[Hardware] Salesforce Analytics-DA-201 Quiz - Analytics-DA-201 Studienanleitung & Analy
107
Hardware Salesforce Analytics-DA-201 Quiz - Analytics-DA-201 Studienanleitung & Analy
Posted at 2/17/2026 02:09:05      View116 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Kostenlose 2026 Salesforce Analytics-DA-201 Prfungsfragen sind auf Google Drive freigegeben von ExamFragen verfgbar: https://drive.google.com/open?id=1A90Xdp5XoPWI8dUAO3fJbM1g3oKdrZhg
Sie können im Inernet kostenlos die Lerntipps und einen Teil der Prfungsfragen und Antworten zur Salesforce Analytics-DA-201 Zertifizierungsprfung von ExamFragen als Probe herunterladen.
Salesforce Analytics-DA-201 Prfungsplan:
ThemaEinzelheiten
Thema 1
  • ABAP Core Data Services and Data Modeling: This section of the exam measures the skills of the SAP ABAP Cloud Developer and covers the fundamental understanding of core data services (CDS) and how to design data models in the SAP ABAP environment. Candidates are expected to know how to define, consume, and optimize CDS views effectively to support application development in the cloud.
Thema 2
  • ABAP SQL and Code Pushdown: This section of the exam measures the competencies of the SAP ABAP Cloud Developer related to performance optimization through ABAP SQL and code pushdown techniques. It ensures that the developer understands how to shift logic to the database layer using efficient SQL scripting to enhance performance in data-intensive applications.
Thema 3
  • Object-Oriented Design: This section of the exam evaluates the SAP ABAP Cloud Developer's understanding of object-oriented principles in the ABAP context. It focuses on class-based programming, inheritance, interfaces, and polymorphism, all crucial for building modular and maintainable ABAP cloud applications.
Analytics-DA-201 Trainingsunterlagen & Analytics-DA-201 LernhilfeProbieren Sie vor dem Kauf! Wir ExamFragen sind verantwortlich fr jeder Kunde. Wir bieten Ihnen kostenfreie Demos der Salesforce Analytics-DA-201, somit können Sie nach der Probe unbesorgt kaufen. Außerdem können wir Ihnen garantieren, dass Sie keine Reue empfinden werden, nachdem Sie unsere Salesforce Analytics-DA-201 Prfungssoftware gekauft haben. Denn Sie können durch die Benutzung ihre Zuverlässigkeit empfinden. Dadurch bekommen Sie mehr Konfidenz angesichts der Salesforce Analytics-DA-201 Prfung.
Salesforce Certified Tableau Data Analyst Analytics-DA-201 Prfungsfragen mit Lösungen (Q134-Q139):134. Frage
You have the following dataset:
Which grouping option should you use in Tableau Prep to group all five names automatically?
  • A. Manual Selection
  • B. Spelling
  • C. Common Characters
  • D. Pronunciation
Antwort: C
Begrndung:
Common Characters: Find and group values that have letters or numbers in common. This option uses the ngram fingerprint algorithm that indexes words by their unique characters after removing punctuation, duplicates, and whitespace. This algorithm works for any supported language. This option isn't available for data roles. For example, this algorithm would match names that are represented as "John Smith" and "Smith, John" because they both generate the key "hijmnost". Since this algorithm doesn't consider pronunciation, the value "Tom Jhinois" would have the same key "hijmnost" and would also be included in the group.
135. Frage
You have the following worksheet.
You want to create a table calculation that shows sales growth over each year.
How should you complete the formula? (Use the dropdowns in the Answer Area to select the correct options to complete the formula.)
Antwort:
Begrndung:
There are different ways to create a table calculation that shows sales growth over each year, but one possible answer is:
* SUM([Sales])
* LOOKUP(SUM([Sales]), -1)
* PREVIOUS_VALUE(0)
To calculate the sales growth over each year, you need to compare the current year's sales with the previous year's sales and divide the difference by the previous year's sales. You can use the SUM, LOOKUP, and PREVIOUS_VALUE functions to achieve this. The SUM function returns the total sales for each year. The LOOKUP function returns the value of an expression in a target row, specified as a relative offset from the current row. The PREVIOUS_VALUE function returns the value of the expression in the previous row, or a specified value if there is no previous row. The formula for the table calculation is:
(SUM([Sales]) - LOOKUP(SUM([Sales]), -1)) / PREVIOUS_VALUE(0)
This formula subtracts the sales of the previous year (LOOKUP(SUM([Sales]), -1)) from the sales of the current year (SUM([Sales])) and divides the result by the sales of the previous year. If there is no previous year, the formula uses 0 as the denominator (PREVIOUS_VALUE(0)) to avoid division by zero errors.
Tableau Certified Data Analyst Exam Prep Guide, page 11, section "Creating Calculated Fields" Tableau Help: SUM Function Tableau Help: LOOKUP Function Tableau Help: PREVIOUS_VALUE Function
136. Frage
You plan to publish a workbook to Tableau Server.
You want to ensure that users can see other published dashboards from their current dashboard.
Which setting should you configure? (Click the appropriate Option in the Answer Area.)
Antwort:
Begrndung:
To achieve the requirement of letting users navigate between different published dashboards directly from their current dashboard, you need to enable the "Show sheets as tabs" option. This setting allows each sheet in your workbook, including dashboards, to be displayed as a tab, making it easy for users to switch between different views or dashboards within the same published workbook.
Here is the option you should configure:
* Check the Show sheets as tabs checkbox in the 'More Options' section.
This action will ensure that all sheets, when published to the Tableau Server, appear as tabs, facilitating user navigation across multiple dashboards included in the workbook.
137. Frage
Open the link to Book1 found on the desktop. Open Disciplines worksheet.
Filter the table to show the Top 10 NOC based on the number of medals won.
Antwort:
Begrndung:
check the steps below in explanation.
To filter the table to show the Top 10 NOC based on the number of medals won, you need to do the following steps:
* Open the link to Book1 found on the desktop. This will open the Tableau workbook that contains the Disciplines worksheet.
* Click on the Disciplines tab at the bottom of the workbook to open the worksheet. You will see a table that shows the NOC, discipline, and medals for each country.
* Drag Medals from the Measures pane to the Filters shelf. This will open a dialog box that allows you to filter by different criteria.
* Select Top from the dialog box. This will show you options to filter by the top or bottom values of a field.
* Enter 10 in the text box next to By field. This will filter by the top 10 values of Medals.
* Select NOC from the drop-down list next to By field. This will filter by the top 10 values of NOC based on Medals.
* Click OK to apply the filter. You will see that the table now shows only 10 rows, one for each NOC with the highest number of medals.
References: https://help.tableau.com/current/pro/desktop/en-us/filtering.htm https://help.tableau.com/current
/pro/desktop/en-us/filtering_topn.htm
138. Frage
You create the following worksheet
The Pick Measure parameter contains the following list of values
Users can select a value from Pick Measure to change the visualization to show either the Sales measure or the Profit measure.
Which formula is used in the Selected Measure calculated field lo switch between measures?
  • A. Case STFMEPick Measure])
    WHEN "Sales" then ([Sales])
    WHEN "Profit" then ([Profit]) e::i
  • B. Case AVG([Pick Measure])
    WHEN [Sales] then 1
    WHEN [Profit] then 2
    END
  • C. Case [Pick Measure:
    WHEN [Sales] then 1
    WHEN [Profit] then 2 END
  • D. Case [Pick Measure]
    WHEN 1 then ([Sales])
    WHEN 2 then ([Profit])
    END
Antwort: D
Begrndung:
https://help.tableau.com/current ... parameters_swap.htm
This formula uses a parameter (Pick Measure) to switch between the Sales and Profit measures. When the user selects '1', it shows Sales, and when '2' is selected, it shows Profit. This dynamic switching is enabled by the Case function.
139. Frage
Die Konkurrenz in unserer Gesellschaft wird immer heftiger. Unsere ExamFragen ist noch bei vielen Prfungskandidaten sehr beliebt, weil wir immer vom Standpunkt der Teilnehmer die Softwaren entwickeln. Z.B. die gut gekaufte Salesforce Analytics-DA-201 Prfungssofteware wird von unserem professionellem Team entwickelt mit großer Menge Forschung der Salesforce Analytics-DA-201 Prfung. Obwohl wir eine volle Rckerstattung fr die Verlust des Tests versprechen, bestehen fast alle Kunde Salesforce Analytics-DA-201, die unsere Produkte benutzen. Was beweist die Vertrauenswrdigkeit und die Effizienz unserer Salesforce Analytics-DA-201 Prfungsunterlagen.
Analytics-DA-201 Trainingsunterlagen: https://www.examfragen.de/Analytics-DA-201-pruefung-fragen.html
Laden Sie die neuesten ExamFragen Analytics-DA-201 PDF-Versionen von Prfungsfragen kostenlos von Google Drive herunter: https://drive.google.com/open?id=1A90Xdp5XoPWI8dUAO3fJbM1g3oKdrZhg
