/open?id=1fcN4ghZ4OclNDBKUJNkCaMKYmSjd0KfH
