[General] ISO-9001-Lead-Auditor Braindumps Pdf & ISO-9001-Lead-Auditor Cheap Dumps
107
General ISO-9001-Lead-Auditor Braindumps Pdf & ISO-9001-Lead-Auditor Cheap Dumps
Posted at 2/17/2026 02:05:00      View119 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestBraindump ISO-9001-Lead-Auditor PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1uTMxgfzAF26KMjcRWNYcFNndSqfnfQ0a
Quality first, service second! We put much attention and resources on our products quality of ISO-9001-Lead-Auditor real questions so that our pass rate of the ISO-9001-Lead-Auditor training braindump is reaching as higher as 99.37%. As for service we introduce that "Pass Guaranteed". We believe one customer feel satisfied; the second customer will come soon for our ISO-9001-Lead-Auditor Study Guide. If you want to have a look at our ISO-9001-Lead-Auditor practice questions before your paymnet, you can just free download the demo to have a check on the web.
We can say that the PECB ISO-9001-Lead-Auditor practice questions are the top-notch QMS ISO 9001:2015 Lead Auditor Exam (ISO-9001-Lead-Auditor) dumps that will provide you with everything that you must need for instant ISO-9001-Lead-Auditor exam preparation. Take the right decision regarding your quick QMS ISO 9001:2015 Lead Auditor Exam (ISO-9001-Lead-Auditor) exam questions preparation and download the real, valid, and updated PECB ISO-9001-Lead-Auditor exam dumps and start this journey.
ISO-9001-Lead-Auditor Actual Test & ISO-9001-Lead-Auditor Accurate Pdf & ISO-9001-Lead-Auditor Exam VceInfinite striving to be the best is man's duty. We have the responsibility to realize our values in the society. Of course, you must have enough ability to assume the tasks. Then our ISO-9001-Lead-Auditor learning quiz can give you some help. First of all, you can easily pass the ISO-9001-Lead-Auditor Exam and win out from many candidates for our ISO-9001-Lead-Auditor study materials are the most effective exam materials in the market. Secondly, you can also learn a lot of the specilized knowledage at the same time.
PECB ISO-9001-Lead-Auditor Exam Syllabus Topics:
  • Quality management system (QMS) requirements: It assesses your abilities to point out and explain different requirements for a quality management system based on ISO 9001.
  • Managing an ISO 9001 audit program: This topic evaluates your abilities to establish and managing a QMS audit program.
  • Fundamental audit concepts and principles: Questions about interpreting and applying the main concepts and principles related to a QMS audit appear in this topic.
  • Closing an ISO 9001 audit: The topic focuses on concluding a QMS audit and conducting audit follow-up activities.
Topic 5
  • Conducting an ISO 9001 audit: It evaluates your skills to conduct a QMS audit.
PECB QMS ISO 9001:2015 Lead Auditor Exam Sample Questions (Q41-Q46):NEW QUESTION # 41
An audit team of three people is conducting a Stage 2 audit to ISO 9001 of an engineering organisation that manufactures sacrificial anodes for the oll and gas industry in marine environments. These are aluminium products designed to prevent corrosion of submerged steel structures. You, as one of the auditors, find that the organisation has shipped anodes for Project DK in the Gulf of Mexico before the galvanic efficiency test results for the anodes have been fully analysed and reported as required by the customer. The Quality Manager explains that the Managing Director authorised release of the anodes to avoid late delivery as penalties would be imposed. The customer was not informed since the tests very rarely fall below the required efficiency. You raise a nonconformity against clause 8.6 of ISO 9001.
Which of the following options for the best description of the nonconformity?
  • A. Products for Project DK have been released before product approval through the quality control process.
  • B. A retrospective concession was not sought from the customer once the test results had been approved by the Quality Manager.
  • C. Release of the product without acceptable test results has been accepted by the customer for Project DK.
  • D. The untested product was not recalled until the galvanic efficiency of the anodes was verified.
Clause Reference - ISO 9001:2015 Clause 8.6 (Release of Products and Services):ISO 9001 requires that products and services are not released to the customer until:
* All planned verification activities have been completed.
* Acceptance criteria have been met.
* Any necessary approvals have been obtained.
In this scenario:
* The sacrificial anodes for Project DK were shipped before the galvanic efficiency test results were analyzed.
* This constitutes a nonconformity against Clause 8.6 because the products were released without completing the required tests.
Option Analysis:
* A. A retrospective concession was not sought from the customer once the test results had been approved by the Quality Manager:Incorrect. While obtaining a concession might mitigate the situation, the nonconformity pertains to the process failure of releasing the products without completing required tests, not the absence of a concession.
* B. Release of the product without acceptable test results has been accepted by the customer for Project DK:Incorrect. The customer was not informed before the release, and there is no indication that this was accepted beforehand. Furthermore, ISO 9001 requires planned processes to be followed, regardless of later acceptance.
* C. Products for Project DK have been released before product approval through the quality control process:Correct. This description accurately reflects the nonconformity. The quality control process required test results to be analyzed and verified before release, which did not happen.
* D. The untested product was not recalled until the galvanic efficiency of the anodes was verified:
Incorrect. The issue is not about recalling the product but about releasing it without completing the required tests. Recalling the product is not mentioned in the scenario.
Why C is Correct:
* The nonconformity is a clear breach of Clause 8.6, where the products were released without meeting the planned verification requirements.
* This demonstrates a failure in adhering to quality control processes, which is a critical aspect of ISO
9001 compliance.
Key ISO 9001 Reference:
* Clause 8.6: Products and services shall not be released to the customer until all planned activities (e.g., testing) have been satisfactorily completed, or the customer has approved the release with knowledge of deviations.
NEW QUESTION # 42
According to the guidance provided in ISO 19011, a second-party opening meeting should cover many elements.
From the following options, select the four items that should not be included in the opening meeting.
  • A. Audit objectives
  • B. Analysis of the corrective actions pending from the previous audit
  • C. Conditions under which the audit may be terminated
  • D. Introduction of the Audit team
  • E. How far is the auditee able to apply to the National Quality Award
  • F. Risks to the organization resulting from the presence of the auditors
  • G. Strengths of the Quality Management System, based on the document review during the audit planning
  • H. Audit team leaders' email address
Answer: B,D,F,G
NEW QUESTION # 43
In the context of a second-party audit, match the activity with the party responsible for conducting it.
Here is the correct matching of the activities with the responsible parties in the context of a second-party audit:
* Define the audit scope: Customer
* Develop the audit plan: Audit team leader
* Respond to the audit findings: External provider
* Conduct the audit: Audit team
This reflects the typical division of responsibilities in a second-party audit, where the customer (the party commissioning the audit) sets the scope, the audit team leader manages the planning, the external provider responds to findings, and the audit team carries out the audit.
NEW QUESTION # 44
During an internal audit, a manufacturer of polystyrene packaging products for the electronics industry found that six per cent of finished products being ejected from the moulding machines fell onto the factory floor instead of into collection baskets. The factory floor was wet and dirty in places, so a lot of products were rejected at inspection. Auditors raised a non-conformity to the Maintenance Manager.
Select three options for the corrective action to be taken by the Maintenance Manager that could be needed to prevent rejects from recurring.
  • A. Install guides at the point of ejection to better direct products into the baskets.
  • B. Set up a system of regular inspection of the floor condition.
  • C. Ask customers to accept dirty products.
  • D. Place a worker at the ejection point to place any product falling to the floor into the baskets.
  • E. Clean up dirty products before release to the customer.
  • F. Make staff aware that products are falling onto the factory floor.
  • G. Record every product falling onto the floor as a non-conformity.
  • H. Redesign the factory layout to better handle finished products.
Answer: A,B,H
ISO 9001:2015 requires organisations to take corrective action to eliminate the cause of a nonconformity in order to prevent recurrence, not merely to contain or correct individual instances.
Relevant ISO 9001 requirements
* Clause 10.2.1 - Nonconformity and corrective actionThe organisation shall react to the nonconformity, evaluate the need for action to eliminate the cause(s), and implement actions to prevent recurrence.
* Clause 8.5.1 - Control of production and service provisionProduction shall be carried out under controlled conditions, including suitable infrastructure and environmental conditions.
Explanation of the correct corrective actions:
D). Redesign the factory layout to better handle finished products
This addresses a systemic cause of the problem by improving how finished products are handled after ejection, reducing the likelihood of products falling to the floor. This is a true corrective action aligned with Clause 10.2.
E). Set up a system of regular inspection of the floor condition
The dirty and wet floor is a contributing cause to product rejection. Establishing regular inspection and maintenance of floor conditions addresses the environmental conditions for production, as required by Clause 8.5.1, and helps prevent recurrence.
G). Install guides at the point of ejection to better direct products into the baskets This directly eliminates the root cause of products missing the collection baskets by improving equipment control. It is an effective corrective action that prevents the nonconformity from happening again.
Explanation of why the other options are not corrective actions:
* A: Recording nonconformities is detection, not prevention.
* B: Placing a worker is a temporary containment action, not elimination of the root cause.
* C: Asking customers to accept dirty products is unacceptable and contrary to ISO 9001.
* F: Awareness alone does not remove the cause of the problem.
* H: Cleaning products before release is correction, not corrective action, and does not prevent recurrence.
ISO-aligned conclusion:
Corrective actions must remove the root causes of nonconformities. In this scenario, improving product handling design, controlling environmental conditions, and modifying equipment to ensure correct ejection are the only actions that effectively prevent the recurrence of rejected products. Therefore, the correct answers are D, E and G.
NEW QUESTION # 45
In the context of a third-party audit, match the activity with the party responsible in relation to the audit process.
In the context of a third-party audit, the activities and the parties responsible can be matched as follows:
* Review the organization's processes: This is typically the responsibility of the audit team. They examine the processes to ensure they comply with the specified standards1.
* Review the audit results: The audit team leader usually reviews the audit findings to ensure accuracy and completeness before they are finalized1.
* Issue the certificate: The certification body is responsible for issuing the certificate if the audit is successful and the organization meets the required standards1.
* Select the audit team: The individual(s) managing the audit programme are responsible for selecting the audit team. This ensures that the team has the appropriate skills and knowledge for the audit1.
These roles are essential to maintain the integrity and effectiveness of the audit process. The audit team conducts the actual audit, the team leader oversees the audit process, the certification body grants the certification, and the management of the audit program ensures that the right team is in place to conduct the audit1.
Based on the description of the image you've provided, here's how the activities match with the responsible parties in the context of a third-party audit:
* Review the organization's processes: This activity is typically the responsibility of the Audit Team.
They are tasked with examining the processes to ensure they meet the requirements of the standard being audited.
* Review the audit results: The Audit Team Leader is usually responsible for this activity. They oversee the audit process and are in charge of reviewing the findings and ensuring that the audit objectives are met.
* Issue the certificate: The Certification Body is responsible for issuing the certificate if the organization's management system is found to be in compliance with the standard.
* Select the audit team: The Individual(s) managing the audit programme are responsible for selecting the audit team. They ensure that the team has the appropriate competence and resources to effectively conduct the audit.
These roles are defined within the framework of ISO 9001:2015 and are essential for the proper conduct of a third-party audit. The audit team and its leader play a critical role in the operational aspects of the audit, while the certification body and those managing the audit programme have overarching responsibilities for the audit' s governance and integrity.
NEW QUESTION # 46
Did you often feel helpless and confused during the preparation of the ISO-9001-Lead-Auditor exam? Do you want to find an expert to help but feel bad about the expensive tutoring costs? Don't worry. Our ISO-9001-Lead-Auditor exam questions can help you to solve all the problems. Our ISO-9001-Lead-Auditor Study Material always regards helping students to pass the exam as it is own mission. And we have successfully helped numerous of the candidates pass their exams.
ISO-9001-Lead-Auditor Cheap Dumps: https://www.testbraindump.com/ISO-9001-Lead-Auditor-exam-prep.html
2026 Latest TestBraindump ISO-9001-Lead-Auditor PDF Dumps and ISO-9001-Lead-Auditor Exam Engine Free Share: https://drive.google.com/open?id=1uTMxgfzAF26KMjcRWNYcFNndSqfnfQ0a
