[General] Associate CRT-450 Level Exam & CRT-450 Latest Test Prep
106
General Associate CRT-450 Level Exam & CRT-450 Latest Test Prep
Posted at 2/17/2026 00:02:53      View158 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PDFBraindumps CRT-450 dumps from Cloud Storage: https://drive.google.com/open?id=1ZU7VvQQ5tS2bkJ1JSf1CSAe-K-dxku8l
Many candidates find the Salesforce Certified Platform Developer I (CRT-450) exam preparation difficult. They often buy expensive study courses to start their Salesforce Certified Platform Developer I (CRT-450) certification exam preparation. However, spending a huge amount on such resources is difficult for many Salesforce CRT-450 Exam applicants. The latest Salesforce CRT-450 exam dumps are the right option for you to prepare for the Salesforce Certified Platform Developer I (CRT-450) certification test at home.
Salesforce CRT-450 exam comprises 60 multiple-choice questions that must be completed within 105 minutes. CRT-450 exam covers several topics, including Apex programming, data modeling and management, user interface (UI) development, and testing and debugging. CRT-450 Exam also includes questions on the Salesforce Lightning Component Framework, which is a modern UI framework that is used to develop dynamic and responsive web and mobile applications on the Salesforce platform.
Associate CRT-450 Level Exam - 100% Perfect Questions PoolTime is the sole criterion for testing truth, similarly, passing rates are the only standard to test whether our CRT-450 study materials are useful. Our pass rate of our CRT-450 training prep is up to 98% to 100%, anyone who has used our CRT-450 Exam Practice has passed the exam successfully. And we have been treated as the most popular vendor in this career and recognised as the first-class brand to the candidates all over the world.
Passing the Salesforce CRT-450 Exam is a great achievement for any Salesforce developer. It demonstrates that the individual has a deep understanding of the Salesforce platform and is able to develop high-quality applications that meet the needs of their clients or organization. Additionally, earning this certification can help individuals advance their careers and increase their earning potential.
Salesforce Certified Platform Developer I Sample Questions (Q43-Q48):NEW QUESTION # 43
A developer wants to display all of the picklist entries for the Opportunity StageName field and all ofthe available record types for the Opportunity object on a Visualforce page. Which two actions should the developer perform to get the available picklist values and record types in the controller? Choose 2 answers.
  • A. Use Schema.RecordTypeInfo returned by Opportunity.SObjectType.getDescribe().getRecordTypeInfos().
  • B. Use Schema.PicklistEntry returned by Opportunity.StageName.getDescribe().getPicklistValues().
  • C. Use Schema.PicklistEntry returned by Opportunity.SObjectType.getDescribe().getPicklistValues().
  • D. Use Schema.RecordTypeInfo returnedby
    RecordType.SObjectType.getDescribe().getRecordTypeInfos().
NEW QUESTION # 44
Where are two locations a developer can look to find information about the status of asynchronous or future cals? Choose 2 answers
  • A. Paused Flow Interviews component
  • B. Time-Based Workflow Monitor
  • C. Apex Flex Queue (Missed)
  • D. Apex Jobs (Missed)
NEW QUESTION # 45
What is the value of the Trigger.old context variable in a before insert trigger?
  • A. A list of newly created sObjects without IDs
  • B. Undefined
  • C. An empty list of sObjects
  • D. null
Trigger.old in a before insert trigger:
TheTrigger.oldcontext variable contains the old version of the records being processed in the trigger.
In abefore inserttrigger, the records being processed are new and have no prior state in the database, soTrigger.
oldisnull.
This behavior is specific to insert triggers because there is no "old" record to reference before the record is created.
Why is it null?
The Trigger.old variable is only populated for triggers that handle updates or deletions (e.g., before update, after update, before delete, after delete). For insert operations, no previous state of the record exists.
Why not the other options?
A: An empty list of sObjects:
This is incorrect because Trigger.old is not initialized as an empty list for insert triggers-it is simply null.
B: Undefined:
Trigger.old is defined in the trigger context, but it is null for insert operations. Undefined is not a valid Apex state.
D: A list of newly created sObjects without IDs:
This describes Trigger.new in abefore inserttrigger, not Trigger.old. Trigger.new contains the new records being inserted.
Apex Triggers Documentation
Trigger Context Variables
NEW QUESTION # 46
Universal Containers stores Orders and Line Items in Salesforce. For security reason, financial representatives are allowed to see information on the Order such as order amount, but they are not allowed to see the Line items on the Order. Which type of relationship should be used?
  • A. Indirect lookup
  • B. Direct Lookup
  • C. Master Detail
  • D. Lookup
NEW QUESTION # 47
A developer created a Lightning web component called statuscomponent to be Inserted into the Account record page.
Which two things should the developer do to make this component available?
Choose 2 answers
  • A. Set is Exposes to true In the statuscomponent.js-meta.xml file.
  • B. Add <targer>lightning_Recordpage</target> to the statuscomponent. js file,
  • C. Add <mastertabel>Account </masterLabel> to the statusComponent. js-meta.xm1 file.
  • D. Add <target>lightning RecordPage</target> to the statusComp .js-meta.xml file.
To make an LWC available for use on a record page:
Target Configuration:
Add<target>lightning__RecordPage</target>in the component's.js-meta.xmlfile to specify where the component can be used.
Expose the Component:
SetisExposedtotruein the.js-meta.xmlfile to make the component available for use.
Example.js-meta.xmlFile:<?xml version="1.0"encoding="UTF-8"?>
<LightningComponentBundlexmlns="http://soap.sforce.com/2006/04/metadata">
<apiVersion>57.0</apiVersion>
<isExposed>true</isExposed>
<targets>
</targets>
</LightningComponentBundle>
A: Incorrect placement. The<target>tag must be in the.js-meta.xmlfile, not the JavaScript file.
D: The<masterLabel>tag is used for metadata labeling, not for exposing or targeting a component.
ReferencesWC Metadata Configuration: https://developer.salesforce.com ... etadata_config_file
NEW QUESTION # 48
CRT-450 Latest Test Prep: https://www.pdfbraindumps.com/CRT-450_valid-braindumps.html
Posted at 2/18/2026 22:19:28        Only Author  2#
This article has truly been inspiring, thanks for sharing! Free CCRP reliable test answers resources to help you. Wishing you the best of luck in your exam!
