CIS-Discovery Study Plan & New CIS-Discovery Test Tips
101
Posted at 2/17/2026 00:41:31      View102 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CIS-Discovery dumps are available on Google Drive shared by Pass4cram: https://drive.google.com/open?id=1gQ675wUl4vm_29js-dJy8OINUdyWM4aM
One of the biggest advantages of our CIS-Discovery learning guide is that it you wont loss anything if you have a try with our CIS-Discovery study materials. you can discover the quality of our exam dumps as well as the varied displays that can give the most convenience than you can ever experience. Both of the content and the displays are skillfully design on the purpose that CIS-Discovery Actual Exam can make your learning more targeted and efficient.
ServiceNow is one of the most widely used cloud-based platforms for IT service management, offering a wide range of tools and services to help businesses streamline their operations. To ensure that their users have the skills and knowledge required to make the most of their platform, ServiceNow offers a range of certification exams, including the Certified Implementation Specialist - Discovery (CIS-Discovery) certification. CIS-Discovery Exam is designed to test your knowledge of ServiceNow's Discovery application, which allows you to automatically discover and map your IT infrastructure.
New CIS-Discovery Test Tips & CIS-Discovery Real TorrentOur CIS-Discovery quiz torrent can provide you with a free trial version, thus helping you have a deeper understanding about our CIS-Discovery test prep and estimating whether this kind of study material is suitable to you or not before purchasing. With the help of our trial version, you will have a closer understanding about our CIS-Discovery Exam Torrent from different aspects, ranging from choice of three different versions available on our test platform to our after-sales service. In a word, you can communicate with us about CIS-Discovery test prep without doubt, and we will always be there to help you with enthusiasm.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q47-Q52):NEW QUESTION # 47
In a pattern operation, to correctly call the value of the execDir variable from tabular process variable, we should use ________ .
Response:
  • A. process(execDir)
  • B. $process.execDir
  • C. $process_execDir
  • D. "process_execDir"
NEW QUESTION # 48
Given a custom column named u_custom_column on table cmdb_ci_linux_server, which variable syntax should be used to populate the column in a horizontal discovery pattern using the Set Parameter Value operation?
  • A. $user_var_custom_column
  • B. $cmdb_ci_linux_server.u_custom_column.INSERT
  • C. $cmdb_ci_linux_server
  • .u_custom_column
  • D. $u_custom_column[1].cmdb_ci_linux_server
The correct variable syntax to populate a custom column in a horizontal discovery pattern is $cmdb_ci_linux_server.u_custom_column.INSERT. This syntax indicates that the value of the custom column will be inserted into the cmdb_ci_linux_server table for the current CI. The other options are either invalid or incorrect syntaxes for this operation12.
* Set Parameter Value operation
* Pattern variables
NEW QUESTION # 49
Which are the core CMDB Tables in ServiceNow.
Response:
  • A. cmdb_core_ci
  • B. cmdb_core_rel_ci
  • C. cmdb_ci
  • D. cmdb_rel_ci
NEW QUESTION # 50
Which of the below choices are benefits of Tracked Configuration Files? (Choose two.)
  • A. Files tracked as CIs
  • B. Content version comparison
  • C. Unwanted files removed from target
  • D. No credentials needed
Tracked configuration files are files that contain settings and parameters of certain applications or devices that Discovery can find and add to the CMDB. Some of the benefits of tracked configuration files are:
* Content version comparison: You can compare the content of different versions of the same configuration file and see the changes that occurred over time. This can help you troubleshoot issues, audit changes, and restore previous configurations if needed.
* Files tracked as CIs: You can view the configuration files as configuration items (CIs) in the CMDB and see their relationships with other CIs, such as the applications or devices they belong to. This can help you understand the dependencies and impact of the configuration files on your IT environment.
References: Configuration file tracking, Modify tracking changes in configuration files
NEW QUESTION # 51
What are the reasons if Discovery does not go beyond Port Scan phase?
Response:
  • A. Incorrect configuration of mid server
  • B. MidServer Credentials
  • C. Connectivity
NEW QUESTION # 52
It is apparent that a majority of people who are preparing for the CIS-Discovery exam would unavoidably feel nervous as the exam approaching, If you are still worried about the coming exam, since you have clicked into this website, you can just take it easy now, I can assure you that our company will present the antidote for you--our CIS-Discovery Learning Materials. As the most popular study materials in the market, our CIS-Discovery practice guide can give you 100% pass guarantee. You will feel grateful if you choose our CIS-Discovery training questions.
New CIS-Discovery Test Tips: https://www.pass4cram.com/CIS-Discovery_free-download.html
2026 Latest Pass4cram CIS-Discovery PDF Dumps and CIS-Discovery Exam Engine Free Share: https://drive.google.com/open?id=1gQ675wUl4vm_29js-dJy8OINUdyWM4aM
