[General] Juniper - JN0-481¨CHigh-quality Pass Test
7
¡¾General¡¿ Juniper - JN0-481¨CHigh-quality Pass Test
Posted at 2/16/2026 23:35:25      View£º227 | Replies£º0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Juniper JN0-481 dumps are available on Google Drive shared by Test4Cram: https://drive.google.com/open?id=1FKtBzzIzWxDsQCODelWInzE7GktUeCfl
Many customers may be doubtful about our price. The truth is our price is relatively cheap among our peer. The inevitable trend is that knowledge is becoming worthy, and it explains why good JN0-481 resources, services and data worth a good price. We always put our customers in the first place. Thus we offer discounts from time to time, and you can get 50% discount at the second time you buy our JN0-481 question dumps after a year. Lower price with higher quality, that¡¯s the reason why you should choose our JN0-481 prep guide.
Why we give a promise that once you fail the exam with our dump, we guarantee a 100% full refund of the dump cost to you, as all those who have pass the exam successfully with our JN0-481 exam dumps give us more confidence to make the promise of "No help, full refund". JN0-481 exam is difficult to pass, but it is an important reflection of ability for IT workers in IT industry. So our IT technicians of Test4Cram take more efforts to study JN0-481 Exam Materials. All exam software from Test4Cram is the achievements of more IT elite.
New JN0-481 Test Sims - Best JN0-481 PracticeSo rest assured that with the Data Center, Specialist (JNCIS-DC) (JN0-481) practice questions you will not only make the entire JN0-481 exam dumps preparation process and enable you to perform well in the final Data Center, Specialist (JNCIS-DC) (JN0-481) certification exam with good scores. To provide you with the updated Juniper JN0-481 Exam Questions the Juniper offers three months updated Data Center, Specialist (JNCIS-DC) (JN0-481) exam dumps download facility, Now you can download our updated JN0-481 practice questions up to three months from the date of Data Center, Specialist (JNCIS-DC) (JN0-481) exam purchase.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q55-Q60):NEW QUESTION # 55
What is the purpose of a Juniper Apstra rack?
  • A. It stores device port data rates and vendor information.
  • B. It stores information on how pods connect to super spines.
  • C. It stores IP address and ASN pool information.
  • D. It stores information on how leaf nodes connect to generic devices
A Juniper Apstra rack is a physical entity that contains one or more network devices, such as leaf nodes, access switches, or generic systems. A rack is used to organize and manage the network devices in the Apstra software application. A rack has the following characteristics:
It stores information on how leaf nodes connect to generic devices. This is because a rack can include generic systems, which are devices that are not managed by Juniper Apstra, but are connected to the network. A generic system can be a server, a firewall, a load balancer, or any other device that has a network interface. A rack stores the information on how the leaf nodes, which are the devices that provide access to the end hosts, connect to the generic devices, such as the port number, the link speed, the LAG mode, and the roles.
It has a rack type, which defines the type and number of leaf devices, access switches, and/or generic systems that are used in the rack. A rack type is a resource that is created in the data center design phase, and it does not specify the vendor or the model of the devices. A rack type can be predefined or custom-made, and it can be used to create multiple racks with the same structure and configuration.
It has a rack build, which assigns the specific vendor and model of the devices to the rack. A rack build is created in the staged phase, and it uses the rack type as a template. A rack build can also assign the resources, such as the IP addresses, the ASNs, and the VNIs, to the devices in the rack. It has a rack deployment, which applies the network configuration and services to the devices in the rack. A rack deployment is performed in the active phase, and it uses the rack build as a reference. A rack deployment can also monitor the network performance and compliance of the devices in the rack.
NEW QUESTION # 56
You are using Juniper Apstra to design a data center fabric. In this scenario, which object type associates a specific vendor model to a logical device?
  • A. device profiles
  • B. agent profiles
  • C. interface map
  • D. templates
Device profiles are objects that associate a specific vendor model to a logical device in Juniper Apstra. Device profiles contain extensive hardware model details, such as form factor, ASIC, CPU, RAM, ECMP limit, and supported features. Device profiles also define how configuration is generated, how telemetry commands are rendered, and how configuration is deployed on a device. Device profiles enable the Apstra system to render and deploy the configuration according to the Apstra Reference Design.
NEW QUESTION # 57
IBA probes analyze telemetry data from specified devices within a blueprint. Which component Identities devices that supply data tor a specific probe?
  • A. processor
  • B. data selector
  • C. search engine
  • D. graph query
A graph query is a component that identifies devices that supply data for a specific probe. A graph query is an expression that matches nodes in the Apstra graph database based on their attributes, such as device name, role, type, or tag. A graph query can be used to select the source devices for the input processors of a probe, as well as to filter the data by device attributes in the subsequent processors of a probe.
NEW QUESTION # 58
Within Managed Devices in the Juniper Apstra Ul, you notice that several devices have the OOS- Quarantined status. The devices cannot be added to any blueprint. Which action would solve this problem?
  • A. Acknowledge the device.
  • B. Upload a new pristine configuration.
  • C. Install the agent, even though connectivity is established.
  • D. Fix the hardware issues with the quarantined devices.
When an agent installation is successful, devices are placed into the Out of Service Quarantined (OOS-QUARANTINED) state using the Juniper Apstra UI. This state means that the device is not yet managed by Apstra and has not been assigned to any blueprint. The device configuration at this point is called Pristine Config. To make the device ready for use in a blueprint, you need to acknowledge the device, which is a manual action that confirms the device identity and ownership. Acknowledging the device changes its status to Out of Service Ready (OOS- READY).
NEW QUESTION # 59
What are two formats that the cabling map can be exported as? (Choose two.)
  • A. HTML
  • B. XML
  • C. JSON
  • D. CSV
NEW QUESTION # 60
Using the Juniper JN0-481 updated product of Test4Cram will result in cracking the JN0-481 real test on the first try. The reliability and accuracy of our Juniper JN0-481 practice questions make us one of the trusted brands in the market. Test4Cram proudly presents you with an JN0-481 Exam Dumps that carry actual Juniper JN0-481 questions.
New JN0-481 Test Sims: https://www.test4cram.com/JN0-481_real-exam-dumps.html
The JN0-481 test practice questions are not only authorized by many leading experts in this field but also getting years of praise and love from vast customers, Juniper Pass JN0-481 Test 100% high-quality dumps, As a new member of our users, you can enjoy the highest qualified service of the JN0-481 guide torrent, one of which is the totally free update fee within a whole year, All these three Test4Cram JN0-481 exam questions formats are easy to use and perfectly work with desktop computers, laptops, tabs, or even on your smartphone devices.
This forces any applications that need to use a specific JN0-481 type of data to access it in one location, Using the mouse to select files by pointing is a challenge, The JN0-481 Test Practice questions are not only authorized by many leading experts in this field but also getting years of praise and love from vast customers.
Valid Pass JN0-481 Test - Authoritative JN0-481 Exam Tool Guarantee Purchasing Safety100% high-quality dumps, As a new member of our users, you can enjoy the highest qualified service of the JN0-481 guide torrent, one of which is the totally free update fee within a whole year.
Free updates for 90 days.
