[General] Pass Guaranteed Salesforce - Arch-303 - Salesforce Certified B2C Commerce Archit
92
【General】 Pass Guaranteed Salesforce - Arch-303 - Salesforce Certified B2C Commerce Archit
Posted at 2/17/2026 01:32:56      View:90 | Replies:0        Print      Only Author   [Copy Link] 1#
Did you often feel helpless and confused during the preparation of the exam? Do you want to find an expert to help but feel bad about the expensive tutoring costs? Don't worry. Arch-303 learning materials can help you to solve all the problems. Arch-303 learning material always regards helping students to pass the exam as it is own mission. With Arch-303 learning materials, you only need to pay half the money to get the help of the most authoritative experts.
In this age of the Internet, do you worry about receiving harassment of spam messages after you purchase a product, or discover that your product purchases or personal information are illegally used by other businesses? Please do not worry; we will always put the interests of customers in the first place, so Arch-303 Test Guide ensure that your information will not be leaked to any third party. After you pass the exam, if you want to cancel your account, contact us by email and we will delete all your relevant information. Second, the purchase process of Salesforce Certified B2C Commerce Architect prep torrent is very safe and transactions are conducted through the most reliable guarantee platform.
Pass4sure Arch-303 Dumps Pdf | Arch-303 Test Simulator FreeMany customers may be doubtful about our price. The truth is our price is relatively cheap among our peer. The inevitable trend is that knowledge is becoming worthy, and it explains why good Arch-303 resources, services and data worth a good price. We always put our customers in the first place. Thus we offer discounts from time to time, and you can get 50% discount at the second time you buy our Arch-303 question dumps after a year. Lower price with higher quality, that’s the reason why you should choose our Arch-303 prep guide.
Salesforce Certified B2C Commerce Architect Sample Questions (Q13-Q18):NEW QUESTION # 13
The Client wants to have a flashsate on a few products every day. These products are sold through B2C Commerce as well as an in store Point of Sale system that it tied to the same inventory.
An Architect analyzes the following proposed solution:
Inventory feed w*l continue to run dailybut add a web-service call to compare and update B2C Commerce inventory in real time during checkout after a flash product's inventory reaches a threshold.
Which two risks should the Architect communicate to the Client about this solution?
Choose 2 answers
  • A. Because the job would still be configured to run daily there will be a degrade in performance during non-flash sales periods
  • B. The default rate limiter configuration for the web-service could cause the web-service to return an exception during high traffic.
  • C. If the externals hosted web-service is unreliable. It could be a point of failure in the site s order placement flow.
  • D. If the product Inventory threshold that triggers the web service calls is reached too often. It will have a negative Impact on site performance.
The risks associated with the proposed real-time inventory update solution during flash sales are:
* Option A (The default rate limiter configuration for the web-service could cause the web-service to return an exception during high traffic): This is a critical risk because high traffic during flash sales could exceed the rate limits set for the web-service, leading to exceptions and potentially failing to update inventory in real-time.
* Option B (If the external hosted web-service is unreliable, it could be a point of failure in the site' s order placement flow): Reliance on an external web-service for crucial operations like inventory updates introduces a risk of downtime or performance issues if the service is unreliable, directly impacting the ability to complete orders during peak sales periods.
Both risks could severely disrupt operations during critical sales events, suggesting a need for robust contingency plans and potentially reevaluating the solution architecture to ensure reliability.
NEW QUESTION # 14
Northern Trail Outfitters uses an Order Management system (OMS), which creates an order tracking number for every order 24 hours after receiving it. The OMS provides only a web-service interface to get this tracking number. There is a job that updates this tracking number for exported orders, which were last modified yesterday.
Part of this jobs code looks like the following:
Based on the above description and code snippet, which coding best practice should theArchitect enforce?
  • A. Standard order import should be used instead of modifying multiple order objects with custom code.
  • B. Configure circuit breaker and timeout for theOMS web service call to prevent thread exhaustion.
  • C. The transaction for updating of orders needs to be rewritten to avoid problems with transaction size.
  • D. Post-processing of search results is a bad practice that needs to be corrected.
Given that the OMS provides a web-service interface and updates tracking numbers for orders modified the previous day, it is crucial to manage the potential risks of service unavailability or delays that could lead to thread exhaustion in Salesforce Commerce Cloud. Implementing a circuit breaker pattern helps to manage failures gracefully by halting the interaction with the OMS if it becomes unresponsive, thereby preventing the service from impacting the entire system. Additionally, configuring timeouts ensures that the service calls do not hold up resources indefinitely. These strategies help maintain system stability and responsiveness, particularly when dealing with external systems over which there may be limited control.
NEW QUESTION # 15
A new version of the Page Show controller is required for implementation of Page Deserter specific look. It requires implementation of a specific, cache period for Page Designer pages, which b not currently available in the base Storefront Reference Architecture (SFRA) cache.js module What two steps should the Architect instruct the developer to implement?
Choose 2 answers
  • A. Create new Page.js controller in client s cartridge. Copy code from base and modify the Page-Show route to include the new cache middleware function.
  • B. Create new cache,js in client's cartridge. Extend cache,js from app_storefront_baseand add a function for the Page Designer caching.
  • C. Create new Page,js controller in client's cartridge. Extend the code from base and prepend the new cache middleware function to Page-Show route.
  • D. Create new ceche,js client's cartridge. Copy cache,js from app_storefront_base and add a function for the Page Designer caching.
To implement a specific cache period for Page Designer pages in SFRA:
* Option A involves creating a new Page.js controller in the client's cartridge, where the existing Page- Show route can be modified to include a custom caching logic. This ensures that the specific caching requirements for Page Designer pages are met without altering the base functionality for other pages.
* Option D calls for extending the existing cache.js module in the client's cartridge to include a function specifically for Page Designer caching. This allows for reusing the existing caching logic while adding enhancements specific to the Page Designer pages, thus maintaining efficiency and clarity in the codebase.
Both options provide a clean, maintainable approach to customizing caching for specific requirements in SFRA, avoiding disruptions in other areas of the site functionality.
NEW QUESTION # 16
Northern Trail Outfitters (NTO) wants to migrate its online shoo from a custom ecommerce platform to B2CCommerce. NTO needs to migrate several thousands of customer records profile information, address book). WTO can provide a B2C Commerce feed. It is currently using SHA-256 as an encryption mechanism for the customer passwords.
What approach can the Architect propose?
  • A. Do not import customer records and asks customers to create new accounts the firstfame they try to log in to the B2C Commerce storefront.
  • B. Import the customer records, including the hashed password, as B2C Commerce supports SHA-2S6, and they will be able to login with their existing password.
  • C. Import the customer records, excluding the password field, and B2C Commerce will automatically require a password reset the first time a customer logs m to the storefront.
  • D. Import the customer records, with the hashed password as a custom attribute, and during the login compare the entered password with the hashed password and save it in the password field.
B2C Commerce does not directly support the import of hashed passwords for use in authentication due to security protocols and the platform's password management system. The best approach is to import customer records without the password field. Upon their first login attempt on the new system, customers would be prompted to reset their password. This method ensures that password security is maintained according to B2C Commerce standards and that customer data remains secure during the transition from the old platform.
NEW QUESTION # 17
An Architect isperforming an audit of production logs via Log Center and finds some potentially dangerous custom log output.
In which two ways It this log output Improper In a production environment? Choose 2 answers
  • A. The log information includes the customer s cardname as it appears along with the credit card number (PAN), which violates PCI.
  • B. Information logs should not be used in a production environment
  • C. The log information includes the customer's card CW (card security code) and expiration date, which violates PCI.
  • D. The log information includes the order number and customer s email, which violates PCI.
In a production environment, logging sensitive customer information such as credit card details (PAN, CVV, expiration date) can lead to severe security and compliance issues, specifically violating PCI DSS (Payment Card Industry Data Security Standard) requirements. The standards strictly prohibit the storage of CVV codes and mandate that any PAN displayed must be masked. Storing such data in logs is not only a risk for data breaches but also non-compliance with these standards can lead to penalties.
* Option A: Including the customer's card name along with the full credit card number in logs is a clear violation of PCI DSS requirements, which stipulate that no more than the last four digits of the card number may be displayed.
* Option B: Logging the card security code (CVV) and expiration date is explicitly prohibited by PCI DSS, which requires that sensitive authentication data, including CVV, must never be stored post- authentication, even if it is encrypted.
NEW QUESTION # 18
Perhaps you have no choice and live unhappily now because you cannot change your current situation. Our Arch-303 exam materials will remove your from the bad condition. Life needs to be colorful and meaningful. We must realize our own values and make progress. Do not worry. Our Arch-303 Study Guide will help you regain confidence. we can claim that with our Arch-303 practice engine for 20 to 30 hours, you will be quite confident to pass the exam.
Pass4sure Arch-303 Dumps Pdf: https://www.prep4cram.com/Arch-303_exam-questions.html
All content includes the most accurate and authentic materials with scientific arrangement for your reference with our Arch-303 quiz torrent materials, Salesforce Related Arch-303 Certifications This ways will cut off your preparation time, Salesforce Related Arch-303 Certifications The society is cruel and realistic, so we should always keep the information we own updated, If you buy the Software or the APP online version of our Arch-303 study materials, you will find that the timer can aid you control the time.
Work more efficiently with Quick Action and other Arch-303 Latest Material shortcuts, These hotfixes are installed automatically when using the SharePoint installer, All content includes the most accurate and authentic materials with scientific arrangement for your reference with our Arch-303 Quiz torrent materials.
100% Free Arch-303 – 100% Free Related Certifications | Efficient Pass4sure Salesforce Certified B2C Commerce Architect Dumps PdfThis ways will cut off your preparation time, The Arch-303 society is cruel and realistic, so we should always keep the information we own updated, If you buy the Software or the APP online version of our Arch-303 study materials, you will find that the timer can aid you control the time.
I believe after several times of practice, you will be confident to face your actual test and get your Arch-303 certification successfully.
